Fine, by the end of the day, I will have 8 robots posted.
Armory
Weight: 100kg
Armour: 4mm Hardox
Speed: 10mph
Shape: Cube
Weapon: Spike sticking out of the front
Power: 1 USA Interstate Batteries R24 12V battery
Drive: 2x Windscreen Wiper Motors
Strength: Tough
Weakness: Sluggish
Massacre
Weight: 97kg
Armour: 1mm cyrilium (NOT INVINCIBLE!)
Speed: 30mph
Shape: Square about 3cm high
Weapons: small wedge on the back, stinger-like axe on the front, 3 spikes on each side
Power: 1 USA Interstate Batteries R34 24V car battery
Drive: 2x Bosch 750w motors
Strength: Very Fast
Weakness: 1mm cyrilium is as strong as 2.5mm scandium
Thats 2.
Are these car batteries SLA types?
ARGH... :lame:
Cyrilium armour does not exist. You cant use it.
You need more detailed stats, and until then, Im still not letting you in. Sorry.
Ask for help in the How Could I Improve section to get some help, because believe you me, you need it.
He has. Doesnt someone have some sort of basic guide on what works and what doesnt in vapours, or am I thinking of something else?
Ill team with any1. I hav 8 vapourbots, their stats can b viewed on my profile.Mark, I cant partner u until u hav real components, sorry.
Couple of things about my vapours- they all have 0 turning circle.All have 0mm ground clearance except for LockJaw, which has 2mm.
Ill team up with anyone if they want.
Robots:
NAME- Death Threat 0.2
SHAPE- Long box with rounded back,
COLOUR- dull grey all over
WEIGHT- about 100kg
DIMENSIONS- L:95cm W:70 cm H:30cm
SPEED- 13mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- 0mm with hinged skirts, 10mm underneath
ARMOUR- 5mm hardox
MOVEMENT- Tracks with 2XBosch Motors with 3 Ni-cad battery packs at 24 Volts
WEAPONS- Horizontal crushing claws at front made out of titanium with 6.25 tons of crushing power
SRIMECH- Invertible. Side spikes to stop it resting on its side
NAME: Axes of Evil
SHAPE: Hexagon, sloping in to a point in the middle.
COLOUR: dark green.
WEIGHT: around 100kg
DIMENSIONS: 60x60x50
SPEED: 15mph
TURNING CIRCLE: 0mm
ARMOUR: 20mm polycarbonate
GROUND CLEARANCE: 0mm all over with skirts, 15mm with.
MOVEMENT: 2WD inside robot. powered by two Bosch motors running at 24 volts.
WEAPONS: Rack and Pinion axe mechanism powered by two CO2 tanks at 160psi. It has two terrorhurtz style heads, one on either side of the shaft, because Axe of Evil doesnt work with the pun, and the name has to be accurate.
SCRIMECH: the axe has spikes sticking out to aid self righting from any angle.
NAME: Cat With Wheels
SHAPE: Wedge with sloped sides.
COLOUR: Like a Tabby Cats coat
WEIGHT: Around 100Kg
DIMENSIONS: L:100cm W:70cm H:50
cm
SPEED: 18mph.
TURNING CIRCLE: Omm
ARMOUR: 7mm Titanium
GROUND CLEARANCE: 0mm at front, skirts at sides give 0mm, 15mm at back and underneath skirts.
MOVEMENT: 2 wheels with Vulkanon tires and aluminium hubs powered by 2 S28-150 Magmotors at 24volts
WEAPONS: Front hinged high pressure C02 flipper, powered by two rams, running at 500psi.
SCRIMECH: flipper.
SHAPE: Box with wedge at front and inverted wedge at back.
COLOUR: Deep Red.
WEIGHT: Around 100kg
DIMENSIONS: L:110cm W:65cm H:23cm
SPEED: 30mph
TURNING CIRCLE:0mm
ARMOUR: 5mm hardox
GROUND CLEARANCE: 0mm at the front, 0mm with hinged skirts at sides, 20mm at sides under the skirts and at back. (Well, technically 23cm at the very back, thanks to the inverted wedge.
