Robot SMASH!! III: Lock3d and Load3d
Actusally, swap Reventon for Shredding Madness.
Stats:
Shredding Madness (Previously Turbo Shredder)
Body Shape: Box
Weight: 100 kgs
Top Speed: 15 mph
Dimensions: 96 X 93 X 42
Armour: 3.25mm Hardox All Around
Ground Clearence: 5mm all around
Wheels: 4 X Wheels Inside (Aluminum Hub)
Power: 2 X LEM-130s running on 36 volts
Battery: 4 X BPK-3600-36 BattlePacks
Weapons: A very nasty 25kg, 3000RPM horizontal spinning disc made out of titanium, and 4 X Hardox Teeth. powered by a LEM-130 on 36V, Heavily Shock-Proofed as well
Srimech: Invertible
Strengths: Powerful Weapon, Great Pushing Power
Weaknesses: None Hopefully
1) Joey McConnell
a- Nidhogg Evo
b- Gabriel III
c- Eye of Ran
d- No Consequences
e- Stiltskin
f- Hex Appeal
g- Lights! Camera! Traction!
h- Gemini (RW5)
2) Paul Cuomo
a- Knyfe
b- Heyght II
c- Inferno
d- The Rock
e- Nitro-Gene 5.0
f- MeCannibal 3.0
g- WORCK-ER
h- Storm II
3) Christopher Mason
RESERVED
4) Martijn M Benschop
a- Back to Rock III
b- Flick of the Wrist 2
c- Liar 2
d- Axe to Fall 2
e- Sheer Heart Attack 2
f- Under Pressure
g- With or Without You
h- Razer
5) Richard Southworth
a- ???
b- ???
c- ???
d- ???
e- ???
f- ???
g- X-Terminator (RW7)
h- Nightmare (BB5.0)
6) Samuel Park
a- Deadbeat
b- Paralyzation 2
c- Bubonic Palgue
d- Fatality
e- Walk Dont Run 4
f- Shredding Madness
g- Ramminator 1 1/2
h- Tsunami (RW7)
7) Kody Kunz
a- Wedginator Devilution / Wedgin8or
b- Super Gore Revo
c- Seung Mina V
d- Tira IV
e- Killobite Hex
f- Macduff the 3rd / 4th
g- Intriguer
h- Envy
8) Daniel Stickler
a- Supreme
b- Dervish: The I337 Generation
c- Monsoon Magnum
d- Pure Evil: Back to Basics
e- Squish Reincarnated
f- Macbeth
g- Requiem
h- Terrorhurtz (Most recent)
9) Ben Read
a- Robo-Hedgehog
b- Robo-Mosquito
c- Robo-Platypus
d- Robo-Mammoth
e- Robo-Bee
f- Robo-Panda
g- Robo-Sheep
h- Axe Awe (RW5)
10) Alex Holt
a- Black Panther
b- Achilles
c- Tengu VII
d- Dante
e- Darkestar
f- Slammer VI
g- Baldur Gamma
h- Supernova
11) Steven McGregor
a- Wedge Devolution
b- Killotine: EVO
c- Spin Dash Unleashed
d- E Clawdius Unum
e- Turbo Tails
f- Whirligig 4.5
g- Traffic Warden
h- 13 Black (Extreme 2)
12) Danny Bailey
a- Crimson Thunder
b- Cat with Wheels
c- Sithis
d- Leviathan
e- Lethal Execution
f- Blue Sparks
g- Death Threat 0.2
h- Chaos 2 (Extreme 2)
13) Frank Goacher
a- Cobalt
b- Dead Horse Beater
c- The 6isc
d- ISDSFA
e- Sakura
f- Masamune
g- The May Tracks Has You
h- Firestorm (RW7)
14) Leo Van Miert
a- Mantis
b- Sideswipe
c- Eternia
d- Holepunch 2.0
e- Splinter
f- Obsidian
g- Symmetry
h- GBOD
15) Andrew Jackson
a- PsycloniZer
b- Axeon 3.0
c- SOR X
d- Ge5orce
e- Monolith
f- Rupture
g- Exertion
h- Tornado (RW7)
Just realised I counted Martijn twice by mistake, (sorry!) so there is a place still left in, and thankyou to those who are lending HRs :)
The open spots will become realie teams if they are still open when I get stats from Richard and Chris
Here are my six vapours:
Agro 3.5
Battle Raptor V
Dendroaspis
Drilla Killa VII
MORD2
SYNDOS
AGRO 3.5
Weight: 100kg
Shape: Low invertable wedge with a low square hinged plate at the front
Dimensions: 85 x 65 x 40 (cm; l x w x h)
Speed: 17mph
Ground Clearance: 0 at front due to hinged plate, 1cm at sides and rear
TC: 0
Armour: 4mm Hardox
Wheels: 2, inside robot, and RC gyro for added control
Power: 2 Perm 080s motors on 24V powered by 24V @ 12amp batteries
Weapon: The hinged plate at the front allows 0 ground clearance - it can surpass skirts with a good push. At the rear is a 10kg 3000RPM X Terminator-like vertical spinning disc at the rear, made of titanium and powered by a D-Pack.
Srimech: Invertable.
Tactics: Try to get under opponents and shove, or use the rear disc on them.
Strengths: Fast, manouverable, dangerous weaponry
Weaknesses: A little tricky to control, high ground clearance
BATTLE RAPTOR 5
Weight: 100kg
Shape: Invertable box with Tornado-like central bars on sides and rear (to prevent it resting there), painted orange with black stripes like the raptors in Jurassic Park
Dimensions: 80 x 50 x 30
Speed: 17mph
Ground Clearance: 0 at front due to low plate, 3mm at sides and rear
TC: 0
Armour: 4mm Hardox, with holes drilled in it to reduce weight
Wheels: 4, inside robot, poke out the top so the robot can run inverted, uses skid steering
Power: 4 Perm 080s motors on 24V powered by 24V @ 12amp batteries
Weapons: On the front are two electrically powered Vlad the Impaler-style lifting forks - attached to their tips is a plate which runs flat along the floor for 5cm, to get under skirts. On top is a titanium pneumatic axe with a Terrorhurtz-style blade, which pivots at a point about 1/4 of the robots length from the front.
Srimech: Axe can act as srimech. Axe blade fits inside the robot and doesnt poke out the top, so can run inverted if axe fails in resting position.
Tactics: Try to lift opponents while hammering them.
Strengths: Dual weaponry, invertable, fast and manouverable due to skid steering and lack of skirts
Weaknesses: Limited CO2 for axe, no weaponry at sides and rear, easily flipped
DENDROASPIS
Weight: 97kg
Shape: High wedge with two large enclosed wheels, painted black
Dimensions: 80 x 50 x 45
Speed: 20mph
Ground Clearance: 0 at front due to hinged plate, 0 at rear due to skirt, 1cm at side and behind skirt
TC: 0
Armour: 6mm Hardox - rear skirt is 3mm titanium
Wheels: 2 stuffed tyres inside robot, and RC gyro for added control
Weapon: Two electrically powered arms with stabilising wheels, one on the top wedge and one on the bottom, similar to Cuad the Crusher - the arm at the bottom lifts the whole wedge to overturn a robot thats on it. There is also a static spike on the left and right sides, which can be used when the robot raises itself and spins on the spot.
Srimech: Invertable
Tactics: Get under opponents with the hinged plate at the front, and lift to overturn them. Can also try to cause damage with the spikes by spinning, or push with the rear skirt.
Strengths: Fast, manouverable, versatile
Weaknesses: Lack of damaging weaponry, easily flipped from sides
DRILLA KILLA 7
Weight: 99kg
Shape: Low invertable box, painted red, with a Tornado-like low wedge at the front, and an upside down one at the back for when the robot is upside down, and skirts at the sides fixed at the centre so they work whichever way up the robot is
Dimensions: 110 x 40 x 25
Speed: 17mph
Ground Clearance: 0 at front due to wedge; 0 at sides due to skirts, 3mm behind skirts, 25cm at most at back due to inverted wedge
Turning Circle: 2cm
Armour: 5mm Hardox
Wheels: 6, inside robot
Weapon: Each wedge has a hole in the centre - inside each hole is a diamond tipped drill, spinning at 600 rpm, which comes out of the hole using a motor. It can come out to cause damage when an opponent is on the wedge, or can stay out and cause damage when the robot rams opponents.
