Thanks Kody - actully, I need them for the speed aspect of the robot, but thanks anyway.
I dont think a spinner needs much speed, just maneouverability. If its too fast, then itll go out of control. Typhoon 2 IIRC had a 12mph top speed (or was it 8mph?) 25mph is WAAAAAAAY too much. When you get up to that drive speed, and your weapon is up to full spinning speed, gyroscopic tendencies will cause you to end up on your back.
Just a pointer. :)
Typhoon was at 18mph. Look, Kody, Im using a translational spinner system, which Antony Politzi uses for Cyberdemon, which moves at 35mph. I dont plan on making an enemy before we even have a fight (with vapourbots)
Im not trying to either. Im just saying that bots with spinning weapons and fast drive speeds are highly unstable.
can you make a drawing of it? I am inclined to agree with Kody on this one, but i would like to see what you have in mind.
I could be wrong on this, but I think a translational spinner with 0 mm GC skirts is a recipe for disaster.
25 MPH is too fast, unless you mean spinning speed. If that is the spinning speed, whats the movement speed?
I just have a few things to say please:
Leo: I cant draw it up, because I dont have that type of software on my computer
Frank: As I have said, Im basing Grizzly Bear on Cyberdemon (Stats here, If Im correct)
Weight: 100kg
Shape: Turtle Road Kill
Speed: 35mph
Armor: 6mm Hardox 600
Power: 3 S28-400 Magmotors on 24v with 2 Palasonic 12vs powering them. Also, 2 2kg CO2 tanks for the self righter.
Weapon: Like Heart of Fire, the bot IS the weapon. It has a Y-Drive which allows it to spin and move, though pretty uncontrollabley. Its high speed makes it extremley destructive, as well. The many teeth also allow for quick hits due to the decent torque. Also, theres now a self righting plate that pops out sideways [its the white square on the top] It dosent have too much power to self right, but hopefully it wont need to self right TOO much.
GC: 6mm.
Strengths: EXTREMLEY Destrutive.
Weaknesses: nasty control.
And also, Im going to admit, although I have before, I dont have the faintest idea on how to build a robot. I just thought, make a translational spinner with a bar on.
As far as my concerns go, Cyberdemon doesnt have skirts, although what I said about speed applies to that too.
No, you see, I need the skirts to strike low on flipper blades. Grizzly Bear is sort of an flipper-killer, and the skirts help me on that.
You dont need skirts, just low teeth. Skirts on a machine that has to attack by spinning around, and moves while spinning are likely to drag around on the floor and cause control problems, or if theyre on normal loose hinges will probably be lifted up by the force, negating the effect they were put there for.
To me, Grizzly Bear sounds slightly like The Translator - a vapourbot me and Aaron put together last year. Although your take on it is slightly different in the way ours was a a full body spinner and yours is a bar spinner.
LEM130s arent actually that heavy, and certainly arent limited to just rambots. I use them in pretty much all of my vapourbots, as they are much lighter in weight and more powerful than your standard Bosch 750 or S28-400 Magmotor. If anything, it would be the armour or weapon set-up putting Grizzly Bear overweight rather than the motors.
In terms of the skirts, theres no way some spikes are just going to rip a flipper plate off every time. As well as this, skirts are a bit risky on translational spinners and there is no real need for them. As Frank says, if you want to wreck low-lying objects use some low teeth on the bar to slice them up instead. On the subject of the bar, you say its destructive - but youll have to prove it... there is no mention of what powers it.
And to conclude, is this a Psyclonised killer or a flipper killer? You seem to have drifted away from the original intention. Skirts and the like are just parts that can be ripped off when facing someone like Psyclonised.
OK, Ill remove the skirts, and make the teeth slightly longer, now make the length 7cm
It is sort of designed to be a Psyclonised killer, as the cage and the hammers provide the perfect items to grab hold of and rip. And its not designed to rip the flipper out, its designed to rip off extension plates.
And also:
WEAPONRY: THIS IS AN INNOVATION ON THE BAR SPINNER - IT€™S A TRANSLATIONAL SPINNER, WITH A BAR REACHING OVER THE TOP. IT WEIGHS 20KG AND HAS 2 x 2.5kg HARDOX WEIGHTS. IT IS DEMONISHLY DESTRCTIVE. THE BAR REACHES DOWN TO ABOUT 20CM OFF THE GROUND
So, here it is again, the bar is part of the robots shape! The translational ability just helps it produce more force, and cut down on spin-up time.
