Mayhem: Fatality
Football: Axetra
Tag Team: Mad Dash, Ramminator
Mayhem: Fatality
Football: Axetra
1) Kody Kunz
Wedginator Devilution
Super Gore Revo
Tira IV
Troubloon 6
Kilobite 5.0
Intriguer
Curse Of Dread
Shadow Zone Returns
2) Samuel Park
Fatality
Axetra
Mad Dash
Blade Of Doom
Ramminator
Walk Don€™t Run 3€˜n a half
Paralyzation 2
Storm 2
3) Liam Eliot
Apocalypse
Brutalis 2.0
Helix
Collateral Damage
Hercules
Bumble
Exodus
Shocking (stats needed)
Mayhem:
Fatality
Brutalis 2.0
Football:
Brutalis 2.0 & Lockjaw Epedemic
Axetra & ?
Tag Team:
Forza & Bumble
Mad Dash & Ramminator
Replace Shocking with Systematical Shockerlarity please Ben, it has stats and they are in the same place as the rest of my stats :)
Im guessing no-one else is going to enter, sigh, there goes my career as a writer
You can always do your competition with less competitors. :)
Samuels suggestion is really good. Dont start off with majors, do a few minor tournaments first.
Ok, I need 6 people to enter 6 robots
100KG for wheels
110KG for tracks and shufflers
150KG for walkers
The Line-up will be like this:
Heats:
6 heats of 6
1 robot goes out in the Gauntlet
1 robot goes out in the Trial
2 1-1 KO battles, to go through to semi-finals
Semi-Finals:
4 Semis of 3 robots
1 3-way melee, 2 go through to final
Grand Final:
1 goes out in Gauntlet
1 goes out in Trial
1 6-way melee to decide the winner
Arena: A 20M X 20M square box
Hazards: 2 CPZs, 1 in the top corner, 1 in the bottom, A spinning flywheel on the left wall of the arena, it spins at 5000RPM, A pit in the bottom left corner, below the pit there is a pair of hydraulic pincers that can push forward and pit the robot, there is a flipper in the top right hand corner and a drop zone just to the right of the centre of the arena, the house robots are 21 Deadly Sins, Zoo-Keeper and Cage (All on ZED)
Gauntlet: A 100M X 60M box
A circular cage at the start, there are three routes:
1) To the left, you must push a box up a ramp and into a hole, then drive over it onto another ramp, at the bottom of the 2nd ramp there is the house robot 21 Deadly Sins (Stats on ZED)
2) In the centre there are 5 rows of 3 sets of 2 killsaws, 1 set of each contains killsaws, 1 contains flywheels and 1 contains nothing, pick the best route
3) The route to the right contains 14 squares, some are pits, some are flippers (some throw forward, some throw back) and some are just squares that do nothing
Trials: Football,Sumo,Tug Of War,Skitttles,British Bulldog
Football: A 15X15 octagon with a goal, gaurded by Cage (Stats on ZED)
Sumo: A 15X15 Circle, simple, push Cage out of the arena
Tug Of War: Pull Cage into the pit
Skittles: Push a ball into pins, knock them over
British Bulldog 1: 5 Blocks, get in between them then past Cage and Zoo-Kepeer
I also need 6 robots for an Mayhem event
4 teams of 2 robots for football
and 8 teams of 2 for Tag-Team
Stats and Pics please
Mad Dash
Weight: 100kg.
Body Shape: Box with a front scoop.
Color: Chartreuse Body, Pure Black Scoop.
Dimensions: 100 X 90 X 36
Drive: 2 X LEM-130€™s @ 36v powered by 4 X NiCad Batteries.
Top Speed: 20 mph.
Tyres: 4 X Vulkanized Tyres.
Armour: 3.92mm Hardox
Ground Clearence: Completely 0mm on the front and 6mm anywhere else. (including sides)
Turning Circle: Zero, what does it look like?
Weapon 1: Static Scoop to deflect other spinners.
Weapon 2: In the middle of the scoop, there is a Tornado-esque drum thingy powered by S28-150, spinning at 3220RPM.
Srimech: Invertible, Side spikes prevent it from getting beached on its side.
Strengths: Can run both ways up, EXTREME Pushing Power, Deadly Drum, Can get under anything, Shock-Proofed.
Weaknesses: So-So Turning.
Fatality
Weight: 100 kg
Body Shape: Cone.
Colour: Flourescent Blue Body with Turquoise and Green Teeth.
Dimensions: 96 X 96 X 42 cm.
Drive: 2 X S28-400€™s @ 24v powered by 4 X NiCad Batteries.
Top Speed: 15 mph.
Tyres: 2 X Vulkanized Tyres.
Ground Clearence: 7mm all around. It has to be.
Armour: 6mm Hardox FBS shell, 6mm Polypropylene Base.
Turning Circle: Zero! Need I say more?
Weapon: A very nasty 36kg, 1500RPM FBS shell with 2 X 2kg Hardox Teeth and small Tungsten Carbide-tipped teeth all around, powered by an LEM-130 @ 36v. This can reach top speed in 2 seconds, and brings out about 80kJ. The teeth are curved, jagged, and barbed. Has a buttload of shock proofing inside to stop it from self-destruction. Holes drilled into it to reduce weight.