Srimech: Invertable; cannot rest on sides due to skirts
Tactics: To get under unskirted opponents, slam them around and bring out the drills to damage their underbellies; to ram skirted opponents with the drills out and try to cause damage
Strengths: Good pushing power
Weaknesses: Drills may not penetrate very thick armour; high ground clearance at back
M.O.R.D2
Weight: 110kg
Shape: Box, with sides that slant outwards from the top and bottom edges to form triangles, like Tornados rear (hopefully this will lower the effectiveness of spinners)
Dimensions: 90 x 32 x 35
Speed: 20mph
Ground Clearance: 0 at front due to plow, 0 at sides and rear due to skirts, which are fixed to the points of the triangles and can work either way up, 4mm behind skirts
TC: 5cm
Armour: Body is 4mm Hardox; scoop is 4mm titanium; skirts are 3mm titanium
Movement: Camshafts like Drillzilla
Weapons: At the front is an electrically powered scoop which operates through 180 degrees, so it can work when the robot is inverted. Behind the scoop is a 20kg spinning drum with 8 titanium teeth on it, spinning at 2000rpm and hopefully able to flip robots as well as damage them. The drum comes into play if the scoop is lifted.
Srimech: Invertable; triangles at sides and rear prevent it resting there
Tactics: Shove opponents with the scoop; then lift the scoop and attack with the drum
Strengths: Fast; good traction; powerful drum
Weaknesses: Less manouverable than wheeled robots
SYNDOS (SLICE N DICE ON STEROIDS)
Weight: 96kg
Shape: Invertable box with rounded sides and rear
Dimensions: 60 x 60 x 45
Speed: 12mph
Ground Clearance: 4mm at front, 0 at sides and back due to skirts, 4mm behind skirts
TC: 0
Armour: 4mm Hardox
Wheels: 2, inside robot, with RC gyro for extra control
Weapon: 25kg 3000rpm titanium vertical spinning disc at front
Srimech: Invertable
Tactics: Mash with big-a** disc, and try to flip as well.
Strengths: Powerful weapon; low ground clearance
Weaknesses: No weapons on sides and rear; a bit on the slow side
Right! All spots filled, just need entries from Chris and Matty :)
My realie will be Hexadecimator, most UTD version.
ORKA MK4
Weight: 100 kilos
Body Shape: Behemoth
Speed: Some 15mph
TC: 0
GC: 8mm, 0mm at front.
Wheels; 6 inner
Armour; 7mm titanium
Power; 3x 12v batteries, powered by S28-400 Magmotors, at 24v.
Weapons; A Behemoth like bucket scoop, made from titanium 5mm thick, and quite capable of lifting 300 kilos. It has a claw like device, also pneumatic, to grab an oppodent, like the claw on Mantis. The scoop is pnumatically powered by CO2, and has about 45 odd flips.
Srimech: It has a pneumatic dorsal fin piston that self-rights the robot, ala Vlad The Impaler.
Inspiration; Ive always liked Orcas. Adding the K made it sound more dangerous.
Strengths; Weapon
Weaknessess: Hard to turn
DIE-CERATOPS RE-INVERTUS
Weight; 100 kilos
Body Shape: Wheely Big Cheese
Speed; 15mph
TC; 0
GC; 0mm at front, 10mm at sides and back.
Wheels; 4 inner, the back two sticking out only slightly,
Armour; 8mm titanium
Colour; Green, with Killer Carrot style wrinkles, mouth and eyes. One of the eyes has a plaster over it, the other is a black eye. A few bandages are painted on this time.
Weapons: A huge Wheely Big Cheese style pneumatic CO2 flipper, capable of flipping a tonne or so.
Srimech; As the name suggests, the robot runs inverted. Bars prevent side strandings, and the back is rounded, so stranding THAT way is outta the question. The flipper works upside down.
Inspiration; Ive always liked Dinosaurs. This is a pun of Triceratops. The Invertus part is pretty obvious.
Strengths; The ability to work upside down and still be able to use its weapon, now easier to control.
Weaknessess: Facing more agile vapourbots
CYCLONE FORCE 3
Weight; 100 kilos
Body Shape; Storm 2 without the wedge (at first, see set-ups for more detail)
Speed; 20mph
TC; 0
GC; Side is 0mm due to skirts. Otherwise, 10mm. See set-ups for front GC
Wheels; 6 inner
Armour; 11mm Titanium.
Power; LEM130s at 36 volts, ala Storm 2. 3x12v batteries.
Colour; A blue-ish grey tone all over.
Weapons; The robot has 3 set-ups...
SET UP 1...An electric lifter device, similar to Storm 2. In theory, it can lift 190 kilos. The front makes a wedge and results in a 0mm GC. However, the wedge is useless upside down.
SET-UP 2...Two large 30 centimetre long spikes, powered by their own pneumatic system and running off CO2. The front with this GC is 10mm.
SET-UP 3...A simple bucket scoop, like X-Terminator. The scoop is static, but can get underneath virtually zero ground clearance. Its front is 0mm.
Srimech; The robot runs inverted, the sides are protected by the skirts and back stranding is impossible.
Inspiration; The original Cyclone was named because it is the name of a storm and it sounds threatening. The force came later, after it became a pusher.
Strengths;Raw power
Weaknessess;Limited control.
LEPROSY INFECTION
Weight; 100 kilos
Body Shape; Tetanus Booster
Speed; 18mph
TC; 0
GC; 6mm
Wheels; 4 inner, top sticking out. Hinged mini-skirts hang from the side, and these protect the wheels from low lying discs.
Power; 3x 12v batteries, powered by S28-400 Magmotors. LEM130 motor for the drum.
Weapons; A very large, very dangerous vertical drum, capable of reaching speeds of 4000rpm. The teeth on the drum are curved upwards so they can flip as well as damage and very sharp at the tip. There is a reason for this explained below. By the drum are two hindged wedge type devices, which drive oppodents onto the drum.
Weaknessess; Wheels may be vulnerable to axes
MEGA MASHER 2
Weight: 100 kilos
Body Shape: A Triangle shape, a bit like Inshredable (from Series 6). 0.85m in length and width, and 0.35m at its highest point. The sides are heavily angled, a bit like UFO in S7, only more so.
Speed: 15mph
TC: 0
GC; 0 at front, 6mm elsewhere.
Wheels; 6 inner, aranged in a 3-wheel-a-side formation. This means that four wheels are always on the ground at any one time.
Armour: A nice 3.25mm Hardox, all over.
Power: 3x 12v batteries, plus Bosch 750s at 36v.
Colour: Red and yellow.
Weapons; The front is a wedge, and the back has a nasty vertical titanium 35cm in diameter disc, powered by its own LEM130 motor and spinning at 2000 rpm. It can probably flip as well as damage.
Srimech: The robot can run inverted, with the sheer angling at the sides making stranding near impossible.
Strengths: Power, weaponary
Weaknessess: New and untested design.
AXE-O-LOTL
Weight: 100 kilos
Body Shape: Comengetorix
Speed: 20mph
TC: 0
GC: 6mm
Wheels: 4 inner
Armour: 3.25mm Hardox all around.
Power: Same stuff as Storm 2 and Cyclone Force uses.
Colour: Has interchangable panels. One set is pure black, the other pure white with pink tinges.
Weapons: A very nasty pneumatic axe, with the power of Dominator 2. The head is diamond tipped, and the whole weapon is VERY persistant. It can fire about 40 times in one fight.
Srimech: The axe rights the robot. The robots body is designed so it cant be side stranded.
Inspiration: My favourite amphibian, the axolotl.
Strengths: Powerful weaponary
Weaknessess: Obviously a limited CO2 supply.
And for the sake of having fun, which any Robot Combat tournament should be about...
SPRING-BOK!
Weight: 100 kilos
Body Shape: Firestorm.
Speed: 12mph
TC: 0.
GC: 0 at front, 7mm at sides.
Wheels: 2 inner.
Armour: 8mm titanium, covered in 2mm orange fur.
Power: 3x 12v batteries, powered by a couple of Magmotors (S28-400s).
Colour: Orange, thanks to the fur.
Weapons: A launch pad. Heres how it works...basically, the robots drive up the wedge, then the front panel, which is attached to four large car springs, fires outwards via hydraulics. A miniture piston device is attached to the panel to prevent it getting fired off, and also re-sets it. Should that fail, it does have a back-up plan (see notes).
Srimech: Two arms that extend around the side of the body, a bit like that of Philliper, only bottom hinged rather than top hinged, act as the Srimech.
Inspiration: Its named after an antelope.
Notes: This is the re-make of the former comedy yet highly sucessful robot Fluffitor, who won a previous Children In Need special. Has an in-built police siren which it activates if the going gets tough. The idea is that the oppodent will think hes about to be arrested then run off.
Strengths: Experience, unique weapon.
Weaknesses: Untested, Flammable, back-up plan probably wont work.
