The Crash & Burn Tournament 2
Lets start Heat D!
Enter the May Tracks (7) vs. BIACS-LE vs. Panic Attack
Enter the May Tracks (7) made it to the Finals last time but was beaten out by Orka MK4. Frank Goachers looking for a major comeback, and Enter the May Tracks returns with its front CO2 flipper, and steel tracks for mobility. It also is very fast at 20mph, and can prevent robots from just flying straight over the wedge using steel sunglasses.
C&BT1: Beat out Son of Ripper 5.0, Mother Of All Bricks IE, and Terrorhurtz in Heat B before losing to Orka MK4 in the Finals.
BIACS-LE is a newcomer to the game, but none less dangerous at all! Matthew Fowlers monster is equipped with a 3mm titanium mesh chassis under a 8mm fibreglass shell. This axlebot also has a 18kg vertical disc, on which the blades/teeth are mounted diagonally, to rip and flip, but it has slow acceleration. The chassis can swing over the top to protect the axle and wheels not protected by the disc, so try and damage that!
C&BT1: Did not enter.
Panic Attack was built by Kim Davies and entered by Martyn Forsyth. The low yellow fellow we all know too well has the boron carbide lifting forks and slow srimech on the top. It has side skirts as well but that hasnt stopped robots from getting under them. Will Panic Attack scare the daylights out of bots or be sent shrieking back to his builder?
Roboteers, stand by...
Booth 1: Enter the May Tracks, BIACS-LE
Booth 2: Panic Attack
Tira-san and Ancalagon the Black are our party favours today. :proud:
3...
2...
1...
ACTIVATE!
Straight off the mark is EtMT, and his plan is to go right after Panic Attack, which he is indeed doing! Panic Attack gets the gist of this plan and goes, not in the opposite direction, but right at him! WHAM! Both bots spring backwards as the flipper and forks meet. BIACS-LE slowly comes out from his spot and is almost tentative about who to attack first. Panic Attack helps him make that decision by turning away from Franks machine and heading straight for him! Its unfortunate for Martyn that the disc has reached full speed, however.
CRASH!!!
A real stunner from BIACS-LE sends Panic Attack up into the air, the forks rather buckled, but thankfully he comes down on his wheels. But not safe for long as EtMT flies in for an opportunity, which Panic Attack dismisses by heading towards the flame pit. BIACS-LE heads for EtMT now but the latter is busy chasing down Panic Attack. Panic Attack veers away from the flame pit and nearly takes a shot from the arena saws, but EtMT doesnt avoid them in time. Sparks shower the floor but the 3.25 is extremely resilient to the saws, and EtMT crashes into Panic Attack, sliding under the rear and FLIP! Over goes the yellow fellow! BIACS-LE isnt nearly satisfied with the way things are going, but decides to help Frank take out the underdog and heads straight for Panic Attack. Out comes the self-righter but its too late: as the panel starts to lift Panic Attack off the floor, BIACS-LE crashes into him.
CRASH!!!
Panic Attack reels, and says good-bye to his left side skirt as it skids across the floor to land on the pit, but this has also righted him. FLIP! And now hes inverted again thanks to EtMT, who shoves him into the wall. BIACS-LE now retreats from the wall and goes for the pit release button, but EtMT has different plans. FLIP! Panic Attack sails, but not out of the ring. He flies sideways along the wall, and crashes right-side-up. EtMT is seething but BIACS-LE having opened the pit gets the message and collides with the fleeing Panic Attack.
CRASH!!!
The corner of Panic Attack takes a huge blow and is somewhat devoid of armour now, but Panic Attack seems to be okay, landing back onto its wheels. EtMT charges in but misses Panic Attack, who retreats away...no there is definitely something wrong with Panic Attack. I think the hit...yes, that hit from BIACS-LE took out Panic Attacks left front tire! Quite a hit! And now Panic Attack is trying to stay alive for the rest of the match but I dont think thats going to happen! EtMT charges in, slamming into the forks and is foiled again. BIACS-LE enters the fray again and Panic Attack attempts to push EtMT away, but in fact, quite the reverse is happening: EtMT is pushing Panic Attack, and right against the wall! BIACS-LE charges straight in and tackles Panic Attack once again.
