Mechanical Maelstrom Season 2.0
(apologies if this seems cranky, but as someone who understands and creates designs that include monocoques, this monocoque abuse does get on my nerves a bit)
http://en.wikipedia.org/wiki/Monocoquehttp://en.wikipedia.org/wiki/Monocoque
If the technobabble mystifies you, a monocoque is when your frame and armour are one, or the armour is constructed such that the only thing that could be described as a frame would be some internal bulkheads to mount the motors and axles.
In robots, monocoques tend to be welded (from a single type of metal) or bolted/riveted (welding giving more strength and being more common) with a single panel being removable for servicing (I favour making this the base as its less likely to be attacked, but others have their own views), this is usually bolted or screwed on to the surrounding panels.
This should usually be sited away from positions where it can be it by high impact weapons :P
Firestorm and Inverterbrat were monocoques.
The other predominant technique in robot construction is to have a separate chassis with armour panels and components mounted to it (the one Paul hilariously misidentified as a monocoque some time ago :proud:). Tornado is the best example of this I can think of.
There are advantages to both types of construction, a seperate chassis can make the robot stronger but weighs considerably more (and is a lot easier to repair), while a monocoque is a lot lighter and can make up for the strength lacking in a separate frame by using thicker material.
It is possible to combine the two methods of construction and have a monocoque body with a subframe for weaponry support (look at DisConstructor and Dominator 2) but generally robots are either one or the other.
...this is how I understand it anyway, technically minded people should feel free to correct me if they know otherwise. :) Hope this is of some use.
(Message edited by joeychevron on November 17, 2008)
Oh...right. I was just under the impression that to have just one sheet of armour would be impossible without making the robot very, very flat. The instant I see a bend, I just take that as another sheet altogether. Be fair, Ive never actually heard of the term before.
I wouldnt have said Firestorm was completely monocoque though. How else would Hypno-Disc have torn off its wheel guard?
Will accept your proposal AJ. :)
And Im busy right now, so cant write tactics. :/
Tactics for Holepunch 2.0, crush down fast, crumple the opponents frame so it stops driving.
Tactics for Eternia, conserve gas, flip only when the opportunity is there to flip oota or in the pit.
Supreme vs Gabriel IV: Enjoy the Violence (2) vs Cobalt vs Talisman
Tactics are to first attack Talisman. If its shaped exactly like Grey Matter, then those big exposed wheels are exactly what Cobalt should be good at :proud: After that, attack Gabriel due to its weak baseplate and skirts.
The May Tracks Has You vs Wedga Triton vs Neo-Mecha vs Pure Evil: Back to Basics
Get in some tyre shredding action on Neo-Mecha in order to screw up his handling, then do the same to Wedga Triton and work on getting both OOTA.
Fancy a team up in both fights for old times sake, Dan? :)... Especially since May Tracks and Pure Evil are being teamed up on :proud:
Frank, can I actually offer a team-up with Cobalt?
Ill accept Kodys team up offer for BP.
Dantu to keep on the move and not risk being pushed but otherwise go for whosever armour is flimsiest.
Time to get this tourney started...
Entrants
Team Varying Every Day, Sheer Heart Attack 2 (1)& Back to Rock III
Team Chevron, Gabriel IV: Enjoy the Violence (2) & Nidhogg Evo
Team Braveheart, Spin Dash Unleashed (3) & Traffic Warden
Team Dino Warriors, Leprosy Infection (4) & Mega Masher 2
Team Zlayerz, The Zodiac & Tira V
Team Insanity, Nitro-Gene 5.0 & Autoism 3.0
Team Wet €˜n€™ Wild, Visioned & Hot Sauce
Team Manglo-Saxons, Binary Hell & Talisman
Team Bored, The May Tracks Has You & Cobalt
Team ???, Wedga Triton & Monolith
Team Fatal Robotics, Neo-Mecha & Death Sentence
Team Britespark, Supreme & Pure Evil: Back to Basics
Team Devil€™s Incarnate, Roo 2 & Hypertension MK3
Team Accolades, Black Panther & Dantu
Team RCC, Eternia & Holepunch 2.0
Team Killa Vapourbots, Drilla Killa VII & Dendroaspis
Welcome back to Mechanical Maelstrom! This is the second season of robotic crash, bang and wallop to hit your screens and tonight will see the first four robots enter the arena to do battle, but only two can make it through to the second round.
Round 1
Nidhogg Evo vs Autoism 3.0 vs Spin Dash Unleashed (3) vs Back to Rock III
Representing Team Chevron, Nidhogg Evo!
This rollover design with Lightning-style wedge and effective weapon synergy is a contender for the title. It has a powerful Razer-style hydraulic vertical crushing beak and a front hydraulic lifter designed to get opponents€™ wheels off the ground for the crusher to come into play. The hardox armour will keep most weaponry at bay and it has good lynch motors in the drive, but with just two wheel drive and a narrow area of attack it may have difficulty if it needs to push opponents around.
Representing Team Insanity, Autoism 3.0!
This Big Nipper-esque machine has 4 wheels on top the top and bottom, and like Nidhogg Evo features hydraulic weaponry that can lift and crush, but in this case it€™s a horizontal crusher. The aluminium armour is weak, but it is protected by a tough exo-skeleton that should stop spinners making their mark. The magmotors in the drive are over-volted for more speed and power, but with Nidhogg in there the aluminium armour could prove to be its downfall.
Representing Team Braveheart, seeded 3, Spin Dash Unleashed!
This simple box shape got the bronze medal last time around, using the bottom-mounted saw blade and six wheel lynch motor powered drive to box rush opponents into hell. The 4mm hardox armour will keep most opponents away from the internals and the magmotor powering the weapon goes at a nice speed, but the weaponry will be useless against most armours.
Representing Team Varying Every Day, Back to Rock III!
This next robot is also a six wheel driven machine powered by lynch motors and also has a saw blade, so by that it sounds a lot like Spin Dash Unleashed, but unlike the Scottish machine it packs a Behemoth-style electric lifter with the saw blade mounted vertically within the lifter itself, more accurately placed to go for opponent€™s tyres.
