Tuesday doesntQuote:
Originally Posted by kodster
Liam, it was NEVER clear you meant Thursday midnight. Everything else I've ever entered, when they set a deadline, it means at the latest. You didn't specify that at all, and that's why I was annoyed at you.
And furthermore, how was I meant to know any of this when I, as I clearly said, couldn't get on?
If you had just made all of this clear, maybe I wouldn't have gotten so annoyed.
...you say you 'couldn't get on' yet you evidently WERE able to get on when you reserved a spot?
I hate to say it but it doesn't take long to copy and paste stats, and you evidently weren't entering anything new that needed final checking and statting, so if you could post to reserve a spot you could have foregone reserving, just entered your robots back then, and saved us all a lot of bother and unnecessary arguing.
Yes, that was when the password was saved. But when I tried to enter later (when I knew who I'd be entering), it wouldn't show up, and because it's such a stupid password, I couldn't possibly be expected to remember it, was I?
Either way around it, there's no point now. But, next time Liam, just a bit of advice...when you say Friday, mean Friday, and not Thursday midnight.
... :rofl:
Seung Mina V vs. PsycloniZer vs. Liar 2 vs. Neo-Mecha
Team-up with Seung Mina V accepted. Go after Neo-Mecha first, and use the usual tactics. Spin up to a relatively fast speed and unleash the hits, hopefully tearing panels and dealing shock damage. If I can take out the vertical flywheel as well, that would be great. The skirts are also targets to try and rip away at. Next up will be Liar 2. Again, repeat the usual tactics, but try and focus on the wheels. They are pretty strong, but hopefully I€™m powerful enough to damage the wheel axles and at least reduce Liar 2€™s manoeuvrability.
Another Night At The Bar vs. Iron Awe 2.1 vs. The Final Cut vs. Pick Axe of Doom
Quite confident about this to be honest. I think it€™s been discussed that Another Night At The Bar€™s own instability will be its downfall. My first target will be Pick Axe of Doom. If I can get a nice hit on the Polycarbonate areas, it could possibly even shatter. It should cause some big slices at least. I think myself and Iron Awe can damage it to the point where it is immobilised. Then I can go for Iron Awe 2.1. We all know how much damage Typhoon 2 did to this robot, and I fully intend to do the same. If required, I€™ll try and get some hits on Another Night At The Bar€™s wheels.
Gravity vs. Curse of Dread vs. Shovearound 2½ vs. Storm II
Flip! Flip! Flip! Send them flying, preferably out of the arena.
Flick of the Wrist vs. Killobite Hex vs. Wedga Triton vs. 259
It would make sense for me to go after 259 first. Get under those sides and flip it over, and hopefully that should be it eliminated. Then I€™ll assist Killobite Hex against Flick of the Wrist. I€™ll try and stack it against the arena walls or throw it out of the arena.
In the other battles I think Nidhogg To The Power Of Three & Jack in the Box, Mornington Crescent & Still Hurting, Envy & Typhoon 2 and Gabriel IV & E Clawdius Unum will go through. Good luck everyone! :)
The Easter Bunny Tribute Championships 2009
Heat A, Round 1
N^3 vs. Jack in the Box vs. CrOokEd vs. Lethal Weapon
Representing Team Picus, N^3!
This wedge shaped robot has made its name in a few tournaments, perhaps most notably reaching the grand finals of Robot SMASH!!, Robot SMASH!! Series 2: Recharged and PTT: Regeneration. Its interesting weapon synergy comprises of an overhead hydraulic crushing arm and a set of hydraulic lifting forks to clamp opponents, and the hydrostatic drive allows for immense speed, power and control. The self-righting issues from previous incarnations have been more or less fixed, and the titanium/polycarbonate armour is adequate, but the aluminium base armour is weak and could be bent out of shape easily, which could result in the robot being beached with its wheels off the ground.
2008: N/A
Representing Team Braveheart, Jack in the Box!