Would it possible Matty if I could just have a list of names for draw purposes? :)
Boxed In
Heimlich
Ha-Ka
PTT5
Roo
Hypo
BIACS-LE
259
all stats can be found at http://vapourbots.crystalnode.net/forum/viewforum.php?f=8&sid=5ef792b51c508979d3ac619967e9 c985http://vapourbots.crystalnode.net/fo...92b51c508979d3 ac619967e9c985
Thank you all, draw will be up soon!
Personally, I cant wait for the draw - itll be a tourney to look forward to! You really have improved vastly since you first arrived. You were doing internet slang and writing very short fights, and not being organised. But now youre writing your 3rd major of the year - keep up the good work :proud: and good luck to AJ with PsycloniZer in defending the crown :wink:
Damnit. Is it too late to make a change?
If not, replace Super Gore Revo with Kracko please. :)
And yeah, Macduff the 4ths stats are up on ZED. If you wish to wait for Wedgin8or, set its heat down on the list. If not, just use the Devil Wedge. :P
(Message edited by kodster on September 27, 2008)
Final Entries
1) Joey McConnell
a- Nidhogg Evo
b- Gabriel III
c- Eye of Ran
d- No Consequences
e- Stiltskin
f- Hex Appeal
h- Gemini (RW5)
2) Paul Cuomo
a- Knyfe
b- Heyght II
c- Inferno
d- The Rock
e- Nitro-Gene 5.0
f- MeCannibal 3.0
g- WORCK-ER
h- Storm II
a- Orka MK.4
b- Cyclone Force 3
c- Die-ceratops Re-invertus
d- Spring-BOK!
e- Mega Masher 2
f- Leprosy Infection
g- Axe-o-Lotl
h- Hexa-Decimator
a- Back to Rock III
c- Liar 2
d- Axe to Fall 2
f- Under Pressure
h- Razer
a- MORD2
b- Dendroaspis
c- Drilla Killa VII
d- Agro 3.5
e- SYNDOS
f- Battle Raptor 5
6) Samuel Park
a- Deadbeat
b- Paralyzation 2
c- Bubonic Palgue
d- Fatality
e- Walk Dont Run 4
g- Ramminator 1 1/2
h- Tsunami (RW7)
7) Kody Kunz
b- Kracko
c- Seung Mina V
d- Tira IV
e- Killobite Hex
g- Intriguer
h- Envy
8) Daniel Stickler
a- Supreme
c- Monsoon Magnum
f- Macbeth
g- Requiem
9) Ben Read
a- Robo-Hedgehog
b- Robo-Mosquito
c- Robo-Platypus
d- Robo-Mammoth
e- Robo-Bee
f- Robo-Panda
g- Robo-Sheep
h- Axe Awe (RW5)
10) Alex Holt
a- Black Panther
b- Achilles
c- Tengu VII
d- Dante
e- Darkestar
f- Slammer VI
g- Baldur Gamma
h- Supernova
11) Steven McGregor
a- Wedge Devolution
b- Killotine: EVO
d- E Clawdius Unum
e- Turbo Tails
f- Whirligig 4.5
g- Traffic Warden
12) Danny Bailey
a- Crimson Thunder
b- Cat with Wheels
c- Sithis
d- Leviathan
e- Lethal Execution
f- Blue Sparks
g- Death Threat 0.2
13) Frank Goacher
a- Cobalt
c- The 6isc
d- ISDSFA
e- Sakura
f- Masamune
h- Firestorm (RW7)
14) Leo Van Miert
a- Mantis
b- Sideswipe
c- Eternia
d- Holepunch 2.0
e- Splinter
f- Obsidian
g- Symmetry
h- GBOD
15) Andrew Jackson
a- PsycloniZer
b- Axeon 3.0
c- SOR X
d- Ge5orce
e- Monolith
f- Rupture
g- Exertion
h- Tornado (RW7)
16) Will Harrison
a- Boxed In
b- Heimlich
c- Ha-Ka
d- PTT5
e- Roo
f- Hypo
g- BIACS-LE
h- 259
Seeds
01. PsycloniZer (NEWCOMER)
02. Wedge Devolution (1)
03. Nidhogg Evo (NIDHOGG) (2)
04. Back to Rock III (UNSEEDED)
05. Black Panther (NEWCOMER)
06. Supreme (SUPREME GLORY OMEGA) (3)
07. Killobite Hex (KILLOBITE 5.0) (10)
08. Mantis (NEWCOMER)
09. Flick of the Wrist 2 (FLICK OF THE WRIST) (12)
10. Orka MK.4 (NEWCOMER)
11. Achilles (NEWCOMER)
12. Cyclone Force 3 (NEWCOMER)
13. Cat with Wheels (NEWCOMER)
14. Spin Dash Unleashed (METAL SONIC SPIN DASH) (UNSEEDED)
15. Dervish: The L337 Generation (Dervish V)( UNSEEDED)
16. Axeon 3.0 (NEWCOMER)
17. ISDSFA (N/A)
18. Gabriel III (GABRIEL II) (14)
19. Sheer Heart Attack 2 (UNSEEDED)
20. Envy (NEWCOMER)
21. SOR X (NEWCOMER)
22. Razer (8)
23. Knyfe (RUNNER-UP OF RS!! MINI-TOURNAMENT 1) (NEWCOMER)
24. E Clawdius Unum (UNSEEDED)
25. Tengu VII (NEWCOMER)
26. Dante (NEWCOMER)
27. Macduff the 4th (NEWCOMER)
28. Monsoon Magnus (MEGA MONSOON) (UNSEEDED)
29. Sideswipe (BRONZE MEDALLIST OF RS!! MINI-TOURNAMENT 1)
30. Die-ceratops Re-invertus (WINNER OF FLIPPER FRENZY) (NEWCOMER)
31. Intriguer (WINNER OF AXE ATTACK)
32. Shredding Madness
Line-ups
Heat A:
PsycloniZer (1) vs. Eye of Ran vs. Storm II vs. With or Without You
ISDSFA (17) vs. Ramminator 1 ½ vs. Robo-Sheep vs. Agro 3.5
Heat B:
Nidhogg Evo (3) vs. 259 vs. Exertion vs. Masamune
Sheer Heart Attack 2 (19) vs. GBOD vs. Lethal Execution vs. Supernova
Heat C:
Black Panther (5) vs. Lights! Camera! Traction! vs. Heyght II vs. Hexa-Decimator
SOR X (21) vs. Under Pressure vs. Battle Raptor 5 vs. Fatality
Heat D:
Killobite Hex (7) vs. Nightmare vs. Tsunami vs. Monolith
Knyfe (23) vs. Killotine: EVO vs. Leviathan vs. Gemini
Heat E:
Flick of the Wrist 2 (9) vs. Hex Appeal vs. WORCK-ER vs. Symmetry
Tengu VII (25) vs. Boxed In vs. Sakura vs. Sithis
Heat F:
Achilles (11) vs. Walk Don€™t Run 4 vs. Dead Horse Beater vs. Obsidian
Macduff the 4th (27) vs. MORD2 vs. Robo-Panda vs. 13 Black
Heat G:
Cat with Wheels (13) vs. Super Gore Revo vs. BIACS-le vs.
