The K-TOAD tournament
ROUND 1
BATTLE 4
Axe to Fall VS METAL SONIC SPIN DASH
Zip around to the sides, scrape under the 7mm ground clearance and nibble those wheels. Smash around the arena a few times and dump it in the pit, presuming there is one. I dont think Daves told us about the arena yet. :lame:
In the lack of any pits, ram and nibble to death.
BATTLE 12
Counter VS TURBO TAILS
Charge spinner-first and dig in. :proud:
DEATH THREAT 0.1 VS Boxy
Erm... Crush.
IF CATS HAD WHEELS WE COULD HAVE CAT RACES, HOW COOL WOULD THAT BE VS SoR Hex
Get to the sides and flip around, hopefully get it out.
Tenderizers Revenge 2 vs. Resonance
Spin up, rush in and try to catch an edge of the armour with the drum. The ti/polycarb armour shouldnt put up too much of a hassle. Avoid the front wedge, attack the sides and back.
Flyte vs. Autoism
Id love to scream overweight right now, but its up to the author to police that :proud:. Tactic to use against Autosim is a tactic of patience, basically, @ 23MPH it will be a hard robot to control and will spend most of its time sliding around and crashing into the walls. Ill bid time by dodging his attacks, wait till he runs into a wall then slide under the corner of a skirt (Ala Voltronic VS Biohazard) and flip him. Will try to stack him against the wall or flip him out the arena. Im not worried about his weapon because of the amount of armour I have, and the sloped sides on Flyte make gripping the bot hard, even just for lifting.
I dont see this being an easy or a hard battle, its more of a case of catch his mistakes as a driver and capitalising on them. I knew I should have entered a spinner for this match :proud:
If its all the same to you, Ill post tactics later. Im not feeling at all well right now, nor have I been for 4 days.
Hope youre feeling better soon Chris.
I cant find stats for Hypertension, but I know enough to know that its a flipper which is less than I need to know, so just so you know these tactics might not be completely in the know, you know?
Tactics: Grab, push, pit.
Bit worried about May Tracks opponant, it seems to be a challenging first round... I guess all I can do is try to get under it and flip it OOTA as soon as possible, or Im dead. Not happy about my chances at all:lame:
(Message edited by Pcbore on January 24, 2008)
OK! My predictions and tactics!
Acronyms vs. Hypertension Mk 3: I dont think that the shape of Hypertension is going to help Acronyns a awful lot, so I predict that HYpertension is going to place Acronyns down the pit.
Baldur vs. Tira 3: Tira cant self-right and might not be fast enough to combat Baldur. Alex to place Tira on its side and win.
Orka MK4 vs. Avarice (4): Again, another nasty battle for Kodys robot, and another loss I feel, as Orka pushes it down the pit.
Metal Sonic Spin Dash vs. Axe To Fall: A one-sided fight I believe, and it will go the way of Martijn and Axe To Fall, wholl win on a JD.
Wedgas Revenge vs. GBOD: I might go for a victory for the very-resistant Wedga
Flick of the Wrist vs. Forklift 2 (3): Im guessing that the lifting forks of Flick shall get underneath the skirts. If that happens then Martijn shall get another robot in the next round.
Tenderizers Revenge 2 vs. Resonance: Im going for Resonance, as I believe it can seriously damage Richards robot.
Disco-Tech 2 vs. BIACS-LE: I have no idea.
Drilla Killa 7 vs. D-J: Drilla KIlla to resist the blows from the discs and pit Tims robot.
Nitro-Gene 2 (2) vs. Die-Ceratops Re-Invertus: I believe I can win this fight if I just stay away from the nose of the robot. If he gets under, use my high ground clearance to drive off the flipper. If I get around the sies/rear of Die-Ceratops, waste no time, just get under and then push him into the sides and toss him over.
Flyte vs. Autosim: Another blast! This time a much less experienced robot but one that could do well. I have more power, so charge head-on and lower down the claw so it dig into the ground, allowing me to get underneath the front. After that, crush down and keep hold. Dont let go or try anything clever, just go for the pit release button, and keeping hold, push him down.
Turbo Tails vs. Counter: I know the stats for Counter and I predict he might win this as it can kill spinners in the best way possible.
Shiny Happy People vs. The May Tracks Have You (1): May Tracks.