This box-shaped machine has skirts all around and tough 4mm hardox all over, which should keep the spinners, axes and crushers at bay. The main weapon is a flipper, it isn€™t the usual kind, as instead of being hinged at the front or rear like traditional flipping weapons it isn€™t hinged at all. The whole shell is propelled upwards by the powerful pneumatic rams to throw opponents up into the air. So the armour is strong and the weaponry powerful, but you can€™t guarantee the skirts getting under the lowest of robots, and there isn€™t any damaging weaponry.
2008: N/A
Representing Team Orr, CrOokEd!
This box wedge machine is powered by 2 mags running the go-kart wheels, allowing it decent manouevrability, but not a load of pushing power. The armour is strong at the front, as it is 6mm hardox, and the rest of the machine is pretty strong too as it is made of titanium. There is a traditional rear hinged flipper running up the machine, made of 8mm mild steel and powered by a single high pressure pneumatic ram. This has the potential to throw the other robots clean out of the arena, but can CrOokEd€™s simplicity defeat the other machines or will it end up crooked?
2008: N/A
Representing Team Berserked Robotics, Lethal Weapon!
This interesting robot is based on the Battlebots realie MechaVore, but Tony had been sure to make better of that robot, first and foremost by adding a Big Nipper style drive, with four wheels on top and four on the bottom, allowing it to run even when inverted. The spinning disc is powered by chainsaw engines and the drive by magmotors, so don€™t underestimate its power. However, the armour is undoubtedly the weakest in this round at just 3mm of titanium all round with no extra protection.
2008: N/A
Roboteers, standby!
Booth 1: Joey McConnell (Team Picus) & Steven McGregor (Team Braveheart)
Booth 2: Jack Orr (Team Orr) & Anthony Politzi (Team Devil€™s Incarnate)
3...
2...
1...
ACTIVATE!
The match begins and Nidhogg is first off, the hydrostatic drive allowing it to move swiftly across the arena towards Lethal Weapon, who dodges away to begin spinning up the horizontal disc before Nidhogg Cubed can get in on the attack. Tony is successful in evading the eye-catching crushing robot and turns to launch an attack of his own now with the spinning disc, charging at the front of Nidhogg and meeting Joey€™s machine head on! With a slam the two meet in the centre of the arena and both are flung away by the attack, and Nidhogg is left with a scar on the tough front wedge, but no real damage has been caused and so Joey goes on the attack himself now, ramming in underneath Lethal Weapon from behind and runs Tony into the pit release button!
The siren wails and the chasm descends, but Lethal Weapon isn€™t going anywhere as Nidhogg€™s hydraulic forks lift it off the ground and the crusher comes into play, squashing the titanium armour with ease and crumpling down into the workings of the machine.
Meanwhile Jack in the Box has driven straight at CrOokEd and has succeeded in getting underneath the front wedge of Jack€™s machine. Jack fights to get away, but Steven fires his flipper and sends CrOokEd up into the air, not flipping it over, but keeping it off the ground with repeated flips. However 98kg landing on you can€™t do too much good and Steven, worrying for damage caused by CrOokEd crashing down onto his machine drives away for a moment before crashing back in on the attack, but this time Jack is ready and comes forward to meet him, this time gaining the advantage and getting under the front skirt of Jack in the Box, ramming Steven back across the arena and flipping him up into the air! Steven lands on his wheels though and quickly drives back in underneath the momentarily exposed front ground clearance of CrOokEd, flipping it up and over sideways onto its back. The flipper resets, but Jack in the Box is still on the attack, ramming in underneath the up-turned CrOokEd and pushing it into the arena spike, getting underneath and flipping it again, this time knocking it up onto the rails that surround the arena! CrOokEd wobbles precariously before falling back into the arena and driving at Jack in the Box, once again gaining the advantage and this time Jack pushes the robot of his namesake back across the arena and into the rear of Nidhogg Cubed, who has a hold of Lethal Weapon but loses its grip as CrOokEd and Jack in the Box career into it from behind!
