Tetanus Booster
http://uk.youtube.com/watch?v=i7pP39W6ITEhttp://uk.youtube.com/watch?v=i7pP39W6ITE
Tetanus Booster
sorry, not paul, Ben, I need stats from Ben
And thanks for the info Paul on Tetanus Booster
I need sleep.......zzzzzzzzzzzzzzzz
With all except Ben, there are 22 robots signed up so far:
1: No Exceptions
2: Phoenix Down
3: Sideswipe
4: Symmetry
5: Baldur Gamma
6: Slammer VI
7: Bad Temper Jnr
8: Spring-bok!
9: Noo Monsoon
10: Supreme
11: Flick of the Wrist
12: Sheer Heart Attack 2
13: Wedge Devolution
14: Whirligig 4.5
15: Macduff 3rd
16: Tira IV
17: Heyght
18: Inferno
19: Brutalis
20: Systematic Shocker
21: Paralyzation 2
22: Fatality
8 more robots (4 more people) and Ill run those numbers through a RNG to determin who enters when in the rumble
So, i had to edit my post because i realized that the weaknesses are in the wrong place.
Fatality
Weight: 100 kg
Body Shape: Cone.
Colour: Flourescent Blue Body with Turquoise and Green Teeth.
Dimensions: 96 X 96 X 42 cm.
Drive: 2 X S28-400s @ 24v powered by 4 X NiCad Batteries.
Top Speed: 15 mph.
Tyres: 2 X Vulkanized Tyres.
Ground Clearence: 7mm all around. It has to be.
Armour: 6mm Hardox FBS shell, 6mm Polypropylene Base.
Turning Circle: Zero! Need I say more?
Weapon: A very nasty 36kg, 1500RPM FBS shell with 2 X 2kg Hardox Teeth and small Tungsten Carbide-tipped teeth all around, powered by an LEM-130 @ 36v. This can reach top speed in 2 seconds, and brings out about 80kJ. The teeth are curved, jagged, and barbed. Has a buttload of shock proofing inside to stop it from self-destruction. Holes drilled into it to reduce weight.
Srimech: An extremely blunt spike that comes out at the top, powered by 1 X 2kg CO2 Tank.
Strengths: Deadly Weapon, Fast Srimech.
Weaknesses: Weak Base Armour, able to shoot only 15 times with the srimech
Paralyzation 2
Weight: 100kg.
Body Shape: Low Box ala Tetanus Booster.
Colour: Interchangable Panels: One is desert yellow and the other one is pure gold.
Dimensions: 100 X 78 X 20.
Drive: 2 X LEM-130s @ 36v powered by 4 X NiCad Batteries.
Top Speed: 15 mph.
Wheels: 4 inner, Tightly Foam-Packed Wheels with Asmaprene Urethane on them.
Armour: 3.4mm Hardox 500.
Ground Clearence: 3.5mm all around.
Weapon: 19 kg Drum powered by a LEM-130 Lynch, spinning at 5000 RPM. There are 8 teeth, which are all curved upwards and jagged to rip and flip opponents.
Srimech: Invertible. Side spikes prevent it from getting beached.
Strengths: Deadly Weapon, and a Great Pusher.
Weaknesses: Exposed Tyres although very strong.
With the Addition of AJ, I need 6 more robots (3 more people). I am waiting on Ben, so really we only need 2 more. Come on, I wanna write this fight already!!
STATS: Robo-Goat
Shape: A wedge with angled sides
Colour: Grey-White
Speed: 20MPH
Weight: 100KG
Armour: 7MM Titanium
Drive: 2 C40-300 Magmotors @ 48V
Power: 5 NiCad Battlepacks @ 48V
Locomotion: 2 Vulkalon coated wheels
Ground Clearance: 0MM at front, 1-2MM on sides, 3MM at back
Turning Circle: 0
Dimensions: 110X40X25
Weapons: 1) A angled front-hinged flipper powered by 3 100X80 rams
2) 2 Linear actuated hardox goat horns to hold opponents in place
Srimech: The flipper
Strengths: Powerful flipper, Quick
Weaknesses: Not good at pushing
Robo-Hedgehog:
Shape: Box
Colour: Yellow and Black danger stripes
Speed: 25MPH
Weight: 110KG
Armour: 5MM Titanium
Drive: 4 LEM130s @ 36V
Power: 8 NiCad Battlepacks @ 36V
Locomotion: titanium tracks with a vulkalon coating
Ground Clearance: 0MM at front, 4MM everywhere else
Turning Circle: 0
Dimensions: 120X70X20
Weaponry: 1) A 15KG pointed sledgehammer, powered by pneumatics that comes down in 0.8 seconds
The next three weapons are interchangeable
2) A static Hardox wedge at the front
3) 5 static Hardox forklift arms at the front
4) A hinged Hardox scoop
5) 8 rows of 5 curved teeth, the first 6 rows face the rear and collapse when you drive forward and become rigid and damage the tyres of other robots when you drive backwards, the last row faces the opposite way and are fixed in place
Srimech: Axe, can run inverted if axe is taken off
Strengths: powerful weapons, weapons synergy and is capable of 1 or 2 hit KOs
Weaknesses: Thin armour, easily flipped and sides and rear are vunerable
Ben: Robo goat seems...plausable, so Ill enter him, just curious about the goat horns. Do they go over the top of the robot or beside the flipper (IE: to hold the robot in place so you can flip him whenever, like close to the wall or the pit) ?
Robo-Hedgehog is a little confusing. First, which set up will you be using for the rumble ? Second (and only answer if you plan to use it): can you elaborate on the curved teeth a bit ? Not sure I understand, and third: your batteries; 8 packs @ 36v = 2 sets of 4, 9v batteries. I am guessing the extra set for capacity benefits, but I dont think you can make a 9v pack from Nicads. You can get 9.6v Nicad packs. Up the operating voltage to 38.4v, then its based on real packs.
Cheers
deleted.
(Message edited by leorcc on August 17, 2008)
Oh yeah, aiall add 20kg extra of NiCads to both my bots
