Re: Armour for a full combat feather
ok i've got some 1.6mm titanium is that good enough against a spinner? or do i want some hdpe behind it aswell or infront?
i wana be able to take the odd big hit from robots like 360, hornet and drumroll to name a few and not end up getting mutilated.
i would back it i dont because of the weight but 360 will get through that and others will knock the hell out of it but it will be much hard for them good choice :idea:
where did you get the ti???
the ti was off ebay:)
i will in some places have 12mm hdpe like it was suggested earlier in the thread but seeing as most robots i make end up being heavy its looking like ill have to go with just the titanium all over with either no hdpe or at least a bit behind the ti
That's an odd reasoning. Because you probably have a heavy robot you put an armour on it from a material that is heavier than the other choice.
