Very true. Will do Geoff matey.
Mr Stu
Mr Stu
Fortunately event organisers do not have to follow FRA rules which allows for common sense to prevail at tech checks. M2 as will M2XT uses a 2500mcd LED cluster immediately behind 10mm poly, this is far superior to for example, a vulnerable 40mcd LED surface mounted according to the FRA rules. Im with Stu on this one :)
Even the Zeobots have a light to comply with this questionable rule and they are surface mounted 40mcd.
Note to self, dont get wound up over power lights again.
Paul
Na you wont Paul - coz your with me on this one, im not on the other side to get you wound up :) Hehe.
But this really is a sticky one.
IF the FRA rules state Have power light on robot which is visable then people are going to have flashing leds, neon lights, mutlicolours, ask questions what type, ask question how big etc, so thats why the FRA has been more accurate of a type of LED to use, these LED surface mounted ones, like the yellow one on Technbots. Its just going to be an on going thing to talk aobut this. lol
Anyway - back to IBCs - they have a small Yellow LED fitted to them, will it be ok if we mount it inside our robots and you can cleary see it through the polycarb pannel - will that be ok for a power light? :proud:
Mr Stu
Our 4 IBCs have super bright blue LEDs :D Can use them as torches in the dark.
Brett changed the LED color in the second version of the IBC since he got sick of being blinded when working on IBC with power in them :proud:
Seem to remember that surface mounted only ended up being in the wording so people didnt say
Roboteer - Yes Ive got a power light
Tech Checker - Where is it
Roboteer - Inside, under this panel, behind the batteries and just next to the bottle
I dont believe the intention was to suggest that putting a piece of clear polycarbonate over the light was against the rules.
Ed
Yeah very true. So as Geoff said, maybe the wording of the rules or somethnig needs to be looked at then.
Mr Stu
The LED Thread is too big so Ill post here :). On Blue we had a blue power light on a blue painted robot and no one complained. Although we did change it to red every now and then due to wiring up the wrong LED.
On the new version it is Surface Mounted in the only bit of Aluminium chassis, there is 4.5mm of white polypro (not transparent) above it. When the light is on you can see it clearly as about 3cm sq of the polypro turns red. Much more visible than just a single 5mm LED would be.
I also dont remember anyone complaining about Mighty Mouse and the other one I cant spell :) where there is a massive white halogen (I think) light inside his robots that light up through all the gaps in the armour, also very visible.
At the end of the day its the tech checker and event organiser who will say if its expectable or not, For minor rule discrepancies Ive seen tech checkers say they will allow it to run this time but they must alter it for next time, so even if you do turn up with a new robot with a power light not surface mounted then the worst that should happen is you are told to change it for next time.
For a picture of the new Blue, now renamed Litter Hitter because its not painted blue, see my profile. It€™s now CO2 instead of a compressor and has a bigger ram with twice the size buffer tanks and an axe head twice the weight of the original. On the picture the LED is located next to the lower left bolt on the top surface but is not visible as it€™s on the kitchen floor and has the link removed.
I love it Mark!!! Nice One!! And you have an IBC in that as well so it fits in the thread :)
Mr Stu
Wow, neat robot. How far does it jump when you fire the hammer? :proud:
Resistance is futule, all threads will be assimilated by the LED conversation
*shivers*
Contacts Species 8472!
Mr Stu
Ps - Only treckies will know what im on about, and im not retarded, just special :proud:
mmmmmmm
http://www.geocities.com/Hollywood/8459/species8472.htmlhttp://www.geocities.com/Hollywood/8...ecies8472.html he is one ugly bugger
You will all become one with the LED conversation.
And only last night you was saying that i was sad because of my interests Stu hehehe... :) each to there own.
Chris - http://www.featherweights.org/forum
Fair Play Chris, Fair Play :)
Mr Stu
Enough the Borg quotations,huh? Fair enough.
