Pussycat Tribute Tournament 3...continued!
HEAT P - THE STORY SO FAR:
ROUND 1
SPUNOUT 3.0 (2) AND THE TEAM THAT WASN€™T THERE won their battle after Charybdis was pitted by two members of the Team...after KOing a 3rd member
BIGGER BROTHER (18) AND FALCHION won their battle after Hammerer was flipped out of the arena by the No.18 seed
ROUND 2
SPUNOUT 3.0 (2) knocked out one of Falchion€™s drive motors
THE TEAM THAT WASN€™T THERE pitted Bigger Brother (18) using three of its five segments
LATER ON:
HEAT P
ROUND 3
HEAT FINAL
SPUNOUT 3.0 (2) Vs THE TEAM THAT WASN€™T THERE
Thoughts? Tactics? Did you enjoy Round 2?
Thank you! :)
Great last Round 2 there Steve-o! :proud: I canna wait for the semis!
Predictionaries:
I think SpunOut will win, mainly because of the discs power. It should sent the little wedges flying all over the arena.
And off we go again! :)
Our final Heat is about to draw to a close, but before Hector and Tom scrap it out once more in the PTT€™s history, let€™s use our last time travel trip :proud: to take a look back at their previous meeting...the Grand Final of PTT2! :proud:
PUSSYCAT TRIBUTE TOURNAMENT 2
GRAND FINAL
SPUNOUT (Tom Roper)!!!!!!!!!!
(has beaten Disc-Turbed, Forthgill, Bigger Brother, Slam Job, The Matador(10) and Pure Evil)
Vs
THE BUSINESS ENDS (Hector Gilbert)!!!!!!!!!!
(has beaten C2, Son of Ripper 2, Hypno Disc(2), Wheely Big Cheese(14), Biohazard and Razer(11))
House Robots- Sgt. Bash, Mr. Psycho, Sir Killalot, Growler
Roboteers Stand By......
3...2...1...
ACTIVATE!!!!!!!!!!
Right away, The Business Ends and SpunOut charge towards each other!! But as the two approach the arena centre, TBE veers off to one side and reverses into SpunOuts rear!! The axe fires and the arm attached to the rear raises!!! But SpunOut is merely lifted off the ground and lands back on its 6 wheels!!! Now the pusher slams into TBEs rear, carefully avoiding the arm, and shunts the hammerbot into the arena wall!!! TBE tries to get away, but SpunOut starts to ram into it!!! As it backs off, TBE quickly darts away and SpunOut just about ends up crashing into the wall!!! After a very quick recovery, SpunOut charges disc-first towards TBE!!! But as it approaches, TBE slams into reverse and the two crash into each other in the arena centre!!! As the two collide, SpunOuts disc meets TBEs arm, but the lifter holds up with little more than a scratch, while the disc seems to have been temporarily stopped!!! The rear arm of TBE manages to just get under SpunOuts disc and, with one fire of the axe and a lot of reversing, successfully flips SpunOut over!!! Being invertible, SpunOut takes this with little bother!! But as it tries another shove, TBE drives under the rear of the machine and with some more reversing, fires the axe and sends the robot over again!!! Now facing TBE disc-first, SpunOut charges with all its might, slams into TBEs front ram and pushes it so hard that the section of the arena wall the two hit almost comes loose!!!! Now SpunOut is reverting to the Tornado tactic...ram it, ram it, RAM IT!!! But after taking a few nasty shoves, TBE successfully manages to turn around, allowing a charging SpunOut to meet the spinner head-on!!! The disc hits the ram and, although the spike is now rather bent, the disc has stopped again!!! TBE seizes its chance and manages to drive under SpunOuts currently static disc!!! The now legendary axe activates and SpunOut, who seems to be pinning TBE to the arena wall, is suffering blow after blow after blow!!!! Despite having stronger top and bottom amour, the hammer is making a fair few dents!!! Blow after blow rains down on SpunOut, who is still keeping TBE against the wall!! Refbot intervenes by approaching the two and, while carefully avoiding TBEs hammer, pries the robots apart!! The two separate and TBE zooms to the arena centre with SpunOut in hot pursuit...the disc and spike had become stuck together!!!! As SpunOut hits TBEs side and starts to shove it to the arena wall again, TBE quickly pulls forwards and darts away as SpunOut very nearly hits the wall again!!! Now quickly getting into reverse, TBE drives under SpunOuts exposed rear and nearly flips it over again!!! As the pusher tries to get some room and shunt TBE away, the hammerbot drives under SpunOuts rear and lifts it again!!! The pusher is almost turned over...and very nearly propped against the wall!!! With SpunOut pinned sideways against the barrier, TBE reverses into SpunOuts rear and manages to get underneath, while also hitting a wheel!!! The axe fires, the rear arm goes up, TBE pushes with all its might, the sideways SpunOut goes up...and the pusher is now beached on its side against the wall!!!!! The Business Ends has done it!!!!! Its plan worked!!!!! As the mighty hammerer backs off and watches the pusher try desperately to get off the wall, Refbot approaches and begins to count out the marvellous, destructive, but finally conquered SpunOut!!!!!
1...2...3...4...5...6...7...8...9...10!!!!!!
As Mr. P approaches the beached SpunOut, TBE backs into the arena centre and starts to bash the floor with utter joy!!!!! Hectors done it!!! Hes won the 2nd Pussycat Tribute Tournament!!!!! Mr. P meets the abandoned pusher and picks it up with his hideous claw!!! As Bash kindly releases the Pit for him, and while TBE continues to bash the floor into sawdust, Mr. P raises SpunOut as high as possible, turns to the Pit and trundles over!!! Once at the edge, Mr. P releases its grip and all watch as the great SpunOut tumbles into oblivion!!!!! One €œBANG!€ later and the smoke begins to rise from the Pit!!!!! We have a new PTT champion...and his name is THE BUSINESS ENDS!!!!!
CEASE!!!!!
WINNER OF THE PUSSYCAT TRIBUTE TOURNAMENT SERIES 2:
THE BUSINESS ENDS!!!!!!!!!!
FINAL RESULTS:
1st- THE BUSINESS ENDS (Hector Gilbert)
2nd- SPUNOUT (Tom Roper)
3rd- PURE EVIL (Daniel Stickler)
4th- RAZER (11) (Martyn Forsyth)
Of all the fights I€™ve written, I think this is one of my personal favourites. :)
Now, it€™s back to the future to see our last Heat Final (and to get rid of this machine - the CIA have been tracking me for a while, you know :proud:)
It€™s been a long while...a long, long, loooooooong while :proud:...but we€™re finally about to fill the last place in our Series Semi-Finals! Once again, Gilbert and Roper meet in another Clash of the Titans, but who will triumph this time - the 5-way newbie clusterbot or the ram-happy 2nd seed? Our Final Heat Final will provide us with an answer... :)
HEAT P
ROUND 3
HEAT FINAL
House Robots- Matilda and Growler
3...2...1...
ACTIVATE!!!!!!!!!!
SpunOut 3.0 gets off to the quicker start with its serious acceleration, but already, the Team That Wasn€™t There has begun to start separating!! With the disc revved up, the No.2 seed darts forwards and rams right into the middle of the line of Lightweights!! Although this attack has put a great slice into one of the members, this charge has also managed to smash the mini rammers free from each other!! Now all five are beginning to roam the arena!! Disc back up to speed, SpunOut takes a dart towards an advancing segment, but as it does, another member shoots across the ring and under the No.2 seed€™s side before it can swing round and retaliate!! As the powerful cluster piece merrily pushes Tom€™s machine across the arena, another Team member darts over and into the Pit Release Button!! However, as the siren blares and SpunOut is smacked into the arena wall, the blow knocks the No.2 seed off the €œsnagging€ ridge of the cluster piece€™s wedge!! Back in action, Tom quickly sends SpunOut dashing off the front wedge and back into the arena!! As two more segments come on the attack (one of which Tom crippled earlier on :proud:), the No.2 seed tries a new tactic - as the 2 Lightweights get closer, the PTT2 runner-up uses its six wheels to swing right round and strike both cluster pieces with the dreaded flywheel!! While one member is scarred, but safe, the already wounded segment looks worse for wear...due to the fact that only one side seems to be working!!! SpunOut revs up the disc again and dodges another joint assault, as Refbot starts to count out the half-immobile Lightweight!!!
1 down, 4 to go!!! Disc back up to speed, the No.2 seed just dodges a second twin onslaught and twirls round for another go at that unpleasant pair!! But just as Tom€™s machine prepares to attack the two advancing Lightweights, another Team member darts over and slip underneath the No.2 seed€™s side!!! When the fourth remaining segment trundles over as well, SpunOut tries to shoot free...which is tricky when the €œsnagging€ ridge is locked onto the outer cage protecting the wheels!!! Delighted with his little manoeuvre, the triumphant cluster piece makes its way over to the Pit, the other Team members clearing the way!! SpunOut€™s disc spins wildly - but there€™s nothing to attack!!! The wheels twirl desperately - but it can€™t release itself from the ridge!!! Tom tries to wriggle his machine loose - but it€™s too late!!! The little Lightweight has reached the Pit edge, abruptly halted and shaken the No.2 seed into the eternal darkness...
CEASE!!!!!
SpunOut 3.0 couldn€™t survive the big push! :proud: The No.2 seed falls victim to the quintuplets€™ ruthless teamwork and misses out on the title a second time!
