Fair anough,
w.a.r 1: viewtopic.php?f=201&t=2285&start=0
w.a.r 2: <a class=postlink-local href=http://www.fightingrobots.co.uk/foru...=0<br /> w.a.r
Fair anough,
Ill enter
Im writer of the Crazy Bots tournies and last year best new writer
Nurse Pain
Weight: 150kg
Shape: Son of Whyachi (Battlebots 3.0)
Colour: The chassis is green, the weapon is black, and the bracing rods are blue.
Dimensions: 110cm x 80cm x 30cm
Drive: 2 C40-300 Magmotors at 36.3 volts, geared 4.5:1, powered by 11 M1 A123 Li-Ion cells.
Locomotion: 2 Drillzilla-style shuffling feet.
Armour: 10mm hardox for the tribar, and 3mm titanium for the main body.
Speed: 12mph
Ground Clearance: 1mm all around due to the hammers almost touching the ground. 5mm under the body of the robot.
Turning Circle: Zero.
Weapons: The weapon is a deadly 21kg Son of Whyachi-style tribar powered by 2 36.3v LEM-130 motors at 4000rpm. Each end of the tribar has a 3kg Hardox hammerhead attached to it. It can put out 277.5kj. It also has bracing rods that are part of the tribar, and therefore give the tribar the full 21kg of weight.
Srimech: None
Strength: Absolutely deadly. Can kill almost anything.
Weakness: No srimech, but that won't matter.
Bio: Nurse Pain replaces Dr. Thwack in the field of activity, but might not see service until either a new tournament starts or it'll have to wait until the new ARC season.
Win/Loss Ratio: N/A
Im ready for you guys :mrgreen:
EQUINOX
BODY SHAPE: Box with 30* wedge at the front and angled rear ala Tornado like >. Sides are 45* to deflect spinners.
WEIGHT: 100kg
DIMENSIONS (L X W X H): 95cm x 70cm x 9cm
COLOUR: Dark blue with yellow skirts and forks
LOCOMOTION: 4 x internal wheels, each is 80mm in diameter and has vulkalon tyres for grip. They are mounted on a slant ala Tazbot for extra control. Instead of one in each corner they are mounted at the rear and middle of the machine, with two ball castors in the two front corners. This gives very good manouevrability, allowing Equinox to really glide around the arena like Panic Attack.
GROUND CLEARANCE: 0 at the wedge, effectively 0 at sides and rear due to skirts, but 10mm behind them.
SKIRTS: 5mm grade 2 titanium skirts at the sides and rear, joined by 4mm hardox hinges to stop them breaking.
DRIVE MOTORS: 4 x S28-400 magmotors run @ 24v
DRIVE BATTERIES: 4 x NiCad battlepacks at 24v in parallel
SPEED: 15mph, designed to be very fluidly controlled
TURNING CIRCLE: 0 metres
BODY ARMOUR: 6mm grade 5 titanium/vanadium 10% alloy monocoque. The removable panel is the top panel, but this is mounted on rubber bolts, rendering axes and hammers useless.
CHASSIS:
WEAPON 1: Running down the front wedge and flat along the floor are two 60cm long lifting forks, each powered by its own linear actuator, capable of rising to full height in 2 seconds, fast enough to be effective, but slow enough for controlled lifting.
WEAPON 2: Running along the top of the robot are two sets of Mute-style tungsten carbide barbs to trap opponents. Also hinged at the rear of the robot is a 95cm long clamping arm with a serrated tungsten tooth at the end of it, this is powered by an S28-400 magmotor @ 24v and is usually raised to vertical and then used to clamp opponents in place, can be used in unison with the lifting forks and barbs to good effect.
SRIMECH: The clamping arm can right the robot in 1 second.
STRENGTHS: Excellent manouevrability, controllability and pushing power, weapon synergy, tough armour
THEME SONG: Meet Me on the Equinox by Death Cab for Cutie
One problem, Too heavy, no weight bonuses here.Quote:
Originally Posted by death robotics
Name - Back to Rock III
Shape - See picture, it€™s a box with a scoop at the front and a rounded back. The front is higher than the back and has an €œarc€ like Behemoth had, all for more efficient self-righting.
Weight - 100 Kilogram
Speed - 18mph
Dimensions - 90x84x33 cm
Ground Clearance - 0 underneath the lifter and skirts, 5 mm everywhere else.
