i got bored so i started making a new parts list and if anyone has opinions on it then say. i hardly call that repeating, the old one was a bit vague so i needed to make a more refined one
I'm not talking about that specific instance
ye, i know i have done because i always forgot to save thing into files etc so i need to ask again and retain the info
goodQuote:
alright, a bit big and hefty but they'll get you moving
how many packs? discharge rates?
good
i'm planning;
bosch 750's
wotty
a123 packs, maybe nimhs
fp pneumatic system, 2-3 burkerts, aiming for about 1l volume ram
well i was unsure of battery size so i just went for the same that my drive packs on my FW are.
im using 2 burkets but with a 100mm bore, 120mm stroke ram
100mm bore 120mm - 0.95l, i was more thinking 75mm bore 200mm stroke modified hydraulic cylinder. nimhs i'd say 10ah+ though you might get away with less depends on the discharge rates that the cells have.
my thinking was toon raider uses 3000mah nicad.
and i have looked into a mod hydraulic ram but i need to find one at a good price
You'll rip the chassis to pit with a ram that size, and no point if your only having one burkert feeding it. See if you can find out what size it had in before and aim around that, i would guess something like a 63mm bore 200mm stroke (same as Merlins). Why see what weight you have available and just use some cheap SLA's.
what size ram did knightmare have in it? i was think something along those lines
ah crap, ye, good point alan, i could probably push to 75mm but i dont think much more than that