THE TEAM THAT WASN€™T THERE GOES THROUGH TO THE SERIES SEMI-FINALS!!!
Congratulations to Hector Gilbert!!! :proud:
And with that, we finally have our 16 PTT3 Semi-Finalists!!! :proud:
1) No. 1 seed and reigning PTT champion THE BUSINESS ENDS (Hector Gilbert has beaten Dantomkia, AWOL and Stratus 2)
2) No. 3 seed PLATINUM PURE EVIL (Daniel Stickler has beaten Big Fred, Pyro II and The Robot That Wasn€™t There)
3) Newcomer DISCTRUCTION EVO (Aaron Knight has beaten Turbo Falcon, 21st seed Double Killa and 5th seed Voltronic)
4) Newcomer CRANKSHAFTED (Tom Roper has beaten Storm 2, 23rd seed Thermidor 2 and 7th seed Biohazard)
5) No. 9 seed and PTT1 champion BETA (Karl Fletcher has beaten Dervish Mach 2, Junkyard Maw and Electro)
6) No. 27 seed DISHONOURABLE DISCHARGE (Hector Gilbert has beaten Clustram, Suicidal Tendencies and 11th seed Chaos 2)
7) Newcomer ULTRAVERTER (Tom Roper has beaten 13th seed 259, 29th seed Slammer 2 and Battle Raptor)
8) PTT2 veteran SPINVERTER 3 (Tom Roper has beaten 31st seed Cassius 2, Snakebite Evolution and 15th seed Hypno Disc)
9) Newcomer MASS DISCTRUCTION ULTIMATE (Aaron Knight has beaten Vlad the Impaler, 32nd seed Firestorm 4 and 16th seed Behemoth)
10) No. 30 seed TORNADO (Karl Fletcher has beaten Axe-L-Bot X 2, Achilles and Flea 2.0)
11) No. 28 seed TENGU 4 (Alex Holt has beaten Kat 3, Blade Runner and 12th seed Wheely Big Cheese)
12) Newcomer THE CRASHING BORE (Frank Goacher has beaten 2 Bell & Back, Armageddon Mk 2 and 26th seed Flip-O-2)
13) No. 8 seed SON OF RIPPER 0.2 (Andy Jackson has beaten Robocake 2: The Upside-Down Cake, That Good R&D and Kan Opener)
14) PTT2 veteran HEIR TO BLACK PANTHER (Alex Holt has beaten Baird, 6th seed The Matador and Bad Cluster)
15) No. 4 seed RAZER (Martyn Forsyth has beaten BackSpin 2.0, Dragonfly and Supreme Glory Beta)
16) Newcomers THE TEAM THAT WASN€™T THERE (Hector Gilbert has beaten Charybdis, 18th seed Bigger Brother and 2nd seed SpunOut 3.0)
Although I am still to do the draws for Round 4 yet, I can tell you into which Semi our top 16 machines have been placed:
SEMI-FINAL 1
The Business Ends (1)
Disctruction: EVO
Beta (9)
UltraVerter
The Team That Wasn€™t There
Heir To Black Panther
The Crashing Bore
Tornado (30)
SEMI-FINAL 2
Platinum Pure Evil (3)
CrankShafted
Dishonourable Discharge (27)
SpinVerter 3
Razer (4)
Son of Ripper 0.2 (8)
Tengu 4 (28)
Mass Disctruction Ultimate
Draw up ASAP :)
We€™re now only 16 fights away from the PTT drawing to a close once again. With all our qualifier Heats now swept under the rug, it€™s time to face the FRA Firing Squad and ask...how wiz that, Jimmy? :proud: (roughly translated as €œHow are you finding the tournament€™s writing up until now?€Â) Pros, cons, the good times, the bad times, the top fights, the plop fights :proud: - ANY views on the tourney thus far will be more than welcome! :)
Thank you! :)
Fantastic stuff so far Steve-o :proud: I really cant ait for the semis! :proud::proud::proud:
Keep up the good work, and show us all why you won that best tourney award:)
Steve, this is a fantastic tourney, and you know it! :proud:
Robots I do not want to fight:
CrankShafted
MDU
Tengu V
SpinVerter 3
Son Of Ripper
Robot I want to destroy:
Razer (rematch from PTT2 :proud:)
Youre a wonderful audience, you really are! :)
Anyway, in amoungst Chemistry revision, I bring you the long-awaited PTT3 Semi-Final draws!
SEMI-FINAL 1
ROUND 1
Tornado (30) Vs UltraVerter
Beta (9) Vs The Crashing Bore
Disctruction EVO Vs The Business Ends (1)
Heir to Black Panther Vs The Team That Wasnt There
SEMI-FINAL 2
ROUND 1
Razer (4) Vs SpinVerter 3
CrankShafted Vs Mass Disctruction Ultimate
Son of Ripper 0.2 (8) Vs Tengu 4 (28)
Platinum Pure Evil (3) Vs Dishonourable Discharge (27)
The fights may not be posted for a while, but at least youll have plenty of time to add comments and tactics.
Thank you:)
OMG! *Grabs front row seat and hard hat :proud:*
Tournaments been great, Steven! No robots of mine in the semis, but theyve been upgraded and hopefully Ill have better luck next time! Here are some predictions:
Semifinal 1
Ultraverter flips Tornado OOTA
The Crashing Bore smashes up Beta
The Business Ends pits Disctruction Evo
The Team That Wasnt There overwhelms Heir To Black Panther
The Business Ends beats Ultraverter on a judges decision
The Crashing Bore smashes The Team That Wasnt There one by one
Semifinal 2
Spinverter 3 flips Razer OOTA
Mass Disctruction Ultimate takes out Crankshafted in a battle of the machines you have nightmares about
Son of Ripper flips Tengu IV OOTA
Platinum Pure Evil flips and slices Dishonourable Discharge
Mass Disctruction Ultimate smashes Spinverter 3 and wins on a judges decision
Son Of Ripper flips around and slices Platinum Pure Evil and wins on a judges decision
So that would be The Business Ends, The Crashing Bore, Mass Disctruction Ultimate and Son Of Ripper in the final. But thats just my opinion.
Just seen Daniels post - Ill come and join you! *throws away sign on seat saying Reserved For Craig Charles and sits down*
Meh, Ill do my predictions as well :proud:
SEMI-FINAL 1
Tornado (30) Vs UltraVerter: UltraVerter to flip Tornado OOTA.
Beta (9) Vs The Crashing Bore: Im gonna go for TCB here to grapple Betas axe and pit it.
Disctruction EVO Vs The Business Ends (1): Im going for Disctruction EVO to maul TBE.
Heir to Black Panther Vs The Team That Wasnt There: Due to the pushing ability of the freaky fivesome, Im gonna go for them to push HtBP into the pit.
SEMI-FINAL 2
Razer (4) Vs SpinVerter 3: Razer to get beaten easily.
CrankShafted Vs Mass Disctruction Ultimate: THE FIGHT EVERYONE WANTED TO SEE! Im gonna go for Aarons bot to destroy Toms MDU clone. :proud:
Son of Ripper 0.2 (8) Vs Tengu 4 (28): SoR to flip Tengu 4 OOTA after receiving and delivering a lot of damage.
TACTICS:
Platinum Pure Evil (3) Vs Dishonourable Discharge (27): Oh dear, not the best robot I wanted to fight. I cant flip it, so Ill use the rear disc to whack the wheels until one of them (hopefully) gets broken.
YAY! :proud: How long have I been waiting for this moment? :proud:
SEMI-FINAL 1
Oh dear, I can see poor old Torando going into orbit here :proud: I think it will be a quick victory for UltraVerter...
Hmmmmm, I think The Bore will be able to pull of a good win here, I cansee that drill going through the polycarb just now :proud:
Actually, we may say a fair fare-well to the champion here, but I cant pick this one...
Hmmmmm, hard to pick again, but I think TTTWT could pit HTBP here :)
SEMI-FINAL 2
I think Razer will find it hard crsuhing SpinVerters armour, plus it needs to get under the skirting first to get a clamp...
YAAAAAHOOOO!!! :proud::proud::proud::proud::proud: This may unfortuanetly be the only time they will fight, Im digging MDU to win here though, but it should be an absolute stunner!!!
Not to sure about this one, if PPE can safely slide under the middle drum then it could possibly toss it OOTA :)
Ill post my battles tactics and thoughts later on...
I dont normally do predictions but meh:)
Tornado could last long than everyones giving it credit for here. That low low wedge and good pushing power has gotten it past some skirts before... Still, Ultraverter to launch Tornado into orbit, where it bounces off the moon, lands behind UltraVerter and pushes it into the pit:proud:
...Seriously, UltraVerter to go throgh:wink:
Hmm, polycarb... Not the strongest material against impact weapons if memory serves, so I should be able to grapple on nicely. If I can just get under him, his electromagnet wont be able to stop me pushing him, so Ill grapple and shove him. Ill also try to damage his hammer shaft so he cant attack me effectively. But hey, if I lose Im going out to the ex-champ:)
Business Ends to get around DiscTruction EVOs sides and shove it around.
TTTWT to bully Heir into submission.
SEMI-FINAL 2
ROUND 1
Tom actually said once on MSN that Razer COULD get under him, so Ill go for Razer to do what Razer does best... Get in first and never let go:proud:
Crankshafted and MDU destroy each other on first contact. Neither can continue so they get replaced with Behemoth and Biohazard:proud:
Behemoth vs Biohazard
I reckon Behemoth can get under the skirts, but Biohazard to win, and win with style.