Sideswipe (29) vs. The May Tracks Has You vs. Robo-Bee vs. MeCannibal 3.0
Heat H:
Dervish: The L337 Generation (15) vs. Nitro-Gene 5.0 vs. Axe-o-Lotl vs. Dendroaspis
Intriguer (31) vs. Bubonic Plague vs. Robo-Mammoth vs. Baldur Gamma
Heat I:
Axeon 3.0 (16) vs. Requiem vs. Whirligig 4.5 vs. Slammer VI
Shredding Madness (32) vs. Robo-Platypus vs. Wedginator Devilution vs. Blue Sparks
Heat J:
Spin Dash Unleashed (14) vs. Axe Awe vs. Splinter vs. Firestorm V
Die-ceratops Re-invertus (30) vs. PTT5 vs. Pure Evil: Back to Basics vs. The Rock
Heat K:
Cyclone Force 3 (12) vs. Drilla Killa VII vs. Stiltskin vs. Inferno
Monsoon Magnus (28) vs. Axe to Fall 2 vs. Paralyzation 2 vs. Seung Mina V
Heat L:
Orka MK.4 (10) vs. No Consequences vs. Liar 2 vs. SYNDOS
Dante (26) vs. Macbeth vs. Traffic Warden vs. Chaos 2
Heat M:
Mantis (8) vs. Spring-BOK! vs. Terrorhurtz vs. Robo-Mosquito
E Clawdius Unum (24) vs. Hypo vs. Tornado vs. Darkestar
Heat N:
Supreme (6) vs. Holepunch 2.0 vs. Robo-Hedgehog vs. Roo
Razer (22) vs. Rupture vs. Eternia vs. The 6isc
Heat O:
Back to Rock III (4) vs. X-Terminator vs. Deadbeat vs. Squish Reincarnated
Envy (20) vs. Turbo Tails vs. Crimson Thunder vs. Ha-Ka
Heat P:
Wedge Devolution (2) vs. Cobalt vs. Heimlich vs. Tira IV
Gabriel III (18) vs. G5orce vs. Death Threat 0.2 vs. Leprosy Infection
Just realised Hypo is Hypertension MK.3 :proud:
w00t for the slightly delayed draw :P
Here are the, now new and improved with bolding and CAPITAL LETTERS,
TEAM CHEVRON OFFICIAL DOCUMENTS OF TACTICS AND PLANS TYPE THINGS, PART NUMERO UN
HEAT A
PsycloniZer vs. Eye of Ran vs. Storm II vs. With Or Without You
I think Id like to suggest a team up with the reigning champ here, if that isnt possible just avoid him like the plague. :proud: Go for WOWY first, with the blade spinning at usual power I should be able to take out one or both of the fairly easily, and then assist Psy in disposing of Storm. In theory. :P
HEAT B
Nidhogg Evo vs. 259 vs. Exertion vs. Masamune
Im kind of relying on Masamune to turn 259 over early on here, does that count as a team up? :P If that happens, and even if it doesnt, I shall go for Exertion and...well...you know Nidhogg by now, you should be able to predict what Im going to say here...lift, crush, pit.
HEAT C
Black Panther vs. Lights! Camera! Traction! vs. two other robots I cant be bothered to scroll up to check the identity of and whose identities are irrelevant anyway considering the nature of LCT
Basically drive around and push things. Or hit them. Avoid anything in the arena thats not other robots but could damage me, including arena hazards (even though the armour should be good enough to protect against most of them) and the arena walls, and hope, really :P
HEAT D
Knyfe vs. Killotine: EVO vs. Leviathan vs. Gemini
Split, flip things. :proud:
HEAT E
Flick of the Wrist 2 vs. Hex Appeal vs. WORCK-ER vs. Symmetry
Ah, the debut of the Hex Appeal, which was such a bugger to actually make work. :P
Tactics here are to ask Marti if he wants to team up, as he can probably keep people distracted while we get in position, and then deliver WORCKER and Symmetry to us for their doom. :proud:
HEAT G
Wot, no fourth robot in the first melee? :P
For heats I-P, I shall wait for them to come up before any detailed tactics are made, but I am open to offers of teaming up on things.
...i cant find the missing robot, so whoever it belongs to just say and Ill add it in
Also it should be Kracko on that fight and not SGR :lame:
I cant see Mega Masher 2 anywhere.
Robo-Sheep: want to team up samuel, Ill take IDSFA, you take Agro: get around the sides and crush, lift, spin, pit
Robo-Panda: Team-up Kody?, Ill take 13 black, you take out MORD2: Use the scoop, push into CPZs, hazards and the pit
Robo-Bee: Let Frank and Leo battle while I Destroy MeCannibal 3.0: try to ruin the weapon, then just, DESTROY!
Robo-Mammoth: team up with Baldur: go after bubonic plague, push into wall at high speed to knock something loose and pierce the armour
Robo-Platypus: team up with wedginator: go after blue sparks, OOTA!
Axe Awe: turn firestorm into a pincushion
Robo-Mosquito: Grind the sides of Spring-BOK!
Robo-Hedgehog: use the forks, SMASH! Roo
PsycloniZer vs. Eye of Ran vs. Storm II vs. With or Without You
Indeed I shall team up with Eye of Ran. If Typhoon 2 could cause damage to Storm II, Im pretty sure PsycloniZer can do the same. Spin up to full speed and try and knock those pannels off. There are quite a few edges to attack. Without You apparently only has 180o of protection against opponents under 200mm in height. Well it just so happens PsycloniZer is 175mm in height :lame: So if I can get to those unprotected areas, the 4mm Aluminium is at my mercy. And once one part is out, both parts are out.
Looks like another great tournament. Good luck to all.
Too chicken to take on the opponents yourself there Ben? :wink:
I cant find stats for Robo Sheep, are they in the how can I improve thread? ...Do I really have to trawl through that before I can make proper tactics? :sad:
Shape: Cylinder with hinged skirts
Colour: Black, but covered with white fur
Speed: 22MPH
Weight: 100KG
Armour: 7MM Titanium
Drive: 2 LEM200s @ 48V
Power: 10 NiCad Battlepacks @ 48V
Locomotion: 4 Vulkalon coated wheels
Ground Clearance: 0MM thanks to skirts
Turning circle: 0
Dimensions: 80X80X40 (Including skirts)
Weaponry: A pneumatic crushing jaw with two points which can exert a force of 10 tonnes, the claw is mounted on a turret capable of turning 360 degrees
Srimech: A linear actuated bar on the back of the claw
Strengths: Powerful weapons, 360 degree attack, Fast, Nice pyrotechnics show
Weaknesses: Slow to self-right, flammable
They are on the pt.2 thread, August 2nd.
I agree that this should be great - heres my tictacs and predictions:
Heat A:
PsycloniZer (1) vs. Eye of Ran vs. Storm II vs. With or Without You: Im screwed here :angry: My only chance of survival here against three almighty spinners is to ram into one part of With Or Without You and slam him into PsycloniZer, killing him dead, and then stop Eye Of Rans spinner before pitting him - but Im doomed.
ISDSFA (17) vs. Ramminator 1 ½ vs. Robo-Sheep vs. Agro 3.5: The Robot SMASH!! 3rd place to deffo go through...with Richard and Agro 3.5
Heat Winner: Between the two seeds here...too close between them, but I think that maybe PSYCLONIZER has the edge.
Heat B:
Nidhogg Evo (3) vs. 259 vs. Exertion vs. Masamune: Nidhogg and Exertion have more experience than these two, which bring me to believe that theyll go through.
Sheer Heart Attack 2 (19) vs. GBOD vs. Lethal Execution vs. Supernova: Sheer Heart Attack, GBOD and Lethal Execution stand good chances here, but Ill go for the suprise prediction of the seed going out.
Heat Winner: I think that maybe GBOD stands good chances.
Heat C:
Black Panther (5) vs. Lights! Camera! Traction! vs. Heyght II vs. Hexa-Decimator: Unlike my first battle, I feel EXTREMELY confident here. HexaDecimator lacks an effective self-righter as its flipper doesnt have the right amount of leverage to self-right. Simple here - flick HexaDecimator over, or OOTA, it wont be too tricky to get under him with my 18hp drive or to OOTA him with my 1400kg-1700kg flipping force. Out of the other two, I would rather take out Black Panther NOW than to fight him later, so when his back is turn charge in, get under, push to the edge and score another OOTA, so me and Joey can go through.
SOR X (21) vs. Under Pressure vs. Battle Raptor 5 vs. Fatality: SOR X wont like going head-to-head with Under Pressure, so I believe the seed will go out here. Out of the others, Under Pressure to go out as well.
Heat Winner: I LOVE my chances here, but my main competition is FATALITY.
Heat D:
Killobite Hex (7) vs. Nightmare vs. Tsunami vs. Monolith: Monolith will be useless if flipped, but I believe that the two vapourbots will go through.
Knyfe (23) vs. Killotine: EVO vs. Leviathan vs. Gemini: YES! This is a GREAT draw for Knyfe - a clusterbot that will be made mincemeat of, Killotine: EVO who I believe I can pummel, and a Behemoth-esque opponent. I wish to team-up with Leviathan, so me and Danny can take out Killotine together. My weapon choice will be...
5: A 15mm Hardox wedge angled at 42* with an extension, perfect for deflecting vertical spinners and getting under other robots.
This weapon set-up will make my front end as heavy as possible, and allow me to get underneath Killotine each time, and just pummel him. Open the pit, and pit Killotine, or let Leviathan OOTA him. Gemini will be easy to beat, so thats fine.
Heat Winner: Again, I like my chances, but LEVIATHAN is my main rival in this heat - GO DANNY!
Heat E:
Flick of the Wrist 2 (9) vs. Hex Appeal vs. WORCK-ER vs. Symmetry: Balls! :lame: This is annoying - Hex Appeal I dont understand but it doesnt pose much of a threat to me, but the others do! Try and dispose of Symmetry as quickly as possible by OOTAing him, then get rid of Hex Appeal. If Flikc joins in, get under his high GC and stack him against the walls.
