Mechanical Noise - Series 2
Paul, it isnt a rant. People are trying to offer you advice, which you seam reluctant to take, and if people feel you are just going to ignore their helpful advice people will give up on you.
...did Martyn just type a decently constructed post?!
Holy smoking barrels, call the pigmasks Lucas, weve got a situation here!
Wow, I guess I really HAVE been out of the loop that long...
Someone end the insanity...:proud:
Heat B
Round 1
Fight 2
Axeon 2.0 vs NSBFR-X vs Shovearound 2
Axeon 2.0: Andy€™s axebot :proud:. Axeon uses the rack and pinion system popularised by Terrorhurtz and takes it to another level. The drive of this machine is great too.
In MN1: Did not compete.
NSBFR-X: Or Never-Seen-Before-Fic-Robot-X is yet another interchangeably armed machine, entered by Frank. With 5 sweet set-ups, good armour and a nice drive, this is a great all-rounder.
NSBFR-X will use the drum today.
Shovearound 2: Tony happens to own one of the most successful vapours of this year. This invertible pushing wonder is the current Fowler Fic War champ.
In MN1: Has beaten Leprosy Infection, with Whirligig 4.0, to be beaten by Going Crunch in round 2.
3€¦
2€¦
1€¦
ACTIVATE!
Shovearound and its 4 LEMs leave the starting square immediately, soon to be followed by Axeon and NSBFR. The fresh king of FFW drives in a good line to NSBFR, who attempts to get away, but still has Shovearound closing in on its side. The lifting forks reach out towards NSBFR€™s side skirts, but they don€™t get under! Instead, the forks scrape over the skirts and touch NSBFR€™s rounded side. NSBFR is shoved aside abit before getting rid of Shovearound, and faces Axeon head-on!
CRASH!
CLANG!
NSBFR€™s drum hits Axeon€™s front while Axeon€™s axe hits NSBFR€™s top :proud:. The axe-blow isn€™t that effective since Axeon is swept away by the drum on impact. NSBFR€™s acceleration proves excellent when the interchangeable machine boxrushes Axeon.
CLANG!
The drum slams the front-skirt upwards and keeps on rattling against it like a€¦ rattle, and the it looks like the hinge is about to give in when Shovearound comes in at NSBFR-X from behind! With a great clash Shovearound€™s forks ram their way under the rear-skirt.
CRASH!
Tony€™s recklessness boxrushes NSBFR closer to Axeon, and now the hinge DOES give! Axeon€™s front-skirt now is damn loose and Shovearound raises its forks. Axeon gets out of the way before facing another drum-blow and meets the lifted NSBFR at its side, and fires its axe!
CLANG!
NSBFR€™s armour is pierced now and Axeon pulls back. Shovearound moves forward, causing NSBFR€™s drum to contact the floor. With a loud BANG, NSBFR slams back on the ground and is inverted. Back in action, Frank set his sights on Axeon and the interchangeable machine rushes towards it. With nice agility NSBFR has one hell of a go at Axeon€™s side€¦
CRASH!
Axeon topples upwards and but is not quite flipped. NSBFR shows off its ramming abilities now and slams Axeon against the arena wall!
CLANG!
Axeon ends up on its side, but is quick to fire its axe when NSBFR comes in for another ram, Shovearound coming in on NSBFR€™s side, but not quite underneath.
CLANG!
Shovearound€™s interference didn€™t quite stop NSBFR from performing another slam!
10€¦ 9€¦ 8€¦ 7€¦
Time is running out when Shovearound DOES penetrate NSBFR€™s skirt!
6€¦ 5€¦ 4€¦
NSBFR is inverted!
3€¦ 2€¦ 1€¦
CEASE
A true clash of titans, and no winner yet.
Damage: Axeon 2.0 ((7 out of 10)*2=14)
NSBFR-X ((8 out of 10)*2=16)
Shovearound 2 ((5 out of 10)*2=10)
Aggression: Axeon 2.0 ((6 out of 10)*1.5=9)
NSBFR-X ((8 out of 10)*1.5=12)
Shovearound 2 ((8 out of 10)*1.5=12)
Control: Axeon 2.0 ((6 out of 10)*1=6)
NSBFR-X ((8 out of 10)*1=8)
Shovearound 2 ((8 out of 10)*1=8)
Style: Axeon 2.0 ((7 out of 10)*0.5=3.5)
NSBFR-X ((8 out of 10)*0.5=4)
Shovearound 2 ((8 out of 10)*0.5=4)
Axeon 2.0: 14+9+6+3.5=32.5
NSBFR-X: 16+12+8+4=40
Shovearound 2: 10+12+8+4=34
Axeon 2.0 couldn€™t impress the judges
NSBFR-X and Shovearound 2 go through to round 2!
Coming next:
Disco 5 (3) vs NSBFR-X
Shovearound 2 vs Slammer V
Gimme your predictions, gimme your tactics, gimme your thoughts :proud:
(Message edited by MajinB on December 23, 2007)
Depends on what set-up NSBFR-X uses...
Shovearound 2 FTW!!! :proud:
Disco 5 (3) vs NSBFR-X - I believe that Disco is going to stop dancing tonight after this fight.
Shovearound 2 vs Slammer V - SHOVEAROUND 2!!!
will give tactics when frank posts his tactics
Ill use the drum for this fight, as hes fairly tall and thus flippable. Given acceleration and speed, I can out-run him, so Ill aim at his sides and flip him over while pushing, hopefully tearing those skirts off while I do so and putting a hole or two in his armour.
Ram him all over the place and see if I can weaken him some, then go for the pit.
...Oh, and avoid Back to Rock...
i am gonna keep the disc pointed at NSBFR X as much as i can, to try and damage the robot and the drum. i should hopfuly be able to flip it with the disc as well. I will just keep going at it with the disc untill something in NSBFR breaks