Could our own little collective conciousness, (Well, we never seem to be unconcious anyway...), take a look at this http://uk.geocities.com/team_psychostorm/Technical.html
Try 470 for R1 and 100K for R2
Yep I was right. In the middle of the night it hit me. Ive left a 100 Mega ohmn resistor in there. I needed sleep to say the least.
Thanks Stefan, Ill try your sugestion when I get home from college.
+2>HELP HELP HELP HELP
Weve blown our IBC up and want to try our axe robot this weekend!
Have traced the fault to the ATMEL micro and can get hold of one before sunday we need the source code and cant find it anywhere.
Can anyone help.
Would lend you mind, but i lent to Ed and he still has it since Kings Lynn.
Mark id suggest you contact Geoff Smith at teamscorpion@aol.com he will be able to help im sure. Hes going this weekend etc.
Mr Stu
Try http://www.robowars.org/docs/ibc-docs-v0.1.pdfhttp://www.robowars.org/docs/ibc-docs-v0.1.pdf, hope that helps. :)
Not what hes after sadly Aj.
Hes more technical and needs something more technical. LOL.
Mr Stu
Thanks Stu for the quick response Email sent.
AJ, I used this to trace the probelm this is what I cam up with:
Our IBC for our featherweight has gone wrong tonight while testing. Ive been tracing the fault from the circuit diagram. What Ive found is that the Rx signals on the left and right channels get to the ATMEL IC but the AUX channel does not and none of the outputs are working. The 10k resistor is fine, Ive checked the oscillator and reset circuit and both are fine so the only conclusion I can come up with is that the processor is faulty. I have ordered a replacement which should arrive before Sunday but I cant find the source code that the manual says is available. Could you please tell where I can find it or send me the file. I hope that a Dataman 48 programmer will program it as I have access to one at work.
Oh well, I tried. :P
This may be useful http://www.robot-power.com/downloads/http://www.robot-power.com/downloads/
Mark, email Brett at: microsoft (AT) technomagic.com.au
He should be able to send you the code asap.
Managed to get hold of Brett last night and he was a great help and sent the source code so all I need now is a chip and a programmer.
Thanks everyone for your help
Ok, Got the programmer just waiting for the IC
Nice one.
Mr Stu
Got it working (hopefully) :proud:
Replaced the micro and it came to life for about 5 minutes and died again :). The funny thing was it was controlling it forward and backwards fine including turning, but then if you turned on the spot it it went full speed first then started to slow down as you carried on moving the stick.
Checked the wiring again and found that the Red motor wires were OK but the black ones were cross, Doh . Blamed my brother as he connected it up.
After replacing the micro with another one it fired up again. I quickly turned it off and we will try it tomorrow in the arena and hope its lasts.
Your new axe bot looks well impressive Mark, Is it still being called Blue or is it called White now? :)
Going back to its original name, Little Hitter. Seen as theres only a few heavyweights were also taking Litter Flipper tomorrow.
I was just looking through the IBC manual and noticed that the IBC could control a relay/solenoid and was wondering if it could switch over the http://robotcombat.com/store_solenoids.html
No Chris it wont, and you stand a fair chance of cooking the voltage regulator if you try.
The relay control is 12V at a max load of 0.25A
You could use the IBC to drive a small 12V s.p.n.o automotive relay and use that in turn to switch your 120 series @ 24V.
Chris, There is a modification you can do to up the Voltage to the battery voltage but it wont increase the current handling.
Note: We did this and our IBC is no longer working :sad: but due to wiring fault.
Why not simply slave the operation of the big solenoid from a smaller relay?
Sorry to interupt this threads Peaceful slumber but now I have drive worthy enough to test my IBC, I havent a clue why but it appears to be slowly turning, in which direction I havent a clue. The wires are linked up correctly. Me thinks it might be the radio, my skysport 6EXA. Suggestions?
Ps How do I get rid of that noise? I belive it s the pulse width frequency but any way to surpress it?
sounds like you trims are out on the TX, if so just keeping nudging the trim buttons on the TX until it stops. For example if its slowly turning left, nudge the steering trim to the right.
