RS!! Mini-Tournament 1
Disco 5 vs. Sideswipe
Sideswipe doesnt seem to have that good a turning because of its shape, so i should be able to get round the sides and back easily and do some damage with the disc. Also because of the 1cm ground clearance allround, i should be able to get under its sides and flip it over which could cause it problems.
Semi-Final 1
Achilles vs. Knyfe
Knyfe is using the hinged wedge setup for this bout, while Achilles has switched to the hydraulics.
Roboteers, standby!
Booth 1: Alex Holt
Booth 2: Paul Cuomo
5...
4...
3...
2...
1...
SMASH!!
Both these robots have powerful drives, with Achilles€™ E-Teks and Knyfe€™s LEM-200s, and both machines run those at 48v. It is clear at the beginning of this bout though that Achilles€™ lifter is a far more potent weapon than the hinged wedge of Knyfe, and as the two meet head on Achilles€™ front wedge gets in underneath Knyfe€™s own wedge and Alex lifts Paul into the air, and even as Knyfe€™s wheels go round at amazing speeds there€™s nothing Paul can do up there except watch helplessly as Alex reverses into the pit release button! But the impact of Achilles hitting the button shakes Knyfe loose and suddenly Paul finds himself back in action- under the lifter of Achilles! With a perfect attack lined up for him Paul wastes no time and slams into the internal workings of Achilles, driving Alex back across the arena floor and tries to steer him towards the pit, but Achilles shakes him off and gets that lifter back to the ground only to be rammed side on by the consistent Knyfe, this time pushing Achilles just slightly past the edge of the pit (so close!) and onto the killsaws. BZZT! Achilles is thrown away, but now gets under the rear end of Knyfe and begins to lift, but the killsaws hit Knyfe and in a shower of sparks Paul is thrown off the lifter and once again his wedge meets the side of Achilles, narrowly missing the pit for a second time, but now Paul manages to shove Alex into the wall with great force and due to Knyfe€™s speed Achilles is thrown over onto its back! Alex self-rights, but Paul has already pushed in underneath and now the two are heading on a one way crash course to the pit! There€™s nothing Alex can do from up there and Knyfe is in full control- or so it would seem. They reach the edge, but Paul can€™t shake Achilles off in time and both machines take the plunge into the chasm! The audience can€™t sit still for the tension, the judges are re-watching the tape... and it€™s Knyfe! Achilles went into the pit first and Paul goes onto the final!
CEASE!
Achilles€™ heel is exposed; Knyfe goes through like a knyfe through butter!
Semi-Final 2
Roboteers, standby!
Booth 1: Martyn Forsyth
Booth 2: Leo Van Miert
5...
4...
3...
2...
1...
SMASH!!
Both these spinners owned their round 1 opponents, especially Disco 5 who only had to deal with a classic heavyweight. Sideswipe certainly had the harder draw, having to take on Spin Dash Unleashed to get here, but by the end of the match the saw machine had no link and thus Leo was through, and it seems he intends to get through again as that dangerous blade is quickly up to full speed, but so is Disco€™s vertical flywheel and the two approach each other cautiously. Leo makes the first attempt to attack and tries to hit the front of Disco with the blade, which he does and Disco has a small gash in the flipper as well as being spun around by that attack! However, the spinning part may not be such a bad thing and now Martyn reverses into Sideswipe with his disc running at top speed and potency while Leo€™s blade is still spinning back up! CRASH! The force of the slam sees Sideswipe go right up and over backwards, and the spinning blade is bent slightly! However, it isn€™t too badly disfigured and Leo self-rights, only to be pushed by Martyn, who gets the flipper underneath and overturns Sideswipe again! Leo once again rights his machine, but now Martyn€™s flywheel is spinning at maximum rpm again and Disco 5 delivers another blow to the front of Sideswipe, this time sending the T-shaped robot careering across the arena to land on its side, stacked against the wall! Leo spins the blade and gets back down, but in comes Disco yet again and stacks Leo back up with the flipper, not giving Sideswipe time to get that weaponry back up to speed. Leo wearily self-rights again, but is smacked by Disco 5€™s flywheel and cartwheels sideways onto the killsaws! BZZT! Up they come and Sideswipe is bounced away, landing right side up and quickly running off to spin up again, finally succeeding in doing so. Disco 5 follows with the flywheel spun up again and the two spinners meet head on, horizontal blade vs. Vertical flywheel and this time Disco 5 is knocked reeling by the hit, but not as badly as it would have done because Sideswipe€™s blade is still bent out of shape. And now Martyn attacks again, sliding in under the front of Sideswipe and getting right underneath the middle of the long machine before firing his flipper, which fails in turning Sideswipe over this time, but manages to push Sideswipe backwards into the pit release button! The siren wails and the chasm descends, and now Leo sees a chance as he falls off Disco€™s flipper and pushes Martyn side on, almost turning the match on its head by pitting Disco, but Martyn manages to turn away and now smacks into Sideswipe side on with that lethal flywheel! CRASH! Sideswipe turns over and this time the blade is over thin air, as most of the body is still on the arena floor, but the front is upside down and over the pit! Leo can€™t self-right from there, and the crowd roars as Disco 5 goes into a victory spin, celebrating its domination of the battle as it moves onto the final!
