I'm going to Guilford, could do them there but would prefer to do them at home TBH. Could collect them and then post them once there done? Drop me a PM :)
Have you ever taken your robot out of the back of the van/car and thought "I really must tidy the old robot up a bit!" well that happened to me so I have decided to change the rubber armour retaining strips (colour coded:))
Attachment 4587
One side is done the other blanked out ready for fitting :eek:
~Wo it's colour coded! You only normally get that on the GLX models! :-)
Still doing bits to tidy Saint this time its the hub caps.
The old plastic hubcaps got a bit worn and even started to crack a little!
Attachment 4590
I didn't have any green plastic the right thickness but had some white HDPE left over from the Gabriel biuld so that's ok.
OH by the way, the saw you see in the picture has been brilliant, it dose not clog up and with the big blade it cuts straight even with me using it. I got it from Argos. :D
Attachment 4589
That saw looks good! And the yellow spike look like the real mccoy! lol :)
I had a look through the build pictures for Cherub, and found over time the inner parts have changed.
Attachment 4613
Attachment 4614
Cool robot. Is it held together with m8 bolts? And is it ally?
What are those gearboxes craig? They look perfect for what I am after :)
Hi
I have the details for the Drive gearbox and the lift motor.
The Gearboxes for the wheel drive are made by a company called, Pujol from Spain.
The model number is LAC40/10/120-11.
Ratio 10:1
Let me know if you find a supplier as I may need spares one day
The motors are Bosch 750W 24V.
The motor gearbox for the lifter is from a stair lift.
Made by Electric Motor Developments. EMD
The model number is PM63/50-VC24-GB2-75-1BK
RPM 37, the final drive via chain is reduction 2.5:1
This gives the total drive ratio as 187.5:1 reduction, lifting arm length 250mm
This is the same manufacturer for the motors in Seraph, Pilgrim, Spiderbot and the weapon motor in Gabriel.
Worm drive Gearboxes are very bad as far as efficiency is concerned I would think this one is no more than 45% but the advantage is the capacity to handle loads of torque in a small box and most of all for this application they can't be "back or load driven" so no need for a brake.
Hope the info helps :)
Those boxes looks like a worm and worm wheel type boxes. Have something similar with a 80:1 reduction.
Something like this I believe
http://i8.photobucket.com/albums/a49...ps975e7575.jpg