Power - 2x LEM130s at 48v
Movement - 6 wheels, about 12 cm diameter
Turning Circel - Zero
Weaponry - A big rear-hinged lifting arm, basically the red part of the picture. It is powered by a single LEM130 at 36 V, which a €œpinion and rack€Â-mechanism. A pinion around the LEM€™s axle moves up a rack that€™s joint to the lifter about halfway its length. The fancy part is that this runs through a gearbox, with 2 gears. One gear is for powerful and controlled lifting and moves up the arm in about 2-3 seconds, another gear is for quick self-righting and moves up the arm in 1 second.
The two plates at the bottom run almost parallel to the ground and are arranged in the way they are (split in the middle, see picture) for the secondary weapon to come into play, a Pussycat-style vertical diamond-edged sawblade, powered by a S28-150 Magmotor at 24 V spinning at 4000 rpm. The blade is part of the lifter and thereby damages the opponent€™s underbelly while lifting it. The sawblade slicing its way INTO (more or less) my opponent will enhance my grip on it and increase my control over my opponent, which is good.
On both sides of the bot is a 7 mm titanium skirt.
Armour - 5 mm titanium at the bottom, 7 mm titanium everywhere else
Srimech - The lifter self-rights the robot when needed
Strenghts - Nice weapon synergy, high traction, can really control an opponent
Weakness - Untested lifter concept, easy to get under from rear, not as agile as 4WD or 2WD bots
@Martijn - Comments in Blue
Really want those battery stats, as it's a big decider on how this bot could perform and if it fits within the weight limit.Quote:
Originally Posted by majinb
@Jack - Comments in Blue
Missing some important information in there, I can't really gauge how well this design will do without the information, and therefore can't write super awesome battles*!Quote:
Originally Posted by team_orr
@Lian - Comments in Blue
Read the rules please 8)Quote:
* - super awesome battles may or may not be contained in this product...
hi
ye its 1 10cell pack
they are mags s20-400's, on 36v, with 150mm wheels
its 110 bore, and yes i know it does those amount flips because a: i have run it thru the calculator and b: its the same setp i use in my heavyweight
okay then , the new ground clearacnce is 0mm at the front, 3mm at the sides and 5mm at the back
that all?
ta
jack
http://i276.photobucket.com/albums/k...iguality-1.jpg
Intriguality
Shape: Box. Yep, a plain ol' boring box. :)
Colour: The main body is black...most of everything else is pretty much light green.
Weight: ~100kg
Drive: LEM130 Lynch motors run @ 36.3v, geared 9:1 for better control.
Power: 5 packs of 11 M1 A123 Lithium-Ion cells run in parallel.
Motivation: 4WD; features go-kart tires soaked in polyurethane, and custom-made CNC aluminium hubs.
Speed: 12mph
Armour: 6mm Ti/V framework surrounding a 3.2mm Hardox 400 monocoque. The front wedge plates (top and bottom) are 6mm Ti/V, while the sides of them are 4mm Ti/V. The axe shaft is bored through to lighten the load, and is made of Grade 5 titanium, while the axe head is sharpened Hardox. Hinges, inner bulkheads and bearings are 10mm aluminium.
Ground Clearance: 0mm under the wedges, 15mm under the sides and rear, even inverted.
Turning Circle: 0
Dimensions in CM (LxWxH): 151.5 x 83 x 23 (length is 103cm without wedges)
Weaponry: Pneumatic axe mechanism powered by a 150mm stroke 100mm bore double-acting ram, 2kg CO2 tank, and 4L buffer tank. Shots are fired at 900psi and it can fire about 20 times per fight, weakening at about 14 shots (only an estimate though)
Srimech: Axe. Because the ram is double-acting, it can right Intriguality if the shaft is fired before being flipped.
ROUGH WEIGHT CHECK
ARMOUR
Framework = ~16.1kg
Monocoque = ~31.25kg
Wedges and hinges = ~6kg
TOTAL ARMOUR = ~52.35kg
DRIVETRAIN
Motors = 6.2kg
Batteries = 3.85kg
Wheels = ~6kg
TOTAL DRIVETRAIN = ~16kg
WEAPONRY
Axe shaft = ~8kg
Axe head = ~7kg
Gears = ~500g
Weapon power = ~6kg
TOTAL WEAPONRY = ~21.5kg
Other bits = ~10kg
TOTAL WEIGHT = ~99.85kg or ~100kg
I spent a while on the stats, so if you've got a beef with the stats, do spill please, I want them to be as good as they can be made. :)
Urgh, should have mentioned in the stats that it's invertible. *facepalm* There go the 'perfect stats'. :P