Srimech: An extremely blunt spike that comes out at the top, powered by 1 X 2kg CO2 Tank.
Strengths: Deadly Weapon, Fast Srimech.
Weaknesses: Weak Base Armour, able to shoot only 15 times with the srimech.
Blade of Doom
Weight: 110 kg.
Body Shape: Box with Rear Wedge.
Colour: Dark Blue with Turquoise Tinges.
Dimensions: 99 X 88 X 33.
Drive: 2 X LEM-130€™s @ 24v powered by 5 X NiCad Batteries.
Top Speed: 15 mph average, 20 mph max.
Tracks: Titanium Tracks with urethane rubber for superb grip, extremely hard to break.
Armour: 3.3mm Hardox 600.
Ground Clearence: Completely 0mm at the back and 5mm for the rest.
Turning Circle: It€™s completely zero, and you should know that by now.
Weapon: At the front there is a nasty 20kg Fluffy-Style Spinner (Horizontal) powered by a LEM-130 Lynch spinning at 4000RPM. The blade tips are sharpened, barbed and curved to cause max damage. The wedge at the back can also serve as defense for those nasty spinners, and if the blade fails to work, it can push robots around the ring.
Srimech: Invertible, Side spikes prevent it from getting beached.
Strengths: Very Destructive, Heavily Shock-Proofed, Good Control, Immense Pushing Power, Extremely Durable, Tracks Protected from all sides.
Weaknesses: Tracks exposed from the top, even though they€™re EXTREMELY strong.
Ramminator
Weight: 100kg.
Body Shape: Box with front concave scoop, and skirts all around.
Colour: Prussian Blue.
Dimensions: 100 X 77 X 27
Drive: 2 X LEM-130€™s @ 36v, powered by 4 X NiCad Batteries.
Top Speed: 22 mph.
Wheels: 4 Inner, Tightly Foam-Packed Wheels, with Asmaprene Urethane on it.
Armour: 5mm Hardox.
Ground Clearence: 0mm at the front, 0mm anywhere with skirts, and 5mm anywhere without skirts.
Weapon: This mainly relies on pushing power, but there is a diamond-tipped sawblade on the scoop powered by an S28-400, and spinning at 4000RPM.
Srimech: Invertible. Side spikes keep it from getting beached.
Strengths: Very Hard to get under, Immense Pushing Power.
Weaknesses: Let€™s just say the wheels are a bit exposed.
Weight: 110kg.
Body Shape: Disc.
Colour: Emerald Green Weapon, Snow White for top and bottom.
Dimensions: 95 X 95 X 27.
Drive: 2 X LEM-130€™s @ 36v powered by 3 X NiCad Batteries.
Top Speed: 13 mph.
Feet: 4 X Shuffling Pads with Asmaprene urethane rubber, and this prevents WDR from self-destruction.
Armour: 6mm Hardox for the ring spinner, and 4mm Grade 5 Titanium for top and bottom.
Ground Clearence: 5mm all around.
Weapon: 30kg Ring spinner spinning at about 1300RPM, powered by a LEM-130, and has 6 X 1kg Hypno-Disc style teeth, curved, barbed and jagged to rip armour. This brings out about 125kJ, and if the spinner fails, it can use its INSANE pushing power to ram other robots to death. Its also heavily shock-proofed as well.
Strengfths: Deadly Weapon.
Weaknesses: Hates Flippers.
Paralyzation 2
Weight: 100kg.
Body Shape: Low Box ala Tetanus Booster.
Colour: Gold.
Dimensions: 100 X 78 X 20.
Top Speed: 15 mph.
Wheels: 4 inner, Tightly Foam-Packed Wheels with Asmaprene Urethane on them.
Armour: 3.4mm Hardox 500.
Ground Clearence: 3.5mm all around.
Weapon: 19 kg Drum powered by a LEM-130 Lynch, spinning at 5000 RPM. There are 8 teeth, which are all curved upwards and jagged to rip and flip opponents.
Srimech: Invertible. Side spikes prevent it from getting beached.
Strengths: Deadly Weapon, and a Great Pusher.
Weaknesses: Exposed Tyres although very strong.
I will reserve a spot with these bots:
Curse of Dread
Troubloon 6
Shadow Zone Returns
Kracko
The Alexandra Sisters
Iron Awe 5 (realie)
Stats will be posted here tomorrow. If you want to take the ones on ZED right now, fine, but Ill still post them. :P
1) Liam Eliot
Mad Dash
Fatality
Blade Of Doom
Ramminator
Walk Dont Run 3n a Half
Paralyzation 2
2) Kody Kunz
Curse Of Dread
Troubloon 6
Shadow Zone Returns
Kracko
Iron Awe 5
2 Down, 4 to go, and what about Tag-Team, Football and Mayhem
And finally 21 Deadly Sins will be replaced by Tazer
(Message edited by neontetra23 on August 23, 2008)