Tengu VII (25) vs. Boxed In vs. Sakura vs. Sithis: Tengu VII through for sure - gont know about the rest.
Heat Winner: Id say that in the Heat Final Flicks armour would let it down, so I say TENGU VII
Heat F:
Achilles (11) vs. Walk Don€™t Run 4 vs. Dead Horse Beater vs. Obsidian: Achilles through certainly, possibly with Dead Horse Beater.
Macduff the 4th (27) vs. MORD2 vs. Robo-Panda vs. 13 Black: Bye 13 Black. Bye Robo-Panda. MORD and MacDuff through.
Heat Winner: I pick ACHILLES.
Heat G:
Cat with Wheels (13) vs. Kracko vs. BIACS-LE vs. Mega Masher 2: Cat With Wheels has it tough, but if he takes out Mega Masher, it should be easy for him to just take out Kracko.
Sideswipe (29) vs. The May Tracks Has You vs. Robo-Bee vs. MeCannibal 3.0: You want to destroy me Ben? My weapon is a 10mm Hardox ring running the whole perimeter of my robot, made of 1 piece of Hardox, so hit my weapon as much as you wish - Ill destory you before you destroy me. His drum is a 25kg drum, but how fast is it - it doesnt say in the stats. My plan is to destroy the robot trying to destory me. Hit the drums supports, and break them so the drum will break off. Then pummel that 6mm Ti armour with my 2 large Hardox teeth desgined for shock damage so they can use all 155kj that spinner produces.Once Robo-Bee has been destoryed, go after one of the others if they havent finished each other off. Go after the seed and knock him off balance. If that doesnt work, just kill him :wink:
Heat Winner: I have to go with BIACS-LE here.
Heat H:
Dervish: The L337 Generation (15) vs. Nitro-Gene 5.0 vs. Axe-o-Lotl vs. Dendroaspis: Dont like the sound of Dendroapsis, so take him out first. Then move on to Axe-O-Lotl - Id rather take on Dervish later.
Intriguer (31) vs. Bubonic Plague vs. Robo-Mammoth vs. Baldur Gamma: Intriguer through certainly, and hell be joined by whoever survives :proud:
Heat Winner: One word here - INTRIGUER!!!
Heat I:
Axeon 3.0 (16) vs. Requiem vs. Whirligig 4.5 vs. Slammer VI: Axeon 3.0 and Whirligig to kick butt :proud:
Shredding Madness (32) vs. Robo-Platypus vs. Wedginator Devilution vs. Blue Sparks: The seed to die here, along with whoever Wedginator wants to kill.
Heat J:
Spin Dash Unleashed (14) vs. Axe Awe vs. Splinter vs. Firestorm V: The vapourbot certainately through, possibly with Firestorm V.
Die-Ceratops ReInvertus (30) vs. PTT5 vs. Pure Evil: Back to Basics vs. The Rock: I wish to team-up with Chris here, and take out PTT5 and Pure Evil. Ill go for PTT5 first, as I can go underneath the bar. Push into the sides, push against the wall, and then pummel the bar, mostly that the part where it spins so it breaks off. If this fails, pit him. If Die-Ceratops struggles to finish Pure Evil, join in taking out Daniel.
Heat Winner: I think that DIE-CERATOPS REINVERTUS will win here.
Heat K:
Cyclone Force 3 (12) vs. Drilla Killa VII vs. Stiltskin vs. Inferno: I like Stiltskin, and wish to team-up on the others with Joey. Go for Cyclone Force and try to rip some panels off by breaking bolts, then go for Drilla Killa if hes still alive.
Monsoon Magnus (28) vs. Axe to Fall 2 vs. Paralyzation 2 vs. Seung Mina V: Ohhhhhhh...not sure Axe To Fall will survive. Out of the three remaining, I go for the seed to advance, and for Seung Mina to return to greatness :proud:
Heat Winner: I like the look STILSKIN, so Joey FTW.
Heat L:
Orka MK.4 (10) vs. No Consequences vs. Liar 2 vs. SYNDOS: Orka may wish revenge upon Liar 2 for C&B2, so those two may fight a bit. Its betwen those two on who joins SYNDOS in the nest round.
Dante (26) vs. Macbeth vs. Traffic Warden vs. Chaos 2: Traffic Warden is unique, but not as effective as the others, so I go for Dante and Macbeth to go through.
Heat Winner: Go ORKA MK.4!!!
Heat M:
Mantis (8) vs. Spring-BOK! vs. Terrorhurtz vs. Robo-Mosquito: Robo-Mosquito is out already - Both the realies through.
E Clawdius Unum (24) vs. Hypotension Mk.3 vs. Tornado vs. Darkestar: Torando is going to get OOTAed almost at the start. E Clawdius or Darkestar will follow - Hypertension is through already.
Heat Winner: Awesome flippers FTW - HYPERTENSION MK.3 through!
Heat N:
Supreme (6) vs. Holepunch 2.0 vs. Robo-Hedgehog vs. Roo 2: Supreme irritatingly will go through straight away, with Roo 2.
Razer (22) vs. Rupture vs. Eternia vs. The 6isc: Rupture and Eternia through, sending the others down the pit or OOTA.
Heat Winner: I say that ETERNIA will outclass everyone to win!
Heat O:
Back to Rock III (4) vs. X-Terminator vs. Deadbeat vs. Squish Reincarnated: Back To Rock III is certainately through, but I dont know who with.
Envy (20) vs. Turbo Tails vs. Crimson Thunder vs. Ha-Ka: Turbo Tails is out already, possibly with Ha-Ka.
Heat Winner: I go for the one, the only - CRIMSON THUNDER.
Heat P:
Wedge Devolution (2) vs. Cobalt vs. Heimlich vs. Tira IV: The ex-champ certainately through, with Tira IV in my opinion.
Gabriel III (18) vs. G5orce vs. Death Threat 0.2 vs. Leprosy Infection: Gabriel II and Ge5orce through here, by OOTAing everything.
Heat Winner: WEDGE DEVOLUTION - I dont think anyone, even Ge5orce has anything on it.
Good luck everyone - this should be fun! :mrgreen::mrgreen::mrgreen::mrgreen::mrgreen::mrgr een::mrgreen:
Thanks Leo. If Robo Sheep is coming for me, Ill go for him. Flip him on the flame pit first to burn all that fur off so I can safely use the drum, then spend the rest of the fight trying to pit him.
If I get him pitted, attack Ramminator and put him on top of Robo-Sheep.
By the way Paul, Masamune has been around a lot longer than Exertion or Nidhog. Just under different names:wink:
Hex Appeal is a very large 120something kj full body spinner Paul, maybe you could reconsider it not posting a threat to you? :P
It is a threat yes. Change of plan - stack Symmetry, then stack Flick. I dont want to get battered.
Yes. sorry Chris it seems Mega Masher 2 is the missing robot
Heat G:
Cat with Wheels (13) vs. Kracko vs. BIACS-le vs. Mega Masher 2
Sorry, Mistake: Robo-Bee: avoid everything, occasionally go for The May Tracks
Heat A:
PsycloniZer (1) vs. Eye of Ran vs. Storm II vs. With or Without You - Psyclonizer and Storm 2 through
ISDSFA (17) vs. Ramminator 1 ½ vs. Robo-Sheep vs. Agro 3.5 - IDSFA and Agro through
Heat Winner - Psyclonizer for me.
Heat B:
Nidhogg Evo (3) vs. 259 vs. Exertion vs. Masamune - Spin up, hit everything, stay away from flippers.
Sheer Heart Attack 2 (19) vs. GBOD vs. Lethal Execution vs. Supernova - GBOD and... Sheer Heart Attack by a JD
Heat C:
Black Panther (5) vs. Lights! Camera! Traction! vs. Heyght II vs. Hexa-Decimator - HexyD and Black Panther through
SOR X (21) vs. Under Pressure vs. Battle Raptor 5 vs. Fatality - SoR and Fatality through
Heat Winner - SoR
Heat D:
Killobite Hex (7) vs. Nightmare vs. Tsunami vs. Monolith - Killobite and Tsunami through
Knyfe (23) vs. Killotine: EVO vs. Leviathan vs. Gemini - Knyfe and Killy through
Heat Winner - Someone with Kill in their name.
Heat E:
Flick of the Wrist 2 (9) vs. Hex Appeal vs. WORCK-ER vs. Symmetry - Flick and Hex through
Tengu VII (25) vs. Boxed In vs. Sakura vs. Sithis - Anyone fancy teaming up on the seed? Reckon between us we box rush and kill him.