Eternia vs. Dante: A tricky battle, but Ill go for Eternia.
Death Threat 0.1 vs. Boxy: Death Threat 0.1 to win here.
SOR Hex vs. Cat With Wheels: SOR Hex to get underneath and flick the Cat OOTA.
Hope these predictions suit you fine.
D-J: Spin up and hit Drilla Killa 7 and make sure that he never hits the pit switch.
Counter: wait until turbo tails spins up then drive straight into the disc thus the acid will melt turbo tails to death.David against Turbo Tails can I put on a Mario sticker on Counter just to annoy Tails.
Tactics:
GBOD, spin up asap, then manouver slowly not to lose to much momentum on the shell and slam full power into Wedgas revenge when it gets within 50 cm.
Repeat several times if nessassery. :)
Eternia vs Dante, Rush in as soon as possible, come in at an angle to avoid the disk and drive him up to the arena side wall and flip him out.
Oops, its the same as the last series, which is basically a standard robot wars arena, with just the pit and some side fencing.
OK, extra plan for Turbo Tails.
If Counters acid weapon somehow turns out to be halfway plausible, simply charge in, flip it over and dump it in the pit. :lame:
Hah but youre wrong because Ill intentionally destroy myself so the acid will burn your robots.
Dont the FRA have rules about chemical weapons?
Dunno. Probably but Frankie-boy stop raining on my parade.
Brilliant - you destroy yourself - great, you win and your opponet loses, but then youll have to reconstruct the whole robot for the next round. And since when, in your stats, did you include a self-destruct button?
No Ill intentionally drive into Turbo Tails Disc.
Yeah but since you died first you go out, Tim. :P
No, not exactly my wheels will still be working.
First off, there is a total ban on all lasers, corrosives and explosives in the FRA/RFL rules. Always has been. So your bot is disqualified. Second, as dramatic as you think the word acid is, ive yet to see any form of acid dissolve 100kg of metal in a matter of seconds.
I strip paint with battery acid, and even that takes a few days, despite being around the 40 molar mark...
Timmeh, your just a forum troll :lame: Annoy someone else already...
Aaron Knight, you win every single byte the internet is comprised of. :proud:
Dang it! Dave can you change Counter with Bere-y Interesting.
You cant do that now, the line-ups are already up. :P
OK so Im battling with a disqualified robot. No I want to play by the rules mkay Kody.
I wonder which would win, Counter vs. Boxy.
Counter is alright, as the deadly acid weapon wont play a part as its not allowed. Curse my laziness in checking robots
Mmm...recalculated Tira IIIs kJ properly...so Im gonna give proper tactics, and predictions too.
I think Matty could swing this one. An OOTA might do it. Acronyms IIRC is the one with the gimble-system jaw weapon, and it looks NASTY, but I think Hypertension can get around it and go for an OOTA. If not, lord help him. :proud:
Baldur vs. Tira III
Okay. Baldur is quite tough, but if Tira can get some good hits on the 5mm hardox sides and rear she can probably tear off a panel or two thanks to the 98.5kJ she dishes out in every hit. Dont aim for the front at all, as its gonna be hard too damage. Chances are hell get in there a lot anyway, but hell get flipped over every time by the disc, allowing Tira to attack the rear. If Im lucky hopefully Baldurs scoops mechanism will break after enough hits. Tiras side plows should stop him from getting at her own sides and rear, and throw him into the disc. :proud: This battle doesnt look so bad after a while. :proud:
This, however, does. Orka is quite a tough machine, and has more than enough power to boss Avarice around the arena. Im not sure what Avarice can do to Orka, to be honest, but hopefully my newly reinforced axe will stay on after it hits a few times. Anyway my main tactics for Avarice are to try to get under him. It doesnt matter where, just get under him. When Avarice does, ram him into a wall and whack him with that axe. If he doesnt, give him a whack and retreat, then try again. Right whenver I get flipped. Occasionally drive circles around him to confuse him.
Both good machines, but MSSD I think has the advantage due to a weapon that can actually damage vulnerable parts. :proud: I think he will get under Axe to Fall more often than vice-versa, and then saw the tires. Steve for the win, I think.
Im liking GBOD, but this aint his match. Its a good spinner, but I think Wedga will edge him out here.