Son of Ripper to exploit Tengu 4s self righting problems.
Platinum Pure Evil losing to Dishonourable Discharge after a very close battle.
*is seen leaving building when semi 2, round 1, fight 2 is taking place*
May we say goodbye to the house robots and the arena for this fight :)
Other predictions asap
Uncle Daves Presents
PTT3 Semi Final Predictions
SEMI-FINAL 1
ROUND 1
The question, what weapon for Tornado? If its the scoop it will push UltraVerter into the pit before you can blink.
May we say goodbye to the PTT1 champion here. The Bore to remove the axe and flip it onto its end.
The Business Ends to put Disctruction Evo into the pit.
Heir to Black Panther can not do anything to this 5 way clusterbot. I predict there will be some more 5 way clusters coming soon, so I must say Fiver is old.
SEMI-FINAL 2
ROUND 1
Razer to get underneath those useless skirts and crush and pit.
Steve, do you want to use the FAR arena for the fight of the 2 powerful spinners. But the gyrosopic forces on impact will basically destroy both robots, and so it will be 1 hit killers. Both robots to go out to be replaced by *drum roll* Wedge 1 and SFM 4 :)
Ta ta Son of Ripper 0.2. Bin bags are located here * points to a roll of bin bags hanging up by that hidden house robot* Tengu 4 to hit and remove those wheels.
Dishonourable Discharge is a drum robot. How many wheels left on Platinum Pure Evil? *Looks in pit* 0 wheels on my robot :)
It has too get through the 4mm thick Hardox wheel guards first dave :)
SEMI-FINAL 1
ROUND 1
-after a pushing match between the two tornado to have a meating with mr.camera track
Beta to be smacked and itted
I think in a close fight we will be needing a new champion
The team that wasnt there to bully and push heir to black panther into the pit
SEMI-FINAL 2
ROUND 1
Humm. Slide under the skirts crush it hit the pit release and drop spin verter in it
Erm a big bang as the two connect with mdu just suriving and going through
Son of ripper to flip tengu out of the arena.
The axle bots going to need to put its wheels back on after this
Basically what will happen when CS and MDU meet will be a loud bang, the generated energy will be in the area of 1 MJ to each robot, and that energy will blow apart both robots, and basically create a huge hole in the floor, in which both robots will fall and because MDU has petrol on board a giant fireball will come up and kill sir killalot :)
To quote someone
That robot came in a traller, now you can put it in your glove box
mmmm, I like the predictions :proud:
Im fairly confident in this battle, main tactic, get in early and attack CS before it has a chance to get to max power and Ill try to break him before I break both of us :proud:
Ive wanted this grudge match to happen for a while!
pss, before you go off and kill each other.
Kill the house robots, two deadly spinners in the arena, the house robots are easy targets :)
Ill kill the house robots after Ive scattered enough parts of CS around :)
They are GOING to kill each other. Tom will of course keep Crankshafted away from MDU until hes spinning up fully, and both you and Tom assure us the robots inevitably kill with one hit... do you see?:lame:
I think MDU will survive mainly on its pure design of having a spinning mass as armour :)
Im hoping to use my slightly heavier weapon and powerful turbine to attack first and damage his weapon early, but if it comes to death blows, the extra weight should help my weapon as the strength is higher.
Thanks a squillion once more, guys! :) ...now who wants some fights? :proud:
This day has been anticipated since the War began, but it€™s finally here...the first Semi-Final of PTT3!!! :proud:
First up today, former UK champion and No.30 seed Tornado take on the fearsome newcomer UltraVerter! The current RW king justified its title win by pitting Axe-L-Bot X 2, Achilles AND Flea 2.0! But UltraVerter has just as impressive a record, flipping 13th seed 259 and send 29th seed Slammer 2 and Battle Raptor out of the arena! Will the Tornado be blown the same way or will UltraVerter€™s world be turned upside-down?
Next up, we see a Clash of Kings - PTT1 champ and No.9 seed Beta against PTT newcomer and NSBFL2 champ The Crashing Bore! The series one champion happily hammered past Dervish Mach 2, Junkyard Maw and Electro to make its 3rd Semi-Final, but Frank Goacher€™s prove his worth as well, defeating 2 Bell & Back, Armageddon Mk 2 and 26th seed Flip-O-2! One of these kings will be dethroned and the other will rule supreme - which one it€™ll be is anyone€™s guess!
After that, we welcome back another champion - our current PTT magistrate and No.1 seed The Business Ends, who will be clashing with newcomer Disctruction EVO! After rising (or should that be €œlifting€Â) to the top of PTT2, Hector€™s machine returned to defend its title on fine form, defeating Dantomkia, AWOL and Stratus 2! But Disctruction made a powerful impact in its Heat by defeating Turbo Falcon, 21st seed Double Killa and (most surprisingly) the No.5 seed Voltronic! Whatever happens when these bots get down to business, disctruction is guaranteed!
Finally this not-so-merry morn, we have our first Semi conflict between two unseeded machines - PTT2 veteran Heir to Black Panther and PTT newcomer(s) The Team That Wasn€™t There! Slashed out of Round 2 last season, the Panther€™s return sparked more of this season€™s shocks, giving the knockout blow to Baird, 6th seed The Matador and Bad Cluster! However, the Team has proved the biggest surprise of the War thus far, pitting Charybdis, 18th seed Bigger Brother and 2nd seed SpunOut 3.0, the highest seed casualty of the season up €˜til now! A panther against 5 little terriers...that€™s animal cruelty, surely?!
But enough of zis! Gloom and glory await...for whom, we shall find out... :proud:
SEMI-FINAL 1
ROUND 1
BATTLE 1
TORNADO (30) Vs ULTRAVERTER
Tornado was entered by Karl Fletcher and is armed with interchangeable weaponry. Its an extremely powerful 4WD box, can run upside-down and is currently the Robot Wars UK champion!
IN PTT1 (S5 version): it was immobilized by Matilda in Round 2 of the Semi-Finals against Peligro
IN PTT2 (S5 version): it lost in Round 2 to Bigger Brother on a judges decision
(S6 version): it was flipped out of the arena in Round 1 by Pure Evil!
SEEDING: 30th
PTT3 HIT LIST: pitted one half of Axe-L-Bot X 2, pitted Achilles and pitted Flea 2.0
UltraVerter was entered by Tom Roper and is armed with a flipping arm on top of the robot. It€™s a low square box with skirting all round, runs on 6 inner wheels and the flipper has nearly twice the power of Wheely Big Cheese!
IN PTT1: did not compete
IN PTT2: did not compete
PTT3 HIT LIST: flipped over No.13 seed 259, sent No.29 seed Slammer 2 out of the arena and sent Battle Raptor over the fence as well
Today, Tornado will use the good ol€™ scoop - and will also release some air from the tyres to make the machine that little bit lower (just like in the Ex 2 Challenge Belt fight against Terrorhurtz)
House Robots- Matilda and Shunt
3...2...1...
ACTIVATE!!!!!!!!!!
Both machines get off to a nippy start!! The two wedges collide in the arena centre and a little pushing match seems to have gotten underway!! The initial shove gives Tornado a nice thrust against its enemy, but with two more wheels, UltraVerter pushes back and slams the No.30 seed smack-bang into the arena wall!! This ram sends the UK champion sliding up the front wedge of the PTT newcomer!! Tom prepares to fire the devastating flipper, but Karl finds that Tornado still has traction on the newbie€™s sloped front!! With the gas going as hard as it can, the PTT veteran darts off the wedge and shoots off back to the arena centre, just as the powerful flipper fires!! Retracting the arm in the blink of an eye, Tom backs his machine away from the barrier...but as he does, Tornado shoots into the newcomer€™s rear, wedge-to-wedge, and successfully slams the conqueror of 259 into the wall!! However, this slam has caused the No.30 seed to slide up onto the arm again!! Karl tries backing his machine away again, but proves too late!! The arm fires...and Tornado rockets into the air spinning like a Catherine Wheel!!! With the speed and height it€™s flying at, it seems more of a cannon than a contestant at the moment!!! Fearing the worst, Karl hands down the controls...then picks them back up in a mad dash when he sees that Tornado has landed back on the right side of the wall, a bare few feet away from crashing out!!! Delighted at staying in the ring, Karl guides the No.30 seed away from another attack, although the hard landing has made Tornado€™s responses pretty slow!! Swirling round again, UltraVerter heads after the UK champ once more, as it trundles into the Pit Release Button!! However, as Tornado swings round to try and get wedge-to-wedge with Tom€™s machine again, the PTT newcomer ploughs under the No.30 seed as it bares its side and slams it into the arena wall!!! Back underneath again, Tom fires the flipper...Tornado is flung over the wall, smacks off the protective Plexyglass screen, smashes off the edge of the arena fence and lands with a hard crash onto the camera track!!!
CEASE!!!!!
Tornado goes from raging wind to broken wind! The No.30 seed gets blown around and breezes out the arena!
ULTRAVERTER GOES THROUGH TO ROUND 2!!!
SEMI-FINAL 1
ROUND 1
BATTLE 2
BETA (9) Vs THE CRASHING BORE
Beta was entered by Karl Fletcher and is armed with a powerful double-headed 36V Etek driven electric axe. It has a wedge at the front, back and sides and was created by UK competitors Team Hurtz for Battlebots.
