no, they are only ram bots but one has a lifter (or will do)
does anyone know how much a fw pneumatic setup weighs ( not including the ram) ? would it be under 2kg because thats all i have to play with.
Have you got to get the CO2 bottle in that 2kg? A standard .6kg bottle weighs about .96 kg empty! (the .6kg liquid CO2 does not count).
Is it going to be full pressure or 10 - 16 bar, because a regulator can weigh .5 kg!
Methinks you may have to start drilling holes in your bot! (ouch!!!)
im building a 49cc r/c dragster. a little side project. anyone ever built one? anyways anyone have any cheap performance mini moto parts or go kart wheels / tyres (Wide ones) also lookin for some skinny wheels for front like 50-80mm dia anyone got any old radio gear they dont use? any mhz will do
(Message edited by xtreme on June 21, 2007)
no ,that weight doesnt include the co2 bottle, so how much does a 9oz paintball bottle weigh than? my chassis and base plate is quite heavy is heavy, i can always make is from something lighter.
anyone got kart wheels / tyres?
Im fairly sure a 9 oz paintball gun cylinder is the same size as .6kg but without the brass valve and hand wheel. Can anyone confirm / contradict this?
20oz cylinder is the equiv of 0.6kg
Oops! miles out, I stand corroded!
hey fellas do you know if there is anywhere to get some spoked wire wheels from about 80-100mm like these: http://www.top-flite.com/accys/topq6000.htmlhttp://www.top-flite.com/accys/topq6000.html
any help will be appreciated. also looking for go kart wheels, tires, hubs, bearings, bearing carriers. also thin walled round tube 10mm and 8mm dia, mild steel or stainless.
i may also be wanting some aluminium folding into what i think a rather difficult shapes but that wont be for a week or so. the spoked wheels at the top are the main thing at the moment.
cheers.