Actually, I hope Grizzly Bear does end up in the same heat as the #1 seed. Ill look forward to it if it happens:wink:
(Message edited by paulc on October 07, 2007)
Sorry, I think this is how an actual translational spinner works - It spins around, and drives around at the same time. So then the Tip Speed of Grizzly Bear is 510mph
I suppose with translational spinner you mean what we call meltybrain, the robot spins, therefore the bar spins, and you move by giving the right motor more speed at the right time, giving you motion in all directions.
How do you propose that it saves spinup time? Because now you are spinning up more mass than you would with the bar alone. Force I can agree a little on, except that the real energy that matters is at the tips of the bar, not so much on the rest of the robot.
What kind of size wheels and what gear ratio would you have to reach 510mph tip speed?
510mph is roughly 816kmh
60cm diameter is a circumference of 1.9 meters
So you would need to spin your 100kg robot with 7200rpm to reach that kind of speed.
Activity is very quiet at the moment! :uhoh: When will we see the opening draw? And we will be see the new stats from the remaining entrys?
All these questions and more will be answered...very soon:uhoh:
:rofl:(Cue EastEnders theme song):rofl:
I cant post the draw when Im still waiting for some bots paulo
sorry lads just posting. no offence :)
hey there, thought it might be great fun to update the entry-list
1- Alex Holt
a. Tengu VII
b. Black Panther Queen
c. Achilles
d. Archangel of the Abyss
e. Salamander III
f. Nodachi
g. Baldur Gamma
h. Slammer V
2- Chris M
a. Orka MK4
b. Die-Ceratops Re-Invertus
c. Cyclone Force 2.5
d. Leprosy Infection
e. Mega Masher 2
f. Y4
g. Axe-O-Lotl
h. Obliteration
3- Kody
a. Wedginator 5.0
b. Super Gore: TD
c. The Epidemic
d. Surgeon General (Season 5)
e. Macduff the 2nd
f. Dysfunction 2.0
g. Shadow Zone
h. Intrigue
4- Richard
a. Battle Raptor IV
b. Death Adder III
c. Double Killa
d. Drilla Killa VII
e. MORD2
f. Snakebite IV
g. SYNDOS
h. Tenderizer€™s Revenge
5- Steven
a. Wedge Devolution
b. Killotine: EVO
c. Metal Sonic Spin Dash
d. Whirligig 4.0
e. Clawdius Decimus Murderous
f. Turbo Tails
g. Chaos 2 (Extreme 2)
h. Mega Hurts L.T. (Series 7)
6- Frank
a. The Crashing Bore
b. Tempest Evileroution
c. The Disc 5
d. NSBFR-X
e. Starstorm 2
f. Enter the May Tracks
g. IDSFA
h. Firestorm
7- Alex M
a. Flank Attack: DT
b. Return of Feedback
c. Snijder
d. Eurypterus Evolved
e. Cosmic Thunder 2
f. Cacodemon
g. Malaria
h. Meat Slicer 2
8- Paul
a. MeCannibal
b. Great Bite Shark
c. Grizzly Bear
d. Turbulence
e. Merlin
f. Storm 2
g. Sky Blast
h. Hyena
9- Andy
a. Psyclonised
b. Yet Another Cut Above The Rest
c. GeForce 4.0
d. ForcePower 5.0
e. Wedga€™s Revenge
f. Axeon 2.0
g. SOR 5.5
h. Aneurysm
10- Matty F
a. Unknown
b. Unknown
c. Unknown
d. Unknown
e. Unknown
f. Unknown
g. Unknown
h. Unknown
11- Tony
a. Unknown
b. Unknown
c. Unknown
d. Unknown
e. Unknown
f. Unknown
g. Unknown
h. Unknown
12- Martyn
a. Unknown
b. Unknown
c. Unknown
d. Unknown
e. Unknown
f. Unknown
g. Unknown
h. Unknown
yeah, still 3 people to enter their stuff
and may I remind Martyn, that with Chris Cooper not entering, Wind Chaser will be seeded 16th :proud:
Very interesting line-up.
I just to say 1 thing
The Turbulence Ive entered is the new MK2 version of the machine, which has the new armour improvement, and a full-pressure flipper - believe or not, the previous version was LP!
And for those whove never heard of Merin, go to the competitors section for details.
o, and I have one quick query about your bots Paul... Hyenas stats state theres a flywheel, but not wheter its vertical or horizontal. enlighten me :proud:
Its horizontal. It states in the stats that Ill use like SD IVs saw to damage skirts and tyres. I know it sounds kind of stupid, but I just decided about it.
And do you also understand the jaw mechanism?
