Hahahaa! It might be made to be scared a little sooner than I thought. I found some 90mm long bolts that will work as drive shafts and the shaft mounts will take a M6 bolt without adaptation (they were sold as being M5s I think) so really, it is just the M10 bolts to hold the motor mounts in. I think, based on a test I did, they need to be about 110mm long. I might treat the wheels to some new M8 bolts that are slightly shorter to clear the wheel well as well. I also have some wheels around from an aborted BW project that will work as fixed castor wheels at the front.
After that, I'll reassemble the body and get the RageBridge installed and running.
