Just remember who used single tooth first over here boys :lol:
Nice machine James. I may have missed it as I was only able to watch a bit of the video but are the arms and tail operational?
Looking awesome James.
It looks & sounds like everything runs real smooth on the video.
Just a thought, is there a way you can use the 3mm ti to double both as armour and a way to stiffen the chassis up further? Particularly the parts of the chassis which take the most stick when the disc impacts.
Thanks Gary, yes all the functions work but we had trouble with the cheap orange rx. The mid point drifted out so quickly within 30 seconds we couldn't trim it and not long after the stick range wasnt enough to stop it moving the arms and head. Changed it to a spektrum rx so I'm hoping its all ok now.
Cheers Sam. Yes definitely. Was hoping 3mm ti armour would take most impacts around the sides but all the front would probably need some hardox. If NST got into the neck area it would cause alot of damage. Im trying to stiffen it with some more bracing on the neck so it doesnt twist the head but I think it will need some real protection too. The tube is only 10mm od and 8.6mm id so its not going to stand up to direct hits argh. It will definitely be at the UK Champs, what happens to it after that depends on if it gets mangled and if the new robot gets finished.
Hi James, it's back in the uk, speed controller for drive and it's ready to roll, will be posting vid after Xmas now
Looks really nice and unusual
Build quality - well certainly beyond my Black and Decker workmate :lol:
Been working on the top armour. Created a Polycarbonate top so I could shape it to the bars underneath.
Once the shape looked good I cut it from 1.2mm Ti
Shaping it to fit the tubular body was a pain but here it is finished and fits nicely. Hopefully now when the head hits itself it has some protection!
so you give us hope with a polycarbonate top then take it way with a Ti replacement :cry:
Nice work :mrgreen:
Thanks Chris :)
