Hi John
Thanks for that
is that the only place to buy those battery tags it says they are out of stock on that site and its in us??
cheers
Hi John
Thanks for that
cheers
No, it's not the only place - I just Googled for hyperion a123 battery bars
or a123 solder bars
couldn't find any shops int he UK that did them.
http://www.rctechnics.eu/a123-systems-s ... -2293.html
If your after A123 battery bars give Andy a ring at RobotBirds... He stocks the A123 battery bars and i'm sure will sort you out with some.
He also has ALOT of A123 cells instock in the UK, although at the time he bought them they were at the peak prices so may cost a good amount more.
Gary do you know if they above seller i posted first off sells the cells in the form they came in from the dewalt pack? ie not breaking the cells up into indivduals?
thanks alex
The cells arrive broken up but some still have half the steel tag on top. Easy to remove with a pair of pliers