If not, Ill try my best to explain :proud:
(Message edited by paulc on October 21, 2007)
Hurry up, lads! (That means Tony, Matty, and Marty) Times-a wastin! :wink:
What I see is pretty much a Growler-esque clamper with stationary underjaw...
Thats nearly correct. I was just worried someone might see it that way.
What it is a stationary underjaw, with the top part feeding off hydraulics to make it work like a axe and jaw.
Just needed to tell you.
(Message edited by paulc on October 22, 2007)
Can someone link me to the FAR forum, please? Its been so long since Ive last done this I dont remember where it is...dont even have it bookmarked anymore, lol.
http://farr.proboards21.com/index.cgi?board=Hitmenhttp://farr.proboards21.com/index.cgi?board=Hitmen
Have fun :proud:
ty
Looks like we can go with 8 vapours, so...
Cyberdemon [It did well last season IIRC]
Shovearound 2
Terror Gear 3
Novastorm 2
Stalker 2
SUNCUST
Shotgun Slapper
Jack Kennedy
And you just gave me the link so I dont think I need to give it back to you XD
Hmm...
Ive had a change of heart. Take out Surgeon General.
...and put in Seung Mina II. You know where the stats are.
cool Kody, and AWESOME Tony :proud:
thats 2 series of vapours to go (Matty? Martyn?) and Andy, if you still feel like upgrading your squad, theres still time to do so
yup, I received some frighting names from Matty through msn...
B2B
Hypertension
Boxing Clever
The robot formerly known as Ha-ka (Im inventing a symbol )
Riptile 3
BIACS-LE
and 2 newbies Cortizone and Bruno
so thats only 1 Martyn left to wait for...:P
That seems a good load of choices, Matty.
Can I ask which Hypertension it is?
And also, could WE (As in everyone on the forum:proud:) please see the stats for the robots Matty is entering?
(Message edited by paulc on October 29, 2007)
yeah, thats the point, stats arent completely done yet, but I CAN write Mattys stats in the draw now (after Martyn enters his stuff), and thats cool :proud:
Hypertension Mk.3
Weight- 98.4kg
Dimensions- H- 40cm, L- 90cm, W- 70cm
Speed- 17.6mph
Shape- Wedge
Ground Clearance- 0mm at front, 3mm at sides, 4mm at rear
Turning Circle- 0
Armour- 7mm Hardox
Locomotion- 2 x 150mm drilled aluminium wheels with reinforced rubber grips + small front wheels for manouvreability.
Batteries - 20 x CP3600 Nicads at 1.2 v each making 24v and each weighing 80g
Motors- 2 x c40-300 Magmotors running at a gear ratio of 4:1 and producing a total pushing force of 7.64BHp
Failsafe Position- Under the armour at the top of the flipper.
Paint Scheme- See through
Weapons- a CO2 powered flipper running at 750psi with 2 x 70mm bore, 220mm stroke rams behind it with a 2.5kg gas tank. It can flip about 2 tonnes, though that shouldn€™t be necessary. It should send a 100kg robot about 1.7m into the air and had around 15 flips in the tank. The idea is that we reserve flips as much as possible and only use them when in prime position.
Srimech- The flipper.
Strengths- Powerful flipper, strong armour, good speed
Weaknesses- Limited manouvreability, limited CO2.
Weight Distribution
Chassis - 22kg
Armour - 35kg
Wheels - 7kg
Batteries - 1.6kg
Motors - 10.8kg
Weaponry - 12kg
Odd Bits (always estimated at 10kg)
Total - 98.4kg
BIASC-LE
Weight- 98.4kg
Dimensions- H-80cm, W- 70cm L- 80cm
Speed- 17mph
Shape- Practically the same as before, but more compact and slightly more rounded.
Ground Clearance- Everywhere from 0-20cm
Turning Circle- Potentially 0
Armour- The semi-hemispherical cage that goes over the top, is now made of 6mm ABC rods, with a layer of 3.5mm Polypropylene over that.
Locomotion- 2 Atilla style wheels, with small-drilled aluminium hubs and aluminium embeddings to gain purchase.
Power- 2 S28-150 Magmotors, giving out 6BHp. These are powered by 2 12V TPC batteries
Failsafe Position- Inside the axle. One on either side disables power to one side, meaning we should nearly always be at least able to run like a skateboarder. I.e. /\/\/\/\/\/\/\/\/\ etc.
