well, speed control, batteries reciver, armour, the list goes on :D
how far should M5 grub screws go inside the holes in argos drill motors?
until the output shaft stops rotating
so that it does not rotate at all?
no you only want to screw them so there is a slight rotation which is stopped with the little bumps on the plate hitting the grub screw
I usually go that little stage further and tighten them until there is no rotation on the shaft but each to their own
