Got more done. front wheel protecters fitted top armour fitted its is there just got to paint it 15mm thick will be changing to metal if any weight left over. just got to wire it up now.
Pic on profile.
Pic on profile.
looks good tony, what weight/speed you have in the disk? have you built this for battlebots event?
not sure of weight of disc think it is about 20kg. the disc motors are bosch 750s run at 24v at a 2 to 1 reduction. not sure what that speed is.
this is a rebuild of a old robot.
Disk will run a bit over 1500 rpm then. Fast enough for a 3teeth model.
Disc :wink:
Well it looks like one when it spins. Latest pic on profile
Well done Tony, nice rebuild!
Id seen a couple of pics of it beforehand when it looked very long and had the wheels on the inside but its looking really good now :)
Cheers Jamie. It is shorter now by about 10inch just hope my welding holds out when it gets flipped. :)
it is a nice rebuild you got there tony. well done dude. :)
Am I the only person who thinks it looks like Supernova?
