Re: Turnigy tz85a from BotBitz
its probably just windows 8. its a real stupid OS, really annoying sometimes. would be useful if Microsoft made two different OSs for different users (advanced and a simpler one) so you can do what you want to do with out the limits and restrictions of the simplified windows 8.
Shakesc would you mind talking me through exactly what HK software you've used please?
Thanks to everyone for their help
Hi
I used a windows 7 machine. My other machine is Mac. Might try that at some stage , I believe KK s/w is just a Java app
Downloaded the KK multicopter flash programming software, see
http://lazyzero.de/en/modellbau/kkmulticopterflashtool
The USBAsp drivers can be a little fuzzy to install. If they are an issue then have a look at
http://www.fischl.de/usbasp/
and for just the drivers
http://www.fischl.de/usbasp/usbasp-w...2011-05-28.zip
I also did what Dan said and used a plug for the gnd wire
Just saves some soldering
Done it! Thanks for the help everyone. It's not the most user friendly piece of software but the KK multicopter worked a treat.
Now I just need some cable to handle the amps, nearly set the fire alarm off today burning through some T&E.
What's wrong with the cable on the turnigy 85a controllers? Should be more than up to the job for some drills etc
We're using something slightly larger than drill motors and very Bitza. Although I was surprised that it ate any cable!
Those wires should be plenty big enough. If those go up I'd be more worried about the rest of the esc going up first.
The wires on the ESC were fine, it's the rest of the loom that was showing the strain.
Ah right I understand what you guys mean now
hi all,
Was wondering if someone could help me out. I'm a complete noob when it comes to computer programming and i would love to learn but Im a little pressed for time due to work, family commitments and all the other problems I'm having with the bot (the control isn't working either but i think this may also be down to the ESCs translating the commands into movements).
If possible, could someone much cleverer than me please compile the latest code for me into a .hex file (i think this is the link to the latest C code file although i may be wrong: http://bazaar.launchpad.net/~brushed-te ... ushedESC.c ) so that i can reflash my ESCs and hopefully solve some of the problems.
Forgot to say that what i need changed in the code is the TEMP_LIMIT set to 0 . This will then turn it off as the temperature limit which triggers the thermal protection to kick in is quite low really. My bot died after two minutes because of this
Cheers
Dan