Roboteers, standby!
Booth 1: Joey McConnell, Paul Cuomo
Booth 2: Steven McGregor, Martijn Benschop
3...
2...
1...
ACTIVATE!
As the match starts Autoism 3.0 and Nidhogg Evo quickly move towards each other, with Autoism lifting the claw into the air to get the attack in, fitting the horizontal grabbing device snugly around Nidhogg Evo€™s vertical crushing beak and utilising the hydraulic lifting part of the multi-purpose weapon to take Nidhogg€™s wheels off the ground! The crowd gasps in surprise, but Paul keeps his head and holds Nidhogg Evo aloft, reversing across the arena now to hit the pit release button and trigger the siren as the pit descends, but the impact with the pit release button has loosened Autoism 3.0€™s grip on Nidhogg Evo, and Joey€™s wedge shaped machine falls back to the arena floor, where it can quickly run from Autoism 3.0 to line up for another attack. Meanwhile Spin Dash Unleashed has taken on Back to Rock III, but unfortunately for the number #3 seed the front lifting plates of Back to Rock III have allowed it get under the front mounted horizontal saw blade of Spin Dash Unleashed, but the blue invertible box which is now inverted as Back to Rock III uses the electric lifter to lever it up and over! The bottom-mounted saw blade is now a lot less effective as its primary tactic is to attack skirts and tyres, which it cannot do if the robot is inverted (and the saw in the air). Steven pushes Spin Dash up against the lifter of Back to Rock III, hoping that Martijn will oblige and use the lifter to help the Scottish machine back onto its normal position, but Martijn has other ideas and ploughs forwards with Spin Dash Unleashed stuck on the wedge and slams the seeded robot against the spike strip, using the electric lifter again to lever Spin Dash Unleashed up and over and prop it against the fence! Steven is well and truly beached, but Martijn isn€™t happy to leave him there and heads in on another onslaught, getting those nifty front lifting plates underneath Spin Dash and raising up into the air to get Spin Dash Unleashed onto the top of the barrier! The blue battering ram wobbles worryingly at this precarious angle, and is given the final nudge by the promising Behemoth-like machine as it tumbles over the arena wall and onto the camera tracks, lying in a broken and beaten heap on the wrong side of the wall!
This leaves three machines in the arena, and shockingly it€™s the seeded robot that has been the first to bite the dust this season. Autoism 3.0 and Nidhogg Evo are still locked in a deadly embrace as Nidhogg had finally got an attack in while Back to Rock disposed of the seed. Joey has managed to lift Autoism into the air, but his powerful crushing beak has hit nothing but a bar of the exo-skeleton, stopping its progress in its tracks and preventing Nidhogg Evo from penetrating any armour and causing any damage. Autoism is however not in an entirely unhappy position as the claw is close enough to Nidhogg€™s beak to grasp around it and fire the lifting device of its own! This of course creates havoc as with both machines attempting to lift and crush each other they are locked together and as Nidhogg Evo€™s wheels are not gaining enough purchase on the ground for educated movement neither bot can get anywhere. Back to Rock III decides to play referee though and moves in on the attack, ramming in underneath the side of Nidhogg Evo and sending sparks off the base plate as the Dutch machine gets to work on the clamping robot from Pontefract/Kuwait, getting some more action and tipping the battling pair onto their side! And as Nidhogg Evo rolls over on the barrel shape they separate, but while Joey is left tumbling and reeling from the attack Autoism€™s Big Nipper-style drive setup allows it to carry on the match without even having to reverse the drive.
Autoism 3.0 just drives into the side of Nidhogg Evo and gets that horizontal claw sideways around the main overhead weapon of Nidhogg Evo, using the 5000kg of lifting power to hoist 100kg of Nidhogg Evo into the air, and although Autoism tips forwards with the weight suddenly becoming double on one side the claw doesn€™t relinquish its grip and Nidhogg is left helpless as Paul drives his machine slowly but surely over to the chasm where he quickly deposits Nidhogg Evo, the promising robot with a powerful hydraulic weapon synergy
CEASE!
Spin Dash Unleashed (3) spins out and Nidhogg Evo needs to evolve again; Autoism 3.0 and Back to Rock III move onto the second round!
Do we perchance have another halo writer on our hands? Well done Lewis!
And crap for predicting a battle almost completely wrong. XD
Just to point out - where it says Team Accolades on my site that is just the title of the list of awards, my teams actual name is Team Doomforall.
But anyway, good fight, I look forward to seeing more.
Autoism won?...it did:
+2>WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOT!
Well done Steven and Joey for putting up a fight, well done to Lewis for writing a great battle, and good luck to everyone in the next fight :wink:
PS: Dont feel bad about predicting wrong Kody - I didnt predict myself a win, and Im the git who MADE Autoism (when I say made, I mean came up with, and its an intangible robot :proud:) so dont feel too bad.
(Message edited by paulc on November 23, 2008)
Uhh...maybe you didnt see the XD at the end of my message...or are you unfamiliar with some smileys, Paul? lol :P
I did - I just dont have a clue what most of them mean.
Binary Hell: Team up with Gabriel IV if possible, do a speed run and ram everyone ito the walls, the hazards and the pit
Talisman: OOTA everyone except Cobalt
Sorry about the long wait
Eliminator 2
Mega Masher 2 vs The Zodiac vs Hot Sauce vs Binary Hell
Representing Team Dino Warriors, Mega Masher 2!
This triangular shaped robot has dangerous wedge/box-rush capabilities similar to Minion, and also like the aforementioned Battlebots Superheavyweight Champion it has a vertical spinning flywheel at the rear. This one is powered by a good old lynch motor, but is small enough for the robot to run inverted so don€™t expect any classic attacks.
Representing Team Zlayerz, The Zodiac!
