FRFFT: Series Two: Redone!
Will: Tidal Wave will do
Now the party can begin!:proud:
Seeds:
Featherweight
1: Deadly Lampshade
2: Little Hitter
Middleweight
1: Hazard
2: Typhoon
Heavyweight
1: The Hurting
2: Nitro-Gene 5.0
Superheavyweight
1: Drive
2: Ziggy
And the line-up!
Heat A
Tidal Wave VS Little Flipper 3
Blizzard MW VS Doom
2nd Revenge of Black Death VS BIACS-IS
The Red Knight VS Ziggy
Heat B
Isolation VS Deadly Lampshade
Hazard VS Complete Control
The Hurting VS Axeon 3.0
Cause and Effect VS Drive
Heat C
Little Hitter VS Sith
Typhoon VS Purer
Nitro-Gene 5.0 VS Armoured Wedgie
Shrederator Supreme VS Uberforce 2.0
Heat D
Micrompression VS Overdrive
Hyper-Ventilate VS ROID
Achillies VS Maleficant
Toro VS Drive
Any tactics or predictions?
Isolation: Spin around a lot, let Deadly Lampshade attack me and then when it does, assuming Im still running, rush into it and try to prevent it from spinning up again, shove it into the house robots and pit if possible.
Doom: Drive at Blizzard. Take losing well.
The Hurting: Keep wedge to it till disc is spun up, and then clout it with the disc until it stops. Try and flip and shove it as well, but mainly disc it.
Drive: Get round Toros sides and/or rear and first opportunity I get, shove it down the pit. Stay away from the walls where possible.
Good luck people :)
Drive is there twice: Heat B and Heat D...
Yeah, Vertigo is missed out
Cause and Effect will fight Vertigo
As you may remember, I began FRFFT: Series Two a few weeks ago. But do to incompetence, yes, incompetence on my part, I had to cancel it...
But, here, I am starting again! So welcome to Fighting Robots Fan-Fiction Tournament: Series Two!
Before we begin the first fight of the show, lets look at whos fighting:
Ziggy, from the USA, entered by Will H, won the Series One Superheavyweight Competition and is seeded second for the series. With a powerful flipper, Will hopes to do well
From England, Tidal Wave!
Entered by Will H also, this high pressure flipper hasnt been around for long, but it looks heavily armoured. Its quick, but as said before, it is inexperienced in the robotic combat field.
From England, Little Flipper 3!
Another newcomer entered by Paul, Little Flipper is Big Nippers younger sibling. Armed with a Co2 powered flipper, it looks set to do well. But once the Co2 runs out, Little Flipper could be flipped itself!
Roboteers, stand by!
3-2-1: Activate!
Tidal Wave tries to get around the side of Little Flipper, but Paul turns away and turns to face the back. Tidal Wave comes back around and FLIPS Little Flipper over! Little Flipper self-rights and tries to get revenge. Tidal Wave gets caught sideon and is THROWN against the wall. It uses the flipper to self-right, but Little Flipper took advantage and is able to push it against the wall again! Will Tidal Wave go out? NO! Little Flipper isnt that powerful. Will recovers and comes around the side again, this time he gets a flip in, but Little Flipper comes back right way up. Paul presses the pit release button, and gets THROWN out of the way by Tidal Wave. It self-rights, and Paul comes in again! It lifts Tidal Wave up, but not over! Close so far! Tidal Wave charges in and flips again! Little Flipper on its back, but it self-rights and tries to fight back. Refbot looks on. Tidal Wave gets under Little Flipper, but doesnt flip! And theres why! Its being pushed towards the pit! OH, and Paul manages to back off at the last minuet! Tidal Wave almost drives in, and Will doubles back, but Little Flipper catches it first and FLIPS it onto its back! Can Tidal Wave...yes, it can self-right from there, but Paul rams it from behind and ALMOST into the pit. Right on the edge! They are playing a dangerous game here, both roboteers! Its close so far! I think Little Flipper is on top here. Tidal Wave is trying to lure Little Flipper to the edge, but Paul isnt buying it! They go back to the centre of the arena, and Little Flipper pushes fron the side! Tidal Wave gets away and tries to sneak around the side. It fires its flipper, but misses! Wasted Co2 there! Will is nervous. Paul thinks he has this one in the bag. The last ten seconds count down. Little Flipper charges headlong at Tidal Wave and gets stuck on the front! OH! Over it goes! Little Flipper self-rights and nudges Will one last time!
