Your assuming one thing mr McGree
You can get around the rear of storm, and its more than twice your speed.
true:P
Then I will let it ocme to me and wiat until it is otherwise preoccupied :P
I also doubt Storm 2 will breach the skirts, as it doesnt have a 0 MM front. However, that doesnt mean it cant shove PRP around. Sorry Matty, but I think Storm 2 to go through.
Thats fine:)
HEAT D
ROUND 3
Powerpoint Reaches Pressurepoint VS Storm 2
Powerpoints blade seems a bit too tall to make any effect on Storm and unless the skirts can prove lower and drag it up enough into the spinner, I think the RW World Champll be slamming it around the Warzone until the Pit beckons :proud:
Heat D Final
It€™s been a long time coming, forever delayed by the downloading of bootlegs, but finally it is here, the fight to decide who goes forward to the semi finals.
Storm 2 vs. PRP
Storm 2 got here by slamming 2 Blue into the arena hammer and into X-Terminator before making Matt€™s robot spin out of the arena. In round 2, it did the same with 7th seed Flaming Hell, hit, hit and hit it again not giving the spinner any chance in spinning up before Flaming Hell joins the rankings on the camera tracks.
PRP had an easy round 1 in which it did nothing. Flaming Hell took out 2 of the clusterbot, whereas another part took out the final part and the 75% rule came into force. In round 2, a very close decision put PRP ahead of X-Terminator by 1 point to be here today.
3
2
1
ACTIVE
Richard flicks on the power of Storm 2 as it storms away from the starting line, PRP is spinning it€™s bar up to speed, a new bar for a new fight after the old bar got torn apart. PRP is trying to keep close to the sliding door as possible as Storm 2 turns the corner, reversing a bit to get the best speed, as PRP starts to move away from the door which has slide back into the wall for another day.
Matt is waiting for the attack from Storm 2, as the all-to familiar sound sounds, as the pit drops to show the black hole of misfortune, while my guitar gently weeps, I look at the floor, and I see my guitar gently weeping, meanwhile, back to the fight and a minute has pasted without much action. Storm 2 is driving around to wait for the right time to attack. Matt is whistling as he sits still spinning the bar around at 75% of full speed, any faster for a long time and the heat generated from the motor is enough to burn the electrics.
Storm 2 suddenly turns and comes onto the attack, slamming into PRP at full speed, the skirt has cope with the attack well, but PRP is being pushed into the wall, as the bar hits the top of Storm 2, as a panel is removed from the front, as Storm 2 slams PRP into the arena wall at some speed that the wall shakes under impact. That can€™t have been good for PRP, and look at the bar, the first to take the impact and it has bent under the pressure. Surly PRP can€™t come back from here?
Storm 2 turns and rams into PRP and flips PRP over onto it€™s top, a quick self-right from Matt€™s machine, as Storm 2 gets ready to slam PRP across the arena, looking for the arena wall. PRP is pushed onto the spike. PRP is onto it€™s back, as Storm 2 carries on with the attack, and manages to pit PRP, as it self-rights down the open void.
Cease
Result: PRP hit, hit, and pitted, Storm 2 storms though to the semi finals.
Next Time:
Martyn sings for a laugh
Scott renders another robot
Steve writes another song
Andy moans about something
And: Heat E...
Tornado (31) vs. Call out hook vs. Megabite Rev 1.0
Son of Ripper 4 (2) vs. Glasgow Kiss vs. Raven the 3rd
Stop press, due to the problem of numberous accounts, the following heat will be played in place of E:
Heat F
Typhoon 2 (9) vs. Tenderizers Revenge 2 vs. Jaws of Hell
NSBFR-X (24) vs. Chaos 2 vs. Windiest Killer
Tactics, Predictions, did you like heat D?
Erm, Im in trouble. Ill have to keep out of Typhoons way, and use the tearer on Tenderizers revenge, as the weapon wont work on Typhoon (If I fight himlater, Ill have to use the tearer as a grabber rather than its intended purpose)
HEAT E
ROUND 1
1) Jaws of Hell VS Tenderizers Revenge 2 VS Typhoon 2 (9)
Probably the RW champion to fall here after being rammed about and immobilized
2) CHAOS 2 VS N.S.B.F.R. X (24) VS Windiest Killer
Eep. Guess this depends on Franks set-up, but throughout, the basic plan is to stick to the sides of either bot and try to get one out of the ring. Failing that, open Pit and try to flip em in.
This is how you treat your electronic elders? Bah! :lame:
Spinning bar job. Much as I love Chaos 2 for its innovation, its weak armour and relative unreliability under punnishment make it the ideal target.
Tenderizers Revenge will ram Typhoon 2 with its wedge if it comes close, and try to slow it and overturn it, and if Jaws of Hell attacks, I will try to stay out of the pincers which it probably has and go for its sides unless theres a weapon there.