IN PTT1: it became the champ, pitting Hypno Disc in the Final!
IN PTT2: it lost a judges decision in Round 1 of the Semi-Finals to Pure Evil
SEEDING: 9th
PTT3 HIT LIST: helped to pit Dervish Mach 2, beat Junkyard Maw on a 31-19 judges decision and pitted Electro
The Crashing Bore was entered by Frank Goacher and is armed with a front Mousetrap-style guillotine (which can actually cause damage) and a front extending drill. Its a box-wedge shape and has 2 Hypno Disc-style srimechs
PTT3 HIT LIST: jammed 2 Bell & Back€™s flipper before it was overturned, beat Armageddon Mk 2 on a 28-25 judges decision and beat No.26 seed Flip-O-2 on a 28-22 judges decision
House Robots- Mr Psycho and Sgt Bash
3...2...1...
ACTIVATE!!!!!!!!!!
For this bout, the Crashing Bore gets the nippier start and uses its greater speed to trundle around to the side of Beta in an attempt to get underneath!! Although the electromagnets are pretty much useless on a wooden floor :proud:, the low wedged sides of the No.9 seed are still proving a challenge for Frank€™s machine to slip under!! Finding this to time-consuming and noticing that Beta is turning for a hammer blow, the Bore fires the guillotine and gets a whack in first!!! The blade smacks down on the polycarbonate and puts a nice indent into the ex-champion€™s outer shell!!! But although the Bore now has a good grip on Beta, the No.9 seed has successfully managed to swing round and face its rival...and down comes the axe!!! Again and again, the hammer bashes down on the Bore€™s 6 mil titanium shell, as the PTT newcomer starts shoving the No.9 seed down the arena...towards Mr Psycho€™s CPZ!!! Upon approaching the corner of the arena, the Bore retracts the guillotine and deftly shoves Beta deeper into the House Robot€™s lair!! Nursing the several blows added to its armour, the PTT newcomer backs away, as Mr Psycho closes in on the former champion!!! Karl fires up the axe again, hammering at thin air!! The House Robot trundles closer, pushes the No.9 seed further into his domain...and smacks the hammer down on the PTT1 champ€™s top...causing barely any damage!!! Being the brute that he is, Mr P hasn€™t realised just how robust this year€™s Semi-Finalists are - or that Beta has slipped right past him and back into the arena!!! :proud: Meeting the Bore back in the centre of the ring, Karl steers his second Semi-Finalist past the PTT newcomer, trying to swing into the side and hammer the top there!! However, the slightly nippier Bore also twirls round, just as Beta fires its axe (putting another nice dent in the newbie)!! Frank fires the guillotine...and locks onto the axe-head!!! Karl tries shaking the blade off by attempting to fire the axe - but the pressure from that mighty mousetrap is keeping the hammer firmly down!!! The former champion can€™t get free...and Frank has an idea of what to do with it!!! Putting his machine into reverse, Frank guides the Bore down the arena, with Beta being dragged along with it!!! Despite the occasion stutter from the No.9 seed trying to pull itself free, the run goes steadily in Franky€™s eyes...and contemplates this as the Bore gently nudges into the Pit Release Button!!! The newcomer turns to face the abyss, but a tug from the No.9 seed sends the Bore sharply off course!! Keeping concentrated, Frank steers his machine (and the pinned former champ) back in the right direction - over to the Pit!!! The No.9 seed desperately tries to yank itself free as the crater looms nearer!! But, with the superior traction, the Bore slides past the Pit edge...dragging Beta into the great abyss in the process!!!
CEASE!!!!!
From Beta to worse! The No.9 seed is dragged out the contest and goes straight back to Step Alpha! :proud:
THE CRASHING BORE GOES THROUGH TO ROUND 2!!!
SEMI-FINAL 1
ROUND 1
BATTLE 3
DISCTRUCTION EVO Vs THE BUSINESS ENDS (1)
Disctruction EVO was entered by Aaron Knight and is armed with a large front vertical flywheel and rear bottom-hinged flipper. Its a box shape with a rear wedge and runs on 8 inner legs
IN PTT1: did not enter
IN PTT2: did not enter
PTT3 HIT LIST: helped to pit Turbo Falcon, wrecked both parts of No.21 seed Double Killa and immobilized No.5 seed Voltronic
The Business Ends was entered by Hector Gilbert and is armed with a motorized 180 degree axe with a scoop attachment at the back (like Sallad from Battlebots), a rear wedge and a front Killerhurtz-style ram. Its a truncated triangular prism with skirts and has car steering
IN PTT2: it became the PTT champion, after propping fellow newcomer SpunOut against the arena wall in the Final!
SEEDING: 1st
PTT3 HIT LIST: helped to immobilize Dantomkia, beat AWOL on a 30-23 judges decision and immobilized Stratus 2
House Robots- Growler and Dead Metal
3...2...1...
ACTIVATE!!!!!!!!!!
As the faster of the two machines, The Business Ends gets the quicker start!! The reigning champion dashes around to the side of Disctruction EVO€™s side and gives the PTT newcomer a quick jab from the electric axe!! However, the front flywheel of the Heat C winner has already begun whirling up - and Aaron decides to demonstrate its deadliness by turning the walker disc-first into The Business Ends€™ side!! The blades of the spinner slice into the No.1 seed and even manage to make the machine jump a bit off the ground for a second!! With a rather gruesome slice down one side of his machine, Hector quickly guides The Business Ends across the arena, with Disctruction in hot pursuit!! Suddenly, though, the reigning champion shifts into reverse and shoots backwards, round in an arc...and smack-bang into Disctruction€™s side!!! With the rear little scoop underneath the box-wedge, the axe activates and, combined with a smart push backwards, Hector has made Aaron€™s machine topple onto its back...but not for long!!! No sooner has The Business Ends whirled round to bring the axe into play, then Aaron fires the rear flipper and flicks his walker back onto its wheels!! Back right-side-up and with the disc already trying to get back to full swing, Disctruction twirls round to try and give The Business Ends another smack, but the No.1 seed has already shot away and released the Pit!!! With the siren echoing across the arena, Aaron€™s walker scuttles across the arena and successfully clips the side of the reigning champion as it shoots past to try and dodge any blows!! With another scar to be content with, Hector puts his machine back into reverse and swings back underneath Disctruction€™s side, nearly suffering a third slice in the armour in the process!! With the scoop back underneath, the axe activates, the champ reverses and the newcomer falls over a second time!! With Disctruction topsy-turvy again, The Business Ends swings back round and, just as the flipper fires to swing the walker back over, Hector activates the axe...and grapples onto Disctruction€™s underbelly!!! The walker€™s not righting anywhere with the champ pinning it down!! Retracting the flipper, Aaron prepares to try again, as the underbelly takes more bashes from the electric hammer!!! Suddenly, the flipper fires again and, this time, the Heat C winner is toppled back onto its legs!!! Infuriated at this onslaught, Aaron revs the flywheel back up again!!! The Business Ends darts away, but, at 15mph, Disctruction isn€™t too far behind!! Deciding on another attack, the No.1 seed abruptly gets into reverse and, in a wide arc, prepares to slip under the PTT newcomer a third time!! However, as the champ gets nearer, Aaron turns Disctruction round to face The Business Ends...and gives the No.1 seed a rearful of disc!!! The reigning champion hops before a second blow from the flywheel is struck, this time on the side!!! Realising its danger, the disfigured Business Ends dashes away, Disctruction not too far behind!! Suddenly, Hector puts €œreverse€ on again, darts back to the side of Aaron€™s entry, performs a neat and sharp 180 turn and smacks the top of the PTT newcomer, almost receiving another attack from the flywheel!! Keeping a grip on the walker, Hector decides to use the limited traction of Disctruction to his advantage!! Keeping the axe pinning down the newcomer, The Business Ends starts shoving the walking wonder up the arena...right up to Growler€™s CPZ!!! Slipping Disctruction right into the corner, the champ shoots away - just as the House Robot crashes into the side of the mighty walker, smacking it against the wall in the process!!! Although the innards have been given a right good shaking, Aaron€™s entry still seems fully operational - even the 5 mil Hardox armour only has a slight bash to it!!! Quickly scuttling back into the arena as Growler tries to grapple the flywheel, Disctruction returns to challenge The Business Ends...who promptly greets the newcomer by darting over and sliding the rear scoop back underneath the side of the machine!!! The axe activates, the champ reverses and the newbie is back on its back!!!
10...9...8...7...
The No.1 seed twirls back round to get the axe back in action, but Disctruction has already managed to right itself with the flipper!!!
...6...5...4...
Noticing the flywheel is quickly revving back up again, The Business Ends darts away from the newcomer...but not before taking one last blow to the side armour!!!
...3...2...1...
CEASE!!!!!
With one last clip to the champ€™s side, the fight draws to a close. With both Semi-Finalists still on the go, we€™ll need to see the judges for a decision. Will The Business Ends meet its end - or will Disctruction become disc-content? This could very well decide the fate of the crown, so let€™s get a result...
Style (/10): D:EVO=6 TBE(1)=7
Control (/10): D:EVO=7 TBE(1)=8
Damage (/10): D:EVO=8 TBE(1)=6
Aggression (/10): D:EVO=7 TBE(1)=8
TOTAL (/40): D:EVO=28 TBE(1)=29
The decision has come through...you know the criteria by this stage...the fate of the champion hangs in the balance on 1 single point...but there won€™t be any anarchy today! They€™ve gone for The Business Ends!