Weapon- This was where the major problem was last time, but I think it€™s now sorted. Before, the double diagonal disc ran through the axle, but now, with saved weight, it now runs off a drive chain. Powered by another Magmotor, and spinning at 2000rpm, the weapon now weighs 25kg and always spins up on. It produces 58Kj, according to the Kinetic energy encounter, but this doesn€™t take into account the tiny holes in the disc. . It€™s on the end of a 20cm arm and a small box casing made of 3.2mm Hardox protects the chain that drives it. The cage will now spin over, as the disc swings over the other way, and act like a di-xe! It also has 2 small arms, going about 4cm below and above the disc to stop the disc hitting the floor.
Srimech- Invertible, once disc and cage are sorted.
Strengths- Destructive to the extreme, well protected. To attack, weapon must be challenged.
Weaknesses- Unpredictable when flipped
Distribution of Weight
Chassis- 0kg
Armour- 43kg(Inc. support)
Batteries- 10kg
Motors- 3.4kg
Weapons- 25.2kg
Weapon Power- 8kg
Electronics- 9kg
TOTAL- 98.6kg
B2B (Back 2 Basics)
Weight- 100.6kg
Dimensions- L-75cm W-54cm H- 36.5cm
Speed- 8.5mph/ 3.8 m/s. This however still gives excellent acceleration and the speed of the hits will help us do the Tornado thing:proud:
Shape- Normal Wedge, with rollbars on the back panel made from welded 1cm titanium.
Locomotion- 2 x 270mm diameter wheels with custom cut treads from an old adapted Go-Kart
Ground Clearance- 0 at front, 0 underneath hinged skirts at sides, 4mm underneath skirts and at back.
Turning Circle-0
Power- 2 x 36V Dustin Motors running off 3 x 24V TMC batteries weighing a total of 9kg for the batteries plus 2.6kg for the motors (Lightweight or what:proud:). It gives a total (Presuming efficiency is at maximum) of 4.42BHp. Not the best shover, but with the wedge shaped, the idea will be that before pushing you scoop the wheels off the ground.
Armour- 7mm Titanium/Vanadium Alloy all around weighing a total of 28.4940747kg for the whole body. The titanium bars on the back weigh a total of about 8.4kg.
Chassis- The chassis is made of 1cm aluminium bars, and weighs around 12kg.
Weapon 1- The weapon is a Helium powered flipper, with 2 x 3kg helium rams, capable of firing about 40 times within the course of a fight, and despite running off just 400psi, is easily capable of flipping 250kg. The rams in total, plus gas, and bottles etc. weighs around 16kg and the actual flipper is made out of 4mm Titanium/Vanadium alloy and is around two-thirds the width of the body and goes up the whole wedge. It weighs 5.022kg.
Weapon 2- the bottom of the front wedge is an entirely detachable wedge made of 1cm aluminium. It€™s been designed to be heavy enough to prevent the front wheelying when driving, and therefore means that it should be simple to flip any robots over. It covers about 10cm of the wedge, and is more than capable of resisting attacks. It€™s been designed well and uses the force of gravity and balance to keep it down, whilst only weighing 3.288384kg in total.
Removable Link Position- In a hole with a swinging flap about 10cm into the back panel, but you have to get past the rollbars to get to it.
Srimech- The flipper acts as a self-righter, and will always land on his wheels thanks to the rollbars on the back, once we self-right. The only time this won€™t work is if we can€™t get enough pressure in the ram to fire us over.
Strengths- Powerful, long-lasting weaponry. Manouvreable. Flipper should never fail to slide underneath.
Weaknesses- Not the best pusher in a straight shoving battle.
Weight Distribution-
Chassis- 12kg
Armour- 37kg
Batteries- 9kg
Motors- 2.6kg
Locomotion- 9kg
Weapons- 7kg
Weapon Power-16kg
Electronics-8kg
TOTAL- 100.6kg
Shape: Low Wedge with small rear wedge
Motivation: it now uses four storm 2 style Vulcalon wheels
Speed: 12.5 Mph
Weight: 100kg
Height: 300mm to top of body, 600mm to the top of the disc
Length: 1300mm
Width: 600mm
Weapon: 500mm Vert. flywheel @ 3000rpm. Has a 4.00 second spin up time due to the C40-500 Magmotor on 36v with a 2:1 twin tension cog belt reduction. The flywheel produces 31.5Kj€™s at maximum RPM but is lethal at around 1 second. The second weapon is also the srimech, this weapon is a low pressure pneumatic flipper running on 10Bar (145psi) running into a single 80mm bore ram. This produces 509kg at the ram and is then transferred into the flipper with a leverage point ratio of 1:1. This is a forward facing flipper like FireStorm and will have no problem toppling the heaviest of robots.
