that was the old beast tho and that was 10 times better then new 1
the last fight with that robot we beat thz with his axe full on and then we stuck thz back in the arena after we flipper it out :P
hope to have a buffer in envy for the next event. should help stop the freezing.
just for the record sewer snake was in a porley postion when we had a play ( 1/2 drive on one side) so its not fair to say we beat it.
ok dad
we will have to go battle bots now to have a re match
you do try dont you LJ
What are/were the seven robots youve built Mr.Swan?
I know Envy, Trax and Hells Teeth but thats all.
hells teeth 1,2 and 3 were all different robots just the same name, trax, air, 2 versions of envy. hells teeth 1 only the very few will remember with the pink chassis. hells teeth 2 was the one that appeared on the tv, and then there was hells teeth 4wd. trax you have seen, air was an attempt at a mega flipper but failed. still hit roaming robots roof with another robot tho and it did have potential. envy 1 was a front hinge flipper and the envy now is a total rebuild of the origional which sits in jonnos workshop waiting to be rebuilt which might happen and might not. answer your question ok there Liam :)
thre are pics and or vids of all the robots. :)
Thanks!I thought Trax could have done better in robot wars 7, but was unlucky to get drawn up against Storm II so early on...
we just didnt realise trax would have no grip at all. on that fight we welded blobs onto the tracks and filed them to a point but still no grip. also in doing that it lifted the scoop up off the floor so we had no chance of getting under storm2. still all history now :)