THE BUSINESS ENDS (1) GOES THROUGH TO ROUND 2!!!
SEMI-FINAL 1
ROUND 1
BATTLE 4
HEIR TO BLACK PANTHER Vs THE TEAM THAT WASN€™T THERE
Heir to Black Panther was entered by Alex Holt and is armed with a pneumatic Mortis-style axe and front lifting plate. The robot is a box with a wedge on all 4 sides and runs on 2 inner wheels
IN PTT2 (as Black Panther): it was pitted in Round 2 by Return of Krazy Baby
PTT3 HIT LIST: beat Baird on a 26-23 judges decision, grappled and pitted No.6 seed The Matador and grappled and pitted one half of Bad Cluster
The Team That Wasn€™t There was entered by Hector Gilbert and is a 5-way clusterbot. Each segment is a 4WD invertible box with a front and inverted rear wedge, a ridge at the top of each wedge for snagging other bots and enough pushing power to tackle a 100kg heavyweight!
PTT3 HIT LIST: two segments pitted Charybdis, three segments pitted No.18 seed Bigger Brother and one segment pitted No.2 seed SpunOut 3.0
House Robots- Sir Killalot and Matilda
3...2...1...
ACTIVATE!!!!!!!!!!
Right from the off, the Team That Wasn€™t There quickly starts to split up, but the much quicker Heir to Black Panther simply charges right towards the separating segments and ramming into the side of one of the quintuplets!! Alex fires the axe and brings the Mortis-style blade down on top of the segment he chose to attack!! The Team member tries to get away as its companions approach also, but HTBP has simply darted backwards down the arena, outrunning its Lightweight opponents and dragging the side-on cluster piece along with it!! The four remaining Team members try to catch up, but too late - HTBP has nudged into the Pit Release Button!!! Just as the siren starts to echo round the ring, the trapped Team member tries to pull itself away, but HTBP still has a firm grip on it with the pneumatic axe!! With the remaining members in hot pursuit, the PTT veteran darts forward, shoving the pinned Lightweight along with it!! The four members narrowly miss their target as HTBP shoots over to the Pit, releases its grip on the struggling Lightweight...and allows it to plummet to the depths of the arena!!! 1 down, 2 to go!!! Angered at the loss of its team-mate, one segment darts over to HTBP...who promptly swirls past the cluster piece and nearly gets it to Pit itself!!! The PTT veteran€™s great manoeuvrability and speed are really coming in useful here!! With another quick dodge after another segment tries a ram attack, HTBP zips back to the arena centre and twirls round to head on the attack...only to go head-on with one of the four remaining members and get shoved across the arena into the fence at the top of the ring - but not before putting two nice little holes in the 1 mil Lexan top of the machine!!! Just as the little Lightweight tries a second ram, HTBP pulls away from the cluster piece€™s line of fire, twirls round and smacks into the little machine€™s side!!! With another fire of the axe, a third hole is punched through the top plate...just as the other three pieces shoot over for a crack at the veteran!!! Sharply turning towards the Pit, Alex piles on the petrol (so to speak) and darts across the arena, the pinned and writhing Team member in front!! Although HTBP is successfully outrunning the other members, the piece he has grappled onto is proving a tough customer!! With the Pit edge barely a few feet away, the Lightweight tries to break away - but ends up simply pulling the PTT veteran round to get its rear facing the Pit!!! With the other Team members closing in, HTBP quickly whirls back round and, with one last shove, gives Alex his second cluster kill of the fight!!! Only one more to dispose of and he€™s through to Round 2...but the last three pieces has finally caught up!!! One gives HTBP a sharp blow to the side, nearly sending it down the crater there and then!! With a sharp dodge, the PTT veteran narrowly misses a second shove from the second segment (who nearly suffers from suicide :proud:) and a quick little dash backwards, Alex avoids a third Pitting attempt from the third member!! As the other Lightweights reform for another attack, HTBP seizes its chance!! The PTT veteran rockets forwards and crashes into two of the surviving pieces!!! With one spun right round on impact, Alex guides the front wedge of his machine underneath its inverted wedge, axes the lid and moves forward with a small burst!!! The axe retracts...the other two Team members shoot forwards...HTBP gets a powerful shove from the rear...and topples into the Pit...on top of Team Member No.3!!! Alex breathes a mighty sigh of relief - before breaking into cheers of delight!!!
With 3/5 pieces in the Pit, 5/5 pieces are out the contest! Looks like the Team That Wasn€™t There won€™t be having a reunion for quite a while now!
HEIR TO BLACK PANTHER GOES THROUGH TO ROUND 2!!!
Typical, innit? You wait ages for a Semi-Final fight, then suddenly, FOUR turn up at once! :proud:
SEMI-FINAL 1
ROUND 2 LINE-UP
Heir to Black Panther Vs UltraVerter
The Business Ends (1) Vs The Crashing Bore
Thoughts? Tactics? What did you think of Round 1?
Thank you! :)
Predictions!
Heir to Black Panther Vs UltraVerter: Sorry Alex, but Im gonna have to go with UltraVerter here to flip ya clean OOTA.
The Business Ends (1) Vs The Crashing Bore: Ooh, a very close fight, in my honest opinion. I think The Business Ends might be able to flip The Crashing Bore over, and push it into the pit, but if TCB can get a hold on TBE, then we might be looking for a new champion.
Awesome battles as ever Steve-o! :proud:
No offence to Alex or Steve here, but I havnt got a clue how this robot has made it this far! :proud: Ill take UltraVerter to catpult it out very quickly...
Difficult one, but I surpose the champion will go through here...itll be close though! :)
Wooooooooot:proud: Great writing Stevenator:)
Heir vs Ultraverter:
Sorry Alex but Im going with everyone else on this one... Heir to be thrown OOTA.
Crashing Bore vs Business Ends
Great... Just great. Having somehow dropped the former champ I get lumbered with the current one:lame: ...Incidentally I think this is the first time Ive run up against one of Hectors creations.
Anyways, pressing on... Car steering on TBE means Ill have better manoverability in close quarters, so Ill rush in and try to keep close throughout the match. Ill concentrate my gillotein blows in the centre of his machine so I should hopefully break or bend his arm out of use.
Im not sure what his armour is so I dont know if I can latch onto him or not, but if I get the chance to get under him hes going either into a painful house robot or down the pit:)
Great battle and I lost with just reasons too :) I enjoyed reading that battle and Id like to say congrats to Hector with TBEs win, good use of technique using my weakness of lack of traction in the DE design, well done.
I think I am going to have to agree with them myself, HtBP is only effective against certain types of opponents and skirted rambots are not one of them, I only beat most things because I can outmanouver them and use the weapon combo, the only thing I can go here is hit and run yet again, using the axe as its skirted, I suppose if I hit it for long enough I may just do something, but from here it looks like a dead end...
However on the outlook this gives me a worst position of eigth, and the quality of my opponent means that it could well be higher.
Great writing, Steven! I predict that Ultraverter will beat HTBP, and The Business Ends will beat The Crashing Bore if its fast enough to get to the rear, otherwise TCB could pull off a shock.
Umpteen thanks once more, guys! :) Now, I give thee the Pyramid Pummelling and the Clash of Kings II - aka the search for our first 2 Finalists... :)
SEMI-FINAL 1
ROUND 2
BATTLE 1
HEIR TO BLACK PANTHER Vs ULTRAVERTER
House Robots- Shunt and Mr Psycho
3...2...1...
ACTIVATE!!!!!!!!!!
Both robots meet in the arena centre!! Heir to Black Panther tries to manoeuvre round to UltraVerter€™s side for an axe attack, but the Aussie pyramid simply slams into the turning veteran and slips one of the skirts underneath Alex€™s machine!! Fortunately, HTBP isn€™t far enough up the front to meet the flipper arm, but Tom€™s about to change that!! Sending UltraVerter into full-on charge, the PTT newcomer shoots across the arena and bashes Alex€™s entry right into the arena wall!! Good news for Tom this time - the force of the blow has knocked HTBP right onto the edge of the flipper...a prime target!! The mighty arm fires...and the PTT veteran is flung straight up into the air!!! 5ft...8ft...11ft...this is really getting scary now!!! After reaching at least 13ft (and after the axe gives a random smack to the surrounding air molecules :proud:), HTBP starts to fall!!! Down...down...down...upside-down and right behind UltraVerter!!! Quickly, Alex fires the hammer and rights the bot almost instantly...back onto the side of Tom€™s machine!!! Noticing his penultimate survivor still has traction on the lethal box€™s rear skirt, Alex gets the Heir to shoot off the rear of UltraVerter, just short of getting another trip to the stratosphere!!! The veteran still lives, although control response seems a bit shaky now!! With the PTT newcomer not far behind, the fleeing HTBP darts across the arena and smacks into the Pit Release Button!!! Just as Alex€™s machine heads back to the arena centre, UltraVerter swoops in for another ram attack - but the Heir€™s great manoeuvrability allows it to dodge the attack!! However, as the veteran swings past Tom€™s machine, the PTT newcomer swings into reverse!! HTBP receives a clip to the side from this next attempted ram and, before Alex could respond, UltraVerter swung round and ploughs right under the Cluster Conqueror!! The Heir€™s axe slams down, but fails to make contact with the top of the Aussie entry!! With another ram, HTBP scrapes further up the skirted side!! Continuing its dash across the ring, UltraVerter€™s flipper fires...and due to the angle, and being at the edge of the flipper, the PTT veteran is flung right across the arena like a missile...and smashes against the wall with an almighty clatter!!! UltraVerter zips over to examine its prey!! The Heir remains alive, but the controls are twitchier than ever!!! Taking advantage of this lack of proper control, Tom rams HTBP back into the wall!! Thanks to this latest blow, the veteran is now finding itself perched on top of UltraVerter, who in turn is jammed right against the arena wall!!! Tom fires the flipper...the Heir soars upwards, at least 15ft...begins to plunge towards the arena wall...and breaks a segment of the fence clean in two before toppling backwards onto the camera track!!! Alex plays Hydra to Tom€™s Gravity and soars out of the contest!!!