CEASE!
Sideswipe is sideswiped; Disco 5 dances on to the final!
Final:
Knyfe vs. Disco 5
where are the stats for Knyfe?
http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=18 6http://strickenone.proboards99.com/i...n=display&thre ad=186
+2>!WOOOOOOOOOOOOOT! Fantastic - a semi-final victory and Knyfe is where I didnt expect to see it, and where I think many people didnt expect to see it. Fantastic fights Liam, fantastic effort from Alex but ultimately one had to win, and it was Knyfe, and Im in the FINAL! :proud:
+1>Final:
Knyfe vs. Disco 5: Disco is no walk-over, not at all. In fact I think that Disco, out of all the contestants, bar Back To Rock, was the one I was least confident of facing in the final. But I have a plan...
The plan revolves around using the same weapon set-up as last time, so if the flywheel over-turns me I can continue fighting. Even though the 31.5kj is nothing to argue with, neither is my armour and shock-padding, so damage isnt something Im worried about. In fact, the lack of shock-proofing on Disco will go in my favour. my plan is to use the invertible wedge to get under the front when the discs are at full speed, and ram him as hard as I can into the furthest wall.
This should:
A) Kill him through joint shock of the ram and the energy from the discs.
B) It will dislodge something so I can fight him more easily.
C) The ram will flip him over, and then, because its a forward-hindged flipper, push it so it pushes into the wall, and it cant self-right.
For the final, Ill avoide opening the pit, because I dont want to risk it. Just go for dogged and persistant rams and shoves, and do my main tactic, and try and win the fight.
Good luck Martyn :wink: and Good luck to Disco 5 :proud:
I was robbed I tell ya. :)
Well done Martyn, good luck in the final.
(Message edited by leorcc on July 22, 2008)
Knyfe vs. Disco 5 (me)
Despite what it says in the stats of Knyfe, nothing is impossible to penertrate or get under. I also think Knyfe is on the dangerous side of being overweight. Anyway for the fight, i dont think the disc will do much damage to Knyfe because of its armour, so i am going to concentrate on trying to get under it useing the wedge, and flip it against the wall or against the pit. I can use the disc to try and shock Knyfe, but also to flip it, if i can get it to flip using the disc i will and then try and get underneath with the wedge and use the flipper on it, as i said before to either pit it or flip it against a wall.
Sorry Martyn, stacking isnt classed as eliminating your oppoent in RS!! and after 30 seconds you will nees to free him.
fine lol, to add to my tactics, after stacking him against the arena wall, use the disc to cause damage and to knock it out of the arena.
Seeing as I think Liam is already biased towards Knyfe... :proud:
...why would I be biased towards Knyfe?
Well?
If youre going to make comments like that at least explain them :P
Come on Liam, Im just bugging you. :P
...forget it. :P
ffffff>Honestly, though, you should remember when you said Paul, I REALLY like the design of Knyfe and I think its your best vapourbot, its really underrated. back in Robot SMASH 2. :P But whatever!
