Charging in series is ok although if the packs are not very well matched you could end up with one pack undercharged or overcharged.Quote:
In parallel is a no no. One pack will end up taking the current and could result in fire or explosion. You should never leave NiMH or NiCd connected in parallel as one pack will discharge into the other with the same result.