CEASE!!!!!
The Heir has been dethroned! Heir to Black Panther loses by a lot more than a whisker!
ULTRAVERTER GOES THROUGH TO THE GRAND FINAL!!!
SEMI-FINAL 1
ROUND 2
BATTLE 2
THE BUSINESS ENDS (1) Vs THE CRASHING BORE
House Robots- Sgt Bash and Growler
3...2...1...
ACTIVATE!!!!!!!!!!
Once more, The Business Ends starts off as the quicker machine!! The No.1 seed dashes over to the side of the Crashing Bore and begins hammering the 6 mil titanium lid of the NSBFL2 champion!! Angered, Frank fires the guillotine, but only succeeds in brushing the axe off of the top of the machine!! Just as the Business Ends prepares for another barrage of blows, the Bore twirls round and gives the reigning champion a good hard shove as it retracts its blade!! Thankfully for Hector, the low skirting has managed to keep the Bore from sliding underneath - however, Frank€™s machine is far from downtrodden, as the NSBFL2 champion activates the guillotine...and slams down onto The Business Ends€™ top armour!! A few centimetres closer and the flipper/axe arm could have been the victim of that attack!! With the blade retracting, the reigning champion takes this opportunity to dash away from the Bore and zips to the bottom of the ring to activate the Pit Release Button!! Just as Frank€™s machine makes it over to the now rather battered Pit Tyre, he notices The Business Ends flash back across the arena!! Growing rather tired of this chasing, the Bore resumes its pursuit...when the reigning champion suddenly halts!! Hector swings into reverse and the No.1 seed speeds backward with an arc-like manoeuvre - right into the side of the Bore!!! The small rear scoop slots under the side of the box wedge and Hector fires the arm!! With the aid of a nice backwards shove, The Business Ends succeeds in sending the NSBFL2 champion onto its back!! Almost instantaneously, however, the Bore€™s €˜mousetrap€™ fires and springs the PTT newcomer back onto its back!! The No.1 seed starts manoeuvring for another attack, when Frank€™s last entry swings round, fires the guillotine and puts another bash in the top plating of the reigning champion!!! As the Bore retracts the blade, The Business Ends swings right round and slots the rear scoop under the NSBFL2 champion€™s side a second time!! With another €œflip-and-push€ technique, the Bore is once again on its back - only to hop back onto its wheels, thanks to the high-powered €˜trap!! After quickly dodging another attack from the blade, the No.1 seed tries a different tactic!! Zipping away from its rival once more (and with the Bore back in pursuit), the reigning champion suddenly twirls right round, performs another arc-like turn into the NSBFL2 champion€™s side and starts shoving the PTT newcomer with its front ram to the bottom end of the arena...towards the Pit!!! With the edge getting nearer, Frank suddenly fires the guillotine!! The blade hits the wooden floor with a mighty €œthump€Â...and anchors the Bore onto the arena a few feet away from the Pit edge!!! With another shove, The Business Ends manages to nudge the €˜mousetrap€™ free from the arena floor, but this just allows the Bore to retract the blade, twirl into the No.1 seed€™s side and bash the lid of the reigning champion once more!!! Now nursing another slice in its top, The Business Ends gives another arc-like manoeuvre round into the Bore€™s side and a further fire of the axe/flipper sends the NSBFL2 champion toppling onto its back!! With its latest scheme underway, the No.1 seed zips to the rear of the inverted newcomer, just as the Bore self-rights with the guillotine...right onto the top of the reigning champion!!! Frank tries to get his machine back onto the arena floor, but The Business Ends simply dashes forward a few feet, fires the axe...and flicks the world€™s first vapourbot into the Pit!!!
CEASE!!!!!
The Crashing Bore suffers a crushing defeat! However, I doubt the oldest vapour€™ will be pensioned off just yet! :)
THE BUSINESS ENDS (1) GOES THROUGH TO THE GRAND FINAL!!!
And so we have our first 2 Grand Finalists!
- Newcomer ULTRAVERTER, with Tom Roper
- No.1 seed THE BUSINESS ENDS, with Hector Gilbert
Congrats to both our Finalists :proud: and a jolly good pat on the back for the other six Semi-Finalists :) So near, and yet so far...hope PTT4 can take you all that little bit further :)
LATER ON:
SEMI-FINAL 2
ROUND 1
Thoughts? Tactics? How did Semi 1 go down?
Thank you :)
Awesome stuff as ever Mr Steve! :proud:
This should be a nice battle in my opinion :) Alex hasnt really got any tactics to use againt me, and there is nowhere it can cause serious damage. So Ill just aim to slide under and toss it over, that SRIMECH is fairly unreliable. Once over Ill just try to push it to the wall and flick it OOTA, only one person doubts that I can do this so far...Also, another option is to run around and make Tengu 4 spin up and spin up my blade and then hit it, those teeth should hit the ground and send it spinning away madly. If he refuses to spin the body, its an easy target for the flipper. Baisically either bash it off course and send it into a mad spin or just launch it OOTA :)
Semi Final: Heat 1 was....
Fantastic
Awesome
First-Rate
Outstanding
Superb
Smashing
Excellent
Esquisite
Wicked
Wonderful
Worthy
and in the words of the great philosopher himself, Barney the Dinosaur: SUPER-DE-DUPER!
It would have gone down better with a large serving of fries and a coke :proud:
Once more, cheers to you all! :) And now, more fights awaiteth! :proud:
Last time, we saw Aussie newbie UltraVerter and reigning champion The Business Ends storm into the Grand Final. Today, we€™ll find out who joins them as we begin our second Semi-Final! :proud:
First up today, we have a true battle of the Giants- No.4 seed and twice RW World Champion Razer against one of the most feared vapourbots devised by Aussiekind, SpinVerter 3! The No.4 seed made very good use of the Pit in its Heat, sending BackSpin 2.0, Dragonfly AND Supreme Glory Beta all down that infamous black hole! But SpinVerter has proved just as capable of using the arena to its advantage, sending 31st seed Cassius 2 out the ring, pitting Snakebite Evolution and ejecting 15th seed Hypno Disc onto the camera track! One thing is certain in this Commonwealth clash - going for the Queen instead of the other bot is NOT an option! :proud:
Next up is one of the most anticipated battles of the War thus far...as the one-hit wonders CrankShafted and Mass Disctruction Ultimate finally square up against each other! Both spinners have taken out some of the top machines around - Tom€™s walker KO-ed RW New Blood champ Storm 2, 23rd seed Thermidor 2 and 7th seed Biohazard, while Aaron€™s walker KO-ed former Battlebots champ Vlad the Impaler, 32nd seed Firestorm 4 and 16th seed Behemoth! Both robots similar in design, both capable of unspeakable chaos...better get the spare stadium ready, Boabby! :proud:
After that, flipper and spinner meets full-body spinner, as No.8 seed Son of Ripper 0.2 takes on No.28 seed Tengu 4! Having reached the Top 8 last time around, Andy is hoping he can make it that little bit further, having already pitted Robocake 2: The Upside-Down Cake, propping That Good R&D against the wall and flicking Kan Opener out of the arena! But Tengu has already proven itself as quite the menace, after obliterating Kat 3, immobilizing Blade Runner and slashing up 12th seed Wheely Big Cheese! Two rippers will enter...two rippers will leave...well, one will be in a bin bag, anyway. :proud:
Finally today, last season€™s bronze medallist and No.3 seed Platinum Pure Evil locks horns (or should that be blades?) with No.27 seed Dishonourable Discharge! Danny had a rather tricky time getting through his Heat, flipping Big Fred out of the ring, immobilizing Pyro II and VERY narrowly beating The Robot That Wasn€™t There on a 28-27 judges decision! However, Dis Dis had quite a fun time in its Heat, ripping up one part of Clustram, Suicidal Tendencies and 11th seed Chaos 2! Hector is looking to avenge TRTWT - and where better to do that then here? :proud:
But that€™s quite enough of that! We€™re 6 fights away from finally filling the Final! So let€™s get a-crackin€™! :proud:
SEMI-FINAL 2
ROUND 1
BATTLE 1
RAZER (4) Vs SPINVERTER 3
Razer was entered by Martyn Forsyth and is armed with a ferocious crushing claw, squeezing at 3 tonnes of pressure! It has a front scoop that can get under almost anything, it has self-righting wings and is twice the Robot Wars World Champion!
