i still can't use sketchup. tried, didn't understand it, gave up. maybe it was just because my mind is used to working with prodesktop
I have looked at my drill motors and they're at their fattest point about 460mm (without filing down unnecessary plastic). So say that gives me 5mm to play with.
I know that isn't enough for any substantial top armour or a very thick base plate, so what I hope to do is say use 6 or 8mm HDPE for top and bottom, and cut out small sections, so that any pointy bits on the drills can have more space. In reality the side plates, and the whole chassis, would be flatter still. Just enough to poke the head of the drill through and keep strength. Right now in the CADs there is far more space than necessary in the sides to accommodate the drills. I could gain a whole cm right there. If I went the cutting gaps for clearance route, as the img suggests a thin metal plate of a mm or two would be bolted on top.
I am not too fussed about speed if it means more torque. I'd prefer have more control over the bot and someone else's than go skidding around doing more damage to myself than anything.
We'll see how it all goes. I'm not quite sure why more feathers aren't made less tall, 10cm wheels is pretty big... so count this as an experiment, lol! If it fails and is impossible I'll let you know! :D
Also, I may never find a suitable set of ~5cm wheels, so all of this could be down the drain from the word go. :P
Thanks for the reply.
On another note, as you can see, there is a lot of space in the centre of the robot. I am sure lots of this will get eaten up by bits and pieces but; if I were ever to fit a 4 bar lifter, do you think it would be possible? And make that whole centre piece of top plate the lifter. Just a thought! :)
Oh and for anyone wondering, the chassis is 350x350, meaning it could be a hell of a lot smaller if I gave up the idea of a space for a weapon, allowing for more sturdy armour. The thicker stuff shown is 15mm, and the plates are 4mm, excluding the metal plate (flat grey thing on the top) of a mm.
(I may be getting way ahead of myself here, I'm excited I guess)
Edit: WOW! More replies!
I see. I knew the risk of overvolting them was there... I thought that since they were geared so leniently the motors would have to work less hard to push the thing. Now that I think of it, I see about 189 flaws with that idea. Thanks for letting me know it's a bad idea. :)
I was fretting over the wheels for quite a while. I was trying to allow more space inside for... robot stuff. I think I might make a new CAD following the idea of just being a rambot at heart (with the wheels inside). Thanks for the reply!
@Harry: I don't normally either. It's just we got this fancy electronic calliper and I'm measuring everything. :proud:
Phew - long post.
Ellis.
I'd definitely recommend you go for 75mm wheels, or at the very least 63mm which I seem to remember is another, though rarer standard 'blue' wheel (or similar rubber type) size. You'd definitely save yourself considerable time and money. This is from the experience of building several four wheel drive drill motor machines a few years ago!
Examples (all built to a 50mm chassis height, base & top plates are additional to this)
https://lh6.googleusercontent.com/_3...sUU/proto1.jpg
https://lh6.googleusercontent.com/_3...E/mm_bench.jpg
https://lh3.googleusercontent.com/_3...k/IMG_1862.JPG
And a four bar (can be done but pretty tricky especially for a first time)
https://lh3.googleusercontent.com/_3...0/IMG_2729.JPG
Additionally don't worry about torque, the limiting factor is grip not motor power with drill motors & small wheels.
Wow! Thanks for the pics!
I'll look into further designs. I could stretch (lol) to the 63mm I guess. I may be able to source wheels locally however, I'll look into that before making any decisions. If the local wheels are too small or will be hard to mount
to a drill then I'll have a look at these 6.3cm jobbies (just had a quick look around, can only find castors :?). Any links to such wheels would be much appreciated!
Also, I have an electric window motor from a Fiat Panda (don't be fooled!), it's 12v, torque'a'plenty and has a nice mechanism that with some fiddling could become an actuator of sorts? Interesting stuffs.
Again thanks for the replies.
Ellis
Robochallenge standard range: http://web.me.com/robochallenge/Robo_Ch ... nical.html
You'll have to contact them about 63mm ones, I'm pretty sure they used to stock that size, but adding nuts would have to be to-order.
Ok. Well as I said I'll do some research and fiddle with new designs before making any final decisions. :)
Quick question for the veterans - how flat really are arena floors? I mean, if I had just ~2mm ground clearance, would I have problems? Thanks.
Ellis
Quick answer: Not very flat :P I believe the Robochallenge arena is a good deal flatter than the RL/RR ones, but you're still going to have a lot of issues with 2mm clearance as it only takes a small dent or rip or bit of debris to beach you. The RL/RR arena floors...aren't flat :P you really need at least 10mm of clearance to evade, among other things, bits of the top of the arena floor separating and floating around loose, the pit and flipper protruding slightly, uneven joins after two days' fighting, bits of other robots, tears and dents where the heavyweights have fought and dropped on the floor from a great height, and all sorts of other problems.
Yeah you need a higher ground clearance, great example of this was the Uk featherweight champs the other day, in the final explosion got beached on the floor allowing Little flipper to get them OOTA and win the champs
Well after some messing around in Sketchup I've replaced the 52mm wheels with 63mm ones, and mounted one of the 200W scooter motors I have as a potential axe weapon motor. Take a look. :)
http://storage.darkdemon.org/16909/1303336407.png
http://storage.darkdemon.org/16909/1303336542.png
And with some really shoddy armour... stuff.
http://storage.darkdemon.org/16909/1303336577.png
http://storage.darkdemon.org/16909/1303336631.png
I really like the idea of an axe, just not sure if it'll all fit in the weight limit and if the 200W scooter motor is quite punchy enough - opinions?
Oh and the ground clearance is about 6mm there, in real life if this were built I'd try for a few more mm. :)