Tony€™s machine falls to the ground and speeds away, spinning around on the spot before running back in on the attack with the disc spinning, slamming into the side of CrOokEd just as Jack fires the flipper, sending Jack in the Box onto the top of N^3, who reacts by spinning to knock Jack in the Box away and in doing so fits the lifting forks under the rear of CrOokEd, who now as a small gash in the titanium side armour.
N^3 begins to lift CrOokEd off the ground and the crusher comes in from above, pinning Jack€™s machine in place as Joey heads towards the pit of oblivion, but Lethal Weapon is ramming on another attack and hits Jack in the Box, who is sent spinning into the rear of N^3 and knocks it around. However N^3 would have retained its grip, if not for Jack firing CrOokEd€™s flipper with impeccable timing creating just enough energy to free itself and Jack quickly reverses away to safety.
Lethal Weapon now decides to follow up its attack on Jack in the Box, who took that hit hard as one of the skirts was removed and it seems to be moving only in circles, perhaps one of the wires to the motor was knocked loose? It doesn€™t matter to Tony, and he rams into Jack in the Box again, ripping off another side skirt and sending it spinning onto the edge of the pit, just before N^3 spins around with expert driving to hit the forks under the front of Lethal Weapon, lifting it up again and ramming it to get the crusher over it. Meanwhile Jack in the Box hangs helplessly on the edge of the abyss, waiting for the apocalypse, which quickly arrives as CrOokEd nips over and maliciously knocks the edge of Jack in the Box, sending it tumbling down into the pit to disappear in a puff of smoke.
N^3 has a good grip on Lethal Weapon now though, furthering the damage it did earlier on and now reverses across the arena with the pit in mind, but the clock is ticking down and Lethal Weapon is saved by the bell.
CEASE!
Jack in the Box is in a different kind of box - the pit!
However three machines remain and so we must go to a judge€™s decision which 2 of those remaining 3 will progress to the second round.
Judge€™s Scorecard:
N^3: 17 points
Damage ~ 7/10 x 4 = 28/40
Aggression ~ 8/10 x 3 = 24/30
Control ~ 5/10 x 2 = 10/20
Dominance ~ 6/10 x 1 = 6/10
The Mean ~ 28 + 24 + 10 + 6 = 68/4 = 17
Jack in the Box: Eliminated
CrOokEd: 16.5 points
Damage ~ 4/10 x 4 = 16/40
Aggression ~ 9/10 x 3 = 27/30
Control ~ 9/10 x 2 = 18/20
Dominance ~ 5/10 x 1 = 5/10
The Mean ~ 16 + 27 + 18 + 5 = 66/4 = 16.5
Lethal Weapon: 18 points
Damage ~ 9/10 x 4 = 36/40
Aggression ~ 7/10 x 3 = 21/30
The Mean ~ 36 + 21 + 10 + 5 = 72/4 = 18
Judge€™s Scoreboard:
4th Jack in the Box ~ 0 points
3rd CrOokEd ~ 16.5 points
2nd N^3 ~ 17 points
1st Lethal Weapon ~ 18 points
So sadly at this stage we must bid farewell to Jack in the Box and CrOokEd;
N^3 & Lethal Weapon advance to the second round!
Seung Mina V [1] vs. PsycloniZer vs. Liar 2 vs. Neo-Mecha
Representing Team Zlayerz, seeded #1, the reigning champion Seung Mina V!
This box wedge shaped machine has it all - hardox armour strong enough to fend off all but the most powerful of hydraulic crushers. The rear hinged flipper is powered by 2 immensely powerful pneumatic rams, which when put together produce enough power to easily toss over 2000kg. The four wheels are powered by lynch motors run @ 36v, providing more than enough power to ram the other robots around the arena. Two generations on, can the champion retain her crown?
