LOL to Chriss comments! :proud:
And YOU shut up Matt, Im not changing anybodys tactics, Im just making suggestions!
Anyways, Juggerbee 3.0 will slot his flipper under the robot with the highest ground clearance, then flip, ram and pit.
I beleive that may be SOR, flip, ram and pit me at your peril! :proud:
And sorry Matt, SOR isnt friendly with full body spinners, so Im still going to try and take you out of the heat as early as possible.
Fine then, Im only in this tourney because somebody wouldnt stop bothering me to enter it until I entered it.
OK AJ, Ill attack the robot with the SECOND highest ground clearance.
That would probably be BOTCG.
Actually, that would be ripoff, 4mm to 2mm
Doesnt matter, as that spinner will probably send Juggerbee 3.0 into shreds.
OK, Mr confident-who-always-tells-other-people-not-to-be-so-confident-then-acts-all-con fident-and-has-done-for-several-rounds-now-which-usually-results-in-him-losing.
Are you talking to me or Matt?:wink:
Hmm, not only is that not true Chris, but Im expecting Ripoff Yet Again! to lose (THAT doesnt mean make it lose because I said that Rich!), its my worst design built.
