The Magnificent Banana
are you using a 5kg as the main tank ?
Im quite sure no one uses more than 1 2kg for
a main tank except an old iron awe ? gilbert ?
and nearly everyone uses 1 2kg for a buffer
and they are powering quite large rams to.
I think you can lose a lot of weight here.
Craig, does beast have a much larger ram bore/stroke, and how many flips do you get per 5kg bottle or how much on average left over after a fight ?
Beast isnt mine, I jus know it uses a 5kg Bottle John Lear or LJ will be able to answer u beast I mean best
Beast uses a 100mm bore ram, with an adjusted stroke of 200mm.
Full ali construction.
And there is a reason I know.
is that because your closer to the LHC than us and the energy field its creating is giving you pshyic powers beyond reckoning?
Either that, or he built the ram. I know the LHC explanation is more plausible. :)
Can we agree then, Mario may have made the ram but he also has become a master pshyic with telekinisis (or however u spell it, and dont say i -t )
After thousands of years of laying in wait the swizz are finally creating an army of super humans with the energy of the LHC
Millions of swizz ready to fight armed with annoying cuckoo clocks
beast uses a mario ram but the stroke has been modified to 150mm or 175mm as we have a spacer in it to make it not go over vertical
we had to cut it down abit so the length was the correct length for our flipper arm
we dont know how many flips we get - with iron awe we had 1 good flip as that was all we needed lol but i dont think we have never come out of a fight with an empty bottle - my dad says we would prob get 30 good flips before something breaks lol
and the next event ill get someone to count
we dont really need a 5kg bottle but u no what my dads like he likes to show off abit and use all jonnos gas lol but you never know when you may need more flips!
o ye after this years replacement of the ram beast is back ready to rule ;)
(Message edited by john on September 10, 2008)
what LJ really means is that hes never done a fight where he was able to count them either...
a) he got stuck upside down trying to selfright
b) he had a gas leak from the first flip
c) he had a wire come loose
d) he got flipped out the arena, or down the pit
one day maybe, there always an excuse !!