This full body spinner didn€™t do too well last time around, with the 6mm ground clearance proving a major weak point against Spin Dash Unleashed. It is unchanged, and still has the four magmotors to spin the shell and another two to work the drive. It has a trusty pneumatic srimech and nastily shaped teeth, but could that all round ground clearance be its undoing a second time?
Representing Team Wet €˜n€™ Wild, Hot Sauce!
Clearly inspired by Firestorm, this hardox beastie has powerful lynch motors to get around the arena and a neat front hinged flipper to throw opponents around and even right out if it gets the opportunity. The paintjob is nice, but that won€™t save it if the design proves to be too old-fashioned and is beaten by the newer, more innovative creations.
Representing Team Manglo-Saxons, Binary Hell!
This six wheeled Killdozer-shaped robot from hell packs a hellish 4-bar lifting or flipping arm to launch the opponent over the fence. The skirts may help against other flippers and it can run inverted, but will the thin armour be exploited by the more powerful vertical crushers, and Team Manglo-Saxons didn€™t do too well last time around when Haldux 2.0 was knocked out of the first round against Leprosy Infection.
Roboteers, standby!
Booth 1: Christopher Mason, Ben Read
Booth 2: Kody Kunz, No Wai
3...
2...
1...
ACTIVATE!
The Zodiac is the most eye-catching robot in this melee as the shell quickly becomes a blur, the sharp teeth looking especially menacing when they are barely visible. Hot Sauce and Mega Masher 2 are also off the mark though and the two wedges collide in the centre of the arena, neither robot getting underneath the other but Hot Sauce€™s more powerful drive allowing it to push Team Dino Warriors entry across the arena and into the spike strip! Mega Masher€™s disc is jammed up against the strip and so can€™t begin to rotate properly unlike the shell of The Zodiac, which is already up to that dangerous top speed and moves in on the attack just as Hot Sauce reverses to safety!
A large section of Mega Masher 2€™s armour is ripped clean off and flies off across the arena, bouncing along the arena floor and coming to rest on the closed pit. Binary Hell hasn€™t done much yet, but now it is attacked by Hot Sauce and Ben is galvanised into action! Hot Sauce€™s wedge shape meets Binary Hell€™s 4-var flipping arm at the front and the two push away at each other, with Binary Hell€™s six wheel drive working hard and this time triumphing and Ben gets underneath Hot Sauce€™s wedge, now ramming No Wai€™s machine across the arena and firing the flipper to send it flying over and over and stacking Hot Sauce against the pit release button!
The siren goes off and the pit descends, with Hot Sauce being stuck where it is as the front hinged flipper is firing into thin air with no effect at all. The wheels aren€™t touching the floor and the yellow and purple wedge is in trouble now as Mega Masher 2 lines up an attack with the vertical flywheel, now up to speed courtesy of that powerful lynch motor. Chris puts the pedal to the medal now and zooms in on the attack of Hot Sauce, but just before reaching his beached opponent The Zodiac intercepts the attack and slams into the unprotected side of Mega Masher 2, tearing out the left drive motor and sending Mega Masher 2 flying across the arena and into Hot Sauce, knocking No Wai€™s decorative wedge down to the ground and back into the fight! Mega Masher struggles to move in circles, but there is no worry as Hot Sauce slides in underneath the side of Chris€™ machine and with a flick of the front hinged pneumatic flipper tips Mega Masher 2 into the pit and out of the match!
With just The Zodiac, Hot Sauce and Binary Hell left in the arena the tension increases as no driver left in there wants to be the second robot to bite the dust today. The Zodiac is back at full speed and heads across the arena towards Binary Hell, who comes forward to meet it and Ben looks confident as he feels that his flipper will easily breach that 6mm ground clearance, but he has reckoned without the friendship that has been clearly visible between Hot Sauce and The Zodiac during this match and Hot Sauce drives in from the side of Binary Hell, defeating the skirt this time and turning to push Binary Hell sideways onto the Zodiac!
With a deafening whack Binary Hell is tossed across the arena and slams into the spike strip before falling back to the arena floor missing a side skirt and a key component- the removable link was knocked out from that hit and that has rendered the number bot immobile!
Binary Hell however cool looking it was is counted down and out.
CEASE!
Mega Masher is mashed and Binary Hell is sent to hell;
The Zodiac and Hot Sauce are hot enough to go on through
Good fight Lewis, yore keeping fanfic going during these lean periods at least :)
oh w00t, the team up worked :)
Excellent writing so far Lewis :proud:
Round 1 Eliminators so far:
Autoism 3.0 and Back to Rock III pitted Spin Dash Unleashed (3) and Nidhogg Evo
Mega Masher 2 was smashed up by The Zodiac and pitted by Hot Sauce, who the helped Kody to destroy Binary Hell.
Next Battle:
Supreme vs G4briel: Enjoy the Violence (2) vs Cobalt vs Talisman
Tactics/Predictions por favor!
Tactics are up above, basically team up with Dan and go against the other two, launch them out of existance. :proud:
-2>pending me catching Dan on MSN and persuading him to agree with me on this
Well if Supreme and G4briel are teaming up, then Supreme will probably go through with G4briel, though Supremes entire front is pretty much 5mm titanium skirting, and if something smacks the skirting away, hes a goner. But...hell go through. I just have a feeling about it. :proud:
(Message edited by kodster on December 05, 2008)
Eliminator 3
Representing Team Britespark, Supreme!
This oddly shaped red robot has two weapons, one is the rear standard horizontal spinning disc, but the primary weapon is very original. On the top of the robot is a heavy hammer, but the key is that it is powered by the kinetic energy generated by the spinning disc to give it a huge amount of power! However without the disc spinning this robot is a lot less effective.
Representing Team Chevron; seeded 2, G4briel: Enjoy the Violence!
Last time around this robot€™s predecessor Gabriel III reached the grand final, throwing out good robots like Do or Die and Leprosy Infection to reach the last battle, where it lost to Sheer Heart Attack 2. This edition features a far more powerful flipper that now runs at 2400psi and some other sufficient adjustments, but is number four perhaps one evolution too far?