Flick of the Wrist, fast drive, powerful lifting spikes, but he presents lots of areas for Forklift to attack, while Forklift doesnt. That flipper of Forklifts will certainly get under the 1st series champ and toss him around quite a bit. This is Martyns match, sorry Martijn. :sad:
Resonance looks devastating. If Tenderizer can get in and stop that drum from reaching full speed, then he has a shot, but its not looking good from my point of view.
If this goes to a JD, Id vote Disco-Tech 2 for cosmetic damage, but I think BIACS-LE can produce a KO here before that happens.
Tim actually has a half-near realistic vapourbot here. :proud: Not that it makes any difference. Drilla Killa to pit him instantly.
Not looking good for Paul. Then again, Chaos 2 had a lot of GC and Wheely Big Cheese couldnt get squat done. In a battle of two good flippers...I think I will side with Nitro-Gene 2 as he has a better rate of attack then Die-Ceratops, but if Die-Ceratops gets one flip in, itll likely be the end for Nitro-Gene.
Flyte vs. Autosim
Flyte to toss Pauls bot OOTA.
Turbo Tails for the KO. :proud:
I think I will take May Tracks here for the KO. :proud:
Eternia vs. Dante
40mm HDPE armour is VERY good for standing up to a mean disc like Dantes. Plus Dante has to self-right every time he gets flipped, and Eternia can just keep charging in every time. Leo will take this one.
Death Threat. :proud:
Cat With Wheels looks like a good vapourbot :). Unfortunately, I think SoR Hex can outdo it here due to that rear horizontal bar. Cat With Wheels to get the skirts torn off, and then some nice flips at the sides will leave it outside the arena. :proud:
Thus, predictions and improved tactics. :proud:
OK Ill withdraw Counter seeing as you freaks dont want fair fights.
People who call other people freaks/idiots are automatically freaks/idiots themselves. YOU do the maths.
We DO want fair fights. What youre clearly doing with Counter is not giving us fair fights. Youre the one to blame, not us.
Ah for some strange reason this reminds me of the time I came up with a robot with a gallium cored cooled spike - gallium being a metal that melts at room temperature. Essentially when it pierced a robot the core would melt due to the temperature in the other bot, drip out and short circuit everything inside the other robots. Its so unbelievably illegal though, lol
This is shaping up to be a great tournament! :)
«Wedga€™s Revenge vs. GBOD»
I am actually quite happy with this draw. GBOD is a very good shell spinner but Wedga€™s Revenge is designed to beat it in almost every possible way. First of all I need to use my front scoop to drive into GBOD and stall the shell. Being rounded and only having a Bosch drive it really isn€™t suited to pushing so from there I should find it easy to push it against the wall. From there I can slide under that 10mm ground clearance and throw it over. Up against the wall I have a good chance of throwing it clean OOTA. If not then just put it on its back - those vertical self righting bars never work, so I€™ll just watch it bounce helplessly around the ring like a mad spinning top. If I repeat this process throughout the match it should be fairly simple.
«SOR Hex vs. Cat With Wheels»
Cat With Wheels is a pretty solid vapourbot, but the difference between the two bots in this fight is that I also have the destructibility factor. I€™ll be using the horizontal bar in this fight. Basically I€™ll be aiming to spin up and try and take out those side skirts. If I can get a couple of decent hits on them they should eventually come off. Then that allows me to exploit that high ground clearance with my flipper and flip it around a bit. Basically I€™ll be nagging away at the side panels and skirts in this match with the spinner, and just using a couple of flips now and then so I can conserve my flipper for self-righting. As I am skirted, invertible and can self-right it isn€™t really going to pose much of a problem.
My predictions for the winners of the other fights are: Acronyms, Baldur, Avarice, Axe to Fall, Flick of the Wrist, Resonance, BIACS-LE, Drilla Killa 7, Die-Ceratops Re-Invertus, Flyte, Turbo Tails, The May Tracks Have You, Eternia and Death Threat 0.1
Tim: The draw has already been made€¦ I doubt you can pull out now. It€™s no good calling us freaks because you made a robot that is clearly illegal. Chris pretty much said it perfectly, you€™re design would be a disadvantage to us, not to you. So why is it us that do not want fair fights? This is by far the best tournament format that has been around for a long time - so don€™t ruin it for us! :P
As you say. Turbo Tails gets a bye into round 2
Im going to try and hit on with the 1st fight this evening...