Cease!
What a fight! I hope you liked it. The judges will make the decision.
Tidal Wave: S: 2 C: 2 D: 1 A: 3 Total: 8
Little Flipper 3: S: 2 C: 3 D: 1 A: 3 Total: 9
It was close. But Little Flipper wins!
Next up, a blizzard could spell certain doom for the revenge of the black death and a bull in a china shop!
See you then.
3-2-1: Activate!
Cease!
Next up, a blizzard could spell certain doom for the revenge of the black death and a bull in a china shop! :proud:
See you then. :)
Oh
I assume you liked the fight, Kody?
You still need a bit more detail in your fights, ELLIOT. And why was a SHW bot introduced at the start of the fight? :P
I was just introducing a well-known robot to the crowd. In Series Five of Robot Wars, Philippa, before the fights, would walk through the pits and introduce the veteran robots in the heat
Its kinda weird when the robot is not in the same weight class, though.
Yes, Kody
Welcome back. Last time, Tidal Wave got calmed by Little Flipper 3. Now, for the Middleweights
From England, Blizzard MW!
Alex has entered this bizzare walking robot. Instead of legs, Blizzard uses screws, shaped in a such a way the robot can move in any direction. Its not easy to grab hold of, but what damage can it really do? Well see.
From Lancashire, Doom!
Entered by Joey McC and David Smith, Doom is an upside down wheelbarrow reinforced with a lunchbox. It can ram opponents with its front scoop, but is made from very weak armour.
3-2-1: Activate!
Blizzard is intriguing, to say the least. Doom tries to push from the side, but look at that, though. Blizzard can move sideways as well! Doom decides to cut it off and charges at the front! But Blizzard, with those screws, can do sideways as well! Doom pursues it, but Alex drives forward at the last moment and pushes Doom with immense force into the wall! The front spikes have embedded themselves into Dooms front, and now Alex can do what he likes with them! Steering them towards the flame pit! We know the lunchbox in Doom that houses the electronics isnt going to last long! Joey tries to pull Blizzard over with it, but Blizzard is too strong! But whats this? Doom has gotten free and slams backwards into the pit release button. It charges back at Blizzard, but gets ambushed from the side! Towards the pit! Joey needs to get away from there! Doom JUST gets away! Blizzard turns to chase after it, but gets slammed again by Doom! Big mistake! The spikes have gotten stuck in Doom again. The drills seem to be doing little damage, but Blizzard makes up for that with 17mph top speeds! RAMMING Doom into the wall again! Refbot looks on. Is Doom immobolised? So far, Blizzard is on top. Joey looks uncertain about Dooms future in FRFFT though! The Refbot knocks the two apart! Something has come off Blizzards front there! Was it one of the spikes? I dont know. Doom slowly, yes, slowly trying to make its escape, but Blizzard pushes from behind and towards the pit...theres no escape this time! Down it goes! What a shame, but Blizzard was truly on top there!
Cease!
Doom in the pit.
Blizzard breezes into the next round!
Now to go behind the scenes. After looking at the damage to Doom, Joey found one of Blizzards ramming/drilling spikes in the armour. This is what the judges scordcards looked like
Blizzard: S: 3 C: 3 D: 1 A: 3 Total: 10
Doom: S: 1 C: 2 D: 1 A: 2 Total: 6
Next time, the heavyweights go head to head for the first time in the series!
Later, all
ELLIOT! Alex asked you to wait for the new stats! It doesnt matter if he won or not, you should at least be courteous to wait for some updates as per what he said earlier:quote:
They will be versions of Sith, MW Blizzard and Red Knight are the three otherweights - but their weights are probably wrogn atm so thats why they need updating before they can pbe properly entered.That, or at least ask Alex if its okay to use the earlier version. :P
May I point out that while I had no particular plans to update them, Im pretty sure than blizzard is overweight unless you are giving it a weight bonus.
All my otherweights were originally designed for some tournament with non-standard weighting categories which is why they needed updating. If of course you dont mind their current weights then feel free to continue, but its probably unfair on everyone else to do so.
Alex, since Blizzard qualifies as a walker, I will accept the 69kg weight limit. Their weights are OK, according to me
Kody, I do apologise, once again. Should I wait for Samuel and Will to post their tactics since theyre fighting in the next battle?