2008: Teamed up with Behemoth to flip Cat with Wheels out of the arena in the first round, then repeated that by itself in the second round by throwing Storm II onto the camera tracks. The heat final was quick and Seung Mina III was merciful, throwing her round 1 partner Behemoth over the fence. Then in the grand final emperor E Clawdius Unum posed the toughest challenge yet, but was eventually flipped into the pit.
Representing Team ???, PsycloniZer!
This invertible ring spinner has two wheels powered by S28-400 magmotors run @ 24v, providing 9HP. The outer ring spins courtesy of a LEM-200 lynch motor, but the keys are the three meaty hammers attached to the ring that are used to whack opponents. It is the champion of two major tournaments, Mechanical Noise and my own Robot SMASH!! Series 2: Recharged, so has already proved its worth in the arena. It is capable of dishing out shed-loads of shock damage with the dangerous weaponry and the hardox armour should stand up to most attacks, but the wheels are exposed from above and below, and this could be taken advantage of by axes or crushers.
2008: N/A
Representing Team Varying Every Day, Liar 2!
This is another invertible robot, this time based on Wheely Big Cheese, with a huge rear hinged flipper powered by nitrogen @ 1000psi. The lynch motors in the drive provide the power and the spikes either side of the front point can be used for spinning on the spot and whacking into opponents. The armour is tough, and don€™t bother with the exposed wheels as they are made of thick hardox. It was a finalist in Robot SMASH!! , and is a widely respected vapourbot. However, the narrow area of attack could prove to be its downfall.
2008: N/A
Representing Team Coldstorm, Neo-Mecha!
This Anklebiter-shaped machine is one of Sam€™s finest, with the powerful vertical spinning disc and linear actuated srimech. The wedge can also be used to shove opponents around the arena, and it seems to be inspired by Kody€™s old house robot Tira. The drive motors are not very powerful in comparison to today€™s other competitors though, and that could prove to be Neo-Mecha€™s downfall.
2008: N/A
Roboteers, standby!
Booth 1: Kody Kunz (Team Zlayerz) & Andrew Jackson (Team???)
Booth 2: Martijn M Benschop (Team Varying Every Day) & Samuel Park (Team Coldstorm)
3...
2...
1...
ACTIVATE!
The second match of the 2009 tournament gets underway now with the first veteran machine, reigning champion Seung Mina V heading straight for Liar 2 while PsycloniZer spins up the powerful ring and speeds towards Neo-Mecha, which gets its own weapon up to speed, ready to face PsycloniZer.
Seung Mina V is the first to make contact, dodging the front of Liar 2 and running under the side of the front nose as Liar cumbersomely tries to turn and get underneath the side of the reigning champion, but Mina is too fast and flicks Liar 2 up and over, much of the flipper power wasted because it was only slightly under Liar 2, who runs inverted and now spins, slamming Mina€™s hardox armouring with the side spike and knocking the champion against the wall! Kody retaliates instantly and drives in underneath Liar 2 again, powering across the arena and firing the flipper, this time truly throwing Liar 2 high into the air for Martijn€™s machine to come crashing down in the centre of the arena, dazed as Mina runs in for a second attack, but unfortunately for Kody she runs straight up Liar€™s flipper this time! Martijn fires his own flipper, which has 1000kg of force, which is only half of Mina€™s power but still a lot when you consider the weight limit for these machines is 100kg, and Seung Mina V turns over in mid-air as she plummets back to earth and crashes down with a bump onto the closed arena pit.
Meanwhile PsycloniZer and Neo-Mecha are getting to ready to make an onslaught, but neither are too keen on clashing spinner against spinner, so hold back, but Andy decides to make the rush and Sam knows he has no choice but to follow suit, and the two crash together in a shower of sparks and perhaps even debris as they are both flung away across the arena in opposite directions. The results of this hit are catastrophic for both machines, especially Neo-Mecha it would seems, whose disc is bent and the robot lies apparently still in the CPZ, devoid of house robots for this round. Neo-Mecha struggles to move, and it simply goes around in a feeble circle, confirming that wiring inside the machine has taken a hard knock.