Kody, are you saying that the only reason I beat Eye Of Ran and the almighty Achilles is because Liam is biased towards me? :uhoh: That indicates at if youd written the Knyfe vs. Achilles fight, I wouldve lost...because youre biased to Achilles :wink:
PS. He did say that Kody, but it was advice to make me think more about weapon choice. In addition...youve got the wrong coloured back-ground.
Poor silly Kody cant do this right
WOOPS :proud:
(Message edited by paulc on July 22, 2008)
Bleh, Im messed up in the head at the moment, and am thinking that if I speak up, everyone is gonna be biased against me. Yeah yeah Im wrong, Im wrong, whatever.
Really, dont mind me, Im just being stupid again. :P
Oh, and I forgot to mention; do you ever check PMs at ZED? :P
No :proud:
What I actually said was Kody that Paul made a stupid weapon choice in RS!!, and until recently he has said that none of his vapours have ever won a heat, I was just giving what I thought was good advice, if you think things like that keep it to yourself :P
Final
Knyfe vs. Disco 5
Knyfe made it here by pitting the destructive Eye of Ran and then exposing Achilles€™ heel and banishing the famous PTT5 champion to the pit.
Disco 5 danced through round 1 with ease as the classic heavyweight Bad Temper Jr was ripped up and tempered, and in round 2 a tough battle with Sideswipe so the Flying Dutchman sideswiped.
Roboteers, standby!
Booth 1: Paul Cuomo
Booth2: Martyn Forsyth
5...
4...
3...
2...
1...
SMASH!!
Knyfe is sticking to the hinged wedge weapon used in the last bout, and Paul hopes it€™ll be a good choice against Disco 5, which packs that powerful flywheel and flipper. Knyfe is immediately on the attack, shooting across the coliseum at breakneck speeds, but is isn€™t well controlled and Martyn simply dodges the attack and gets his flywheel up to full speed, only to be rammed side on by the powerful Knyfe, which slams Disco into the corners and onto the killsaws! BZZT! Disco is shoved away by the saws in a shower of sparks, but keeps the flywheel spinning and now reverses at full speed into the rear end of Knyfe, catching Paul off guard and sending Knyfe flying across the coliseum and landing on its side, from where it falls onto its wheels and in a dazed sort of way comes back on the attack in another slam, but Martyn is ready and manages to slip his flipped under the corner of Knyfe€™s wedge before throwing Paul up and over and quickly turning to smack into the rear of Knyfe with the vertical flywheel again! CRASH! Knyfe is sent head over heels once more and is stacked against the pit release button, the chasm descends, but Knyfe can€™t move as it has no active weapon to free itself from this position! Paul spins the wheels, but to no avail and Martyn just spins up his flywheel before coming in for the final blow in what has been a rather disappointingly one-sided final. CRASH! Knyfe flies over the barrier and crashes out of the final before landing on the camera tracks in a dazed heap, Disco 5 dances through the RS!! Mini-Tournament and claims a victory simple as that!
CEASE!
So the final standings are:
1st Disco 5 (gets 16th seeding in RS!!3)
2nd Knyfe (gets 24th seeding in RS!!3)
3rd Sideswipe (gets 32nd seeding in RS!!3)
4th Achilles
5th Bad Temper Jr
6th Eye of Ran
7th Spin Dash Unleashed
8th Back to Rock III
Can I just say that the outcome of this final bout was nothing to do with Kody€™s comments on me being biased, they were posted after the outcome of the battle had nearly been decided.
Very well done Liam, on a good final. And well done to Martyn on being victorious over Bad Temper Jr, Sideswipe and me to win.
And its good to know that Ill be seeded 24th for RS!!3. What happens if SGO wins RS!!2 though. Will I go up or stay?
If the seeding you get from SGO is lower you will get 24th seed, if it is higher you will get the higher seeding
:-) i won :o well done to paul for getting to the final and Liam on a good mini tournamnet :)
Not that Im complaining, but how did I end up third?
Disco 5= winner
Disco 5 beat you, so you get 3rd
Its almost always how seedings work in vapours:)
Ah we usually have a battle for third an fourth place.
