The Fowler Fic War Series 5
Oh dear...I have walked through the portal to Punland here havent I :proud:
I think for all the problems the original Nitro-Gene had, it probably has the edge over Shadow Zone here, largely cause the rear flippers a bit small and looks a bit exposed. Shadow Zone will be returned to the shadows, while Nitro-Gene...uh....listens to Genesis records?
Heat 9 - Shadow Zone v Nitro-Gene
3...
2...
1...
Activate!
And the 9th heat final off the series begins! And the beginning is, at best tentative with what seems a little like a repeat of the match between Nitro-Gene and Y4, though without doubt Paul will be more nervous in this fight than he would of been in his previous as he faces a far more terrifying prospect this time in Shadow Zone. Kodys machine immediately seems to be looking to be the more offensive one, driving at Nitro-Gene with the front wedge, but immediately Paul just traverses out of the way of the incoming solid block and tries to switch his attention to the skirted sides of the Matador-esque machine. This doesnt really seem to get Shadow Zone worried though, nor does it seem to get Nitro-Gene anywhere in terms of slipping underneath Kodys machine. This doesnt stop Paul continuing to try and nibble away and hope for a weak spot, and when eventually he thinks hes found one, he fires the flipper, but ends up throwing nothing and instead just nearly topples himself under the force of the arm.
As Nitro-Gene fires himself into the air rather than his opponent, Shadow Zone realises what a good opportunity this is and quickly spins and tries to catch Nitro-Gene as he falls down. Instead of catching him on the flipper however, he only manages to get him onto the skirt and part of one of the mini-wedges and as a result cant get the flipper underneath. After a couple of swivveling attempts to get him to fall onto the flipper arm itself, Nitro-Gene falls off the wedge and skirt and continues on his way, though Pauls brow appears to be slightly sweaty as he manouvres away quickly before Shadow Zone has a chance to slip under for real. Kody attempts to immediately catch his escapee, but Nitro-Gene turns around at the last second and the 2 flippers grind together. Shadow Zone backs off and turns around, evidently trying to get back into the habit of using plan A, which was to use the wedge at the front. The machines charge at each other front first, and grind their prospective wedges together, both with an absolute zero ground clearance.
The 2 machines spend a brief moment grinding together, wheels spinning, before Nitro-Genes drive unleashes itself and he accelerates full pelt, and slams Shadow Zone right across the arena and into the arena sidwall where hes met by an angle grinder and the join together in beautiful matrimony and firworks fly into the sky... oh wait, no that[s just sparks as the aircraft grade aluminium gets sliced into. Nitro-Gene turns and manages to get Kodys machine to stay on the extension plate, before driving him into the wall and the next angle grinder along, he waits for a moment, before firing the flipper. Shadow Zone lands on the top of the fence, teeters momentarily, and then falls over the edge, giving Paul a one flip ko, and meaning hes done all he needs to get him through the fight.
CEASE
Shadow Zone was a shadow of his former self whilst Nitro-Gene, levers, or should that be levis his way into the semi-finals.
Next time, heat 10
The May Tracks Has You (30) v Scaramanga
Wheel of Misfortune v La Machine
Thoughts, Tactics, Predictions, A camouflage top?
The May Tracks is going to have Scaramanga I think, the automatic driving wont be enough to dodge the flipper.
Wheel Of Misfortune vs. La Machi...uh...moving on...
Heat 10 - Round 2 Battle 1 - The May Tracks Has You v Scaramanga
3...
2...
1...
Activate!
As soon as activate is called Scaramanga lets off its massive smoke screen which engulfs the arena almost instantaneously causing the audience to boo heavily as within 1 second they can no longer see the fight. Half of me is tempted to say neither can I, however that would be cheating. Alex;s machien moves around autonomously, whilst Franks tactics seems to be to try and convince Scaramanga to come near the arena wall and convince him theyre a opponent. Scaramanga isnt falling for it yet though as hes only locking onto moving targets, however this makes it surprisignly easy for Frank, who mustve eaten his carrots last night to feel his way through the smoke and around the arena. No points for aggression, but plenty for control. Frank sees a better idea though and sits right next to one of the angle grinders, which obviously is permanently moving. He sits and waits for Scaramangas smokescreen to show movement towards it, and then gently edges off, creating his own path in the smoke as he goes.