PsycloniZer has fared slightly better as it still has fine manouevrability as Andy proves by driving away from the arena spike he was knocked into and doing a quick lap of the arena before entering the CPZ where Neo-Mecha lies, nudging it to make sure there€™s no chance of his opponent making a comeback. However the spinning ring of PsycloniZer certainly isn€™t spinning, and you€™ve got to wonder how much damage the internals of PsycloniZer took from that hit, the combined of energy of both spinners certainly would have been more than enough to disconnect weapon motor to weapon... But it would seem Andy was just biding his time as the ring spins back up to speed and PsycloniZer lines up to give Neo-Mecha the death knell, speeding in with both ring and drive at full speed... Poor Neo-Mecha is slammed against the barrier and flipped up by the force of the hit and is left broken and beaten in the CPZ, the removable link lying forgotten on the arena floor next to its carcass.
On the other side of the arena the fight between Liar 2 and Seung Mina V rages on, both machines managing to flip each other numerous times, but Liar 2€™s Invertibility allows it to conserve gas when the seeded robot has to waste co2 self-righting. But now PsycloniZer comes to Mina€™s rescue, slamming into the rear of the distracted Liar 2 and sending it spinning into the arena spike, where the front end gets jammed under the rails! Seung Mina V senses a chance to get Liar while it€™s caught and runs in underneath the rear of the WBC-style machine, firing the flipper, and with 2000kg of force it€™s enough to free Liar 2 from the wall as well as get it up and over said wall. Martijn looks on sadly as Liar tips over the edge and lands on the camera tracks, out of the championships for this year.
CEASE!
Neo-Mecha bites the bullet and Liar 2 is not deceptive enough;
Seung Mina V [1] & PsycloniZer go through!
Heat A, Round 2
Lethal Weapon vs. PsycloniZer
The Mechavore-style machine tackles the ever-powerful ring spinner, who will progress to the heat final to meet either Nidhogg or Mina?
Seung Mina V [1] vs. N^3
A rematch of a Robot SMASH!! Series 1 quarter-final, where Nidhogg won over Seung Mina IV. Will the champion get her revenge?
2mm Titanium/Vanadium alloy...don't think that's going to hold up long with the energies in both spinners. PsycloniZer to win by KO.
Seung Mina V [1] vs. N³
Seung Mina...eeeep. :?
Tactics are going to be fairly simple here. Use my 2wd and speed to get around the sides of the slower turning 4wd Seung Mina, ram underneath the 5mm clearance with the wedge, lift the forks and lower the crusher to pin him on the wedge, and don't waste time trying to damage it, just take it straight to first the pit release button and then release it over the descending pit. No timewasting, efficient, simple, and probably won't work :proud: in which case chase it, avoid the flipper, go for the sides and rear, catch it, fork it, crush it and pit it, wasting as little time as possible with each attempt.
Best of luck Kody
Psy for the KO here.
Tactics on this end will also be fairly simple. Outmanoeuvre Nidhogg-to-the-power-of-three and get to HIS sides, get under them, run to the arena wall and toss him over, or drop him into the pit if it's open and nearby; no fooling around with that bot, just get rid of him quickly. If he tries to get at my sides, I should be able to keep the front pointed at him at all times with my 0 turning circle and high acceleration, and then I'll just wait for him to mistime his actions before charging in with my main tactic; flip out or pit. :proud:
Good luck Joey.
Heat A, Round 2
Roboteers, standby!
House Robots: Shunt & Sir Killalot
Booth 1: Anthony Politzi (Team Berserked Robotics)
Booth 2: Andrew Jackson (Team???)
3...
2...
1...
ACTIVATE!