Chassis: 4mm Grade 5 Titanium monocoque with extra 5mm Titanium ribs to give it more rigidity.
Drive: 2 x S28-400 Magmotors @ 36v with a 10:1 Mod 2 spur gear reduction
Batteries: 90 x 3000mAh NiCD cells producing 36v @ 9amp
Color- the robot and skirts and flipper are blue and the disc is yellow
Clearance- it has 0mm at the front due to the wedge it has 0mm at the sides due to skirts its 6mm with out it also has a 0mm at the rear due to the small wedge which is there to replace the problem of the skirt being flipped into the disc. The skirts are NOT hinged and held down by torsion-springs so they shouldn€™t spring up and the rear one shouldn€™t go up into the disc
Notes- The flywheel is at the back off the robot it goes over the back of the wedge so if I can get a robot up the wedge far enough it will be hit by the disc. The skirts stop the robot landing on its side.
NAME- The deer (was crusher chaos)
SHAPE- Invertible box
COLOR- the robot and claws are a dark green color
WEIGHT- 100kg
DIMENSIONS- 1m x 80cm x 25cm (l,w,h)
SPEED- 15mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- It has 6mm at the front due to the claws and has 0mm at the sides and rear due to the skirts, without skirts 6mm. The skirts also work both ways up.
ARMOUR- 3.6mm hardox
MOVEMENT- 4 inner wheels that make the robot invertible
POWER- 2 x S28 Magmotors on 24v.
WEAPONS- it has a front pair of horizontal hydraulic crushing claws set up like deers antlers (shaped like those you find in extreme destruction.) The claws have 3.5 tones of crushing force on the front tips of the claws at the middle is 6tones and right at the back it has 8 tones of crush. The claws are powered by hydraulics through a 120mm bore rams at 3000psi
NOTES- invertible, wide base means the deer wont topple while crushing
STRENGTHS- Very powerful weapon
WEAKNESSES- it could be turned into venison
NAME- Wind Chaser
SHAPE- Invertible wedge with curved rear
COLOUR- white with 1 pink line on each side
WEIGHT- around 96kg
SPEED- 25mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at the front due to wedge, 0mm at sides due to skirts 5mm at back
ARMOUR- 4mm Hardox
MOVEMENT- it has 6 inner vulcalon wheels
POWER- it uses 2 x lem 130€™s on 48volts
WEAPONS- It has a rear hinged flipping arm, powered by a lem 130 on 60volts, so it can easily get a robot out of the arena.
STRENGTHS- Compact in size, great pushing power, powerful weapn
WEAKNESSES- no rear skirt, no weapon when flipped.
NAME- Rammy Mk 3
SHAPE- Invertible box with front hinged wedge
COLOUR- Blue
WEIGHT- 94kg
SPEED- 20mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at the front due to wedge this is both ways, 0mm at sides and rear due to skirts 8mm without, the skirts can be taken off if they aren€™t needed for the fight
ARMOUR- 4mm Hardox
WEAPONS- The front wedge can lift up and down powered by a linear actuator, this is only used if the opponent is winning to help get aggression points from the judges. The wedge is hinged so works both ways up however the lifter isn€™t as affective when the robot is flipped though it still works
SRIMECH- Invertible
NOTES- Rammy finally comes to the fra after entering frw 8 and some arc tourneys
WEAKNESSES- Comparatively Light
Name- Take me out (thanks to Dave for naming the robot for me)
SHAPE- Wedge
COLOUR- Dark grey
WEIGHT- 100kg
DIMENSIONS- Height: 20cm, Length: 80cm, Width: 65cm
SPEED- around 18mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at the front due to wedge extender, 5mm at sides and rear
ARMOUR- 4mm Aluminium Boron Carbite
MOVEMENT- 4 inner vulcalon wheels, it uses a skid steer system like tornado
DRIVE- 2 LEM 130€™S on 36 volts
BATTERIES- custom 3300mAh NiCad Cell 36v BotPack