Representing Team Bored, Cobalt!
An interesting boxy wedge design with a horizontal disc built into the front wedge with the teeth on top to rip robots from below. It runs invertible, but the disc won€™t work upside down and when the right way up may be exposed to hits from powerful overhead weaponry, like the kinetic energy hammer of Supreme.
Representing Team Manglo-Saxons, Talisman!
The second entry from Team Manglo-Saxons is an odd T-shaped machine with powerful drive motors, armour and a high pressure flipper. It should be able to flip other robots over the fence, but with the flipper not coming anywhere near the power of G4briel there€™s a good chance this one could be outclassed by a similar type of bot.
Roboteers, standby!
Booth 1: Daniel Stickler, Joey McConnell
Booth 2: Frank Goacher, Ben Read
3...
2...
1...
ACTIVATE!
All four robots move off quickly at the start of the round, with Talisman being the first aggressor of the bout and making a beeline for G4briel, breaching the side of the seeded robot and pushing Joey McConnell€™s machine into the spike strip before firing the flipper and sending G4briel skyward!
The elongated pyramid shaped machine lands smack on the rails, wobbles precariously on the rails for a moment, then falls back into the arena and lands on its top, firing the flipper to perform a stylish somersault in the air, but it lands with its back wheels over the rails and the nose of the robot just touching the floor! However a quick shot from the flipper and G4briel is back down to the ground and on the attack of Talisman, getting under the side of the T-shaped machine and firing its own flipper, this time in an offensive manner and slamming Ben Read€™s second entry into the spike strip, most of the power used in the force that propels Talisman across the arena rather than in how far and high it goes like a rear hinged flipper would.
Meanwhile Cobalt has made a move on Supreme and successfully dodged the hammer to get under the side and push Daniel Stickler into the pit release button before his disc gets into play and throws Supreme off the wedge and into the centre of the arena! However Supreme is undeterred by the onslaught and now launches an assault of its own, ramming at the side of Cobalt and spinning up to speed as it does so, swinging the hammer down onto the disc of Cobalt, stopping it dead in its tracks and denting it!
Supreme itself actually jumped forward from the force of its hit though and is now on top of Cobalt again, but there isn€™t much Frank can do as his disc doesn€™t seem to be rotating after that deadly hit from Supreme! The Team Britespark entry is well and truly beached though, so Cobalt makes the most of it and tries to push the red robot down the pit, but G4briel accidentally interrupts this move as it pushes Talisman across the arena, having gotten under Ben€™s robot again after it recovered from the previous attack and now as Joey fires the flipper Talisman careers through the air and slams into Supreme, knocking it free of Cobalt, who is spun around by the 100kg of Talisman that came from nowhere.
G4briel immediately gets back into the action and again attacks, getting the fine nose point under Cobalt and with the touch of a button Frank€™s machine is turned turtle by the powerful G4briel in a snort of gas as the wedge shaped machine is forced to work inverted. Supreme now attacks Talisman, getting in at the rear and bringing the hammer down on top of the T-shaped machine just as the pneumatic flipper comes up and with a SLAM the two meet in the air!
Unfortunately for Talisman€™s flipper Supreme gets the upper hand and the less damaging weapon is forced back into the down position, and from the force of that hit Talisman starts to vent co2- it seems the pneumatic system has been damaged and the gas supply ruptured! This leaves Talisman without a weapon, but this doesn€™t seem to bother Daniel who ploughs on into the back of Ben and withdraws the hammer before swinging it down again on the top of Talisman, putting another crater in the top armour!
And as Supreme reverses away it is revealed that Talisman can now only work in circles- the blow has knocked loose a connection to the left drive motor and now Talisman has critically impaired mobility!
Talisman is counted down and out of the tournament as well as Team Manglo-Saxons, you€™ve been great competitors but it€™s all over for this season.
CEASE!
Three robots left, we have to go to the judges! The 5points for each key area will be split into 3 instead of 2.
Damage:
Supreme ~ 4.5 x 1= 4.5
G4briel ~ 0.2 x 1= 0.2
Cobalt ~ 0.3 x 1= 0.3
Aggression:
Supreme ~ 3.4 x 0.75 = 2.55
G4briel ~ 1.1 x 0.75 = 0.825
Cobalt ~ 0.5 x 0.75 = 0.375
Dominance:
Supreme ~ 2.1 x 0.5 = 1.05
G4briel ~ 2.4 x 0.5 = 1.2
Cobalt ~ 0.5 x 0.5 = 0.25
Control:
Supreme ~ 1.1 x 0.25 = 0.275
G4briel ~ 1.1 x 0.25 = 0.275
Cobalt ~ 2.8 x 0.25 = 0.7
Overall:
Supreme ~ 8.375
G4briel ~ 2.5
Cobalt ~ 1.625
Supreme owns the judge€™s decision with G4briel and Cobalt coughing in its wake, but the seeded machine pulls in enough points to follow it through to the next round!
Next Eliminator:
The May Tracks Has You vs Neo-Mecha vs Wedga Triton vs Pure Evil: Back to Basics
Its not called G4briel, Lewis...I may have to engage in some percussive discussions with Kody about his obsesscion with putting numbers into names :proud:
Nonetheless, it all went to plan and I got through with Supreme, looking good so far. Good work to Frank for staying in there to the end and...I usppose to Ben as well for being there.
oops sorry I got a bit confused :lol:
will call it Gabriel IV again next round
Its G4briel damnit. :rofl:
Yeah I basically predicted before but now I can make an educated guess. :proud: May Tracks I see going through no matter what, and personally I see Wedga going through with him as well.
Oh, and if you call Wedgin8or Wedginator VIII, Joey, I will have to hurt you. :P
(Message edited by kodster on December 06, 2008)
Sorry that I just realised Cobalt isnt invertible, but has a srimech. Im very sorry, but I wouldnt have said it would have made an impact on the outcom of the match. Still, if Frank wants a rematch I will do one
Im taking a 1 month LOA to help improve my physical fitness and my guitar skills:proud:, See ya soon!