Spinners galore in this round 2 battle, with Lethal Weapon revving up that nasty spinning disc while PsycloniZer€™s three hefty hammers become nothing more than a blur as the ring they are connected to spins around, reaching top speed very quickly. Lethal Weapon comes out on the attack, but Andy dodges away this time, using his bot€™s superior manouevrability to evade the first attack from Lethal Weapon. The two wheel drive allows excellent control and PsycloniZer is having no trouble at all in avoiding the spinning disc of the MechaVore-style Lethal Weapon. Tony turns for another assault though and it certainly seems that a clash between these two spinners is imminent.
Both are up to full speed, and we€™re going to find out which is more potent, though you€™ve got to worry about the 3mm titanium/vanadium alloy that€™s armouring Lethal Weapon because PsycloniZer has gone through armour thicker than that in the past. On the other hand the hardox panels of PsycloniZer look like they€™ll hold up against other spinners, so Tony is the underdog here.
And now the collision cannot possibly be postponed by either driver for much longer, as PsycloniZer lines up its attack and Lethal Weapon prepares to follow suit, ready to crash its own spinning weapon into PsycloniZer. The two wheel magmotor-powered drive of PsycloniZer quickly carries it across the arena towards the 8-wheeled Lethal Weapon, but remember only 4 of those wheels are on the ground at a time. Both machines use the same drive motors, but the power is way more spread out in Lethal Weapon so PsycloniZer is likely to have more pushing power, though in a pushing match Lethal Weapon may gain more of an advantage due to the shape of the robot.
The spinning disc of Lethal Weapon is petrol-driven unlike the lynch motor powered spinning ring of PsycloniZer, which is spun by a LEM-200 motor running at a high voltage. And here they go as PsycloniZer speeds into the centre of the arena, which is where the two machines meet as Lethal Weapon rushed forward to meet PsycloniZer... And boy is that damage.
The hammers of PsycloniZer strike Lethal Weapon just as the spinning disc whacks against the bodywork of the cylindrical machine, and both robots go flying away from each other in a collision that looks like it will be even more catastrophic than when PsycloniZer slammed into Neo-Mecha€™s vertical spinning disc in the first round of this heat.
Titanium sparks shower the collision as both bots are left reeling from the impact... And neither appears to be moving after that hit. Lethal Weapon€™s armour is in tatters, as it remains attached to the robot but is peppered with huge dents and gashes from the hammer attack of PsycloniZer. Only one of the two side panels has been removed, but the internal workings are now exposed.
PsycloniZer appears to have taken less damage due to the shockproofing and stronger armour, but it has been slammed against the arena side wall and certainly the hardox armour has scars from the powerful spinning disc of Lethal Weapon. Both machines are somehow still moving though, as PsycloniZer freely moves back into the centre of the arena, while Lethal Weapon hobbles back in there and it seems that the loose armour panels are scraping along the floor, critically impairing Lethal Weapon€™s mobility.
PsycloniZer spins up again, as does Lethal Weapon, but Andy takes advantage of Lethal Weapon€™s critical mobility condition and moves to the side of his opponent, reaching full speed before driving in on his second onslaught and ripping a side panel off Lethal Weapon as well as sending the machine spinning into the arena spike. The skirts are also long gone, and Lethal Weapon struggles across the arena again though, still fighting on. PsycloniZer spins up again and reverses for a run up, ready to deliver the final death knell to Lethal Weapon. Andy at the controls hits the throttle and PsycloniZer sensationally speeds across the arena and slams into Lethal Weapon, and removing the last puny pieces of armour as it does so, as well as knocking the disc loose. Said disc hangs out of the front of the machine now, the chain connecting it to the chainsaw engines hanging limply out of the weapon slot. PsycloniZer powers down as Lethal Weapon makes no movement and Tony applauds Andy sportingly as the house robots move in to finish Lethal Weapon off, Shunt ramming in full force and slamming Lethal Weapon on top with the axe before tipping the broken remains up onto their side with the scoop while Sir Killalot gets ready to grip the defeated machine with his claw, hoisting it up into the air and beginning his trademark spin, finally letting go and allowing Lethal Weapon to sail through the air and to land in the CPZ. Still they aren€™t finished though as Shunt presses the pit release button and Sir Killalot grabs hold of Lethal Weapon one more time, reversing across the arena and turning to hold it aloft over the open pit, finally releasing the claw and letting Lethal Weapon drop into the pit, disappearing from the 2009 championships in a puff of smoke that also signals the end of the match.