Blizzard is a walker??? Now Ive seen everything. :P
I dont know what it is. A screwbot, stompbot and shuffler count as walking robots to me. If they dont to you, Im sorry.
I dont seem to be good at this as I was the first time.
You said that after Ripper beat Tempest in CC1 :P
I think you can write the battle before getting tactics if youre desperate...check that Sams and Mattys bots are the ones they entered this time though :proud:
For the next battle, Samuel has 2nd Revenge of Black Death and Matty had BIACS-IS
So, I can still write it, Joey?
ELLIOT, I think the best thing for you to do would be to write some battles and post them in the HCII thread, where people can help you with them.
And read this thread too: http://strickenone.proboards99.com/index.cgi?board=gen&action=display&thread=460http://strickenone.proboards99.com/i...lay&thread=460
Your fights in the first tournament were pretty much on par with these...I dunno why nobody really helped you there...
yeah thats cool.
Spin up under the arms, lift the arms up wreak havoc.
Will: Correct me if Im wrong:
BIACS-IS is a pyramid. The sides are arms that can go up and down. Underneath the pyramid is a spinning disc? Does it cover the whole chassis of the robot or is it in one place? (Back, front...?)
Its an odd design
From England, BIACS-IS!
An odd design by Will, BIACS-IS is a pyramid with lifting sides that lift up together. But that reveals the main course: a 2450rpm spinning disc! The arms can close to allow the disc to spin up safely, but if it is stopped...the bull could soon be coralled!
From England, 2nd Revenge of Black Death!
Samuel entered this Firestorm-type flipper. The flipper has the same power as real robot Envy, which should provide some powerful flips. At the back is a powerful spinning disc! But once the Co2 runs out, someone will be getting revenge on it!
3-2-1: Activate!
BIACS-IS, I must say, is very odd in design. Samuel turns Black Death around to use the disc and...OUCH! He backed straight into BIACS and was spun away a bit! BIACS turns towards it, but Black Death goes away to spin its disc up again! BIACS is chasing it down, but Samuel goes for a hit again and OH! Sparks fly, and something goes flying off the back of Black Death! Was it a tooth from the disc, I wonder? Samuel decides to use the flipper, and tries to get under BIACS with the Firestorm-style wedge. BIACS is slower, but it is the more effective in weapons! Will lifts the arms up again and charges at Black Death! OH! And a mighty CRASH shakes the arena! Black Death fired its flipper to repel the disc away, but it didnt work. The flipper has a tear in it and BIACS is getting away. It presses the pit release and turns to face the battered Black Death again. The arms raise, and its like a old Western gun fight here! Black Death draws first and charges into Black Death with the flipper still up! SPARKS fly, and Black Death is spun away, ALMOST into the pit. It gets away, but BIACS is closing in and CLIPS the rear disc! Sparks fly, and BIACS disc is stopped. Will closes the arms to spin the disc up again. Black Death takes advantage and SMASHES into the front arm with the disc! No damage, though, just a small gash, but the arms yawn open again and Black Death tries to get away...BUT it doesnt! Another hit and it goes spinning a few feet! The flipper fires, and Co2 pours out. Thats a waste of Co2. BIACS charges in for the kill, but Samuel turns around...OH, and gets caught by BIACS disc as it does! A piece of metal flies off! Black Death looks very tattered. Will closes the arms and tries to push Black Death onto the flame pit, but Black Death has more speed, and pushes it...FLIPS it over! Has that mistake cost Will the match? BIACS self-rights and gets a WHACK from Black Deaths disc! A good battle so far, but I think BIACS is on top, here! The last ten seconds count down. The arms open up for the final hit...OUCH! Black Death has a mighty gash down the side now! It pushes into BIACS and tries to flip it over, but BIACS manages to hold its ground! Into the wall, Black Death finishing the stronger here!
Cease!
What a battle. Both robots caused damage to each other, but the judges will make the final decision!
BIACS-IE: S: 2 C: 3 D: 3 A: 2 Total: 10
2nd Revenge of Black Death: S: 2 C: 2 D: 1 A: 3 Total: 8
The Black Death is coralled!
BIACS-IS is the winner!
Well done to Will and BIACS-IS!
Next up, the final battle of Heat A, and Ziggy, the Series One Superheavyweight Champion, takes on The Red Knight!