Plus I think a rematch is in order
(Message edited by neontetra23 on December 06, 2008)
...just asking (I personally dont feel a rematch is really in order, if Lewis - who is a good, largely realistic writer - thinks Cobalts srimech wouldnt have changed the outcome then why should we argue?), why exactly do you feel a rematch is needed? Just saying you think so without giving a reason isnt really going to help anyone.
And, uh, enjoy your leave of absence I guess. :proud:
Ben why do you want a rematch?
Ben, Lewis didnt make an error with your vapourbot, and besides the Cobalt error the fight wasnt too shabby at all, so why in gods name do you think a rematch is merited?
Its Franks decision anyway, so leave it up to him. :P
I think the srimech mistake did affect the fight, because the srimech also protects the disc from axe attacks. Im not asking for a re-write though.
Plans for the next fight are to take out the rubber coating of Neo-Mecha, then take it out of the fight. After that Ill see whos left and take my chances where I can.
I will use the back wedge to push May Tracks, hopefully into the pit.
Eliminator 4
Representing Team Bored, The May Tracks Has You!
This original Comengetorix-shaped robot has an effective weapon synergy that utilises upward facing spikes on the wedge that penetrate the opponent€™s tyres when the powerful flipper is activated, meaning the opponent€™s manoeuvrability could be in danger here. And once The May Tracks Has You, there really is no escape, however the tracks could be in danger from flipper/axe combinations.
Representing Team ???, Wedga Triton!
This is the latest robot in a long running line of flippers, and in power it doesn€™t disappoint with the ability to throw 1600kg around! The sleek Storm II shape will help it to get under other robots and the adequate magmotors give very good control, but the robot isn€™t an ideal shape for flipping
Representing Team Fatal Robotics, Neo-Mecha!
This Ankle-Biter shaped robot has a vertical spinning disc and rear wedge to push robots around the arena, plus the linear actuated srimech can un-turtle it less than a second. For this battle Samuel Park has teamed up with Wedga Triton, could it be a match made in heaven or will these two be a terrible twosome.
Representing Team Britespark, Pure Evil: Back to Basics!
Like what it says in the name, this simple wedge is pure evil. The powerful nitrogen flipper can toss robots out of the arena and the tracks provide superb traction as well as utilising the 10kg weight bonus unlike The May Tracks Has You. However is it too simple to compete with modern day designs?
Roboteers, standby!
Booth 1: Frank Goacher, Daniel Stickler
Booth 2: Andrew Jackson, Samuel Park
3...
2...
1...
ACTIVATE!
The three flippers and a spinning disc that are competing in this battle all get off the mark quickly, but immediately two separate battles are being fought as Wedga Triton makes a beeline for Pure Evil while The May Tracks Has You launches an assault at Neo-Mecha.
Wedga gets in the first attack of the match, attacking the corner of Pure Evil€™s front wedge and managing to breach it this time, forcing Daniel Stickler€™s second entry back across the arena and flipping it over with so much force the wedge shaped machine flips backwards over and over in the air before landing on its tracks and attacking the flipper-open Wedga Triton, breaching the clearance opened by the gaping flipper and it sends the blue Storm II-shaped robot over onto its back just as the large flipper closes, immediately allowing Andrew Jackson at the controls to activate the flipper a second time and get Wedga Triton back onto its wheels for it to attack Pure Evil, who now has the flipper open and it feels like dj vu, but this time the flip is fatal as Wedga Triton pushes Pure Evil against the spike strip and when it activates the flipper 1600kg of force send Pure Evil up and over the barrier, to the end of its competition.
Meanwhile The May Tracks Has You slides in underneath Neo-Mecha completely avoiding the disc and getting the Ankle Biter-shaped machine stuck on the upward facing spikes before Frank activates the flipper and sends Neo-Mecha over onto its back. Samuel self-rights, but his manoeuvrability is greatly impaired and the spinner barely limps towards The May Tracks, but does manage to score a hit on the front wedge with the spinning disc and flips the front end of May Tracks into the air before limping in so Frank lands on top of the disc, but Neo-Mecha€™s weaponry is of course motionless so no further damage is caused and the disc rolls downwards as The May Tracks Has You is returned to the floor and immediately Frank drives in underneath Neo-Mecha again, pushing it across the arena floor and into the back of Wedga Triton (who at this point has just flipped out Pure Evil), ramming them both against the arena wall, and putting Neo-Mecha on top of Wedga, who turns and rams the pit release, freeing Neo-Mecha and opening the pit in one easy move! And now as The May Tracks goes on the attack again to finish off Neo-Mecha Wedga Triton drives in underneath the side of the clever weapon synergy machine and flips it high into the air!
Frank comes crashing back to the ground on his back and self-rights, but Neo-Mecha has limped over to him and hits the side of May Tracks with a hefty hit from the spinning disc, knocking the side panel skyward and flipping the May Tracks over again! Frank self-rights, but the team-up has proved deadly as Wedga Triton now comes on the attack, now driving in underneath The May Tracks and pushing it right across the arena and over the side of the pit!
CEASE!
Pure Evil should go back to complexity and The May Tracks Doesn€™t Have You;
Wedga Triton and Neo-Mecha advance to the second round!
Autoism 3.0 and Back to Rock III pitted Spin Dash Unleashed (3) and Nidhogg Evo.
Gabriel IV: Enjoy the Violence (2) squeaked through the judges decision between 3 robots after Talisman was eliminated. Supreme owned the judges decision, but Cobalt had just 1.625 points.
Pure Evil: Back to Basics wasnt evil enough for Wedga Triton and Neo-Mecha caused a lot of damage to The May Tracks Has You.
Next Eliminator:
Sheer Heart Attack 2 (1) vs Death Sentence vs Traffic Warden vs Roo 2
Eliminator 5
Representing Team Varying Every Day, seeded #1, Sheer Heart Attack 2!
