Power/failsafe LED
Good God.... its just an LED. I cant believe that this thread is still going...
My comments - Make it any colour except black (for hopefully obvious reasons) and try not to use flashing ones because half of the time they indicate that the power is off!
As Mike said above, the LEDs help marshalls/EOs choose which robots to disarm first. Isnt it just simpler to fit a standard RED/GREEN/BLUE/YELLOW LED instead of continually debating meaningless points?
Please use a bit of common sense people and help keep your EOs happy because their jobs are hard enough as it is. Fit the LED - even to feathers!
Power/failsafe LED
thx then, so as far as im concerned now, just a light to say the robot is turned on?
So i could put one actually on my link so that when its plugged in the light is on, when i remove the link, the light is off?
Power/failsafe LED
Grant,
Just read Daniels comments re meaningless points!
Let me put it as simply as I can..An LED..any damn colour you like..preferably not flashing..attached to your ROBOT..also required for feathers..to come on when your link is plugged in..to go off when your link is removed..end of story!!(hopefully)
Power/failsafe LED
Power/failsafe LED
Ok, clarity is requested (again!) and clarity will be provided, though as suggested above its beyond me where the confusion came from in the first place! :sad:
LED/light fitted in a clearly visible position.
It must come on when the link is inserted, and go off when the link is removed.
Any colour will do, as long as its clearly visable.
Preferred not flashing.
Heavily advised not to be a filament based bulb.
Required on Superheavyweights, Heavyweights,
Middleweights and Featherweights.
Hows that?
Regards
Samuel Jones
FRA Safety Executive (and keeper of all things rules!)
Power/failsafe LED
what about lightweights?
;p
Power/failsafe LED
Thats an interesting point actually - does anyone actually have a lightweight? I considered making one but figured noone else had one. Makes it easy to win trophies tho :proud:
-- Kev
Power/failsafe LED
2 lightweights in an arena, bashing ten bells out of each other would be a lovely thing to see..
Give em a year, the introduction of massive weaponry power, an explosion in numbers turning up at events.. and then we might have to look at the power light situation.
But in answer to your question:
At present no they dont need one :)
Sam
Power/failsafe LED
Sam do antweights need them?
May sound stupid but have you seen Militant? A 40,000+rpm blade weighing over 40g thats gotta hurt. Considering a 3mm led and resistor weighs about 0.5g i think antweights should have to have them but what is the current ruleing?
Regards
Ian
Power/failsafe LED
MilitAnt has a very fierce weapon. If a LED i necessary for a featherweight pusher, then antweight spinners of that class really should have them?
Just my two pence worth.