CRASH!!!
The fully exposed left side is brutalized, the armour torn skyward as Panic Attack spins into the air, dislodged from EtMTs grip, and lands again on his back! EtMT slides under him, and goes for an OOTA, and is successful: Panic Attack bounces onto the railing and lands onto the camera track.
CEASE!
No amount of therapy will cure Panic Attack - hes a lost cause! :proud:
Enter the May Tracks (7) and BIACS-LE advance to Round 2!
Next battle: Allanon vs. Whirligig 4.0 vs. FBSDS
Thats what its meant to do :) Cheers Kody, someone gets it :)
Alex Holt sent in his tactics from MSN, so...continuing!
Allanon is a rather unusual vapourbot, maybe due to Alex Holt being an unusual creator. :proud: It is two FBS bodies joined by top and bottom plates joined to the chassis. Its 18kg shells can go at 1700rpm, but its not the most controlled, and due to its 0.4mm ground clearance, it wont reach its top speed of 25mph any-time soon.
Whirligig 4.0 is a monster of a vapourbot. Steven McGregor knew what he was doing when he made this. It uses shuffling pads and S28-400s for motivation to 15mph, and its shell weighs 33.72kg! Not only this, but the 2 LEM130s powering the shell can spin the shell at 2000rpm, and dish out 183kJ!!! It has 3 blades on the top, middle, and bottom, so it has enough blades everywhere. It is also a pretty good pusher, and it is invertible.
C&BT1: Defeated by Tengu VII in Heat G.
FBSDS was conceived by Alexander MacWilliams and looks pretty impressive. It 35kg shell, heavier than the other ones in this fight, is powered by an Etek @ 48v, reaching speeds of 3456RPM, so its 18 teeth on the top and bottom will certainly catch opponents off-guard. It can even right itself with its own name panel, and it is shockproofed well.
Houses: Asterix Heroicus and Exa-Gore-Ic: AI. Yay. :proud:
3...
2...
1...
ACTIVATE!
Some awesome spinners in this fight and well have an opportunity to see what theyre made of as Whirligig heads in Allanons direction! Allanon is having a hard time moving and FBSDS moves in on Allanon as well. All shells are spinning at full speed and the big collision is coming...!
CRASH!
Whirly reaches Allanon first, but its Allanon who strikes Whirligig with the longer blades! Whirligig bounces away but is unharmed for the moment, and that allows FBSDS to strike!
CRASH!!!
Yep, thats done some damage all right! The left cylinder of Allanon has been smashed, the 5mm boron carbide being crumpled, and Allanon is spun around as the right cylinder starts to spin up. FBSDS is jolted back a bit but is stable. Whirligig is back up to speed and advances on Allanon again, who is still having problems moving around well. And this time, Whirly strikes right where FBSDS left his mark!
CRASH!!!!
WOAH! Talk about spinning force! Allanon has been absolutely trashed by that blow! The left side shell is broken apart, and the rest slides off, revealing a buffet of mechanics and equipment! Whirligig does not spin up to speed but heads for the pit release button, and as Allanon is trying to follow him - to stay alive - FBSDS crashes into Allanon without warning!
CRASH!!!
Allanon keels, as more boron carbide is strewn all over, and his left side drive is blown out completely! The Watcher is clearly afraid to get near these deadly cylinders, but Whirligig isnt too concerned with him right now, and, shell spinning again, is shuffling towards the obviously quailing Allanon, who can only go in circles now, but its FBSDS who smashes him again!
CRASH!!!
If this goes to a judges decision, Allanon might as well quit now as that left side is really destroyed now, and even the exposed wheel looks sad! Whirligig adds to the chaos again.
CRASH!
Allanon isnt out yet! His right side shell was still spinning and the blades caught Whirligig off-guard! And a small nick is seen in Whirlgigs shell, but FBSDS comes in again to obviously complete the destruction of Alex Holts bot.
CRASH!!!