MOVEMENT: 4 Wheels with Vulkanon tires and aluminium hubs powered by 4 36v LEM130s Powered by 6 NiCad battlepacks.
WEAPONS: None but the force.
SCRIMECH: Invertable.
Shape: Cylinder
Colour: Black with red teeth
Weight: 100kgs
Dimensions: L:90cm W:90cm, H:30cm
Speed: 15mph
Turning Circle: 0cm
Armour: 8mm Titanium all around.
Ground Clearance: 7mm
Movement: 4 invertable wheels with Vulkanon treads, powered by a couple of LEM130s at 36V with 3NiCad battlepacks
Weapons: Ring spinner powered by an etek running at 48volts, which can deal out around 80kjs of power. Two five kilo hardox teeth, curved to rip armour. The whole ring is about 20kg.
Scrimech: Invertible.
Name: Lethal Injection
Shape: Stinger, but with static prongs between the wheels.
Colour: Unpainted.
Weight: 100kgs
Dimensions: L:55cm W:60cm H:45cm
Speed: 18mph
Turning Circle: 0cm
Armour: 9mm titanium on the wheels, 5mm Hardox for the prongs and disc.
Ground Clearance: Ermm.. Being a stinger style axlebot, it doesnt really have one. The prongs are 0mm however.
Movement: 2 stinger style wheels with Vulkanon rubber tyres, with 2 LEM130s and 4 NiCad battlepacks at 24volts.
Weapons: Spinning disc positioned in between the prongs. The idea is that the opponent will be wedged on the prongs then caught by the disc. The disc is powered by a LEM130 at 2000rpm and deals about 60kj.
Storm 2
Bigger Brother
I will use Armory and these real bots:
Ming Dienasty
Razer
Inquisitor Series 3
Gravity
Steg 2
Typhoon 2
Anarchy
Danny- team up with me?
I will team up with you, Liam. I will only use my legitimate vapourbot Armory, and the real bots above your post.
I believe me and Aaron are teaming up for this one. Stats and stuff to come...
AJ & I will form Team SpunOut :rofl:
Oh no :proud:
Team Vengeance For All
1. Baldur (Delta?)/Whirligig 4.5
2. Black Panther/E Clawdius Unum
3. Tengu VII/Killotine: EVO
4. Achilles/Wedge Devolution
5. Salamander (IV?)/All Scoop & No Stab Make Steve A Dull Boy
6. Slammer V/Metal Sonic Spin Dash
7. ArchAngel of the Abyss/The Botles Reunited
8. Darkestar/Turbo Tails
Christopher Mason & Martijn M Benschop (need team name)
9. Orka MK4/Another Night at the Bar
10. Leprosy Infection/Axe to Fall
11. Die-Ceratops Re-Invertus/Liar 2
12. Mega Masher 2/Back to Rock III
13. Axe-O-Lotl/Sheer Heart Attack 2
14. Obliteration/Flick of the Wrist
15. Crash Bandi-bot 3/With Or Without You
16. (Spring-BOK?)/Diotoir
Team Chevron Insanity
17. Nitro-Gene 4.0/The Quaestor
18. MeCannibal 2.0/Fire And Ice
19. Autoism 2.0/No Objections
20. D.V.D/147
21. Tri-Tainium/Gabriel
22. WORCK/Nidhogg
23. Square/Life & Death
24. Storm 2/13 Black
Team Dunno
25. Supreme Glory Omega/ISDSFA
26. Manic Monsoon/The 6isc
27. Dervish V/Dead Horse Beater
28. Squishiest/The May Tracks Has You
29. Dennis the Meance/Tempest Evil-est-oution
30. Sonic Boom/Door Stops
31. The Woodpecker/Acronyms FTW
32. Wheely Pure Evil 2/Sakura
Martyn Forsyth
(reserved spot)
Team SpunOut
(reserved 2 spots)
Danny Bailey
(has bots in - waiting for partner. Storm II is taken), you need to select a different realie)
Jamie McHarg
(reserved spot)
Mark Elam, Liam Eliot, Im afraid that none of your vapourbots are qualified at all for this tournament. Sorry, but you cannot enter. Please improve upon your current vapourbots and post them in the How Could I Improve thread to make them suitable for battles, so you can enter for the next one, if there is a next one.
