i recomend the pro peak quattro plus charger, never let me down.
that would be the cheapest decent charger.
where can i get it :DQuote:
Originally Posted by harry hills
The parts have arrived :mrgreen:
my mum through away the controller for my robot riot :angry: :angry: it will never work now :angry:
Here is my beetle weight basehttp://i1101.photobucket.com/albums/...9/3a34ff18.jpg
I tried to modify the servo I got for my beetle weight and the cog snapped :angry: :angry:
Here is the blade for my beetle weighthttp://i1101.photobucket.com/albums/...9/d7ee9570.jpg
please dont use that :shock:
Not properly balanced and designed to unscrew, not a good combination.
I have the electronics in place nowhttp://i1101.photobucket.com/albums/...9/44740fa4.jpg,
It looks great!
I can't know both my servos blew and my reiciver don't work :angry:Quote:
how did you manage to do that
*awaits responce saying he plugged the lipo into the rx*
I can't believe i havent done that yet!
by accident don't do it on purpose
i did not modify the servos properly and they started smoking and they burnt out
i cant deside a name for my beetle weight i fought of battlerage and basherbot and my dad fought of bob! any ideas of what i should call it? :mrgreen:
steve or gerald
hmmm sounds like you put too much voltage through the the servos. Why not just take a photo of how it's connected and let mpeople have a lookQuote:
Originally Posted by Pugster2002
Be sure to fasten the blade so it wont come off when spinning fast as it can both hurt you and destroy the robot itself or other stuff
pugster, cover where the bar is connected and the shaft in araldite to prevent it coming off, also on the thread area so it doesn't un screw.
or just use the sensible, balanced discs that andy offered
the blade is welded on :shock:
anyway, what did you do to the servos again?
good!
i burnt them out because i didnt modify them right :uhoh:Quote:
what did you do to modify them?
what voltage did you run them at?
servos don't tend to smoke becuse of badd modding
i think the reciver might have caused it because it didnt seem to work properly the light didnt come on and it didnt controll properly but when i used my ant weight reciver [wich is the same make reciver]it worked fine. 8)Quote:
Hay I just built this battle bristle bot
http://i1101.photobucket.com/albums/...9/190a9ce2.jpg
I built it on my own
awesome :)
take us though exactly what you did when the servos blew up, what battery were you using?
Lipos and it blew 3 servosQuote:
thought so, it wasn't bad modding or the reciver the voltage was too high for them so they smoked.
dont plug lipos into the rx.
How do you power them then if it's not plugged in to the rxQuote:
you run it though an esc or votage regulator.
Yay my 100th post :mrgreen: new question what events are happening in febuary I have found out about 2 events but I can't go to ever of them any other events you no of.
Oh great I've broke it :rofl:Quote:
hay i just hada idea would it be good if there was a weight class for bristle bots there cheap and easy to make :DQuote:
Forgive me for sounding like an idiot
but whats a bristle bot (a robot made out of a toilet brush? :rofl: )
If you have seen the hex bug advert that's what they are
Hex-what?