...however if you think that is Acronyms vs. Hypertension Mk 3, than your very much mistaken, as that is what you would be expecting
...however if you think that is Acronyms vs. Hypertension Mk 3, than your very much mistaken, as that is what you would be expecting.
Thats the beauty of not having a heat system, it means I can be random and do the matches in any order
turn on the agression, axe him to death, get underneath, clamp down, pit
be an annoying as hell rambot, there must be SOME reason why I won series 1 :proud:
The Killer Toad Tournament.
Round 1, Fight 1.
Right, allow me to press the button on the randomiser to see which of the 16 round 1 fights will come up first.
*flashing lights, funny noises, more lights, as list of fights roll around on a massive screen for no propose other than to look classy*
And the first fight will be:
Metal Sonic Spin Dash vs. Axe to Fall
The first machine into the arena today is Metal Sonic Spin Dash, from Steve, it is a 6 wheel drive machine, where all the wheels are inside the robot, protected by some lovely Hardox, powered by some lovely Lem motors giving 18 or so horsepower, the bite comes from the front mounted vertical spinning saw blade mounted in the wedge, ready to slice and dice other machines into showing the white flag.
The second machine into the arena today is the Ref, sporting a lovely counter in which to count out machines, he is in the arena for the first time this series, ready to catch out any naughty behaviour.
The third and hopefully final machine into the arena today is Axe to Fall, which is rolling in now, sporting that lovely big axe, which is lovely, hopefully Martijn€™s machine will do better in series 3 then it did last series, where it was out-controlled by Forklift and sent over the fence, nothing has been changed, so it still has the Lem drive over 4 wheels, powered at a potential difference to 48 volts compared to the earth€™s surface. Will the axe, axe into other machines?
The fences are up, as all the robots are positioned into the correct starting positions, the Ref is standing in between both machines, ready to allow the battle to begin, but before the battle starts, allow me to introduce you to the judge, whom if both robots are still moving after 5 minutes will be bought in to judge on the battle, and award points in 3 areas. Aggression is how aggressive the machine has been, has it been on the attack or in defence? Damage Caused is the damaged caused to the other robot, not to the arena, however if you self-harm yourself, it won€™t look good in the Control area, on how controlled you have been, each area is ranked out of 10 points spilt between the 2 machines, so a max of 30 points. It might not be the most stylist of systems, but as I can€™t find a 4th area is in which I€™m happy enough to award points in, the 3 will have to do. The judge reserves the right to come out and to inspect the machines for damage, if he wants to.
Right, I think that€™s all the introduction rubbish out of the way, as the announcer of the arena beings to announce to the world:
Roboteers stand by
3
2
1
Activate
And the green light appears on the Ref, as he reverses back out of the way, as Axe to Fall comes out straight onto the attack, to get the axe blow onto Spin Dash before the saw blade is up to speed, there is hardly anything between the 2 machines in terms of speed, where the Scottish Spin Dash has a 0.44 metres per second advantage, but having skirts and 6 wheels, Axe to Fall has the better manoeuvrability in theory, but what€™s theory in practise, as Spin Dash dodges the first attack by Axe to Fall, as Martijn turns his machine to counter-act the attack by Spin Dash to try and get underneath the side and attack the polycarbonate to start scoring points.
Martijn turns Axe to Fall again, so the front scoop is facing the front end of Spin Dash, as Steve puts on full power to try and get underneath Axe to Fall, as at the last moment, Spin Dash spins around to get to the side of Axe to Fall, the Dutch machine spins around, so both front ends meet up, the axe fires for the first time, as Spin Dash gets underneath the front scoop of Axe to Fall and causes some lovely sparks, as the axe comes down onto the Hardox top of Spin Dash, it comes away, leaving a smallish dent in the top of Spin Dash, as Steve puts on full power, as he begins to push Axe to Fall across the arena, Martijn trying to get away, but the front wheels are off the ground, as the axe fires another couple times, landing similar blows into the top of Spin Dash, each time making a small dent into the top, nothing major though.
