more info here:
http://www.robotwars101.org/phpBB/viewtopic.php?t=1391
you might want to join the robot wars 101 forum aswell, its very good for antweights :D
more info here:
I may be able to attend ;D, what would be more powerful Lego Pneumatics or the one on Technobots? (25mm stroke)
they'd probably be about the same.
Noice Noice zoo zoo (Mighty boosh saying ;D) I'm not sure what to do haha D;?
Lego is the thing to use? I'm very intrested, would something like these sets work:
1: http://cgi.ebay.co.uk/Lego-Pneumatic-PR ... 43a29dd005
2: http://cgi.ebay.co.uk/Lego-Pneumatic-AI ... 3a5fcb12d3
3: http://cgi.ebay.co.uk/8-Pneumatic-CYLIN ... 3a5fc3b5a7
4: http://cgi.ebay.co.uk/Lego-Technic-Pneu ... 43a2728398
you'd need a different tank to use 100 psi and you'd have to modify switch and ram yourself. but yes they should work.
Could you tell me if there are any sets that do 100psi pneumatics like them and where to get them.
easiest thing to do is use a different tank (eg deoderant can, breath freshner) and just modify the pneumatics yourself. i could sell you some un modified pneumatics if you want. guides on how to modify can be found at:
http://www.techbricks.nl/
How do you use the tank from a deodrant can do you leave the contents in or take it out? if you take it out how do you put/make an end for it?
spray out contents, drill hole in for fill valve and another hole to go to system
