I try and manipulate things so Steve and Tira are between me and everything at all times :proud:
My target will be the leader.
Ill use the spinning bar and smash up the support, I suggest Alex joins me.
Just asking if anybody else wants to act (and I still need three more to enter for later chapters :P)
Ill kill support too, or I can also function as a portable hazard to protect anyone who gets damaged.
Here is my entry:
ULTO I
Shape: a bowler hat with the rim being a 360 wedge
Colour: Black all over
Speed: 9MPH
Weight: 300KG
Armour: 5MM Hardox
Drive: 4 x C40-500 Magmotors @ 36V
Power 10 NiCad Battlepacks @ 36V
Locomotion: A cheeky boy (which is essentially a number of parallel pendulums, the feet of which move in a vaguely elliptical shape so that there are always enough on the floor to be very stable. walking system for stability powered by 4 x C40-500 Magmotors on 36v. The are made of titanium, bars with a thickness of 7mm and are enclosed entirely within the shell of the robot. The feet are the same pendulum-blades as before with a textured rubber grip to provide some extra traction. The outer shell of the robot is supported on a number of castors to take the weight off the legs.
Ground clearance: 3MM
Turning circle: 0M
Size: 100x100x35 the wedge is 5CM tall and protrudes 7CM
Weaponry: 1) The outer shell spins and is powered by a Perm132, it has 8 2cm teeth on the body and 16 1cm teeth on the 360 wedge
2) 2 Identical lifting arm protrude 120cm from a small Tazbot style turret the top of the robot and go down to the floor at right angles, they are powered by a 140X180MM pneumatic ram
Each is powered by dual 5KG Co2 bottles, it has 5 attachments:
1) A Hardox Forklift Arm which is 15X5X3
2) A Curved Hardox Wedge which covers 180 degrees and is 10X100X3
3) A Hardox Scoop which is 20X20X30
The Other 2 attatchments dont use the original arm they are connected to the turret and all arms are 120 cm long (without attatchments)
4) A Mortis style lifting arm
5) A Toro/Ceros Style Lifting Arm
Specialty: Damage(i hope)
Ben, just go away. Im not even going to bother pointing out all the things that are wrong with it, thats for the other thread. :P
Not accepted.
OK:uhoh:
Ill go in with Sergeant Slaughter please:)
Mkay. Stats and specialty?