The reigning champion returns! It€™s unchanged from last season, still the same old drum with tracks and rear wedges, a very cool design that is packed with originality. The tracks are made from thick titanium and powered by lynch motors while the upward spinning drum is powered by magmotors. It immobilised MeCannibal 3.0 last time in the first round before taking out Spin Dash Unleashed and eventually Gabriel III in the final.
Representing Team Fatal Robotics, Death Sentence!
This is a box shaped rammer with an X-Terminator style scoop at the rear to shove opponents around with. The horizontal spinning disc at the front can dish out some serious pain and the robot runs when inverted, but the tracks are exposed to attacks from above.
Representing Team Braveheart, Traffic Warden!
This awe-inspiring rigid U-shaped machine is also very original, like the seeded machine in this melee. It utilises hydraulic clamps to hold the opposition in place and can then control all but the most powerful rammers with the huge E-Teks that supply over 30HP to the wheels! However the 4mm titanium armour could be thrashed by spinners, which 3 of the other robots in this melee are.
Representing Team Devil€™s Incarnate, Roo 2!
This cylinder shaped machine employs a mega-powerful spinning spike ring around the robot to destroy anyone that comes close, as it dishes out well over 100Kj per hit! It€™s based on Gyrobot from series 7 of Robot Wars, but with a hell of a lot more power, however wheels are exposed from above.
Roboteers, standby!
Booth 1: Martijn Benschop, Samuel Park
Booth 2: Steven McGregor, Will Harrison
3...
2...
1...
ACTIVATE!
All four robots move off their starting positions as the buzzer goes and head towards the middle of the arena, the seeded Sheer Heart Attack 2 making the first move and driving towards Death Sentence, hitting the front disc of the box shaped robot and the two spinners meet and sparks fly, but neither robot is flung across the arena in true spinner style because their grippy tracks hold onto their space sin the arena and so they drive against each other with weapons inactive, Martijn turning Sheer Heart Attack 2 around to get the wedges into play while Samuel does the same to utilise the scoop on Death Sentence, and now Death Sentence gains the advantage, managing to breach the hinged wedges at the back of SHA2 and now Sam pushes Martijn across the arena and into the pit release button!
Meanwhile Roo 2 has spun up and now goes on the attack of Traffic Warden, the huge Kj count shredding the 4mm titanium of the U-shaped robot to ribbons as Steven struggles to get the hydraulic clamps of Traffic Warden into play, but before any major damage is done the spinning ring of Roo 2 is stopped by Traffic Warden€™s attack and the clamps now come into play to not only squeeze Roo 2 tightly, but prevent that spinning ring from beginning to rotate again and now Traffic Warden makes the most of those E-Teks in the drive and forces Roo 2 across the arena, still trapped by the powerful clamps!
While this is going on Sheer Heart Attack 2 has escaped from the X-Terminator style scoop of Death Sentence and has managed to spin up the vertical drum, now turning to put into use and whacking the side of Death Sentence, ripping a side panel clean off and also flipping Death Sentence against the pit release button! But the tracks grip the wall and Sam is able to wriggle out of the tough situation with a little bit of expert manoeuvring, only to be attacked again by Sheer Heart Attack 2, who whacks the rear scoop of Death Sentence this time, tearing that off to leave Death Sentence with a dangerously high ground clearance on all sides!
Meanwhile Traffic Warden still hasn€™t let go of Roo 2 and uses the superior drivetrain to force Roo 2 across the arena and towards the pit that was just opened by Death Sentence pushing Sheer Heart Attack 2 against it! Will struggles at the controls, but Traffic Warden is persistent and the clamps are strong enough to hold Roo 2 in place as Steven turns and dumps the invertible ring spinner in the pit of oblivion, prematurely ending Roo 2€™s run in Mechanical Maelstrom 2.0.
Just a few metres away though Death Sentence has managed to come back a little and has given Martijn a whack with the 21kg horizontal spinning disc mounted on his robot, however the titanium armour of Sheer Heart Attack 2 holds up to the blow and Martijn attacks again, now driving in underneath the ground clearance with those rear wedges and pushing the tracked box towards Traffic Warden, who obliges and puts those clamps to good use again, grabbing Death Sentence and once again using the power in that two wheel drive to pull Death Sentence off the wedges of Sheer Heart Attack 2 and turn around to put it halfway over the pit, with one track trying to save the robot while another dangles over the abyss!
But there is no saving Death Sentence and Sheer Heart Attack 2 moves in, nudging Samuel€™s second bot with a static drum and knocking it into the pit, signalling the end of Death Sentence€™s Mechanical Maelstrom 2.0 in a puff of smoke that sees it disappear from sight.
CEASE!
Roo 2 spins out and Death Sentence is sentenced;
Sheer Heart Attack 2 (1) and Traffic Warden advance to the second round!
Eliminator 6
Dendroaspis vs Tira V vs Black Panther vs Holepunch 2.0
Representing Team Killa Vapourbots, Dendroaspis!
This invertible wedge shaped machine seems to be styled on CUAD the Crusher, the Battlebots Superheavyweight. It has a lifting arm on top and another on the bottom to allow it to lift no matter what side up it is and it has side spikes to allow it to act as a thwackbot, plus the height of the spikes can be altered by moving the lifting arm. The armour is very thick and tough, but the lifters don€™t make for very potent weapons.
Representing Team Zlayerz, Tira V!
The fifth robot in the Tira series of vertical spinners also packs a low pressure flipper mostly for righting the robot plus top guards to stop the disc smacking against the arena floor if it€™s flipped. The spinner is petrol powered and could do some nasty damage as well as flip opponents around as it spins upwards, purposely to do just that.
Representing Team Doomforall, Black Panther!
This oddly shaped semi-UFO robot has dual weaponry, a Terrorhurtz style pneumatic axe and a weak electric flipper, but it isn€™t meant to do any damage, just help Black Panther to employ the hit and run tactics that have made the series so successful over the years.