Spin Dash slams Axe to Fall into the arena wall, as Axe to Fall jumps onto the top of Spin Dash, so the front saw of Spin Dash is showing, as Spin Dash reverses to keep Axe to Fall on top, and away from that axe, Martijn spins Axe to Fall off the top of Spin Dash and firing the axe as he gets away, and Spin Dash spins around, the axe hitting the gap between the side skirt and the side of the machine, causing the gap to get bigger, as Martijn puts on full power and gets underneath the side of Spin Dash, firing the axe again into the lid of Spin Dash, as Axe to Fall slams Spin Dash into the arena wall pit release button.
2 minutes remain, as Axe to Fall releases Spin Dash, as both machines go away from each other to get another attack, as both are coming together, at the last moment, Spin Dash dodges the attack and pulls a bluff onto Axe to Fall, as Martijn spins the wrong way, as Spin Dash comes into the side armour, tearing the polycarbonate up, as the front end of Spin Dash disappears underneath the side of Axe to Fall, as Martijn pulls on the controls and tries to break free from Spin Dash, whose is making some lovely holes in the base plate of Axe to Fall, as Axe to Fall spins away from Spin Dash, the axe fires and lands into the gap at the front of Spin Dash, as the saw is stopped, but the axe blade of Axe to Fall when it redraws is still stuck in Spin Dash, as both machines come head-on for only the 3rd time of the battle, as both machines hit, causing a dead-lock, the wheels are spinning as Spin Dash is being forced backwards, the extra voltage from Axe to Fall is doing the trick, as Spin Dash is forced into the wall, suddenly Axe to Fall shoots forward as Spin Dash shoots up the front end of Martijn€™s machine, Steve is shocked, as he has no traction on the cylinder, as the axe fires, trapping Spin Dash onto the front.
Axe to Fall turns and drives, bringing Spin Dash towards the opened pit, as the distance between pit and robots decreases, smoke is coming from Spin Dash, as all 6 wheels are trying to get grip and to escape, but Axe to Fall raises the axe and breaks, sending Spin Dash down the hole.
Cease
A long battle, which saw damage to both machines, Martijn hasn€™t got a clue at what damage awaits him on the base of the machine, but Super Sonic Spin Dash goes out.
As he will face the winner of Orka vs. Avarice.
The next battle will be
*presses the button on the randomiser to see which of the 15 round 1 fights will come up next.
And the second fight will be:
Doh, wrong prediction :proud:
Good battle there Davey. :proud:
SOR Hex vs. Cat with Wheels
And so it comes around to the 2nd fight in round 1.
The first robot into the arena today is SOR Hex, from Andy J, it is a box wedge with skirts around the sides, and a front nose with the flipper, at the rear Andy has picked to fit the spinning bar to cause destruction, the armour comes from everybody€™s favourite source, at 4mm Hardox.
The second robot into the arena today is €œIf Cats Had Wheels, We Could Have Cat Races, How Cool Would That Be€Â, also known as Cat With Wheels, which is what I shall be calling it because €œIf Cats Had Wheels, We Could Have Cat Races, How Cool Would That Be€ is a long name, and could have easily come from the stables of Frank, but it isn€™t, instead it comes from Danny B. The main weapon comes from a front hinged flipper, and the armour is titanium.
Both machines are in the arena, and without further delay
3
2
1
Activate
SOR Hex spins around on the spot straight away to get the rear end into play, to attack Cat with Wheels, Danny meanwhile has launched into an attack, trying to get to the skirted sides of SOR Hex, as both machines close together, Danny making a quick turn to try to get to the sides, as front end of Cat with Wheels meets side skirt of SOR Hex, and the front end of Cat with Wheels goes up the side skirts, Andy spins around in the hope of introducing the rear spinning bar onto Cat with Wheels.
Danny, who I keep thinking is Paul, makes a getaway before the spinning bar can attack, spinning around to re-think his tactics of trying to get underneath the side of SOR Hex, as he has an idea and reverses to hit the pit release button, meanwhile SOR Hex is crossing the arena, again in reverse to try to bring the spinning bar into play, Cat with Wheels once again drives away from SOR Hex, but turns and puts on full power, slamming right into the rear spinning blade of SOR Hex, sparks fly as the bar hits the armour, making a lovely cut, but Cat with Wheels is underneath SOR Hex, as the flipper fires, sending SOR Hex over onto it€™s back, as Andy drives away keeping the rear end facing Cat With Wheels, as Danny gives chase, in the hope of not giving Andy enough freedom to fire the flipper to send SOR Hex back onto it€™s back.