CEASE!
Lethal Weapon is Psyclonised;
PsycloniZer advances to the heat final!
Representing Team Zlayerz and seeded #1, Seung Mina V!
Roboteers, standby!
House Robots: Dead Metal & Matilda
Booth 2: Joey McConnell (Team Picus)
3...
2...
1...
ACTIVATE!
Both combatants aim to end this match quickly and easily, and that is clear in their starting movements as they both dart out of the starting squares and head across the arena to meet each other, both turning to try and get to the other machines€™ side, but Nidhogg has the two wheel drive in comparison to Seung Mina€™s 4, and so makes the turn quicker and easier, getting the front lifting forks under the side of the champion and lifting immediately, taking half of Mina€™s drive off the ground, but the other two wheels rev quickly and Mina spins off the forks before the crusher can come into play, and Kody quickly runs under the side of Nidhogg, ramming Joey€™s machine towards the arena wall and firing the flipper, but N^3 wasn€™t very far up the wedge and so is slammed against the barrier before rolling dazedly into the CPZ, where Dead Metal quickly grabs him from behind and scrapes the nice paintjob with the circular saw, failing to do any real damage.
Nidhogg is quickly away and goes back on the attack of Seung Mina V, again trying the tactic of driving around to the side of the reigning champion, but failing this as Kody is wise to this trick and instead of exposing his side by trying to imitate Nidhogg this time the champion rams forward into the side of Nidhogg, flipping it high into the air this time to come crashing down onto the camera tracks. It took less than 30 seconds and N^3 is booted out of the 2009 championships.
CEASE!
N^3 needs to cube again;
Seung Mina V [1] progresses to the third round!
Heat A, Round 3
The reigning champion meets the champion of Mechanical Noise and Robot SMASH!! , but which champion will advance to the Championship finals?
Oh...bollocks. Not much you can do about the arena walls though, good work Liam and Kody :proud:
I'll have to go for Psy to win here though, I think the hammers can keep the flipper away from the main body long enough for the spinner to do damage...it might go to the judges but my (monopoly) money's on Andy to win.
oh w00t, flipping it out worked. :proud:
Run straight at him, whether he's spun up or not. Well, actually, not completely straight; I want to drive into his direction of spin so he doesn't hit the side of my flipper (that'd be catastrophic for me), but the front of the flipper. Against the flipper front itself, his blows should be largely ineffective and then I can slow the hammers down, get him fully onto the wedge, run to the wall and eject him from the warzone. If he gets away somehow, keep at it. I'm not going to let him be the aggressor.
Good luck AJ.
in response to that Liam, since you began Team Builders you have retired altogether and after that came semi-back as you called it to only enter tournaments every so often and not as a writer, it wasnt hard to assume Team Builders was cancelled through all this :lol:Quote:
Originally Posted by swimm3r
but thanks for letting us know it isnt cancelled, Team WTF, lets get cracking!
oh yeah :proud: :lol: :rofl: :proud: :uhoh: :lol:
sorry about that :shock:
Heat A, Round 3
Representing Team Zlayerz, seeded #1, Seung Mina V!
Roboteers, standby!
House Robots: Mr. Psycho & Growler
3...
2...
1...
ACTIVATE!
Both machines head out of their corners, PsycloniZer beginning to get that spinning ring up to speed while Seung Mina clearly has other plans, ramming across the arena top stop the spinning before it€™s too late. But again the benefit of having a 2-wheel drive is slapped in Kody€™s face as PsycloniZer neatly evades the onslaught from the reigning champion, allowing enough time for the hammers to have become nothing more than a blur as PsycloniZer malevolently moves in for another attack, gracefully heading towards Seung Mina V with an obvious motive - destroy!