And now a note
TO EVERYONE: I apologise very much if my description of BIACS-IS was NOT to anyones expectations. I researched is as much as I could, and came to the current shape as described in the match
Sorry about the mistakes last time. This battle however, will be to everyones expectations (I hope...)
From the USA, Ziggy!
Will entered the Series One Superheavyweight Champion. Its a superheavyweight version of Biohazard thats more well armoured. Its got an amazing Co2 powered flipper, but when that runs out, Ziggy could get zagged!
From England, The Red Knight!
The Red Knight is a 4WD box, on top of which is a turret powered by a sensor that detects other robots. At the end is a scoop hiding a flywheel powered by a Magmoter. It can self-right, but axes may get a direct hit on the top!
3-2-1: Activate!
The Red Knight takes the first move to the left and as Ziggy approaches, the turret turns to block the flipper. Will gets under the scoop and FLIPS, but it barley lifts the front up! OH! The turret swung around and smacked the side of Ziggy. Sparks fly! Alex backs away, but Ziggy comes in again and tries to flip! It does, but The Red Knights bulky form makes it hard to turn over. More sparks fly as the flywheel contacts with Ziggys steel armour! Will tries to sneak around the back, but the sensor directs the turret to push Ziggy away! A defensive weapon, that turret! OUCH! Ziggy spun away by the flywheel, and Alex is on top here. Refbot looks on as Ziggy...HA-HA! It flips Refbot over, only to be smacked on the side by The Red Knight! Ziggy tries to get around the side and OH! It flips The Red Knight up on its side, but not quite over. Down it crashes, and Ziggy presses the pit release button! Now Will backs towards the flywheel. OUCH! Ziggy gets spun away again! Its taking a beating, but no visible damage as such. Again it turns, and The Red Knight is waiting with its flywheel! OHH! Ziggy goes headlong into the flywheel and tried to flip The Red Knight over, but the front support for the flipper got snapped! Now Ziggys lifter is partially open. It tries to push in reverse from the side, and does so, getting between the turret and the wheels to push it against the wall, but The Red Knight gets away! A good battle so far. Ziggy is weaponless, though. The Red Knight...OUCH! Ziggy almost went airborne from the centrifugal force of being spun around by the flywheel! Sparks litter the warzone floor, and Alex pushes in from the side. OHH! Ziggy smashed against the wall! Is it mobile? It looks like it on one side, and The Red Knight comes in for the kill. OUCH! OH! Ziggy smacked into the CPZ, and now the flipper is back in place! That knock must have unjammed the buckled pneumatic arm, but I dont think its still working properly. And now I think Ziggy is out! Its weapon wont work, and Will has lowered his controls! The Refbot cant count it out, but Red Knights disc is winding down. Alex relaxes and tries to push Ziggy towards the pit with the turret. Almost...and DOWN it goes! Ziggy, the 2nd Seed in the Superheavyweight Competition, is out! What a shame!
Cease!
Ziggy gets caught in a zip!
The Red Knight gallops into the next round!
Im in the pits with Will and Noel Sharkey, one of the judges. It looks like the flippers pneumatic arm was split, so the flipper couldnt work. But the real damage was the movable link. It was shaken from its case during the last hit!
So, Little Flipper 3, Blizzard MW, BIACS-IS and The Red Knight are through!
Not to be rude, but Im losing interest in this because noone else will post anything
Its a lull, fanfic tends to have these from time to time _ I do hope theres some activity soon though.
It usually happens around this time of the year. :P
Would another battle interest you two?
It would interest me as well, because I think I entered Little Flipper 3 and its won a battle - I want to see it win another one :mrgreen:
Oh yes - Nitro-Gene hasnt fought yet:
Nitro-Gene 5.0 vs. Armoured Wedgie
Yay! Lewis first battle, but Im not going to take it easy on you anyway :proud: We are similar in a number of things, we both have flippers (mine has a LOT more power than his, but he has a LOT more flips than me) we both are 4 wheel drive and go at 20mph (but I have a lower centre of mass, and this will make me more stable, harder to flip and easier to control) and we have powerful drives run at 36V (but my S28-400 Mags produce 12hp compared to the 7hp his Bosch 750s produce).
Tactics simple - dodge to his sides (shouldnt be too tricky with my better, more stable control) and shove him to the edge and throw him out - with one flip. If he flips me, I can run inverted.