SOR Hex turns and tries to shock attack Cat with Wheels, but Danny quickly dodges the attack, but fails to get underneath the side, as SOR Hex spins around to dodge the attack, as the rear spinning bar hits the side skirts of Cat with Wheels, which start to peel away from the rear of the armour as a side-effect of trying to get rid of the kinetic energy, as Cat with Wheels comes in with another attack, with another attempt of getting to the side to get underneath to force SOR Hex into the pit, as Danny is all over Andy now, SOR Hex spins around once more to avoid Cat with Wheels from getting underneath the sides, as the spinning bar hits the front wedge of Cat with Wheels, as Danny ploughs in underneath SOR Hex again, CO2 is pouring out of Cat with Wheels, the bar must have hit a vital point in the flipper system, as Danny has a look of panic on his face.
However, he remains in control as SOR Hex is slowly getting pushed towards the pit, Andy fires the flipper, a few feet away from the pit, as SOR Hex self-rights, but Cat with Wheels suddenly flies forward, with the sudden removal of 100 or so kilos of robot, Danny spins, narrowly avoiding the pit, as SOR Hex spins around, and attacks Cat with Wheels front end first, Cat with Wheels€™ flipper is out of action, which is worrying for Danny as that flipper is his self-righting device, as he dodges the attack from SOR Hex, as Andy launches another attack, as Cat with Wheels runs away, of which the judge writes down the details. A minute remains, as Danny knows if it goes to a decision, his damage would cost him, as SOR Hex comes at Cat with Wheels once more with the aim of a quick flip.
Danny dodges the attack and puts all his power into slamming into the rear end of SOR Hex, the spinning bar making some more damage to the front flipper, as Cat with Wheels gets underneath SOR Hex, the wheels are spinning as the grip is reduced down to near nothing, the spinning bar is spinning at nothing, as Cat with Wheels is pushing SOR Hex towards the pit of doom, as SOR Hex tries to get away, but this time Andy€™s machine is flipper side up, so he can€™t use the same trick twice to get away from Cat with Wheels, as Cat with Wheels slams into reverse to stop, sending SOR Hex forward, off the wedge and down the pit. Cat with Wheels tries to move, but there is noise coming from the machine, but no movement from the wheels.
Cease
Danny should be celebrating, but he has a look of worry on his face about the drive system of Cat with Wheels, not to mention the slightly damaged front flipper system, and I use the word slightly in the lightest sense, the word I should be using can€™t be said on this forum, but it has 6 letters, begins with the letter F, ends with ked and has a UC in it between the F and the Ked, and that€™s not to mention the damage to the right hand side skirt, but at least Cat with Wheels is thought into round 2, to face either Boxy or Death Threat 0.1.
The next fight will be:
And with that, Im 0-4 down this week. :sad: Nice fight though, Dave!
Wow. To be honest. I thought I was screwed.
Oh well, Im either going to fight my own robot or what is effectively a bye. Looks pretty good to me.
Another prediction down the drain, surprising result, really. Great battles. :)
My plan to do a couple matches per weekend has gone down the pan, hopefully I will hit on with some more matches this weekend.
So it is time for the 3rd round 1 fight:
The first machine into the arena today is Flick of The Wrist, champion of series 1 with a 3-0 win record, and it hasn€™t really changed from an annoying ram-bot, which rams robots around, power comes from some lovely MagMotors and the armour is titanium. The main weapon is a part of diamond tipped electric lifting forks, which can lift or spike other machines; however the main weapon is the drive, which can make Flicky go at 22 mph. Will Martijn ram his way to victory?
The 2nd machine into the arena is the 3rd seed, Forklift 2. Martyn€™s box with front forklift style flipping arms is unchanged from series 2 where it put out Martijn€™s Axe to Fall in round 1, before entering the pit via Nitro-Gene, before winning against Kody€™s Avarice in the 3rd place playoff. It has Hardox armour, and has 6 wheels to drive the machine powered by MagMotors. Will history repeat itself in the battle of the Marts?
