:mrgreen:Quote:
Originally Posted by knightrous
:mrgreen:Quote:
Yes. :proud:Quote:
Originally Posted by joeychevron
Wedga Triton vs. Orrion
I am going to try and stay around the sides of Orrion. If I can do that, it can't attack me with its weapons. I also have some 1100mm long areas to attack. Once I'm under those large sides, I should be able to push it and flip it around. Simply try and push it down one of the pits or flip it out of the arena. The axe is good, but so is my 4mm Hardox armour. Hopefully I'll be quick enough to avoid it anyway. I'll also fit the skirts for this match to try and prevent Orrion getting under me.
Good luck Jack. :)
orrions tactics:
ooh dang, im up against a good bot, but you can do anything if you put ya mind to it :mrgreen: :uhoh:
situation 1:
lets see, he's got skirts on for this match i belive? well, seeing as the flipper is 0mm i should be able to get under them ( :?: )
then i can flip to my hearts content :) i have powerfull drive so i should be able to drive him over to the arena wall where i can dispose of him, or alternativly push him down the pit
situation 2:
if for some reason i cant get under the skirts i guess i will just use the axe (the axe has quite a large swing so hopefully i can hit him from a distance) il use the special hardox piercing axe head (we have different setups for different opponents) its pierced 4mm befor so i dont see why it cant do it again!
good luck mate
jack
Fixed your quoting (Kody didn't say it) and I'm glad you noticed 8)Quote:
Originally Posted by leorcc
Just an update.
I wanted to post my fist battle last week but I was struck down with the Flu and was not able to do it properly. I am not completely out of the woods yet but work is mounting so it will be at least until next week before I put the first fight up. Sorry for the delay, but I want to do this properly.