Alexs machine seems to have been falled by this though and drives himself straight under the angle grinder and attempts to flip it... immediately getting himself lodged... he tries to escape, but theres no way Frankll help, and despite the fact that theres life in the machine hes got himself lodged and is being counted out by the Refbot, the flipper plate having jammed into the bottom of the angle grinder somewhere. The count of 10 goes, Frank celebrates, Alex is inconsolable. The only think Alex has got to be happy about is that the house robots cant see anything and so cant finish off his robot.
CEASE
Me - Scaramanga.. oh dear... The May Tracks Has a place in the heat final.
...oh dear indeed :proud:
Heat 10 - round 2 - Battle 2 - Wheel of Misfortune v La Machine
3...
2...
1...
Activate!
Much to everyones suprise its La Machine who makes the faster move from the off and comes in on Wheel of Misfortune, attempting to box rush it before it has time to get the disc up to speed. Aaron turns around after the first impact and tries to get some speed behind it, managing to put La Machine off for long enough to get a reasonable hit on him, spinning the former Battlebots champion away, but with little to no damage. La Machine comes flying back after being sent away, determined that hes not going to make this fight the walkover that everyone had it down as. Aarons managed to get more speed behind the disc this time and allows the front wedge of La Machine to meet him straight on, putting a gash into it but as before, no significant damage. He tries to charge in as La Machine spins away once more, but La Machine sees the attack comign and once again just brings the scoop wedge front to meet the disc, seemingly thinking the concave design is the best chance of slowing Wheel of Misfortune down enough to be able tp push him around. Again another gash in the weak armourment but no significant hits yet.
Aaron seems more than happy to bide his time, knowing hes the stronger of the 2 machines and seems perfectly willing just to hang around and wait for La Machine to come to him. La Machine on the other hand just sits there, making sure that hes got time to keep the front facing. The audience dont seem to be happy at the prospect of such a tentative fight and so Aaron edges Wheel of Misfortune slowly closer, the disc now up to its terrifying full speed. He tries to drive in at the side, but La Machine turns away to get the wedge facing. Aaron backs off and attempts to traverse around to the back, but once again La Machine just keeps the front facing. No luck for Aaron. He tries to go down th eleft side, but knowing that La Machine will turn, calls his bluff and turns at the last minute to come down the other side, finally getting the full 2500rpm into play with a huge crash. The side panel immediuately goes in with a cut in it, and it seems to be that that one hit is all its gonna take.
La Machines side pod has been knocked in and seems to be impacting on the drive as he is now only moving in circles. Aaron spins up the disc again and tries to attack the other side. He creates a huge crevace in the other side, but the machine is still driving so he backs off again to spin the disc up. Once more he comes in when the disc is up to speed and crashes straight into the already damaged left side panel. He comes in a little closer to the front this time, and this time instead of just cutting a gash into the panel it tears the panel off completely. He can see all the internals, the motors, batteries, wheels and failsafe, but being the nice guy, decides not to go for the more expensive parts and instead just aims for the wheel. He slams into it, ripping it out of the machine, leaving La Machine a dead duck. The refbot counts him out and the fight is quickly stopped to save La Machine any further humilation.
CEASE
La Machine put up a fight but ended up playing russian roulette with the Wheel of Misfortune. He goes through to the heat final
And so the heat final itself
The May Tracks Has You (30) v Wheel of Misfortune
Thoughts, Tactics, Predictions, A Lawyer?
Hmmm...close one. Wheel Of Misfortune cant do much to May Tracks, but due to it being very wide with a spinning thing May Tracks cant do much to it with regards to flipping either. Depending how it comes out with shoving, flipping and kinetic energy Id go for May Tracks to edge a decision based on control, but it is close.
