A quick look on the web shows me that the R/C version has receiver leads soldered to the board, whereas the non R/C version just has screw blocks.Quote:
Originally Posted by PJ-27
I'm not sure what connections the screw blocks are for but I imagine you should just be able to plug two receiver leads into them. There appear to be four terminals, so I'd imagine a communal positive, a communal negative and two signal terminals?
If so, just get hold of some old/broken servos, chop the wires off, and attach to the controller. Then again, I've never worked with Dimension Engineering products so I could be completely wrong!