Heat F:
Achilles (11) vs. Walk Don€™t Run 4 vs. Dead Horse Beater vs. Obsidian - Achilles and DHB through
Macduff the 4th (27) vs. MORD2 vs. Robo-Panda vs. 13 Black - Macduff and MORD through
Heat Winner - Achilles
Heat G:
Cat with Wheels (13) vs. Super Gore Revo vs. BIACS-le vs Mega Masher 2 - Beat the sheet out of whatever, not worried by any of the other 3 really.
Sideswipe (29) vs. The May Tracks Has You vs. Robo-Bee vs. MeCannibal 3.0 - The seed and the bee out
Heat H:
Dervish: The L337 Generation (15) vs. Nitro-Gene 5.0 vs. Axe-o-Lotl vs. Dendroaspis - Dervish and Nitro through
Intriguer (31) vs. Bubonic Plague vs. Robo-Mammoth vs. Baldur Gamma - Intriguer and Baldur through
Heat Winner - Dervish
Heat I:
Axeon 3.0 (16) vs. Requiem vs. Whirligig 4.5 vs. Slammer VI - Axeon and Whirly through
Shredding Madness (32) vs. Robo-Platypus vs. Wedginator Devilution vs. Blue Sparks - Wedginator through... dunno out the other 3.
Heat winner - Whirly
Heat J:
Spin Dash Unleashed (14) vs. Axe Awe vs. Splinter vs. Firestorm V - Spin Dash and Splinter through
Die-ceratops Re-invertus (30) vs. PTT5 vs. Pure Evil: Back to Basics vs. The Rock - Spin up and attack, probably aim for the seed first, might leave pure evil alone
Heat K:
Cyclone Force 3 (12) vs. Drilla Killa VII vs. Stiltskin vs. Inferno - Drilla and Stiltskin through
Monsoon Magnus (28) vs. Axe to Fall 2 vs. Paralyzation 2 vs. Seung Mina V - Monsson and Seung Mina through
Heat Winner - Seung Mina
Heat L:
Orka MK.4 (10) vs. No Consequences vs. Liar 2 vs. SYNDOS - Orka and SYNDOS through
Dante (26) vs. Macbeth vs. Traffic Warden vs. Chaos 2 - Dante and Traffic Warden through
Heat Winner - Dante
Heat M:
Mantis (8) vs. Spring-BOK! vs. Terrorhurtz vs. Robo-Mosquito - Mantis and Terrorhurtz through
E Clawdius Unum (24) vs. Hypo vs. Tornado vs. Darkestar - Erm, I think the easy thing to do will be to try and get Tornado out of the arena, and then possibly go after Clawdius as I dont think hed do anything that vicious to us.
Heat N:
Supreme (6) vs. Holepunch 2.0 vs. Robo-Hedgehog vs. Roo - Well the idiot who thinks he can smash up a spinning Roo is sorely mistaken, spin up, if a good opportunity presents itself, go on the kill, if not allow people to come to me.
Razer (22) vs. Rupture vs. Eternia vs. The 6isc - Eternia and 6isc through.
Heat O:
Back to Rock III (4) vs. X-Terminator vs. Deadbeat vs. Squish Reincarnated - X-Terminator and Squish through
Envy (20) vs. Turbo Tails vs. Crimson Thunder vs. Ha-Ka - Envy and Turbo both look damageable so I think Ill go after those 2, but I wont lose the axe unless I know Im in a prime position.
Heat P:
Wedge Devolution (2) vs. Cobalt vs. Heimlich vs. Tira IV - I think Ill choose to aim for high ground clearance areas and rather than trying to cause damage go for a grip and pit technique.
Gabriel III (18) vs. G5orce vs. Death Threat 0.2 vs. Leprosy Infection - G5orce and Leprosy through.
Agro 3.5 will try to keep away from Ramminator and Robo-Sheep and attack the sides of ISDSFA with the disc. If Ramminator attacks, Ill either shove or use the disc, whichevers more convenient at the time, but Ill try to keep the disc away from Robo-Sheeps fur.
We€™re the ones with the CRASH!!
We€™re the ones with the BASH!!
We are the ones that take out the TRASH!!
And you€™ll never escape from Robot SMASH!!
*Jonathan Pearce and Henry Rollins appear in the SMASH!! Box, suspended 10 feet above the Robotagon itself with screens behind them showing lists of robots and battles*
JP: Hello and welcome to a brand new series of Robot SMASH!! , entitled Robot SMASH!! III: Lock3d and Load3d.
Henry: We€™re your new hosts Jonathan Pearce and Henry Rollins, bringing the best action from the Robotagon to you live.
JP: Remember you at home can bet on the winners of each battle and the overall tournament winner at Ladbrokes and Betfred.
Henry: I€™ve already bet my house on the reigning champion PsycloniZer!
JP: And although Henry may be rich soon he also stands a 127-1 chance of becoming hopeless, with 127 other machines ready to take PsycloniZer down.
Henry: And this season there are 32 seeded robots in total double that of the 16 ranked machines last season.
JP: There are two seeds per heat, 1 in each four way melee which will see two robots head through into the next round.
Henry: From then on, it€™s dead simple knockout.
JP: So, let€™s see who€™s competing tonight!
*Fearne Cotton and Holly Willoughby appear in the pits surrounded by lots of metal munching machines, Eye of Ran is in the background with Joey working on it*
Fearne: We€™re your pit reporters Fearne Cotton and Holly Willoughby, and we€™ll be bringing you all the action from the pits.
Holly: Tonight is the night the reigning champion PsycloniZer returns, as well as the number #17 seed and 1st series bronze medallist ISDSFA, let€™s take a look around.
Fearne: This is Eye of Ran, a new robot that competed in the RS!! Mini-Tournament 1, it€™s a capital T-shaped machine with a spinning blade mounted on the underside of the machine and a wedge at the rear. It€™s got hardox armour but a high ground clearance.
Holly: A veteran here in the shape of Storm II, it was a finalist in series 1, but lost to Turbo Shredder in round 2 last season. It€™s the Robot Wars World Champion, packing 18 Horsepower of lynch motors in the drive, an electric lifter and an all-new srimech despite being able to run inverted.
Fearne: Here€™s another two-time veteran, the clusterbot With or Without You. It has a brick cluster and a cluster with a blade on the top, but both are ineffective when flipped and the new 50% clusterbot rule won€™t help these guys at all.
Holly: Here we have Agro 3.5, a low wedge shaped newcomer with a vertical spinning disc at the rear. It also as the potential to shove opponents around with the hinged wedge at the front as well, plus it can run inverted.
Fearne: This robot is Ramminator 1 ½ and it packs some punch, with drive motors equal to Storm II and a saw embedded in the ramming scoop. However it€™s certain to be less effective when inverted and it lacks any experience whatsoever.
Holly: Here we have Robo-Sheep, should be very common here in Wales. It€™s a cylinder-shaped machine with a pneumatic jaw that can move right around the robot due to the turret it€™s connected to. However its srimech is slow and the white fur that covers the black bodywork could be in for a roasting.
Fearne: And welcome back the number #17 seed ISDSFA, with the electric front scoop capable of lifting 250 kilograms and the flywheel hidden behind the scoop, used for attacking tyres and weak base armours.
Holly: And here is the reigning champion, the number #1 seed PsycloniZer, the powerful ring spinner with three whirling hammers of destruction connected to a dangerous ring spun horizontally around the robot by a LEM-200 lynch motor, capable of some serious hits.
Battleboard
*Henry appears in the middle of the Robotagon with the robots in their starting squares and the Roboteers on either side of him*
Henry: This is a Robot SMASH!! Series 3: Lock3d and Load3d Heat A round 1 match-up!
In the Red Corner, the number #1 seed PsycloniZer and Eye of Ran!
Opposite them in the Blue corner, Storm II and With or Without You!
PsycloniZer (1):
RS!!1: Didn€™t enter
RS!!2: Sliced and diced Baldur Gamma, Bio-Hazard and Gabriel II (14) to reach the semi-finals, where it smashed up Flick of the Wrist (9) and Black Panther to make the grand final. In the eliminator it took out Nidhogg (2) and in the final defeated Wedge Devolution (1) to win the championship!
Eye of Ran:
RS!!2: Didn€™t enter
Storm II:
RS!!1: Rolled Haardvark around and into the pit in round 1, surprisingly took out Tempest Evil-est-oution in round 2 and the same to Super Gore Evo in the heat final. In the quarters it was smashed in by Supreme Glory Omega, but came 2nd out of four in the play-off.