Representing RCC, Holepunch 2.0!
This wedge shaped robot has a top pneumatic crusher and a roll-cage on top to aid in self-righting, but it could get stacked against the wall still. The crusher comes down though with over 11 tonnes of force, and being pneumatic it€™s also fast. Without a doubt this is one of the most dangerous weapons in the competition. However, with wheelchair motors in the drive it isn€™t the best pusher.
Roboteers, standby!
Booth 1: Richard Southworth, Leo Van Miert
Booth 2: Kody Kunz, Alex Holt
3...
2...
1...
ACTIVATE!
All four robots go flying off the mark as the match gets underway, with Tira V spinning up that vertical flywheel as the dangerous sounding noise of the spinning weapon fills the arena. Alex is at the controls of Black Panther, the flipper/axe combo and together with Kody they aim in at Holepunch 2.0, with Tira V running in on the attack and thwacking Holepunch€™s HDPE armour, ripping out a chunk, but since the plates are each 4cm thick the innards are not exposed and Holepunch ploughs into the front of Tira V while the disc is static, crunching down onto the polycarbonate covering on the disc and down through the hardox armour as well! Black Panther appears to be teaming up with Tira as Alex drives in to help out, but suddenly Dendroaspis appears from nowhere and rams in underneath the rear of Black Panther, ramming it across the arena and activating the bottom lifter arm to flip Black Panther against the spike strip!
Meanwhile Kody is in Leo€™s grasp as the crusher of Holepunch 2.0 holds on in there, now pulling the reverse wedge shaped machine of Tira V across the arena and Leo reverses into the pit release button. This however loosens his grip on Kody€™s machine and it slides off the tip of the crusher before reversing away to spin up the disc, but the flywheel weapon doesn€™t begin to rotate, and as Tira reverses away with no weapon we can accurately guess that the engine that drives the spinning weapon was been crushed by Holepunch 2.0, who now goes on the attack of the once great looking Tira V, who now looks a bit of a mess. Kody turns and manages to slip the rear wedge under the side of Holepunch 2.0, firing the low pressure flipper and rolling Holepunch 2.0 over away from itself.
On the other side of the arena Black Panther has self-righted and is now repeatedly whacking Dendroaspis with the Terrorhurtz-style axe, but the thick hardox armour of Dendroaspis is holding up well and Richard drives in under the front of Black Panther this time, gaining the advantage because of the wedge shape and lifting again, this time not flipping Black Panther, but taking the wheels off the floor and powering across the arena to roll Black Panther across the floor and into the pit! No one expected that attack from Dendroaspis, who now turns to attack one of the other two machines, driving under the side of Holepunch 2.0 and using the bottom lifting arm to again roll it over, but Holepunch is still intent on destroying Tira V, driving underneath the side this time and buckling the hardox armour as the crusher comes down, digging into the robot and all of a sudden Tira V is venting gas- the co2 supply has been pierced by Holepunch 2.0€™s powerful weaponry and now Tira V is entirely weaponless!
And now despite having attacked Holepunch 2.0 earlier on Richard Southworth at the controls of Dendroaspis drives in underneath the front of Tira V just as Holepunch releases the victim and reverses away, and Richard activates the bottom lifting arm again to flip Tira V onto her back, and without the flipper she can€™t self-right!
Tira V is over and out, and with that the battle is over as Black Panther lies in the pit and Tira V remains turtle.
CEASE!
Black Panther is hunted down and Tira V is booted from the next edition of Soul Calibur;
Dendroaspis and Holepunch 2.0 go marching onto the second round!
Eliminator 7
Visioned vs Dantu vs Monolith vs Leprosy Infection (4)
Representing Team Wet €˜n€™ Wild, Visioned!
This invertible box shape with scoop on the front employs LEM-130 lynch motors in the drive to give 8HP continuously and 18HP when at optimum power, and as if that wasn€™t enough it has two Crushtacean style claws at the front of the robot, powered by Litton motors. The six wheel drive will help to push it around the arena and the 9mm titanium armour should protect from most attacks, but like Team Wet €˜n€™ Wild€™s previous season entry Do or Die it can be stacked.
Representing Team Doomforall, Dantu!
This axlebot has a big meaty disc powered by the same motor that powers Visioned€™s drive, but there€™s only one of them here. The disc is vertical to flip and rip and the robot is invertible, plus the hardox armour is very thick and flipping this machine will do almost nothing at all unless you can get it over the fence. It won€™t do too well against rammers though.
Representing Team ???, Monolith!
This the second Storm II-shaped machine entered by Andrew Jackson, but unlike Wedga Triton it doesn€™t have a high power flipper on its side, but what it does have is 10mm hardox monocoque armour and the ability to run inverted with the four wheel drive, powered by 2 magmotors to give more pushing power than Tornado! However, with no active weaponry what can it do to the other robots?
Representing Team Dino Warriors, seeded #4, Leprosy Infection!
This box shaped machine can run inverted, just like all the other robots in this battle. It has a lynch motor to spin the drum upwards and flake away at other robots€™ armour and magmotors in the drive to turn the four wheels, plus it is painted a vile shade of green that could potentially make the other drivers sick!
Roboteers, standby!
Booth 1: No Wai, Alex Holt
Booth 2: Andrew Jackson, Christopher Mason
3...
2...
1...
ACTIVATE!
Monolith has had its skirts removed for this bout seen as there are two spinners. At the beginning of the match Andy€™s bot is also the first to go on the attack, driving at Dantu, who has spun up the disc. The two meet head on, but Monolith completely dodges the flywheel weapon and gets right underneath Dantu, now gunning the magmotors in the drive and pushing it back across the arena and into the spike strip! Dantu drives over the top of Monolith though and turns, catching the rear of Monolith with the disc and flipping it up into the air, but not over. Still though the 10mm hardox absorbs the blow with no problem and Andy pushes under Dantu with his front wedge again, but this time Alex just drives right over the 10cm high Monolith, turning to again catch the rear of Andy€™s machine with the spinning disc, this time flicking it high enough into the air to allow itself to run in underneath and turn to flip Monolith onto its back! Although Andy€™s robot runs inverted the wedge is useless upside down and now the little black robot has a high ground clearance all round!