WEAPONS- The robot has a 1000psi nitrogen flipper on a 80mm bore on a 100-stroke ram which should make around 3.5 tones at the ram (if I am incorrect please correct me) the nitrogen is stored in 2, 2.2kg canisters, the robot has around 25 flips in a fight, the flipper is on high pressure
STRENGTHS- Powerful weapon, good drive
WEAKNESSES- limited supply for the weapon
Name- Panicking (previously panic 3 GTI 2)
SHAPE- Low invertible box
COLOUR- Yellow except for the lifting forks which are black
WEIGHT- 98kg
DIMENSIONS- 65cm x 60cm x 15cm (Length x Width x Height)
SPEED- 23mph
TURNING CIRCLE- 0 mm
GROUND CLEARANCE- 0 mm at front due to forks, 0 mm at sides and rear due to skirts 5 mm with out, the skirts are hinged so flop over when the robot is flipped
ARMOUR- 12mm polycarbonate
MOVEMENT- panic now uses 6 Vulcalon wheels to give extra pushing power
POWER- 2 x LEM130€™s on 36 volts
WEAPONS- on the front the robot has a pair of invertible lifting forks, the forks are like those on panic attack, the forks are powered by 2 linear actuators
STRENGTHS- Low ground clearance, reliable weapon
WEAKNESSES- previously lost to spinners
NAME- Star 69
SHAPE- It€™s a shaped like a five point star but the points are mounted round a inner circle so the points of the star spin round
COLOR- yellow
WEIGHT- 100kg
SPEED- 19mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- about 9mm but is lower under the bottom teeth where it is about 3-4mm
ARMOUR- it has 4mm grade 5 titanium
MOVEMENT- it uses 6 inner storm 2 wheels
DRIVE- it uses 2 x lem 130€™s
BATTERIES- 4 x 30 cell 36volt 3ah Sanyo NiCad packs
WEAPONS- as I said it has an outer spinning ring so is a fbs the ring is powered by a C40-500 Magmotor, the points on the star each have sharpened teeth on them and it spins in a clockwise direction, each point has 3 teeth on it, one on the bottom for tearing at skirts in wheels, one in the middle for body work and that, and one at the top for aerials and tall robots and also used for bottom teeth when flipped
SRIMECH- Invertible, points and blades stop it from sticking on side
NOTES- according to frank the name is rude, first star shaped robot
STRENGTHS- Powerful weapon and drive
WEAKNESSES- nights with no stars
Name-Forklift 2
SHAPE- Low box with rear anti self flipping wedge
COLOUR- Yellowy orange
WEIGHT- 100kg
SPEED- 18mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- 0mm at front due to flipper, 0mm at sides due to skirts 7mm with out, 0mm at rear due to wedge. The skirts are held down by torsion springs
ARMOUR- 3mm hardox
WHEELS- has 6 inner storm 2 style wheels
WEAPONS- it now uses a flipping arm that works much like the matadors or Toro€™s the flipper is powered by co2 on a 120mm pneumatic ram, working at 145psi, the flipper front is pretty unique as its front is like that of a fork lift (it has 2 flat bits of metal) this is welded onto the flipper, the arm can toss robots very high and if possible out of the arena. The prongs of the forklift weapon are used to get under the corners or gaps of skirts
SRIMECH- the flipper self rights the robot but because of the rear wedge thing it self rights like firestorm does i.e. the front wheels will go down first
NOTES- this is a modified version of my robot from the panic attack forum.
STRENGTHS- Power full weapon
WEAKNESSES- limited co2
alright, alright, thank you Martyn... everyone is in now... I only miss some stats from Matty, but I expect to get them when needed... tomorrow, I will update Kodys&my forum so all stats can be read efficiently, but now, I will present you... the SEEDS!
1. Psyclonised
2. Black Panther Queen
3. Disco 5
4. Wedge Devolution
5. Flank Attack: DT
6. Clawdius Decimus Murderous
7. Achilles
8. Die-Ceratops Re-Invertus
9. Cyberdemon
10. Yet Another Cut Above the Rest
11. Novastorm 2
12. Tengu VII
13. GeForce 4.0
14. Orka MK4
15. Forcepower 5.0
16. Wind Chaser
AND... THE DRAW!!!
