so not to link it all together?
i once linked to 7.2v nicad packs together, dont want that happening again!
thanks alex
thanks alex
Put all 3 on profile now, thanks woody and everyonme else for their help
cheers alex
Alex ...Ive uploaded a pic for a possible battery configuration on my profile.
would i reassemble the 5 lots of 2 cells using wire? because on your diagram woody it seems to be from tag to cell
thanks alex
Also soldering it all together, i have a soldering iron gun which you press the trigger to heat up, unlike the usaul soldering iron. is this still ok to use?
thanks alex
A soldering gun is fine ... as is using wire.
Remember the tip from Rob ... cut the tags in half and solder on to them rather than the batteries themselves
and aslong as i get + to - it will be ok to charge?
thanks alex
Yes.
ive tried, to put solder on the wire tip then later re heat and put on the tag, this didnt work so im going to try put it on the tag straight away, any tips?
thanks alex
Tin ( put solder on ) both .... you might find that Flux or Bakers fluid will help you tin the battery tags.....
A high wattage soldering iron will also help.
Id tin the wire first ...... then as soon as the battery tag is tinned.. and still hot.. solder on the wire.
http://www.fernox.com/?cccpage=bakers_no_3_soldering_fluid&sub=9http://www.fernox.com/?cccpage=baker...ng_fluid&sub=9
(Message edited by woody on January 07, 2007)
whats a good wattage? mines 150 watts
thanksa alex
Your gun has more watts than mine ...... I use a 10 year old Weller 9200ud rated @ 100watts.
You shouldnt have any problems in the heat department.
Are you putting the heat to the wire then putting the solder to the wire or putting the heat directly to the solder ?
With some cheap soldering guns often although the quoted wattage is plenty sufficient they are utterly useless at transmitting the heat (I had one that melted its own element housing for instance).
Perhaps the gun isnt up to scratch or perhaps you are not heating the piece before applying solder as Simon suggested?
i just heated the solder, and it may not be a good one made by power craft and bought from aldi?
also has some soldering grease in the kit, whats the use for it?
thanks alex
Thats probably why then. Put the soldering iron on the back of the tab, and the solder on the other side until it melts and it should stick better, then do the same with the wire, heat the wire with the solder pressing on the wire until it melts, that way you get a much btter joint. when both the tab and the wired are coated in solder, solder them together.
The grease is known as Flux. Its used to clean the wire during the heating process.
soldering grease = flux
Dip your wire in it before you solder and smear a little on the battery tabs.
http://www.teamnovak.com/tech_info/how_to/solder/index.htmlhttp://www.teamnovak.com/tech_info/h...der/index.html
Worth a read.
i think i need a new soldering iron, looked on technobots and found some will these be suitable?
Go for the Antex 80W. Thatll do the job.