Another hit to the left side, and Allanons left wheel is hammered badly! Not only that, but theyve reached an empty CPZ! Asterix comes flying out and tackles Allanon hard, sending the dual FBS toppling onto his side! Exa-Gore-Ic is also coming on over but it probably wont matter as Asterix has just about ended the match for Allanon. Whirligig isnt satisfied and Allanon is in for more brutalization!
CRASH!!!
Allanons right wheel takes a giant hit! The rubber is ripped, loose, and gone! That, I think, has REALLY done it for Allanon, and The Watcher seems to think so too. FBSDS, however, wont allow The Watcher through, as hes directly in front of the ref! Exa-Gore-Ic tackles FBSDS.
CRASH!
The claws take punishment, but FBSDS is withstood and shoved against the arena wall. The Watcher comes forward...and receives a shot from the arena saws. :proud: Whirligig again hits Allanon, determined to shred him to metal toothpicks!
CRASH!!!
The right wheel gets it again, and now devoid of traction and protection it buckles and comes loose, and that same blow sends Allanon spinning right into the corner! Asterix rams Allanon again and puts him against the wall, and The Watcher finally gets the hell over there and counts Allanon out, finally.
CEASE!
Allanon reaches bar none.
Whirligig 4.0 and FBSDS advance to Round 2!
Round 2
FBSDS vs. Enter the May Tracks (7)
Whirligig 4.0 vs. BIACS-LE
Tactics and predictions in please. :proud:
(Message edited by kodster on November 08, 2007)
my only prediction right now is that thisll be Whirligig 4.0s heat! :crazy:
HEAT D
ROUND 2
1) Enter the May Tracks (7) VS F.B.S.D.S.
Ooh, a toughie. If May Tracks can get a good flip in, I think itll be able to dominate. Otherwise, F.B.S.D.S. could well shake those tracks loose.
2) Bull in a China Shop L.E. VS WHIRLIGIG 4.0
Basic tactics - dodge the disc, chew up the outer fibreglass and see I can spread the floor with electronics like the oilthirsty git I am. :proud:
HEAT D
ROUND 2
1) Enter the May Tracks (7) VS F.B.S.D.S. - Im going with Steve here - Franks tracks to be rattled and broken by MacWilliams
2) Bull in a China Shop L.E. VS Whriligig 4.0 - Both of these machines are downright dangerous to fight, but the armour on Matts robot is fibreglass. Whirligig to hit, split, destroy, pulverise, batter, kill, annihilate (or any other word meaning to destroy:mrgreen:)
Keep the disc facing, itll absorbe the blows from the shell and deliver its own. and Lol, the electronics are in the fully protected wheels, so you can do what you like to the fibre glass :)
From what I remember, ETMT has armour around the tracks, so barring ETMT getting flipped onto its side somehow, FBSDS isnt getting at those tracks any time soon. Keep nagging away at it until I can flip it, then keep on it and try to pit it, or give it to the house robots.
For the other fight, Im predicting against the fashion. BIACS-LE will be more reliable, plus its armour is mostly sacrificial, wheras it only needs to damage the shell of Whirly once or twice to compromise the weapon.
Well actually, Im going to write the second fight first, as Matty and Steve have their tactics in already. :proud:
Whirligig 4.0 tore through Allanon and advanced with FBSDS.
BIACS-LE tore apart Panic Attack and allowed Enter the May Tracks to flip it OOTA. :proud:
Booth 1: Whirligig 4.0
Booth 2: BIACS-LE
Its Double Whamlet and Obelix Bulguous who take the CPZs by storm.
3...
2...
1...
ACTIVATE!!
Whirligig is starting to spin his shell up but BIACS-LE is hurtling across the arena right at him! Whirligig turns tail immediately, but BIACS-LE is too quick and wallops his shell with the disc.
CRASH!!!
Whirligig goes flying across the arena, and BIACS-LE is only jolted back a few inches, and appears to be completely okay! Indeed the disc has absorbed the intense blow from the shell, and dished it back out! Whirligig isnt having the best of luck, as the shell took quite a bash there, and is slowly getting up to its high speed, but he doesnt have time to, as BIACS-LE without a second thought slams into him again disc-first!
CRASH!!!
