Orrion is the realie.
this is orrion:
http://www.youtube.com/watch?v=HPyQ-kmhINI
Sorry for the wait. Things on my mind, I hope you understand :)
Here is the lineup.
Heat One:
Equinox VS Absolution
All Bar One VS IAN
N3 VS Wedga Triton
Heat Two:
Stinger VS Gravity
Cassius II VS Panic Attack
Orrion VS Bodyhammer
Might be a special event or two in there, but don't count on it. I need stats for All Bar One, IAN and Equinox, but I'm sure I'll find them in due course :proud:
Name: All Bar One
Weight: 100 kg
Shape: A very wide paralelogram wedge
Colour: Battleship Grey
Dimensions: 33cm * 110 cm * 14 cm
Drive: 2 * LEM 130 (95S) on 49.5 V with 6 * 15 cell A123 ANR26650M1 battery packs
Locomotion: 2* 15cm diameter 5cm wide titanium hubbed wheels covered in urethane rubber
Armour: 7mm hardox on the wedges, 5mm hardox top and bottom, 10mm hardox on the ends and heavy shock proofing to protect vital components
Speed: 29mph
Ground Clearance: 0mm at the wedges, varies along the sides to 5mm at the back although technically more due to inverted wedge
Turning Circle: 0 cm
Weapon: Translational spinner and rammer dishing out 8.4 KJ when top speed ramming
While spinning:
18.2 KJ @ 500 rpm
73.1 KJ @ 1000 rpm
(now it might kill itself)
164.5 KJ @ 1500 rpm
292.5 KJ @ 2000 rpm
Srimech: Invertible
Notes: A bar shaped translational spinner that can ram if stopped spinning due to it having two wheel drive.
The robots innards are pushed as far as possible to the sides to maximise weight there with the center being hollow.
Equinox vs. Absolution
Okay, he's 9cm from the ground. Still quite in range of my blades. Anyway, he'd have to have pretty low forks to slide them completely under Absolution without them getting hit, and if he did, it'd be a bit of a laugh. I mean, it's good to have long, low lifting weapons but trying to lift 200kg with thin, 60cm blades, even at the tip, is difficult. He'd probably lift himself over before lifting me. That's not to say that it won't affect me either, as I'd probably go flying out of control as well. Therefore, I'm going to lock the shell at 2000rpm (gives out just over 200+ kJ) and try to be as aggressive as a walker can be here (lol), before his lifters come into play. I'll spin up to dangerous speeds quickly enough. Operate the legs two at a time so I don't have too many stability issues and keep belting his front end and hopefully I'll take his weapon power out of commission before tearing him to pieces. :) If I fly out of control, I should be able to spin back up quickly enough before he can attack.
Stinger vs. Gravity
Stay in the middle of the arena, spin about, thwack overhead a few times and generally have a good ol' time with good ol' Gravity. :)
Good luck Lewis and AJ. :)
Seeing as that last post is being a pain to edit I'll put my tactice in a new post.
All Bar One vs IAN
Run away until up to full spinning speed then aim to hit IAN square on the sides or the back. Try to stay in the middle(ish) of the arena and avoid that flipper on the front of IAN.
If I happen to be stopped from spinning use the normal drive mode to run away and spin up again or ram him into hazards etc if he's too agressive and repeatedly stops me from spinning up.
Cassius II vs Panic Attack
Try to stack it and use the very large spike on the back of Cassius II to give Panic Attack a good poking if I can stack him.
Predictions:
Heat One:
Equinox VS Absolution: Absolution has around 100kj of power less then my own 1-hit Wonder. However, it's still enough to smash up Equinox.
All Bar One VS IAN: All Bar One's been a pretty successful design. It can ram, and it can spin. The fact that Jordan can do both and keep Jack on his toes will win the battle here.
N3 VS Wedga Triton: Wedga looks like a good choice.
Heat Two:
Stinger VS Gravity: Gravity can OOTA Stinger.
Cassius II VS Panic Attack: And Rex has a chance to get some revenge. And I think he will, as Cassius is low enough to get under Panic's skirts.
Orrion VS Bodyhammer: The former Iron Awe 4 to beat Bodyhammer to a pulp, even if the Team Cold Fusion's machine's hammer is working.
Ram in backwards at full speed, it should KO itself.
Equinox stats are in signature, as previously mentioned.
Panic Attack vs. Cassius 2
Cassius 2 was no good at getting under things in the 2 battles it had, and I have a 20kg weight advantage. Lift and pit.
The first battles will be on the weekend. Tactics in by then, please
Additional tactic:
If I do go down the pit with Cassius II then attempt to catapult myself out with the massive spike :proud:
