Re: Newbie - designing a new heavy weight
I would say the main area of concern for any pusher is the amount of traction you can get from the tyres,
Solid tyres give good traction and most people use them. But the compound for the tyres will change your €œluck in the arena.€ Too hard and you get slipping, too soft and they don€™t last the fight.
The Wotty is brush painted red but you could paint it any colour you like. I use a 180 Wotty this works very well and Ian is such a helpful guy too. I recommend them for any heavy weight.
I think the first robot you make once it€™s going you will wish you did bits differently, that€™s the way it is, my advice is to make it so modifications can be made after you have finished it, and to make it so it can be easily repaired. It will get damaged or will damage itself!
The only other bit of advice I would say is make it look interesting and diffrent to all the other robots out there :uhoh: :shock: :shock: :shock:
