The Crash & Burn Tournament: The Dual Duels
Seriously? We actually won that fight? Wooty woot! :proud:
One heat down, seven more to go!
As for Infusion Alpha and GeForce 4.0:
Having just read the description for Infusion, I cant quite picture where the wedge attaches or how it fits, when theres a ring spinner involved (says in the stats ala MDU but Ive not seen MDU hence the lack of being able to picture it :lame:)
So ignoring the wedge, Ill just aim to get TAN in and close the claws around it to try and slow down the spinner.
Better yet, Liam if you could just stick some self-righting hoops on Henry VIII that would be great. From what Ive read on the Aussie forum, he has a passionate dislike for them and their sheer fuglyness should be enough to distract him enough that he wont bother controlling his robot :proud:
As for GeForce 4.0, what do you think Liam? Another flipper, from the stats it sounds a bit like Wedge Devo and we managed to see it off ok, so if TAN was to grab it, it would be in our control for you to stick the axe in repeatedly before pitting it :)
Curses. Thought we were onto a winner with that pairing. :lame:
Hmm, two flippers here. Just stay away from the weapons, slip under the sides, nibble the wheels a bit, shove into whatever horrible weapon Slammers choosing for this match and dump down the pit.
Not really, just makes me more determined to tear them off the robot while tearing it apart...
Aim for the back of TAN, IIRC the armour around the rear ram is thinner and non-hardox, aim for the wheels too, should be able to tear some chunks out of them if not removing them in the process. TAN also has a lot of ground clearance to wedge under and push around, so will try that trick when possible too.
quote:
IIRC the armour around the rear ram is thinner and non-hardox Try non existant, the ram is totally exposed, but very thickwalled.
quote:
aim for the wheels too, should be able to tear some chunks out of them if not removing them in the process.That has been tried by experts and in the past 6 years only one wheel ever got damaged enough to lose the rim.
quote:
TAN also has a lot of ground clearance to wedge under and push around, so will try that trick when possible too.Thats a good tactic. If there is a pit you might get him. Be sure to get as far in the back of TAN as you can, because it has its centre of gravity very far in the rear of the robot (thats why it flips overs so easily when flipped instead of launched in the air).
Ok then Im glad you wont be at the UK featherweight champs, as I will have srimech hoops on Drumroll :lame:
We won?
I cant believe it!!
Great fights from Kody and commiserations to Alex and Steve
As for tactics...
Uh..Try and pit GeForce?
No real tactics as I couldnt seem to find stats and I really cant be bothered to look that hard:proud:
Anyway, the idea behind teaming Wheely with Sakura is so that Wheely can flip me back over if need be. Tactics are to kill, murder, destroy and generally harm.
Theyre on Kodys boards, you lazy arse :proud:}
Use the drum (or disc weapon, whatever you call it :proud:) and avoid Without You. Slam into Crash Bandibot, bludgeon the armour with the drum, and push it into Sithis like theres no tomorrow.
Namie€™s Style & Son of Wedgie vs. Slammer V & Metal Sonic Spin Dash
My tactics for this one are to use Namie and get her to attack Metal Sonic Spin Dash straight away. :P
Good luck to you all. :)