Both Roboteers are in the arena, ready to go
3
2
1
Activate
Blink and you might miss Flicky accelerating away, towards Forklift, as Martyn gets ready to defence himself against Flick of the Wrist€™s attack, as Martijn isn€™t stopping and as Forklift dodges, Martijn quickly flicks the controls of Flick of the Wrist and straight away is back on top of Forklift, well to the side, with the forks raised as Forklift is getting pushed sideways, Martyn is trying to get away, but Martijn has got his machine in a hold, as both machines slam into the arena wall at top speed.
The forks of Flick of the Wrist has actually pierced the side armour of Forklift 2, piercing though the 3mm Hardox armour like it was paper, as Martijn reverses, freeing from Forklift 2, Martyn shots out and comes straight back onto attack, but Flick of the Wrist dodges the flipping attack by Forklift, which looks like to be having some control issues, wanting to pull to the right hand side. Flick of the Wrist wastes no time and this time comes into another side attack, avoiding that front flipper.
Once again Martyn dodges, and this time Martijn doesn€™t come straight back onto attack, and drives off to the other side of the arena, before spinning around and launching onto an attack at the front end of Forklift, the front forks of Flick of the Wrist are raised into the piercing position. Both robots come together, as Flick of the Wrist hits into Forklift and pushes it backwards, the flipper fires, sending Flick of the Wrist over onto it€™s back, as Martijn comes straight back onto the attack, ramming into the other side of Forklift, and counter-acting the dodge, and for a 2nd time of the battle, Forklift is being pushed sideways towards the arena wall.
Bang, as Forklift bounces away from the wall, but once more Flick of the Wrist is back onto it, attacking the rear end, and getting underneath the rear wedge, and raising the forks, so that the rear wheels of Forklift are off the ground, suddenly something flies out of Forklift, and lands, as Flick of the Wrist raises Forklift again and puts on full power, ramming it towards the arena wall, another bang is heard as Forklift bounces onto the arena wall, stuck at an angle, rear end sticking on the fence, where it is stuck, Martyn knows that if he tries to self-right, he would only put himself over the arena wall, as for a moment the camera flicks back to that mystery item which came out of Forklift, it looks like a piece of metal, god knows where that came from, although that might explain the reason Forklift was pulling to the right after result of the first attack.
Flick of the Wrist is redrawing, as the Ref is coming into play, as the count-down has started. 1, 2, 3, 4, 5, 6, 7, suddenly the flipper fires on Forklift sending it over the wall, Martyn preferring to get an OOTA rather than a Technical Knock-Out.
Cease
Flick of the Wrist rams to victory, positioning Forklift so that it self-righted out of the arena.
The next fight is:
Drilla Killa 7 is a box with twin wedges, but the rear wedge is upside down and only comes into play when it gets flipped over, the weapons are a pair of drills, one at either end of the robot, so the drill bit can come out and drill into other machines when they are on the wedge. It has 6 wheels, and the armour is Hardox. Will Drilla Killa drill to victory?
The 2nd bot into the arena is D-J, which has stats in the €œHow Could I Improve€ thread, according to Timmy; however I checked and couldn€™t find the stats. Therefore D-J has been replaced with woody, a very basic 4 wheel drive machine powered by a couple of wheelchairs, one wheelchair at the front and one wheelchair at the rear, with the weapon coming from a tiny flail on the top, the armour is MDF, and the machine is rather top-heavy.
Both Roboteers are ready, Richard in the 1st booth, and a potato in booth 2.
3
2
1
Activate
Richard not believing his luck drives Drilla Killa away from the starting block, the potato hasn€™t moved Woody, as it remains at a stand-still as Drilla Killa comes around to the side and getting underneath the high ground clearance, and still the potato hasn€™t moved, maybe that is a tactic to suddenly move, or maybe because the potato is a potato and can€™t handle the controller.
The drill bit rips into the side wood, like it was made of wood, as Drilla Killa redraws the drill and reverses, before coming into a long run, getting underneath Woody which falls onto it€™s side, the potato is looking rather sad as Drilla Killa drills another hole into Woody, as the Ref is coming Woody out.
Cease
In a rather 1-sided battle, Drilla Killa beats Woody.
Fight 5 will be:
