http://www.youtube.com/watch?v=6z7EapPpKtchttp://www.youtube.com/watch?v=6z7EapPpKtc
Thought ill see if it still runs, may build the disc into Knightmares old chassis for Craigs event.
The more spinners the better :proud:
I love the sound of a petrol engine spinner :)
Lol Tony youre dam right, surprised you stood that close!
Dose anyone have a contactor for 24 volts to control the spinner motor for The Saint, It€™s a Perm 1.5Kw so I think about 180 amps should do it.
Thanks
Give these a shout Craig
http://www.albright.co.ukhttp://www.albright.co.uk
Albright for me for such an application.
Fightin Torque...Heavyweight Pillow Torque,
Dimensions 830mm X 525mm X 155mm
Weight 98Kg +/-
Drive, 2 X Mag C40-300, 2 stage 2Mod gearboxes ratio 6.5:1, final drive 8mm pitch X 20mm HTD timming belts.
Control, Spectrum 2.4Ghz, Roboteq HE with variable rate giro.
Power, 4 X 3000Mah Ni-cad packs.
Armour, various thickness of Hardox/titanium/nylon laminate, shock mounted in critcal locations.
Due early 2009
sounds good geoff- 4wd?