IN PTT1: it was propped against the wall in Round 3 by Voltronic
IN PTT2: it lost a 31-25 judges decision against The Business Ends in its Grand Final Eliminator, before being flipped out the ring by Pure Evil
SEEDING: 4th
PTT3 HIT LIST: helped pit BackSpin 2.0, pitted Dragonfly and pitted Supreme Glory Beta
SpinVerter 3 was entered by Tom Roper and is armed with a rear-hinged flipping arm, equal in power to Wheely Big Cheese! It€™s a low box with uber-skirts and a rear wedge, runs on 6WD and is armoured with titanium/vanadium and Lexan
IN PTT2 (as SpinVerter Version Beta - I think): it was pitted in Round 2 by Voltronic after it slid under the hastily-repaired rear wedge
PTT3 HIT LIST: flipped No.31 seed Cassius 2 out of the arena, pitted Snakebite Evolution and threw No.15 seed Hypno Disc out the ring
House Robots- Sgt Bash and Shunt
3...2...1...
ACTIVATE!!!!!!!!!!
At nearly twice the speed of its opponent, SpinVerter 3 gets the faster start!! The PTT veteran dashes straight towards Razer, but the more manoeuvrable No.4 seed successfully dodges the oncoming onslaught and swings round into SV3€™s side...slipping under the uber-skirts!!! Now THAT€™S a rarity!! However, the claw on the former World Champion proves too slow as SV3 simply dashes off the front wedge and backs off for a charge!! Razer starts pursuing the PTT veteran, when Tom suddenly sends SpinVerter into reverse!! Just when his machine reaches the No.4 seed€™s side, Tom swings SV3 round and ploughs underneath the PTT2 Finalist!! The flipping arm fires and Razer turns gymnast, performing two impressive barrel rolls in mid-air before crashing back down onto its wheels!! SpinVerter comes in for another attack, but the No.4 seed successfully manages to dodge round the approaching PTT veteran!! Just as the Aussie machine begins a backwards ram, Razer swings round and under SpinVerter€™s side!! SV3 tries to get away, but too late - the claw has already lowered onto the flipping arm - even though the crusher can€™t penetrate the thick outer shell of his rival, Marty is still delighted!!! The former World Champ has a hold of the legendary vapourbot and I don€™t think it wants to let go!!! Quickly trying to take advantage of this stroke of luck, Marty sends Razer careering down the arena and into the Pit Release Button!! However, as the siren starts echoing round the stadium, Tom suddenly fires SpinVerter€™s flipper...pushing the claw back upwards and allowing enough force for it to regain traction on the No.4 seed€™s front wedge!! Quick as a flash, SV3 darts away from the former RW champ and back up to the top of the arena!!! Swinging back round, Razer restarts the pursuit!! However, SpinVerter has just swung back round again for another attack!! The No.4 seed starts to turn, to try and swing round past SV3, but this just leaves it bearing its side to the PTT veteran!! The charging SpinVerter slides underneath the PTT2 Finalist€™s side, keeps shoving the UK bot down the arena and fires the flipping arm at the arena centre!! The former World Champion flies down the ring, soaring at least 5ft in the air!!! Marty prepares for the worst...then calms when he sees Razer land on its side a few feet away from the Pit Release Button!! Just as the self-righting arms slowly start pushing the No.4 seed back onto its wheels, the former RW champ suddenly finds itself right-way-up again...mainly thanks to another powerful ram from SpinVerter, which resulted in the PTT veteran colliding with the wall!! Just as SV3 starts backing away, the nearby No.4 seed swings round and manages to scrape underneath the mighty skirts a third time!! Tom tries to get his machine away, but the crusher has already managed to clamp onto the top armour of the legendary vapourbot!!! THIS time, SV3 wasn€™t getting away...and Marty was going to make it permanent!! Already facing in the direction of the Pit, the No.4 seed leaves the Pit Release Button and trundles over to the edge of the hole!!! Tom fires the flipping arm again and again in desperation, trying to shake his machine free!!! The six wheels spin back and forth, but the grip on the PTT veteran is just too tight!!! Finally, Razer reaches the Pit...Marty retracts the claw...and SpinVerter gives one last flip as it plunges to the arena depths!!!
CEASE!!!!!
SpinVerter 3€™s world has been turned upside-down! The mighty vapourbot won€™t be joining its relation in the Grand Final!
RAZER (4) GOES THROUGH TO ROUND 2!!!
SEMI-FINAL 2
ROUND 1
BATTLE 2
CRANKSHAFTED Vs MASS DISCTRUCTION ULTIMATE
CrankShafted was entered by Tom Roper and is a 4-legged full body spinner. The circular shell spins at 1500rpm and the shock of a hit from this robot is capable of causing 1-hit-kills!!!
PTT3 HIT LIST: killed Storm 2 in one blow, No.23 seed Thermidor 2 in two blows and No.7 seed Biohazard in one blow
Mass Disctruction Ultimate was entered by Aaron Knight and is an 8-legged full body spinner. The circular shell and its 9 teeth spins at 4000rpm, the whole robot can run inverted and the power of the spinner is pretty much capable of instant KOs!
PTT3 HIT LIST: killed Vlad the Impaler in three blows, killed No.32 seed Firestorm 4 in two blows and pitted No.16 seed Behemoth in two blows
House Robots- Mr Psycho and Matilda
Roboteers Stand By......
3...2...1...
ACTIVATE!!!!!!!!!!
And so, for the first (and maybe even last) time, the two one-hit killers face each other!!!
Almost instantly, both machines have their lethal spinning shells up to speed...and now comes the first charge!! The two similar entries start strutting their way to the arena centre for the collision of all collisions!! As the slightly quicker machine, Mass Disctruction Ultimate makes it there first, but CrankShafted isn€™t exactly a mile away!! The two machines scuttle closer and closer...and the maddened, whirling shells finally touch...
CRRRRRRRAAAAAAAAAAAAAASH!!!!!
Due to the weight of the two machines, neither walker is flung too far away on impact, although the smash has sent both circular killers twirling on the spot like a pair of psychopathic spinning tops!!! You can almost hear the floor groan as the shockwaves from the two spinning shells€™ meeting shake the wood!!! Suddenly, both machines stop spinning...the shells rapidly begin to slow down...and the legs stop moving!!! Refbot trundles over and halts beside the two machines!! It looks as though they€™ve managed to killed each other!!! The Ref shakes his head from one spinner to the other!! What on earth should he do?! The answer to that comes when his head swings back round to MDU...and notices that a few of the legs have begun moving again!!!! Aaron€™s machine may not be going very far, but at least there€™s still signs of movement...which is more than can be said for CrankShafted at the moment!!! Refbot gives the 4-legged spinner a sharp nudge...but no response is given!!! Aaron cheers with delight and MDU€™s enduring legs scuttle in some sort of little victory dance, as the Ref finally starts to count down the once mighty CrankShafted!!!
CEASE!!!!!
CrankShafted has every right to feel cranky! Aaron proves his one-hit wonder really does work wonders and clings onto life to make it to the next round!
MASS DISCTRUCTION ULTIMATE GOES THROUGH TO ROUND 2!!!
SEMI-FINAL 2
ROUND 1
BATTLE 3
SON OF RIPPER 0.2 (8) Vs TENGU 4 (28)
Son of Ripper 0.2 was entered by Andy Jackson and is armed with a front CO2 top-hinged flipping arm and a rear vertical spinning blade. It€™s a box-wedge shape, the blade runs at 4000rpm and the two inner wheels allow the robot to run inverted
IN PTT2 (as Son of Ripper): it was pitted in Round 2 of the Semi-Finals by Razer
SEEDING: 8th
PTT3 HIT LIST: helped pit Robocake 2: The Upside-Down Cake, propped That Good R&D against the wall and threw Kan Opener out of the arena
Tengu 4 was entered by Alex Holt and is a full body spinner with 2 10cm long teeth. The robot is dome-shaped, runs on 4 small inner wheels and can self right with a flipping bar on top.
IN PTT2 (as Tengu 2): it was flipped into the Pit in Round 3 by Chaos 2
PTT3 HIT LIST: obliterated Kat 3, immobilized Blade Runner and sliced up one of No.12 seed Wheely Big Cheese€™s wheels
House Robots- Dead Metal and Growler
3...2...1...
ACTIVATE!!!!!!!!!!
