what radio system?
what radio system?
Planet T5 2.4 ghz
in that case no.
what chanels have you got the drive plugged into/do you use a vtail mixer?
A video here would be great.
its hard to tell without seeing it but i think you probably have things plugged into the wrong channels, try playing around with that for a bit. are you using Servo's or motors? (my Word is playing up right now so cant open it again) if motors perhaps the ESC is messed up, but i cant see how that would effect the weapon. I did have a sort of similar problem with my transmitter way back at AWS 29 where i only had one wheel drive until i hit the trainer switch, the the other servo would just rotate continuously until i turned it off again, Gary deduced it to be some type of channel cross over in the transmitter: E.G wires touching, dogey connections. perhaps a similar thing could be happening here?
Jack
he's using servos jack
