myeah, theyre both long wedges, I wanted to go into abit more detail but decided to strictly follow the stats to make sure I got what Ben had in mind, thanks Liam :)
nice, but I think its a bit thin
quote:
Dimensions: 110X40X25
I used the dimensions you gave it, you indeed made your robot quite thin :lame:
whoops, that was a typo, it was supposed to be 110X80x25
Ill see if I can fix it, expect Robo-Hedghog to be done somewhere next week btw, running short on time here
http://i74.photobucket.com/albums/i268/_MadBull_/goattt.jpghttp://i74.photobucket.com/albums/i2...ll_/goattt.jpg
w00t
ok, width is now fine, but the horns should be a little longer
... couldnt you have said that after seeing the previous CAD? it had the same horns after all...
Demanding much...
sorry, I suffer from short-term memory loss
