Mean working voltage 36v DC. does that mean that AJs robots are not on 60v the whole time, or is that just the amount he carries in the robot ?
Just Martyns stats now
May well start matchs tomorrow
Reduce them all to 36v then please. Im sure the rules used to be 48v max for RW and 60v for BB, but never mind.
Maybe I should start my campaign for a set of standard vapourbot rules again... :wink:
...Because the last two campaigns went down really well :p
lol, I dont remember that, but Im certian it was a riot :P
Team Omnibot Athletic vs. Vengance UTD FC
Team Lucy vs Team Martyn
Team XI vs. Team Doomforall
Team Hyper Hitmen vs. Team Martijn
Still looking for Martyn and Martijns
Quick tactics:
Allanon to strike, get hold of the ball quickly, Archangel to cover allanon by killing anyone who tries to tackle, Hector to get claws wide, and just spin either way to block shots, it can cover about 2/3 of the goal at any one time, so shouldnt be too difficult to defend. The rest just mark others.
Team Name: Orange
Goalkeeper: van der Sar
Weight: 100 kg
Dimensions: 0.6x0.9x0.3 m
Shape: Very broad 2 wheeled invertible box
Weapons: Big and invertible snow-plough-thingy across the front with side flaps for control, with a pneumatic ram in the middle to kick the ball away (the scoop is slightly concave to guide the ball towards the middle, where the ram is).
Speed: 18 mph
Power: 2 Eteks @ 36v
Armour: 4 mm Hardox
Transmission: Gears
Defender: Boulahrouz
Weight: 100 kg
Dimensions: 1x0.6x0.2 m
Shape: Low 2 wheeled wedge
Weapons: Front-hinged flipper for some speedy tackles, plough-shaped back with side flaps.
Speed: 22 mph
Power: 2 LEM130€™s @ 36v
Armour: 4 mm Hardox
Transmission: Gears
Defender: Opdam
Weight: 100 kg
Dimensions: 0.8x0.8x0.3 m
Shape: 4wd omniwheeled invertible box
Weapons: All 4 sides are equipped with side flaps, and pneumatic rams to sweep the ball forward.
Speed: 22 mph
Power: 4 LEM130€™s @ 36v
Armour: 6 mm Titanium
Transmission: Gears
Attacking Midfielder: Sneijder
Weight: 100 kg
Shape: Tracked box.
Weapons: Behemoth-style scoop, equiped with side flaps, but moves up like Biohazard€™s arm (so basically it€™s Biohazard€™s weapon only a bit wider :proud:)
Speed: 19 mph
Power: 2 LEM200€™s @ 36v
Transmission: Gears
Striker: van Nistelrooy
Weight: 100 kg
Dimensions: 0.8x0.8x0.35 m
Shape: 2wd Pyramid
Weapons: A giant Etek-powered double-headed axe on top of the machine, with a titanium tennis-racket instead of an axe-head. The sloped front and back have side-flaps.
Speed: 18 mph
Transmission: Gears
Tactics: Boulahrouz is there to stop any striker in his tracks and make them lose ball-possession (a low wedge rushing at you with 22 mph should do that trick). Then it€™s time for Opdam to rush towards the ball, from whatever direction, and sweep it forward. There the swift and agile Sneijder should pick the ball up with it€™s scoop, turn 360 degrees (hence the tracks) and lever the ball towards van Nistelrooy. If van Nistelrooy activates his racket at the right time he should be able to slam the ball towards goal. If not, he can always show some nice dribbling with his flaps to get past the keeper.
Just waiting on Martyn now. 1st match already in the writing
Star 69- Goalie
The Deer- Striker
Panicking- Midfield
Rammy Mk3-Defence
The Interestingly Robust Thing Anyone Sent Me -Midfield
The Reindeer- Sub (can play striker and goalie)
Forklift 2- Sub
NAME- Star 69
SHAPE- It€™s a shaped like a five point star but the points are mounted round a inner circle so the points of the star spin round
COLOR- yellow
WEIGHT- 100kg
SPEED- 19mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- about 9mm but is lower under the bottom teeth where it is about 3-4mm
ARMOUR- it has 4mm grade 5 titanium
MOVEMENT- it uses 6 inner storm 2 wheels
DRIVE- it uses 2 x lem 130€™s
BATTERIES- 4 x 30 cell 36volt 3ah Sanyo NiCad packs
WEAPONS- as I said it has an outer spinning ring so is a fbs the ring is powered by a C40-500 Magmotor, the points on the star each have sharpened teeth on them and it spins in a clockwise direction, each point has 3 teeth on it, one on the bottom for tearing at skirts in wheels, one in the middle for body work and that, and one at the top for aerials and tall robots and also used for bottom teeth when flipped
SRIMECH- Invertible, points and blades stop it from sticking on side
NOTES- according to frank the name is rude, first star shaped robot
STRENGTHS- Powerful weapon and drive
WEAKNESSES- nights with no stars
NAME- The deer (was crusher chaos)
SHAPE- Invertible box
COLOR- the robot and claws are a dark green color
WEIGHT- 100kg
DIMENSIONS- 1m x 80cm x 25cm (l,w,h)
SPEED- 15mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- It has 6mm at the front due to the claws and has 0mm at the sides and rear without skirts 6mm. The skirts also work both ways up.