Seung Mina V is not fooled though and drives full pelt at PsycloniZer, aiming for the direction of the spin so that the hammers will be deflected by the wedge! Andy tries valiantly to stop this happening by jerking to the right and aiming for the side of Seung Mina, but Mina is fast and powerful due to the lynch motors in the drive and is successful in this onslaught, ramming PsycloniZer towards the arena wall, but unfortunately for Kody and Andy Growler€™s CPZ is the direction they€™re headed and a 450kg house robot is enough to block their passage to the arena wall.
The careering pair collide with Growler, whose awesome jaws grab hold of a hammer of PsycloniZer, ramming across the arena now and slamming Andy€™s machine into the arena spike, which leaves a dent in the hardox armour! Growler begins to reverse towards the CPZ with PsycloniZer in tow, but Mina rushes in for a side on attack and with a flick of the powerful flipper Growler is on his back, taking Andy with him before relinquishing his grip while upside down! PsycloniZer tries to drive away, but the drive has been reversed and it goes backwards into Growler, the momentary confusion allowing Seung Mina V to dart in and ram it across the arena to the side wall again, firing the flipper to send PsycloniZer sky high before it lands on the rails, balancing worryingly for a few moments before toppling back into the arena and driving back into the security in the centre of the Burrow. The ring spins up again, and PsycloniZer dodges another box-rush from Seung Mina V before whacking the champion from behind, spinning it around and slamming it into the arena spike, leaving a small dent in the front flipper. Mina is far from defeated though and turns to attack again, this time successful as it catches PsycloniZer with the wedge in the direction of the spin and ram it across the arena and into the CPZ again, this time with Mr. Psycho€™s hammer coming crashing down onto PsycloniZer before Seung Mina V rams Andy again, firing the flipper and tossing PsycloniZer on top of Mr. Psycho! The heavyweight house robot twists and PsycloniZer falls back to the ground, but is caught in the massive claw of the 600kg monster and finds itself being crushed, Mr. Psycho gaining a good grip before hoisting PsycloniZer aloft and driving to the middle of The Burrow in order to spin wildly before releasing PsycloniZer and watching it bounce along the arena floor and into the pit release button! The siren wails and the chasm descends, but there€™s no time left for either robot to implement this hazard into their battle strategies as the buzzer sounds for the end of the match.
CEASE!
Both robots still mobile at the end of the match, so it will go to the judges.
Judge€™s Scorecard:
Seung Mina V [1]: 18.25 points
Dominance ~ 8/10 x 1 = 8/10
The Mean ~ 28 + 27 + 10 + 8 = 73/4 = 18.25
PsycloniZer: 17.75 points
Damage ~ 8/10 x 4 = 32/40
Aggression ~ 6/10 x 3 = 18/30
Control ~ 8/10 x 2 = 16/20
The Mean ~ 32 + 18 + 16 + 5 = 71/4 = 17.75
1st Seung Mina V [1] ~ 18.25 points
2nd PsycloniZer ~ 17.75 points
So by a narrow margin of 0.5 points Seung Mina V, the reigning champion is the winner of Heat A and advances to the Championship finals!
Next time, Heat B:
Another Night at the Bar [3] vs. Iron Awe 2.1 vs. The Final Cut vs. Pick-Axe-of-Doom
Next Stop, Jupiter vs. Megabyte vs. Mornington Crescent vs. Still Hurting
WOOO! pick axe of doom is next!!!
great fight mate!
w00t! :proud: Psy did put up a good fight though, can't deny that. :)
Sorry I haven't updated in a while.
I have exams at the moment, so I haven't had time to write fights of a decent standard. But this ISN'T cancelled and I will try and get back on track after the exams, which end iat the end of June, k?