For this fight, use the flipper only for self-righting and for OOTAing when near the wall.
Good luck Lewis :wink:
Against Nitro-Gene Armoured Wedgie will flip him once, then leave him unless he self-rights, in which case flip him again. I should get under him due to my wedge shape. I dont know why Paul thinks hes more stable, and besides bigger motors doesnt mean hell push me, its more about traction. I win in any battle that lasts anyway, so stay away from the sides of the arena, plus the tyres at my sides will make it hard for him to flip me very far anyway unless he gets right underneath, which is impoissble as his front is completely flat.
Good luck Paul :)
Dont give up, ELLIOT! Only four people have written a battle this year, and you are one of them. So keep up the good work during this frustrating boredom...
Agreed with Andy, I would be interested in another battle as well. :)
While Im here Paul, Id like to know where you expect Lewis to get seven horsepower from if hes running two 36v Bosches...
Tornado had 2 x Bosch 750s at 36V, and they produced 7hp.
Exactly, peak power and what a motor will actually do under battle conditions are rather different things, as Ive already told you :P
Welcome to FRFFT: Series Two: Heat B! Last time:
Little Flipper 3 beat Tidal Wave on a Judges Decision
Blizzard pushed Doom down the pit
BIACS-IS won on a Judges Decision against 2nd Revenge of Black Death
And The Red Knight pulverised Ziggy and went into the next round!
First, we have another featherweight battle between No 1 Seed Featherweight Champion Deadly Lampshade and newcomer, Isolation
From England, Isolation!
Shaped like Killerhurtz from Robot Wars, this robot entered by Joey has a tail on the back with a hammer end, allowing it to spin around and whack its opponents. Its invertible, but with only 2XD, it wont win any pushing battles.
From Wales, Deadly Lampshade!
In Series One, it was outdone by Little Hitter in the final, but in EVO, it snatched away the title to be the champion. Daniel hasnt changed it much, but it still has no self-righting mechanism!
3-2-1: Activate!
Deadly Lampshade spins up to full speed and waits for Isolation to approach it. Isolation charges straight ahead...OH! Its spun away by Deadly Lampshade, but regains its bearings and starts to spin around on the spot. The rear hammer can be used to whack robots, but Deadly Lampshade isnt fazed and approaches again. OHH! Isolation spun to one side again and I think the hammer is hanging off! Daniel wants to hold onto that title and SMACKS Isolation again! Isolation spun against the angle grinder, the hammer has gone! Look, its behind the angle grinder, so Isolation now weaponless! Joey wont give in and charges Daniel again. OHH! This time, a mighty gash in the front plow-style design of Isolation! Joey has taken a beating, but Isolation is still moving! It presses the pit release button, and OH! Almost into the pit, I think its trying to lure Deadly Lampshade to the edge! Daniel isnt buying it, and he waits in the centre of the arena. If it goes to the judges, I think Deadly Lampshade will win. Deadly Lampshade moves in...OHH! HA-HA! It spun Isolation into the pit! Joeys tactics didnt work, and he is out of the featherweight competition!
Cease!
Isolation in the pit.
Deadly Lampshade goes into the next round!
Now, for the middleweight battle. Hazard, the No 1 Seed after winning Series One, takes in a newcomer, Complete Control!
From California in the USA, Hazard!
Entered by Samuel, Hazard didnt do too well in EVO, but in Series One, it claimed the title of Middleweight Champion. The spinning tool bar on top can rip robots to pieces. But if its flipped, it has no srimech.
From Canada, Complete Control!
Paul Cuomo and Derek Young entered Complete Control. A box with lifting forks and a hammer, Complete Control could well control this fight. But last time it took on Hazard, the Battlebots arena must have taken ages to clean up!:proud:
3-2-1: Activate!
