That blows asking Frank if he wants to a horizontal/vertical team-up. :P
Ill just charge after... everything, hope to bend a few things... not too confident really:sad:
Matty, you have a very weird mind... :proud:
Nice to see some new blood around here, welcome Timothy!
Well done Alex.
I cant remember a single thing about chalkie apart from that its a titanium brick.
*find stats*
Go without those skirts for the fight to save damage...
*goes off to look for Mega Mashers stats*
I can not find then at all, so until someone points me into the correct page where the stats are, my tactics and set-up later
Well, are you looking hard enough? Well, here they are anyway.
MEGA MASHER 2
Weight: 100 kilos
Body Shape: Minion
Speed: 12mph
TC: 0
GC; 0 at front, 1mm at sides due to skirts.
Wheels; 4 inner.
Armour: A nice 3mm of steel
Power: Similar stuff to what Tornado uses.
Colour: Red and yellow.
Weapons; The front is a wedge, and the back has a nasty vertical disc, powered by its own motor and spinning at 2000 rpm. It can probably flip as well as damage. A side Minion style bar comes out from the side.
Srimech: The aforementioned bar rights the robot, even though it can run inverted.
Strengths: Power, weaponary
Weaknessess: A little bulky, not as heavy as the body would suggest.
BIO
Mega Masher is still hell bent on robot destruction. Whether you think of him as the baddest, most brutal robot ever or just a power crazed crazy thing - just dont tell him when his disc is spinning at full throttle! His wedge is also dangerous; being one of the lowest out there. Dont trust this robot to lose as far as you can throw him! Even better, dont try to throw him at all; hes based around Battlebot champion Minion, and way too bulky for flipping.
Oh well that said Ill go after Mega Masher. I should be able to tear the armour up nicely, which is more than I can do against the others. After that Ill head for Chalkie.
You would Franky :proud:
I will use the sword and drive straight into PowerPoint, its weapon is too high to hit me before I can get the sword under and lift it up enough to push it towards the pit, standard skateboard wheels are crap because they break up so easiy when on steel. I trust Frank to deal with Mega Masher, if he hasnt, I will drive straight into the rear disc, where I should be low enough not to be flipped and repeat the pit tactic...
...then attack those house-robots, wanna team up Frank?
well at least someone likes me
Steve, theres a problem. Due to financial problems, the bore projects been cancelled, so it looks like Im going to have to swap it out with another realie. Is that OK, or do you want it left as is?
Argh! This tourny is cursed, I tell thee!
Franky, Id prefer if the Bore stayed in the tourny as it is. It just jumbles things up, otherwise and besides, its the easy option. If for some reason folk arent happy with this decision, I hate them. :proud:
Fights up in the next few days. I hope. :S
Oh guys, you make me laugh.
Maybe you WILL be able to tear the outer armour. But, didnt I say its based around Minion? And didnt I also say it isnt as heavy as it looks?
Well, Id rather keep out of the way of The Disc, even though Ive always wanted to fight it, and dont want to miss any chance OF fighting it, no matter how many times I do. Keep the wedge pointing at it constantly, and use the disc to attack the other two.