Meanwhile Visioned has stormed right at Leprosy Infection and grabbed hold of the drum with the vertical claws, and with six wheels to the seeded machine€™s four No Wai has now pushed Chris into the pit release button and without even letting go once turned and taken Leprosy Infection to the chasm, running up to it and dropping it into the abyss in pure Crushtacean-style of grab then pit and in the first ten seconds of this round the seeded machine is down and out along with Team Dino Warriors!
And with Monolith inverted Visioned sees it€™s chance, driving straight at the inverted wedge while Andy is bothered with Dantu, getting the claws straight in and grabbing hold tightly before reversing across the arena with Monolith in tow, turning and ramming Andy€™s undamageable machine into the pit, as the shortest fight of Mechanical Maelstrom 2.0 yet draws to a premature close!
CEASE!
Leprosy Infection (4) is infected and Monolith is beaten (but not broken of course);
Visioned owns the fight to move onto the next round with Dantu tagging along!
Eliminator 8
Hypertension MK3 vs Eternia vs Drilla Killa VII vs Nitro-Gene 5.0
Representing Team Devil€™s Incarnate, Hypertension MK.3!
With thick hardox armour and a powerful flipper this wedge shaped machine is here to win. It most likely won€™t be damaged, and the strategy is to only flip when needed to conserve the comparatively small amount of gas on board. However, the strategy could turn out rotten if this machine is forced to flip too much.
Representing Team RCC, Eternia!
Like it€™s teammate Holepunch 2.0, this robot has thick HDPE armour over the main body, meaning holes can be made and chunks can be torn out but hardly ever will the internals be reached by an opponent. This impressive looking robot has a Gravity-style flipper, but the pushing power is weak compared to other vapours.
Representing Team Killa Vapourbots, Drilla Killa VII!
This robot is perfectly shaped for ramming, with a wedge at the front and an inverted wedge at the back so that runs identically the other side up, albeit with the drive reversed of course. Each wedge has three holes in it, out of which come industrial drills, but the question is how much damage will the drills do?
Representing Team Insanity, Nitro-Gene 5.0!
This box wedge shape robot has a high power nitrogen flipper, as well as two magmotors in the drive to give it plenty of power. The hardox armour will protect against most attacks and the front is flat to bash spinners, and even though it can self-right the robot has the ability to run inverted. This however leaves the tyres open to attack from axes.
Roboteers, standby!
Booth 1: Will Harrison, Leo Van Miert
Booth 2: Richard Southworth, Paul Cuomo
3...
2...
1...
ACTIVATE!
As this final round 1 eliminator of Mechanical Maelstrom Season 2.0 gets going Nitro-Gene 5.0 goes on the attack of Eternia, but Leo turns and due to the shape of his machine gets under the front of Nitro-Gene 5.0, firing the flipper to send Paul€™s robot over onto its back! The flipper of Nitro-Gene is fired and the robot stylishly somersaults in the air to land on its wheels and drive at Eternia again as Leo was turning away, getting the flipper underneath and firing the weaponry again to send Eternia high into the air with the 1600kg of force, and as it comes crashing down to earth Eternia lands close to the pit release button, and when it self-rights it just avoids it, so narrowly the pit is still closed!
While Nitro-Gene was battling Eternia Drilla Killa assaults Hypertension, ramming under the side of the wedge shaped robot and lifting it up with the drills, powering into the spike strip with the PERM motors going at their top capacity! Hypertension is thrown away by the force of the ram, but lands behind Drilla Killa VII and seeing his chance Will drives in underneath the inverted wedge at the back of Richard€™s machine and comfortably pushed right in underneath, as even though the drills from the inverted wedge push against the top armour of Hypertension they fail to do any damage at all and Will gets right in underneath before finally firing the flipper and throwing Richard€™s second entry high into the air, and as it was so close to the fence Drilla Killa VII comes crashing down onto the camera tracks.
On the other side of the arena Nitro-Gene and Eternia€™s front ground clearances have cancelled each other out, and Nitro-Gene gains the advantage as it pushes Leo back across the arena, but Hypertension MK3 interrupts as Will sees the perfect chance to gain the second elimination of this battle as he drives underneath the side skirt of Nitro-Gene 5.0 and pushes Paul across to the arena side wall, firing that wedge flipper for the second time in this bout and for the second time it is a fatal flip!
CEASE!
Drilla Killa VII is killed and Nitro-Gene 5.0 blows up;
Hypertension MK3 and Eternia move onto the second round!
(Message edited by Supersporty on December 30, 2008)
Mechanical Maelstrom 2.0 ~ Round of 16
Back to Rock III vs. The Zodiac
Gabriel IV: Enjoy the Violence (2) vs. Neo-Mecha
Dantu vs. Eternia
Hypertension MK3 vs. Visioned
Dendroaspis vs. Traffic Warden
Hot Sauce vs. Holepunch 2.0
Autoism 3.0 vs. Wedga Triton
Sheer Heart Attack 2 (1) vs. Supreme
Eeeep! :uhoh:
Main aim here is to attack those tracks with either the axe or the spinner (will probably use the spinner actually, it allows more opportunity for continued attacks). Just keep focussing on the tracks, break them, tear them, destroy them whatever, just AIM. FOR. THOSE. TRACKS! :proud:
Oh, and avoid the front like the plague.
Darn. :sad: Oh well, got one bot through. :)
Oh blimey. The best I can do here is spin up and hit anywhere I possibly can to inflict the most damage possible. Self-right when needed.
Ill predict Gabriel, Eternia, Hypertension, Traffic Warden, Hot Sauce, Wedga, and Sheer Heart Attack to win the other matches. :)
Good job Lewis. :)