RS!!2: (5) Flipped Obsidian with help from Cyclone Force 3 in round 1, but was beaten by Turbo Shredder on a judge€™s decision in round 2.
RS!!1: Shredded by Whirligig 4.5 in round 1.
RS!!2: Flipped and pushed around by Nitro-Gene 4.0 and Tough as Nails in round 1.
Roboteers, standby!
Booth Red: Andrew Jackson, Joey McConnell
Booth Blue: Paul Cuomo, Martijn M Benschop
House Robot: Furnace (Team Welsh Darklords)
#5... (Red)
#4... (Red)
#3... (Red)
#2... (Amber)
#1... (Amber)
#SMASH!! (Green)
Four robots all get off the mark as the green light is displayed on the wall of the Robotagon and the crowd cheers wildly as PsycloniZer, Eye of Ran and Without You all start spinning up their weapons and moving into the centre of the arena, but Without You surprisingly shies away and let€™s its cluster team-mate With go in on the attack, breaching the front ground clearance of the former grand finalist Storm II and pushing it back across the arena and into the spike strip! With holds it pinned there, and meanwhile PsycloniZer and Eye of Ran move in on Without You, who tries to avoid them, but the reverses into the CPZ! The spinning blade hits Furnace, but doesn€™t penetrate the hardox armour and now PsycloniZer moves in on Without You while Furnace spins on the spot and belches fire madly, cloaking the three robots in flames. We can€™t see what€™s happening amidst the flames, so the camera turns now to watch as With finally releases Storm II, who manages to get around to the side of the 50kg cluster, easily ramming it across the arena and slamming it into the pit release button hard! The siren wails and the pit descends, and meanwhile Furnace€™s attack has ended to reveal Without You in pieces, as the aluminium armour was clearly chopped up by PsycloniZer and Eye of Ran, who seem to have teamed up on the 50kg cluster. And unfortunately for With or Without You it€™s the third round 1 loss in a row, as this season the 50% clusterbot rule has been introduced, and so realising this With just gives up completely and plunges straight into the pit of oblivion while the Refbot moves in to count With or Without You out of its third Robot SMASH!! .
And so with the cluster out of the match and Without You at the mercy of Furnace the match continues between the three remaining machines, PsycloniZer and Eye of Ran immediately turning their attention towards Storm II and this deadly alliance is immediately scary for the RW7 and VFT6 runner-up as the two spinners approach, but Paul guns the six wheel drive and avoids the two spinners, driving around to attack their rear ends! PsycloniZer isn€™t bothered about this as it has three hundred and sixty degrees of attack, but Eye of Ran only as a wedge at the rear and Joey€™s long machine just isn€™t agile enough to turn and face Storm II in time, and the ex-finalist slams into the rear wedge of Eye of Ran, driving up onto the top of the vapourbot! Joey is unsure what to do, so makes for the pit, reversing up to it to try and dump Storm II into the abyss, but amazingly Paul turns the tables and drives off the top of Eye of Ran just as Joey backs up to the pit, landing in front of the spinning blade and reversing into it! CRASH! Blade and armour panel collide, with Storm II€™s rear armour plating flying off across the arena and landing on the camera tracks, but the impact sends both robots flying away, with Storm II being spun away onto the flame pit and Eye of Ran being knocked backwards into the pit it so very nearly dumped Storm II into!
CEASE!
With or Without You is once again without a win and Eye of Ran is blinded; PsycloniZer (1) and Storm II fly through to round 2!
*Fearne walks up to Martijn in the pits*
Fearne: Unlucky there, another round 1 defeat for With or Without You.
Martijn: Yes, it isn€™t a robot designed for melees really, and when two of the others teamed up on me the aluminium on Without You didn€™t have a chance.
Fearne: Despite the three losses in a row will With or Without You be back?
Martijn: Maybe, it depends what the format of the next wars will be.
Fearne: Who are you backing to win the heat now then?
Martijn: The champion has the best chance I think.
Fearne: Thanks for competing.
*Holly walks up to Joey in the pits*
Holly: When you teamed up with PsycloniZer I thought you had it in the bag.
Joey: I had hoped to get through, yes.
Holly: What exactly went wrong?
Joey: Nothing really, I just didn€™t expect anyone to pull off a manoeuvre like Storm II just did in the Robotagon.
Holly: It made pretty good T.V viewing for the people at home.
Joey: That€™s something then.
Holly: Thanks for coming.
Battleboard:
In the Red Corner, the number #17 seed ISDSFA and Ramminator 1 ½!
Opposite them in the Blue Corner, Robo-Sheep and Agro 3.5!
ISDSFA (17):
RS!!1: Flipped and immobilised 259 in the first round, then tossed Pure Evil: Revenge of the Disc out in round 2. In the heat final Killobite 5.0 was flipped out of the competition, as was Whirligig 4.5 in the quarter-finals, but in the semi-finals Wedge Devolution flipped ISDSFA out of the competition as ISDSFA did to Supreme Glory Omega in the play-off.
Ramminator 1 ½:
Robo-Sheep:
Agro 3.5:
Roboteers, standby!
Booth Red: Frank Goacher, Samuel Park
Booth Blue: Ben Read, Richard Southworth
House Robot: Triple Whamlet (Team Dark Zlayerz)
#5...
#4...
#3...
#2...
#1...
#SMASH!!
The seeded robot is first off the mark as this battle gets underway, with Frank driving ISDSFA towards Robo-Sheep, who moves off and heads for the seed! That€™s just as well, but Agro 3.5 spins up the flywheel pretty quickly and hovers around by ISDSFA, allowing Frank to get in underneath Robo-Sheep and lift into the air before moving in and preventing Frank using his own flywheel by smacking ISDSFA in the side, flipping it over and freeing Robo-Sheep! The seed self-rights, but Robo-Sheep has moved around to the side of season 1€™s bronze medallist and brings the jaw into play, gripping ISDSFA and dragging Frank across the arena and using the turret to stylishly swing ISDSFA into the pit release button! The siren wails and the pit descends, but the impact with the pit release button shakes ISDSFA out of Robo-Sheep€™s grip and Frank immediately rounds on his attacker, utilising the linear actuators powering ISDSFA€™s scoop to lift Ben into the air and slam him against the arena wall, bringing the flywheel (capable of 8Kj) into play on the tyres of Robo-Sheep! And as the camera zooms in we see that said tyres have become rather shredded, and Frank is very pleased with that, so now he gets the scoop back down and uses it to stop Robo-Sheep self-righting, now using the lynch motors in the drive to push Ben into the CPZ, where Triple Whamlet pushes in on the attack and brings all three axes down, causing even more damage to the tyres of Robo-Sheep! Ben uses the self-righting arm to get Robo-Sheep back onto its wheels now, but the tyres are so badly damaged that it can€™t get away from Triple Whamlet, who brings all three axes back down onto the sheep again, badly damaging the top armour! ISDSFA moves in now and drives in underneath the almost dead Robo-Sheep, pushing it to the arena wall and pushing the linear actuators as hard as they can go to lift Ben onto the rails, and now Frank delivers the final shove to knock Robo-Sheep onto the camera tracks and out of the competition! Meanwhile Agro 3.5 has been pushing Ramminator 1 ½ into the spike strip while dealing an occasional hit with the flywheel and taking a few rams, though the weaponry of Ramminator does nothing to the body work of Agro 3.5. Now that Robo-Sheep has been disposed of though ISDSFA comes back on the attack of the other two though and scoops Ramminator 1 ½ up, pushing Samuel against the arena wall and pinning him there for the full 30 seconds permitted by the judges. Agro however isn€™t just sitting there and lines up for an attack on the seeded robot with the flywheel going at full speed, reversing at good pace and slamming the hardox armour of ISDSFA once again, this time knocking it over onto its front! And Ramminator immediately comes in on the attack, pushing in underneath the flipped ISDSFA and driving Frank onto the flame pit! The scoop of ISDSFA activates though and Frank gets back down onto his wheels, now driving in on the attack of Ramminator 1 ½, breaching his opponent€™s front scoop this time and ramming Samuel into the spike strip! But once more Richard proves his vindictiveness and uses the hinged plate of Agro 3.5 to drive in under the side of ISDSFA and pushes both Samuel and Frank across the arena, delivering them to the edge of the pit! Richard makes it so that ISDSFA drops Ramminator 1 ½ onto the edge, with one side of the drive hanging over the abyss, but Frank himself is in no better position as Richard puts ISDSFA€™s front wheels over the edge of the pit! Both robots look to be teetering on the edge of oblivion, and although the match looks sure to have ended via pitting time runs out!
CEASE!