Whirligig goes frisbee again, only slightly this time, and crashes into the arena wall, shell immobile, and part of the armour of the shell has been ripped up into the top of the FBS, rending it useless! Thats not good for Steve at all, but its about to get worse as BIACS-LE, having achieved his 4.7 seconds of spin-up time, approaches him again, and all this time the fibreglass shell hasnt suffered a single hit! Whirligig retreats away, being the faster of the two, and slams into the pit release button, and the pit goes down, down, down. BIACS-LE almost reaches him there but Whirligig again avoids conflict and goes away towards one of the arena saw hazards. WHATS THIS?! Whirligigs shell is starting to spin up to speed again! BIACS-LE continues to chase Whirligig down despite this, yet now the shell has reached maximum damage potential, and Whirligig is back in business. Before BIACS-LE can decide what to do now, Whirligig darts around and hammers his right side.
CRASH!!!
The fibreglass shatters upon impact, and pieces litter the floor as the titanium mesh crumples a bit, yet BIACS-LE hasnt been phased much by that hit, and responds by burying his own spinning weapon into Whirligig!
CRASH!!!
Whirligig is flipped into the air, and comes down heavily onto the arena floor, inverted, yet this time there is hardly any damage inflicted. Whirligig scurries away, yet not as quickly as before, possibly giving away the suspicious that something did happen, but the shell starts to reach dangerous speeds again. BIACS-LE spins up his own weapon but not quickly enough as Whirligig crashes into him.
CRASH!!!
BIACS-LE does the Tornado thing, spinning and spinning as Whirligig bounces a little, and spins up again. BIACS-LE comes to a halt, and suddenly Whirligig is out of control! Holy flying Mauler 5150 Batman! Whirligig is spinning almost like a coin, only a very thick and scary coin! :proud: BIACS-LE, knowing nothing better to do, races in and smacks Whirligigs underside quickly.
CRASH!!!
Whirligig is tossed again, only very far this time! He hits the wall and crashes down onto the floor as BIACS-LE continues his aggression. Whirligig gets away and BIACS-LE almost hits the wall, and Whirligigs shell is again attempting a spin-up. BIACS-LE isnt letting up and pursues Whirly once again. Whirligig is back at full speed and attacks BIACS-LE, dodging the disc and smashing into the left side!
CRASH!!!
Now the armours really taken a beating, as more of the fibreglass is destroyed, and the cage is looking rather sad, but again this has allowed BIACS-LE to attack Whirligig in return!
CRASH!!!
Whirligig soars, flying up, up, and down back onto the floor, righted, thus proving what 62kJ of energy can do. :proud: And hes right near the pit! BIACS-LE hurries forward looking to end the match but Whirligig gets away again...or does he? He went right into Obelixs CPZ, and now Obelix is making him pay for it! WHAM! Down comes the hammer and Whirligigs top armour takes a huge mashing! Whamlet heads over to Obelixs CPZ but BIACS-LE gets there first.
CRASH!!!
Whirligig flies up again, right onto Obelixs hammer arm, and the shell is looking miserable: great chunks have been ripped out and the blades are dented! Whamlet reaches the CPZ and shoves BIACS-LE out of the way, giving him a good thwack for good measure. Obelix brings the hammer down again and the arm sends Whirligig away from Obelix, and past Whamlet right to the edge of the pit, but Whirligig avoids death before BIACS-LE can take advantage.
10...9...8...7...
BIACS-LE shoots past Whamlet and right at Whirligig, who avoids the hit but cant spin up his shell.
6...5...4...
Whirligig heads over to the pit again but takes a hit from the arena saws causing some sparks, and BIACS-LE runs into them as well. :proud:
3...2...1...
Whirligig rolls around the pit as BIACS-LE comes behind in pursuit...
CEASE!
Fantastic battle! Judges, I dont envy you for a second. :proud:
Whirligig 4.0 - BIACS-LE
Style = 3/5 - 2/5
Control = 1/5 - 4/5
Damage = 2/5 - 3/5
Aggression = 1/5 - 4/5
Strategy = 1/5 - 4/5
Total = 8/25 - 17/25
Whirligig slides down the drain.
BIACS-LE advances to the Heat D Final!
Next battle: FBSDS vs. Enter the May Tracks (7)