Tengu 4 gets off to the quickest start, darting away from Son of Ripper 0.2 as the rotating shell starts getting up to speed!! As the No.8 seed starts pursuing it, Alex€™s machine manages to reach its 1000rpm peak!! The No.28 seed swings into reverse and smacks right into the front wedge of SoR 0.2!! Both robots are catapulted away from each other as the spinny shell meets the SoR shell!!! Alex quickly regains control and revs the spinner back up as it charges towards the No.8 seed...who is still swirling like a cow in a hurricane after that last crash!! :proud: Finally regaining control of his machine, Andy prepares to send SoR off to get some space for a charge - when the whirling Tengu dashes over and, this time, gets a smack on the side of the No.8 seed!! A nice little indent has been put into the Hardox wheel guards of the PTT2 Semi-Finalist, as the bot in question narrowly avoids a third injury from the No.28 seed!! Just as Tengu prepares for another attack, SoR swirls round, activates the rear spinning blade and backs into the rotating shell of the No.28 seed!! The blow manages to knock the full-body spinner a little unbalanced - enough to make the shell hit the floor and halt the spinning process!! Seizing its chance, SoR dashes into Tengu, slides underneath and throws the No.28 seed over onto its back!! However, this only proves a temporary setback - as the No.8 seed gives its rival a sharp jab with the rear spinning blade, Alex activates the srimech arm, tipping the full-body spinner back onto its wheels and allowing the PTT2 Heat Finalist to dart back across the arena!! SoR chases after Tengu again...and notices that the spinning shell is still working!! Not wanting to give up without a fight, however, the No.8 seed resumes its pursuit of its rival!! Suddenly, the No.28 seed takes another sharp change of direction - back towards SoR!! The PTT2 Semi-Finalist tries to whirl round and activate the blade...but proves too late!! Tengu€™s spinning shell collides with the No.8 seed, which sends the VFT1 champion back into its merry-go-round impression!!! :proud: Now having to cope with another scar, SoR tries to escape any more blows...but this simply proves wishful thinking, as the revved-up No.28 seed charges over and smacks into the No.8 seed€™s side!! This latest blow simply hurls Andy€™s machine all the way up to the arena centre again!! With the shell still spinning, Alex sends Tengu charging over to SoR!! The PTT2 Semi-Finalist tries to get away, but the No.28 seed once again proves the faster of the two!! The full-body spinner once more crashes into the No.8 seed and catapults it up to the top end of the arena!! With the shell still going after the latest collision, Tengu darts up to the top of the ring, as SoR starts trundling away!! Catching up in no time at all, the No.28 seed prepares to strike...but the VFT1 champion simply turns and tries to flee the full-body spinner in the opposite direction!! As the No.8 seed trundles along by the arena wall, Tengu very quickly catches up, whirls into SoR€™s side using a Business End-style arc manoeuvre (not wanting to run into the now-active spinning bar) and gives the side of its rival a good hard wallop!! The PTT Semi-Finalist twirls away from the No.28 seed...bounces off the arena wall (ripping off a piece of it in the process :proud:)...and is flung back down the ring, almost back to the centre again!!! Still spinning, Tengu darts over to the wounded SoR, who seems to be having quite a bit of trouble manoeuvring!! The No.28 seed smacks into the No.8 seed again and the VFT1 champion is once more sent twirling round on impact!! Tengu backs off a bit...sees SoR twitch a bit...then gives it another hard smack to the side!!! The No.8 seed looks like a full-body spinner itself!!! Finally, Alex backs down...while Andy breaks down...or, more specifically, his machine!!! All those blows from Tengu must have shaken many a-gubbin inside the No.8 seed!!! As Alex finally shuts off the spinning shell, Refbot trundles over and begins counting down the valiant, but vanquished Son of Ripper!!!
1...2...3...4...5...6...7...8...9...10!!!!!!
CEASE!!!!!
Son of Ripper proves itself as an embarrassing relative! :proud: The No.8 seed gets smashed, bounced and spun out of the Semis for a second time!
TENGU 4 (28) GOES THROUGH TO ROUND 2!!!
SEMI-FINAL 2
ROUND 1
BATTLE 4
DISHONOURABLE DISCHARGE (27) Vs PLATINUM PURE EVIL (3)
Dishonourable Discharge was entered by Hector Gilbert and is armed with a full-body spinning drum, like Barberous. Its invertible and holds many of its components inside its wheels
IN PTT2: it had its axle snapped by Sir K in Round 3 while fighting Voltronic
SEEDING: 27th
PTT3 HIT LIST: immobilized one half of Clustram, snapped one of Suicidal Tendencies€™ tracks and sliced up No.11 seed Chaos 2
Platinum Pure Evil was entered by Daniel Stickler and is armed with a large front rear-hinged flipper and rear vertical disc. Its similar to Wheely Big Cheese and runs on 2 Stinger-style wheels
IN PTT2(as Pure Evil): beat PTT1 champ Beta and 5th seed Voltronic to reach the Final, losing to SpunOut in the eliminators but flipped Razer out of the arena in the Play-Off
SEEDING: 3rd
PTT3 HIT LIST: threw Big Fred out of the arena, immobilized Pyro II and narrowly beat The Robot That Wasn€™t There on a 28-27 judges decision
House Robots- Sir Killalot and Sgt Bash
3...2...1...
ACTIVATE!!!!!!!!!!
Both machines get off to a nippy start!! While Dishonourable Discharge quickly gets its massive drum up to speed, Platinum Pure Evil whirls round and begins revving up its rear flywheel!! The two then suddenly charge (or in the No.3 seed€™s case, reverses) into the arena centre and the spinners collide with a deafening crash!!! Both disc and drum have stopped - Dis Dis has received a nice slash down the drum, while Pure Evil has several little slashes around the disc area!! Just as Hector€™s machine prepares to start revving up again, Dan€™s axlebot whirls round and manages to slot the huge flipper underneath the currently static drum!! The flipper fires...and the No.27 seed is flicked nearly 4ft in the air before crashing back down to earth!! Just as Pure Evil whirls round to give the Heat F winner another taste of its re-revved flywheel, Dis Dis charges straight at the front flipper, the drum back in action!! The blades of the cyclonic cylinder manage to catch the underside of Pure Evil...flicking the axlebot off the ground!!! The No.27 seed quickly nips under Dan€™s entry as it falls back down, allowing the drum to slice into the underbelly!! Now having to nurse more scars and scrapes thanks to Hector€™s latest attack, Pure Evil lands back on the ground as Dis Dis scuttles away from the No.3 seed to rev the drum up again!! Quickly getting its own spinner up to speed, Dan whirls his machine around and backs his axlebot into the revving drum of the No.27 seed!! Thanks to this latest assault, the Heat F winner is now sporting a great slice down the cylindrical body!!! But the PTT2 bronze medallist isn€™t stopping there!! As Dis Dis backs away to try and get some room to get the drum up to speed, Pure Evil charges straight at Hector€™s machine!! The ram stops the drum and allows the axlebot to scrape under the barrel-on-wheels, although the No.3 seed has taken a few more scratches and scrapes as a consequence!! Not wanting to waste any more time, Dan fires the flipper and sends the No.27 seed another few feet into the air!!! Just as Dis Dis starts to fall, Pure Evil whirls round to bear the spinning disc to its opponent!! The Heat F winner lands with another clatter, only to have the No.3 seed charge rear-first into the disc and add another slash into the now-rather battered-looking drum!!! Thinking he may be onto something with this pattern of attacks, Dan whirls Pure Evil back round as Dis Dis tries spinning up again!! The flipper slides under the drum (taking a few more nicks and scratches) and sends the No.27 seed back on another little fight!! As it tumbles back down to earth, Pure Evil twirls round, backs just a little bit...and allows the Heat F winner to fall right onto the rear flywheel!!! Another great slice is added to Hector€™s problems!! However, as the No.3 seed swings back round for another flipper attack, Dis Dis jerks away from the axlebot€™s launching pad and trundles down the arena!! Dan can€™t help but get the feeling he€™s in trouble...well, Pure Evil is, anyway, as the No.27 seed€™s drum is finally revving up again!!! Cautiously, the PTT2 bronze medallist reverses over to its opponent - but apparently, not quickly enough to satisfy Hector!! The Heat F winner nips over to the side of the slower axlebot and sinks its rotating claws into the armour!!! Tiny gashes are now appearing in the side of that ferocious flipper!!! Realising he has to do something as Dis Dis revs up the drum a tad more, Dan swings Pure Evil head-on into the drum - although his bot takes more little scars, his gambit seems to have paid off...the drum has stopped once more!!! Quickly sliding under the fellow axlebot, Dan fires the flipper and stands back to admire the No.27 seed shooting upwards...then tumbling downwards, back onto the arena floor!!!
10...9...8...7...
Narrowly dodging another swipe from the swinging Platinum Pure Evil, Dis Dis starts revving up the drum once more!!
...6...5...4...
Danny quickly tries to get once last blow from his disc, but it€™s the No.27 seed who makes the final blow of the bout by smashing into the side of the flipper, with sparks and scrapes galore added to the armour!!!
...3...2...1...
CEASE!!!!!
As the No.3 seed backs for a last run at the Heat F winner, the fights draws to a close. With both robots mangled, yet mobile, we€™ll need the judges to call a winner. Will Platinum Pure Evil prove to be €˜fool€™s gold€™, or will Dishonourable Discharge get its marching orders? With the last place in our Grand Final qualifiers up for grabs, this result really matters. And speaking of results...
Style (/10): PPE(3)=7 DD(27)=7
Control (/10): PPE(3)=8 DD(27)=7
Damage (/10): PPE(3)=8 DD(27)=8
Aggression (/10): PPE(3)=8 DD(27)=7
TOTAL (/40): PPE(3)=31 DD(27)=29
The judges have finally made a decision...usual criteria...once again, a very close result...Hector€™s hoping for a bit of vengeance here...The Robot That Wasn€™t There lost to PPE and the judges earlier in the series...and it€™s Judges - 2, Hector - 0! They€™ve gone for Platinum Pure Evil!
PLATINUM PURE EVIL (3) GOES THROUGH TO ROUND 2!!!
Pussycat Tribute Tournament 3...continued!
CrankShafted Vs MDU at last...now that€™s MY idea of Valentine€™s Day :proud:
SEMI-FINAL 2
ROUND 2 LINE-UP
Razer (4) Vs Tengu 4 (28)
Platinum Pure Evil (3) Vs Mass Disctruction Ultimate
Thank you! :)
What a marvelous surprise, thats the end of my PTT...