Judge€™s Decision:
Damage:
ISDSFA- 8 x 4= 32
Ramminator 1 ½- 3 x 4= 12
Agro 3.5- 6 x 4= 24
Aggression:
ISDSFA- 9 x 3= 27
Ramminator 1 ½- 6 x 3= 18
Agro 3.5- 8 x 3= 24
Control:
ISDSFA- 5 x 2= 10
Ramminator 1 ½- 7 x 2= 14
Agro 3.5- 9 x 2= 18
Dominance:
ISDSFA- 7 x 1= 7
Ramminator 1 ½- 4 x 1= 4
Agro 3.5- 8 x 1= 8
Overall:
ISDSFA- 32 + 27 + 10 + 7= 76pts
Ramminator 1 ½- 12 + 18 + 14 + 4= 48pts
Agro 3.5- 24 + 24 + 18 + 8= 74pts
Robo-Sheep is put on the menu and Ramminator 1 ½ isn€™t half rammed; ISDSFA (17) and Agro 3.5 go marching on!
*Fearne walks up to Ben in the pits*
Fearne: Unlucky match there.
Ben: Yes, it seems the flywheel of ISDSFA and Triple Whamlet damaged my tyres and stopped me getting around properly.
Fearne: I guess after that it was pretty frustrating?
Ben: Yes, not being able to get the robot where I wanted it to go was annoying.
Fearne: You did get a good attack on ISDSFA though.
Ben: Yes, that was good.
*Holly walks up to Samuel in the pits*
Holly: Hard luck.
Samuel: Yeah, it was going good at one point, but I guess I just didn€™t do enough.
Holly: How come you couldn€™t get Agro 3.5 down the pit?
Samuel: His hinged plate at the front kept me away and the disc gave me a few knocks as well.
Holly: What would you change for next time?
Samuel: More effective weaponry and more pushing power.
Heat A Semi-Final Draw:
PsycloniZer (1) vs. Agro 3.5
ISDSFA (17) vs. Storm II
JP: We€™ll be back...
Henry: ... Right after the break!
If, when I die and go to heaven (which is rather unlikely but thats a story for another time :P) I meet Sir Isaac Newton, I shall hit him with a big sharp thing for all the roboteers and vapourboteers who have fallen victim to his laws of physics. :proud:
Good opening fights though, even if I didnt do too well...liking the presentation, keep things up. :)
WOOOOOO! x2 - one for the battle being blindingly great, and I managed to survive one of the worst draws Ive ever had!
PsycloniZer (1) vs. Agro 3.5: PsycloniZer has this in the bag, just hitting and hitting and ripping Agro 3.5 into Agro 4.0 :proud:
ISDSFA (17) vs. Storm II: Im going to pull out Storm IIs extra weapon - its new self-righter. You can see it in action here: http://uk.youtube.com/watch?v=5ulDsRIMcJghttp://uk.youtube.com/watch?v=5ulDsRIMcJg. Im going to equip it, and thatll mean that if flipped, I can self-right. Slam into ISDSFAs sides, ram him into a wall to get him on top of me, then reverse onto the pit release button, and dump him in. Just drive him to the edge of the pit, then activate the self-righter to get him off the top and let him slide in.
Good luck Frank :wink:
Great work Liam!
PsycloniZer vs. Agro 3.5
First of all, that hinged plate is looking tasty. Hopefully I can remove that quite quickly and that will be one less weapon to worry about. Agros blade cant really get a hit in anywhere, and if it does the armouring and frame should be able to stand up to the punishment. Offensively, 4mm Hardox isnt exactly PsycloniZers favourite meal, but it has dealt with worse than that before. Just keep attacking until its knocked out.
I totally like the pace in this tournament Liam, and I also like the rest lol
except for my round 1 exit
Great fights Liam, but I reckon Agros going home in a binbag after this one! :sad: I wont bother using the disc at all - Ill be trying to ram PsycloniZer head on into walls and the CPZ, and the pit if we go near there (if I can get underneath at all, Ill shove him to the pit right away). Hopefully the low wedge will absorb PsycloniZers blows a bit better than a flat surface.
Crud, I have to make predictions and tactics now after the fights have started! :proud: And those fights are good! :) And w00t! Triple Whamlet had a go! :proud:
Heat A Round 2
Oh dear. Richard out, I think.
I think ISDSFA can get under it, flip it over, and keep it turned for the entire match. Frank FTW
Heat winner: Psy, probably.
Heat B
Nidhogg and Exertion, easily.
GBOD and Lethal Execution, Id say.
Heat winner: GBOD could give Nidhogg a hard time but not hard enough. Nidhogg FTHW.
Heat C
Heyght and Hexy-D to bite the dust.
If Under Pressures flipped, it isnt as effective. And I think either AJ or Richie will give Marti a flipping. SoR and Battle Raptor through. Fatality out no matter what.
Heat winner: I like the look of SoR X.
Heat D
Tsunami seems the biggest threat so go after it, and try to disable the flipper. If AJ is open for teaming, he can take out Nightmare. :proud:
Killy and Leviathan. Leviathan IMO is underrated.
Heat winner: A bot with kill in its name. :P
Heat E
All hail the recent MDU1 clone! :proud: Flick to join it through.
In a battle of three FBS/ring spinners and one super rammer...Tengu and Sakura through.
Heat winner: MDU, of course! :proud:
Heat F
Achilles and Obsidian, Id say.
Fancy a team-up, Richard? Ill take out Robo-Panda using the wedge set-up. Shouldnt be hard. Get him down the pit immediately. Incidentally, does that answer your question, Ben? :P
Heat winner: Probably Achilles.
Heat G
Cat With Wheels (13) vs. Kracko vs. BIACS-LE vs. Mega Masher 2
Act like a mobile hazard. :proud: Spin up, destroy, move around using my omni-drive, repeat. :proud: Ill stay away from BIACS-LE though if I can help it. :P
Well this MeCannibal isnt so unrealistic like its past incarnations. Either it or the seed to follow Robo-Bee out. Frank is deffo through.
Heat winner: BIACS-LE
Heat H
Dervish and the now in weight Nitro-Gene to go through. :proud:
Avoid Baldur. Attack the other two. Drag to pit or hammer to death, whichever works best.
Heat winner: Dervish :proud:
Heat I
I dont see the seed surviving very long with Whirly in there. It and Requiem to go out.
Flip first, ask questions later. :proud:
Heat winner: Dunno how Im gonna survive Whirligig. :lame:
Heat J
Spin Dash and Firestorm.
Die-Ceratops Re-Invertus (30) vs. Powerpoint the Thrasher 5 vs. Pure Evil: Back to Basics vs. The Rock
Chris and Daniel easily.
Heat winner: Die-Ceratops or Pure Evil.
Heat K
Chris and Richie through.
Monsoon Magnum (28) vs. Axe to Fall 2 vs. Paralyzation 2 vs. Seung Mina V
I remember what happened the last time I ignored a drum. :angry: Attack Paralyzation and get it out quickly. Do the same with Axe to Fall if its still there. Care to join me, Dan?
Heat winner: I feel confident with this particular heat, but a choice from the others would be Drilla Killa.
Heat L
Orka MK4 (10) vs. No Consequences vs. Liar 2 vs. SYNDOS
Liar and NC through.
Oi! Whats my house robot doing in there?! :proud: jk, it and Dante to go through.
Heat winner: Liar
Heat M
Mantis and THz.
E Clawdius Unum (24) vs. Hypertension Mk 3 vs. Tornado vs. Darkestar
Clawdius and Hypo.
Heat winner: Hypertension.
Heat N
Supreme and Holepunch, Id say.
Razer has good chances; Rupture and 6isc...dont. :P
Heat winner: Razer.
Heat O
Back to Rock III (4) vs. X-Terminator 3 vs. Deadbeat vs. Squish Reincarnated
BtR and Squish, of course. :proud:
Envy (20) vs. Turbo Tails vs. Crimson Thunder vs. Hacked Off Ha-ka
Flip over Turbo Tails since it cant self-right. :proud: Then flip about Ha-ka if its going to attack me. :P
Heat winner: Back to Rock.
Heat P
Eep. :sad: Stay AWAY from teh Wedge...attack Heimlich first, then if I kill it, focus on Cobalt. Avoid Wedge Devo if I can help it. Unless it wants to team up. :proud:
Gabriel III (18) vs. GeFiveOrce vs. Death Threat 0.2 vs. Leprosy Infection
GeFiveOrce and Leprosy Infection, shouldnt be too hard for them.
Heat winner: Wedge Devo. :lame:
And thats about it. :)
Magnificently wooterific fights, Sir Eliot of Liam. I shall post my tactics nearer my heat. :proud:
