save me 2 spots
save me 2 spots
Reserve me 2 spots as well please. :proud:
Slammer and Baldur
Increase on batteries for both
http://www.alexjholt.tkwww.alexjholt.tk
Bad Temper Jr and Spring-BOK! please.
STATS UNDER NORMAL CIRCUMSTANCES...
BAD TEMPER JR
Weight: 80 kilos
Body Shape: Rectangular, long and low. Similar dimensions to Tornado, but not invertible.
Speed: 12mph
TC: 0
GC: 7mm
Wheels: 4 inner
Armour: 6mm titanium
Power: 3x 12v batteries, powered by S28-400 Magmotors, at 24v...the usual.
Colour: Red underbelly, black sides, grey top, white weapon.
Weapon: Pneumatic knife blade, powered by CO2. Theres about 40 odd hits in it. Basically, it looks like someone stuck the blade of Overkill onto the axe arm of Dominator 2.
Srimech: The weapon goes that.
Notes: I have a little Lego model if you need pictures.
Strengths: Persistant.
Weaknessess: The arm is fairly long, so it has to be a distance away to work effectively.
SPRING-BOK!
Weight: 100 kilos
Body Shape: Firestorm.
Speed: 12mph
TC: 0.
GC: 0 at front, 7mm at sides.
Wheels: 2 inner.
Armour: 8mm titanium, covered in 2mm orange fur.
Power: 3x 12v batteries, powered by a couple of Magmotors (S28-400s).
Colour: Orange, thanks to the fur.
Weapons: A launch pad. Heres how it works...basically, the robots drive up the wedge, then the front panel, which is attached to four large car springs, fires outwards via hydraulics. A miniture piston device is attached to the panel to prevent it getting fired off, and also re-sets it. Should that fail, it does have a back-up plan (see notes).
Srimech: Two arms that extend around the side of the body, a bit like that of Philliper, only bottom hinged rather than top hinged, act as the Srimech.
Inspiration: Its named after an antelope.
Notes: This is the re-make of the former comedy yet highly sucessful robot Fluffitor, who won a previous Children In Need special. Has an in-built police siren which it activates if the going gets tough. The idea is that the oppodent will think hes about to be arrested then run off.
Strengths: Experience, unique weapon.
Weaknesses: Untested, Flammable, back-up plan probably wont work.
STATS FOR FRARRR PURPOSES...
Bad Temper Jr will have 20 kilo extra in CO2 to power his knife blade, whilst Spring-BOK! will have an extra 22 kilos of weight in batteries. I say 22 because his fur is ALSO being removed (yep, you read that right!).
I think Ill give this a miss....
PSYCH!! :proud:
Ill enter Supreme and Noo Monsoon, both with 20kg of extra battery power. :)
Stats can be found here:
http://strickenone.proboards99.com/?board=teambv&field=ordertime&order=desc&page=2http://strickenone.proboards99.com/?...rder=desc&page =2
THIS SHOULD BE GOOD!!
I am so pleased with the response thus far
Alex: Which weapon set up do you want?
Id like to enter my first two vapours
Twister and Drumblebee, stats and pictures up soon
Here are the stats on Twister Evo my first vapour
Shape: Circular, with optional skirts
Colour: Yellow for the body, grey for the wedge, blue for the main section of the arms, red for the small angled sections of the arms and black for the 2.5 KG hammers
Speed: 10MPH
Weight: 100KG
Armour 5MM Hardox, skirts are 6MM Hardox
Chassis: 4MM steel box section
Drive: 2 NPC 1200s @ 36V
Power: 4 36V NiCad battlepacks
Locomotion: 2 aluminium wheels with vulkalon treads, 5MM in diameter and 3MM in width, with 2 front casters, all wheels are partially inside the body
Ground Clearance: 2MM without skirts, 0MM without skirts, 0mm at front and sides of wedge
Turning Circle: Zero thanks to 2 front casters
Size: Bodys diameter is 45CM, main part of wedge is 20CM wide and 40Cm long, side parts of wedge are 10CM wide at widest point
Weaponry: 4 arms leading to a 2.5KG hammer on each arm, plus a complicated gray fur-covered wedge to scoop up PREY!, sorry victims, I mean opponents, the fur is to hopefully either trap the opponent or provide a spectacular fire show
Srimech: May self-right when it spins upside down
Strengths: Will obliterate anything it touches, strong armour, everything should hopefully stay far away
Weaknesses: May not self-right, battery life may be short
BIO, OBLITERATION!!!!!!!!!!, nothing else, worse than a nuclear bomb
not bad for a first try huh
