Main frame almost complete
Shoulder joints cut from blocks of aluminium
The four 'legs' are turned in the lathe
Almost finished the first shoulder joint!
Second one... lets start again!
The first tail made from 0.6mm Titanium.... Was too thin to weld so its a spare just sat here on the shelf :(
Parts taped together. Starts to look good!
Marking out the 1.2mm aluminium arms
One arm all cut out :)
Tail number 2 being made.... hard work :(
Shoulders in position and ready to have more braces welded in.
Extra braces welded into the chassis
Custom shoulder bolts being made from titanium
Custom bolts complete and weigh just 9.2 grams each!
First attempt at welding aluminium and its the 1.2mm thick arms
Unfortunately the heat distorts it... scrap :( start again.
8kg billet of 2014 aluminium will be turned for the head.
Tubes bent to create the head cradle
Pivot has rubber bushes to absorb the impacts
Second tail made from 1.2mm titanium all welded up!
Plenty of filling to do to get it looking nice!
Tail mount tubes shaped
Tail all finished... Looks awesome!
cradle pivot mounts cut out and positioned for welding
Front cradle brackets all complete and welded on
Tail mounting tubes all welded on
Tail fits perfectly!
Shoulder joints have the lower arm sections attached
Second part of the shoulder joints made and ready for welding
Complete shoulder assembly ready to bolt in. Shoulders also have rubber inserts for shock absorbsion.
Wow
+1 that looks awesome!
looks cool
Thank you very much for the kind comments guys, really appreciated.
Plenty of pics to come!
Looks brilliant as ever, looking forward to seeing the more recent progress. What're you using to power everything? (the moving bits I mean not batteries)
Looks awesome! But you've forgotten to leave space for er,,,,, well anything!
How on earth are you going to fit everything in there?
How did you cut the shapes for the Ali arms?
It is a tiny robot if you take off the arms and tail. Things only just fit it lol... its very tight. I am hoping i can get it well under weight so it can be armoured up for combat.
Left shoulder in position. Only 1 more to do!
New arm plates are made and bent to shape. Bolted to the shoulder.
Ready to be welded.... take two!