HEAT A
Psyclonised (1)
Terror Gear 3
Sky Blast
Panicking
Cyclone Force 2.5
Boxing Clever
HEAT B
Disco 5 (3)
Axe-O-Lotl
Axeon 2.0
NSBFR-X
Slammer V
Shovearound 2
HEAT C
Flank Attack: DT (5)
SOR 5.5
Snakebite IV
Star 69
HEAT D
Achilles (7)
MeCannibal
Jack Kennedy
Seung Mina II
Killotine: EVO
Take me out
HEAT E
Cyberdemon (9)
BIACS-LE
Wedginator 5.0
Turbulence
Starstorm 2
MORD2
HEAT F
Novastorm 2 (11)
Y4
Aneurysm
Salamander III
Riptile 3
HEAT G
GeForce 4.0 (13)
Battle Raptor IV
Dysfunction 2.0
Baldur Gamma
Return of Feedback
Obliteration
HEAT H
ForcePower 5.0 (15)
Greate Bite Stark
Forklift 2
Snijder
The robot formerly known as Ha-Ka
HEAT I
Wind Chaser (16)
IDSFA
Death Adder III
B2B
Cosmic Thunder 2
SUNCUST
HEAT J
Orka MK4 (14)
Mega Hurts L.T. (S7)
Intrigue
Nodachi
The deer
Firestorm
HEAT K
Tengu VII (12)
Eurypterus Evolved
Leprosy Infection
Whirligig 4.0
Bruno
Macduff the 2nd
HEAT L
Yet Another Cut Above the Rest (10)
Cortizone
Double Killa
Chaos 2 (X2)
Grizzly Bear
Shadow Zone
HEAT M
Die-Ceratops Re-Invertus (8)
Wedga€™s Revenge
Stalker 2
Merlin
The Disc 5
HEAT N
Clawdius Decimus Murderous (6)
Mega Masher 2
Super Gore: TD
Hyena
The Crashing Bore
Malaria
HEAT O
Wedge Devolution (4)
Cacodemon
Drilla Killa VII
Shotgun Slapper
The Epidemic
Storm 2
HEAT P
Black Panther Queen (2)
SYNDOS
Hypertension
Turbo Tails
Rammy Mk 3
Meat Slicer 2
As you see, I only tell whos in what Heat at this point... makes things a little more tense I think :proud:
I dunno when everything will kick off... but in the meantime
START PREDICTING SOME HEAT WINNERS ALLRIGHT!!!
My prediction are coming up as well as some tactics!
HEAT A
Psyclonised (1)
Terror Gear 3
Sky Blast - ME
Panicking
Cyclone Force 2.5
Boxing Clever
Thank you. My first tournment, and you stick me with the reigning champion! Cheers [insert sarcasm]! But I cant wait to fight Psyclonised, as Ive come up with an effective plan to beat it! Ram it as early as possible, and win :proud:! Overall, a good first heat!
HEAT B
Disco 5 (3)
Axe-O-Lotl
Axeon 2.0
NSBFR-X
Slammer V
Shovearound 2
None of my robots in this heat, but Ill go for the NEW King of FFW, Shovearound 2 to win, by shoving shoving around NSBFR-X in the heat final.
HEAT C
SOR 5.5
Snakebite IV
Star 69
Again, none of my robots, but Ill go for Flank Attack to pit Tempest in the heat final!
HEAT D
Achilles (7)
MeCannibal - ME
Jack Kennedy
Seung Mina II
Killotine: EVO
Take me out
Quite a good draw for me. I am the fastest in the heat, and Im also the best armoured, with 5mm Hardox on top, and for the ring 20mm of Hardox. I think Ill win easily, but Achilles and KIllotine are top favs for me!
HEAT E
Cyberdemon (9)
BIACS-LE
Wedginator 5.0
Turbulence - ME
Starstorm 2
MORD2
MORD2 and Cyberdemon are threats, but if Turbulence gets under either, simply flip once, get under, and pit/OOTA!
HEAT F
Novastorm 2 (11)
Y4
Aneurysm
Salamander III
Riptile 3
Novastorm is seeded, and so has the most to hout about, including a possible heat win!
HEAT G
GeForce 4.0 (13)
Battle Raptor IV
Dysfunction 2.0
Baldur Gamma
Return of Feedback
Obliteration
Battle Raptor is take out the seed in the heat final.
HEAT H
ForcePower 5.0 (15)
Great Bite Shark - ME
Forklift 2
Snijder
Im doomed - GBS wasnt built for fighting the machines in this heat. ForcePower to smash, bash and crash its way to the semis!
HEAT I
Wind Chaser (16)
IDSFA
Death Adder III
B2B
Cosmic Thunder 2
SUNCUST
Cosmic Thunder to win here!
HEAT J
Orka MK4 (14)
Intrigue
Nodachi
The deer
Firestorm
Orka to rule the sea!
HEAT K
Tengu VII (12)
Eurypterus Evolved
Leprosy Infection
Whirligig 4.0
Bruno
Macduff the 2nd
Tengu is seeded and spinner protected. GOT TENGU!!
HEAT L
Cortizone
Double Killa
Chaos 2 (X2)
Grizzly Bear - ME
Shadow Zone
Ill do well against Chaos 2, but not agianst much else. Shadow Zone, Andys bot and me are the ones who stand a good chance.