Good work Matty, some very well written fighting going on here :)
Tactics are to go for side attacks, and try to flip it into/over the wall or into house robots. Despite having easy to drive in its notes, it looks like an absolute b****r to drive thanks to the huge gyroscopic force of this disc.
Also, the Scaramanga fight was hillarious :proud:
(Message edited by pcbore on February 27, 2009)
Heat 10 - Heat Final - The May Tracks Has You (30) v Wheel of Misfortune
3...
2...
1...
Activate!
And were off for the 10th of our 16 heat finals. Wheel of Misfortune starts on the left and immediately turns around to get his rear facing a rapidly incoming May Tracks. Aaron waits til Frank has nearly reached him before driving away slightly and then swinging round, bringing the disc smashing into the side and immediately shearing a couple of the bolts holding the 4.5mm Hardox side panel in place. The impact sends The May Tracks spinning away and allows Wheel of Misfortune to get his disc back up to speed. Frank stops spinning and tries to come in for a frontal attack, but again Wheel of Misfortune spins into another attack on the same side. This time he hits it closer to the middle and gets a full on impact against the hinge of the skirtingwhich bends inwards and immediately puts pressure on the skirt itself to stay on the floor. Frank has no sooner stopped spinning from this impact than Aaron gets there again and slams into the same skirt, this time tearing it off completely.
Frank moves away and seems to be looking worried as he seems ot be unable to mount a decent attack on Wheel of Misfortune no matter how hard he tries. Aaron has backed off to get the disc back up to speed having seen it slown down by the last 2 impacts. Frank comes in again wedge first, and sees Wheel of Misfortune turn around, however wising up to Aarons preferred tactic he holds back at the last moment, allowing Aaron to overshoot the move and allowing Frank to slide underneath the 10mm ground clearance at the side and flinging him into the air. Aaron lands on his side and drives along on the disc for a minute, chewing up the arena floor before the disc slows and he falls back onto his wheels. franks right back there on his case there and immediately shunts him over to the side wall, firing the flipper again, the flip throwing Aaron straight up, but he falls back down and it gives him opportunity to drive away again.
Frank attempts to box rush into the rear end and tries even to get the tyre with the spikes but only manages to get under the rear end and flips the fleeing Wheel of Misfortune up, sending his back end into the air and the front end down. The disc again impacts with the ground sending Aaron spinning away gyroscopically under the force. He soon falls to the ground though and finds himself facing The May Tracks Has You with the disc and Aaron frantically tries to get it spinning up as The May Tracks Has You comes back in for another attack. Aaron manages to traverse away from the attack though and again finds himself slamming into the same now skirtless side panel, not managing to break through the 4.5mm hardox but again shearing away at bolts and leaving one half of the side absolutely boltless. He tries to come in for another attack on the other half but The May Tracks reverses. This doesnt do him any good though as Aaron manages to get the teeth straight into the gap left by the boltless side and tears the panel off altogether.
All of a sudden, much like his fight with La Machine, Aaron has full access to the internal gubbins of his foe. Frank turns his robot away and tries to encourage Aaron to attack the other side trying to buy himself time from the inevitable. Aaron takes this invitation and smashes into the side, ripping off the other side skirt. The impact sends Frank spinnign away and with no control, Aaron finds it so much easier to come in onto the exposed side panel. In the first attack he manages to tear one of the tracks off immediately leaving The May tracks leaning wonkily to one side. He slams in again, and on the next attack manages to completely wreck one of the movement parts itself, slamming it into the body, leaving The May Tracks unable to drive at all on one side. The refbot comes in to end the fight, leaving Frank with a frown and one of his machines out of the competition.
CEASE
The May Tracks Has... a lot of work to do... Wheel of Misfortunes luck continues and he goes through to the series semi-finals
Next up, heat 11
Wedge Devolution (12) v Acronyms
Die-Ceratops Reinvertus (28) v SYNDOS
Thoughts, Tactics, Predictions, Rent money?
Most excellent stuff Matty :)
Wedge Devo will get Acronyms out probably, and DC-RI will face SYNDOS and RIP in the PIT?