Danny Bailey, Storm II is taken. Select a different realie please.
Just for the Reference - the new Black Panther is online
Seen :)
Kay, swap Storm for... Wild Thing, series 5.
All right.
Can I swap Gabriel for a newer version?
Can I swap Crysis for Super Smash Bros Brawl?
Just wondering Kody, why are my vapourbots illegitimate?
Id reccomend something else Aaron, Brawls an extreme dissapointment.
Opinion. Not fact. I happen to enjoy it. :P
Thinking of entering, Tony?
Liam - You need to get down your stats on a stat sheet.
Heh, I guess youve never played Crysis then... There is nothing more disappointing then Crysis, unless someone tells me there isnt going to be a second series of BBCs Jeckyl.... :lame:
A bit of bad news, Im afraid. :sad:
My laptop is not working at all, it wont load the operating system. This is probably due to that damn networking and firewall problem Ive been having over the past several weeks. :lame: Right now I am typing from the family computer (which sucks), and I wont be able to get anything up until my laptop is fixed.
Of course I am still accepting entries, so I need three more people, plus a whackload of stats. :crazy: :)
Get well soon, Kodys laptop. :sad:
And the stats for Gabriel II are in the improving thread. Im too lazy to post them here :proud:
Anybody else? I dont want my hypothetical of C&BX to be in vain. :sad:
Update on laptop situation...
All my data will have to be erased so the damn thing can be fixed, so I will have to start anew.
It will be fixed on Tuesday, so this thread will become more active at that time.
Just a notice. :)
Still waiting for people to enter...
See you all in a bit, going to retrive my empty laptop now. :lame:
Take the drive out of the laptop, put it into a PC (Need a 2.5 - 3.5 adaptor), throw in an up to date Linux liveCD (Ubuntu is good), run a DD command or two and create a whole image of your crashed laptop drive.
Will get some entries in soon, currently working on a new Infusion + render.
Cant be bothered to. :P
Got my laptop back, and downloading Rhino and Flamingo again. Will render the arena sometime late this week/next week.
So lets see...I need a team name from Martijn and Chris, 3 more people to join, and 4 reserved people to give me their entries.
Dave, Tony, Alex M&W, Samuel, Chezza, you are welcome to join (though if you all enter, two of you will be left out :wink:). Just remember that I need 8 bots, and before joining, always remember to read the rules. :)
(Message edited by kodster on March 26, 2008)
All right, Alex, care to team up? If not, Dave?
There are still some people waiting, like Danny B, Martyn, and Jamie. Danny already has bots in.
MY bots:
Walk Dont Run
Black Death
Turbo Shredder
Paralyzation
Death Wish
Tornado (Realie)
Shredderator (Realie)
Terrorhurtz (Realie)
Sam, fancy a team up?
Where are the stats for your vapourbots Samuel? Can you post them here please?
Theyre are in E.O.T.R 4.
Paul, let him answer. I know you are trying to be helpful but please let people speak for themselves.
Yeah, I would, Danny. ^_^
Right then. Two more people. :)
Me and Samuel agreed over email to go with:
Death Threat/Death Wish
Axes of Evil/Terrorhurtz
Cat With Wheels/Turbo Shredder
Crimson Thunder/Walk Dont Run
Sithis/Tornado
Lethal Injection/Paralysation
Bigger Brother/Shederator
Wild Thing/Black Death
Havent thought of a team name, though.