HEAT M
Wedga€™s Revenge
Stalker 2
Merlin - ME
The Disc 5
Merlin is almost like Storm 2, except it has a flipper and Hardox armour. Ill survive facing Alex and Frank (hopefully) to beat Chris.
HEAT N
Mega Masher 2
Super Gore: TD
Hyena - ME
The Crashing Bore
Malaria
Another good heat for me! Attack with the disc, clamp with the jaw, and pit with...the pit :lol:
HEAT O
Cacodemon
Drilla Killa VII
Shotgun Slapper
The Epidemic
Storm 2 - ME
This heat will be a walk-over, except from the seed. Ill send in tactics if I face him!
HEAT P
SYNDOS
Hypertension
Turbo Tails
Rammy Mk 3
Meat Slicer 2
A clean and simple win here for Alex!
Cant wait to see this juggernaut moving Mr M!
CANT WAIT [squeals with excitment]
*ahem* I just noticed that its not only Matty I need stats of.. Alex M... when will you be putting Snijders and Return of Feedbacks stats online?:proud:
Alright, predictions then.
Heat A
Psyclonised (1)
Terror Gear 3
Sky Blast
Panicking
Cyclone Force 2.5
Boxing Clever
Psyclonized has it pretty easy here except for Cyclone Force. Chris and Andy to meet in the Heat Final, and maybe Chris to lose on a JD.
Heat B
Disco 5 (3)
Axe-O-Lotl
Axeon 2.0
NSBFR-X
Slammer V
Shovearound 2
A lot of good bots here. Shovearound 2 and Disco 5 to meet, I think, but I cant predict a winner from them.
Heat C
Tempest Evil-er-oution
SOR 5.5
Snakebite IV
Star 69
Alex MW vs. a whole bunch of spinners. Ill go for Alex. Place your bets now. :proud:
Heat D
Achilles (7)
MeCannibal
Jack Kennedy
Seung Mina II
Killotine: EVO
Take Me Out
Ah, there I am. :proud: MeCannibal, Jack Kennedy and Take Me Out Im not too worried about, just Killy and the seed. Flip, flip, until I drop. :proud:
Heat E
Cyberdemon (9)
BIACS-LE
Wedginator 5.0
Turbulence
Starstorm 2
MORD2
MORD is the one I gotta watch out for here. Aim for the sides, and toss him once. Then just ram him to death.
Heat F
Novastorm 2 (11)
Y4
Aneurysm
Salamander III
Riptile 3
Haha, Aneurysm and Salamander again. :proud: Ill take Salamander to win the heat.
Heat G
GeForce 4.0 (13)
Battle Raptor IV
Dysfunction 2.0
Baldur Gamma
Return of Feedback
Obliteration
That flipper of Dysfunctions is gonna work wonders against these guys. GeForce and Battle Raptor are the main obstacles.
Heat H
ForcePower 5.0 (15)
Great Bite Stark
Forklift 2
Snijder
ForcePowers got it easy here. His heat for sure.
Heat I
Wind Chaser (16)
IDSFA
Death Adder III
B2B
Cosmic Thunder 2
SUNCUST
I actually like IDSFAs chances here. Either him or Cosmic Thunder to smash the seed in the Heat Final.
Heat J
Orka MK4 (14)
Intrigue
Nodachi
The deer
Firestorm
Uh...damn it. Why did I have to run into Orka? Anyway do what I can, go for anywhere but the front, and hax0r him to death.
Heat K
Tengu VII (12)
Eurypterus Evolved
Leprosy Infection
Whirligig 4.0
Bruno
Macduff the 2nd
Oh yes. :proud: Macduff was made to kill off FBSs. Its Eurypterus that will give me the most trouble. Ram him and try to get under him, maybe flip him.
Heat L
Cortizone
Double Killa
Chaos 2 (X2)
Grizzly Bear
Shadow Zone
The seed worries me the most.
Heat M
Wedga€™s Revenge
Stalker 2
Merlin
The Disc 5
ArchAngel to destroy everybody. :proud:
Heat N
Mega Masher 2
Super Gore: TD
Hyena
The Crashing Bore
Malaria
Crap. Clawdius. :lame: Definitely his heat.
Heat O
Cacodemon
Drilla Killa VII
Shotgun Slapper
The Epidemic
Storm 2
Storm AND Wedge Devo?! Beautiful. Thanks a lot Martijn. :lame:
Heat P
SYNDOS
Hypertension
Turbo Tails
Rammy Mk 3
Meat Slicer 2
Alex can win this heat, but Martyn and Matty stand an equal chance as well.
Looking forward to this Martijn. :)