Hazards tool bar is very dangerous, so Complete Control will want to be careful and NOT MAKE history repeat itself! But Hazard got on the side there, and sparks fly! Complete Control gets away, but Samuel and Tony Buchinani give chase! Paul hits the pit release button...OUCH! Hazard came in and BUCKLED one of the front forks! Complete Control tries to get away, but Hazard gives chase. It turns around to face Hazard and OHH! Sparks fly, and one of the forks is hanging limp now! Weve seen the damage Hazard can do before...AND now a gash down the side of Complete Control! Hazard is on top, but Complete Control charges and GETS under...OHHH! In its attempt to get under, it lifted a skirt into the tool bar and it SNAGGED its own weapon, Hazard! What a comeback by Complete Control! But before that, the fork was ripped off! It whacks Hazard on the top with the hammer, but Hazard pushes it, pushes it onto the flame pit! Complete Control gets under again and LIFTS Hazard up! Oh dear, Samuel, after being on top, looks very concerned now! Its pinned Hazard down with the hammer, Complete Control and can now carry it wherever it wants to...OVER to the pit! Hazard...OH! Into the pit! The Reigning Middleweight champion is out! What a shock! Samuel lowers his controls and goes to shake hands with Paul. Complete Control took a right battering, but turned it around at the end!
Cease!
Hazard took itself out!
Complete Control is the winner!
Im down in the pits with Noel Sharkey, one of the judges. Hes given me the scordcard up until the point Hazard was pitted
Hazard: S: 2 C: 2 D: 3 A: 3 Total: 10
Complete Control: S: 1 C: 2 D: 1 A: 2 Total: 6
Not too close, you can see.
Next up, The Hurting, the reignining Heavyweight Champion takes on Axeon 3.0 and newcomers Cause and Effect and Vertigo go head to head!
Simple tactics against Cause and Effect, just try and get around nto the side to ram it around and flip it everywhere. Hopefully get it down the pit or over the fence.
Good luck Daniel :)
Welcome back! Last time, Complete Control turned the battle around to pit Hazard and Deadly Lampshade knocked Isolation into submission!
Next up, The Hurting, the reigning Heavyweight Champion goes up against AJs new robot, Axeon 3.0
From England, The Hurting
The Hurting has beaten robots such as Absolution and Nitro-Gene 5.0 in the past. It hasnt changed: A petrol driven spinning disc that in turn provides kinetic energy for the rear flipper. Joey still wants to hold onto the title!
From England, Axeon 3.0!
A box wedge armed with a powerful Terrorhurtz-style pneumatic axe! It has magnets to keep it to the arena floor when the axe is fired. But its new, and inexperienced to FRFFT!
3-2-1: Activate!
The Hurtings disc has caused so much damage in the past, but Axeon charges in straight away and SPARKS fly! The disc connects with the Hardox armour, but AJ fires the axe, but The Hurting backs away to spin the disc up again! AJ gives chase, but The Hurting beats him to it. OH! The disc connects with the armour and more sparks fly! Axeons axe SMACKS onto the top of The Hurting, but no visible damage so far. Axeon backs away and The Hurting tries to chase it down, but Axeon turns around and The Hurting CATCHES it on the side! A gash down the side of Axeon, but that doesnt faze it. The Hurting turns around to use the flipper, but the disc has not produced enough energy, so Axeon is lifted up, but not over. The magnets have done their job so far, but OHH! The Hurting turns around to use the disc again and RIPS into the Hardox. Axeons axe comes down and JAMS into The Hurtings top armour. Sparks fly, but Axeon pushes The Hurting away, over the flames! The Hurting has a petrol engine which powers the disc, but The Hurting pulls Axeon away. A tug of war, it would seem. The Hurtings disc makes a few scratches on the armour, but nothing much. Now, IT pulls Axeon along and backs into the pit release button. The axe frees itself, and Axeon gets away to the centre of the arena. The Hurting follows and RAMS Axeon 3.0! OUCH! The front has a gash in it now. Joey wants that title badly! AJ fires the axe and SMACKS into the floor! OH! Its got itself stuck. The Hurting comes in with the disc and OUCH! The axe head split off! OH! Axeon backs away, only to be cornered by The Hurting in the CPZ and OH! The front armour has been buckled back slightly. Joey backs away, and Axeon swings its useless axe MADLY. It tries to get around the side of The Hurting and does so, but cant get under because of the buckled wedge. The last ten seconds count down. Sparks fly as the disc connects with the Hardox. Chips of armour litter the arena, but Axeon is still whacking away. Has it done enough, though?
Cease!
What a fight. The judges will have to decide!
Axeon 3.0: S: 2 C: 2 D: 2 A: 3 Total: 9
The Hurting: S: 3 C: 2 D: 3 A: 3 Total: 11
Axeon 3.0 is axed!
The Hurting goes through!
Next up, Cause and Effect and Vertigo go head to head in the Superheavyweight round!
See you then :)
