FYI, Kaizer comes from Swansea. :)
Is true, if you can answer, which the material of the floor of the arena and what is the unevenness between the plates?
The floor is hardox and there is no unevenness that I am aware of.
Swansea eh? Well that's easy enough to say....
The plates of hardox can have a small gap between them though as Explosion found out last year....
http://www.youtube.com/watch?v=ZGRhTkZK3mo
http://www.youtube.com/watch?v=tuxnioS3uHg
hmm yes very flat not we drove to the start then the wheels very not on the floor and we had 1 flip as there was a lot of swarf in the buffer doh!
[quote=PJ-27]
Honestly this is really bad!
As usually works when a robot gets stuck in the arena, the opponent usually disengages it? In general, how works the mutual aid.
depends if you want to win or not, i'll always try to help, wheather or not that will actually help things, i try none the less.
The floor is all hardox so we dont get any gouges. The edges are all level and each has a 45 degree bevel to avoid hitting the edge if one did get lifted. Some of the panels are very slightly domed which can get some of the very low robots caught. I recommend a ground clearance of at least 5mm for robots. the greater the better.
As was the case in the finals I think debris got jammed between 2 panels which caught Explosion out which was such a shame. This year we will be keeping a close eye on this to avoid it having an impact on battles. Overall the floors are flat together but some have slight dishes from temperature distortion.
It's about the best combat floor you will find