ARMOUR- 3.6mm hardox
MOVEMENT- 4 inner wheels that make the robot invertible
POWER- 2 x S28 Magmotors on 24v.
WEAPONS- it has a front pair of horizontal hydraulic crushing claws set up like deers antlers like you fine in extreme destruction. The claws have 3.5 tones of crushing force on the front tips of the claws at the middle is 6tones and right at the back it has 8 tones of crush. The claws are powered by hydraulics through a 120mm bore rams at 3000psi
NOTES- invertible, wide base means I wont topple while the deer is crushing
STRENGTHS- Very powerful weapon
WEAKNESSES- it could be turned into venison
Name- Panicking (previously panic 3 GTI 2)
SHAPE- Low invertible box
COLOUR- Yellow except for the lifting forks which are black
WEIGHT- 98kg
DIMENSIONS- 65cm x 60cm x 15cm (Length x Width x Height)
SPEED- 18mph (lowered just for this)
TURNING CIRCLE- 0 mm
GROUND CLEARANCE- 0 mm at front due to forks, 0 mm at sides and rear due to skirts 5 mm with out, the skirts are hinged so flop over when the robot is flipped
ARMOUR- 12mm polycarbonate
MOVEMENT- panic now uses 6 Vulcalon wheels to give extra pushing power
POWER- 2 x LEM130€™s on 36 volts
WEAPONS- on the front the robot has a pair of invertible lifting forks, the forks are like those on panic attack, the forks are powered by 2 linear actuators
STRENGTHS- Low ground clearance, reliable weapon
WEAKNESSES- previously lost to spinners
NAME- Rammy Mk 3
SHAPE- Invertible box with front hinged wedge
COLOUR- Blue
WEIGHT- 94kg
SPEED- 20mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at the front due to wedge this is both ways, 0mm at sides and rear due to skirts 5mm without, the skirts can be taken off if they aren€™t needed for the fight
ARMOUR- 4mm Hardox
MOVEMENT- it has 6 inner vulcalon wheels
POWER- it uses 2 x lem 130€™s
WEAPONS- The front wedge can lift up and down powered by a linear actuator, this is only used if the opponent is winning to help get aggression points from the judges. The wedge is hinged so works both ways up however the lifter isn€™t as affective when the robot is flipped though it still works
SRIMECH- Invertible
NOTES- the wedge can lift up to trap the ball under it and then lifts higher and the ball can fly out into goal
STRENGTHS- Compact in size, great pushing power
WEAKNESSES- Comparatively Light
Name: The Interestingly Robust Thing Anyone Sent Me (TIRTASM)
Shape: A low to the ground invertible box shape with a low centre of gravity
Motivation: It uses four Vulcalon wheels like those used in Storm II
Weight: Somewhere around 80kg without any set-ups
Ground Clearance: 10mm all the way around unless stated
SRIMECH: The robot can work invertible
Drive: It is driven by two LEM130 Lynch Motors on 36v powered by NiCAD battery packs giving around 18hp and a top speed of 20mph
Turning Circle: It turns on the spot using a Tornado like 4WD skid steering system
Weapon: A front concave curving horizontal scoop thing made of 10mm Hardox and 10mm rubber behind it for impacts, the outer armour is replaced with drilled 3mm thick Ti. It has two flappy bits on the sides to control the ball
Armour: 5mm thick Grade 5 Titanium
Notes: Interchangeable body panels, all can be changed within the time limit of 20 minutes (Ta to Steve for some help )
Strength: Interchangeable weaponry speed and power
Weakness: High clearance
NAME- The reindeer
COLOR- the body is brown and the claws are red (how festive)
WEIGHT- 100kg
SPEED- 15mph
TURNING CIRCLE- 0mm
WEAKNESSES- it isn€™t Christmas!
Name-Forklift 2
SHAPE- Low box with rear anti self flipping wedge
COLOUR- Yellowy orange
WEIGHT- 100kg
SPEED- 18mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- 0mm at front due to flipper, 0mm at sides due to skirts 7mm with out, 0mm at rear due to wedge. The skirts are held down by torsion springs
ARMOUR- 3mm hardox
WHEELS- has 6 inner storm 2 style wheels
WEAPONS- it now uses a flipping arm that works much like the matadors or Toro€™s the flipper is powered by co2 on a 120mm pneumatic ram, working at 145psi, the flipper front is pretty unique as its front is like that of a fork lift (it has 2 flat bits of metal) this is welded onto the flipper, the arm can toss robots very high and if possible out of the arena. The prongs of the forklift weapon are used to get under the corners or gaps of skirts
SRIMECH- the flipper self rights the robot but because of the rear wedge thing it self rights like firestorm does i.e. the front wheels will go down first
NOTES-the fork lift bits on the ground make guiding the ball easy.
STRENGTHS- Power full weapon
WEAKNESSES- limited co2
oh yeah I just thought of an extra for anne whenever it grabs the ball an little speaker inside it says Mine! also when are the fights starting. The name comes from my real pet golden retriever dog and my siberian husky(hence the names of the robots)from nintendogs and ripe comes from ripper.
(Message edited by dogbot4000 on February 18, 2006)
Hi guys
Havent forgotton it in here, just a bit busy, first halves will be up soon
